CONFIG_SYS_BOOTMAPSZ has been 64M on these boards for some time so we
should also allow the kernel image to be up to 64M decompressed. This
also matches what we pass to the OS based on the ePAPR specification.
Signed-off-by: Jiang Yutang <b14898@freescale.com>
Also added support to save env to spi flash in case of SPIBOOT.
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
Signed-off-by: Zhao Chenhui <b35336@freescale.com>
Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com>
Singed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
Signed-off-by: Shaohui Xie <b21989@freescale.com>
Cc: Mike Frysinger <vapier@gentoo.org>
The tsec driver was defining the default MDIO address as
the TSEC_BASE + 0x520, but on eTSEC2 controllers, the first
TSEC's registers are separated from the MDIO registers. Use
the existing MDIO_BASE_ADDR, instead.
Signed-off-by: Andy Fleming <afleming@freescale.com>
Introduce new CONFIG_SYS_FSL_TBCLK_DIV on 85xx platforms because
different SoCs have different divisor amounts. All the PQ3 parts are
/8, the P4080/P4080 is /16, and P2040/P3041/P5020 are /32.
Bank powerdown through RCW[SRDS_LPD_Bn] for XAUI on FM2 and SGMII on FM1
are swapped.
Erratum SERDES-A001 says that if bank two is kept disabled and after bank
three is enabled, then the PLL for bank three won't lock properly. The
work-around is to enable and then disable bank two after bank three is
enabled.
Part of the SERDES9 erratum work-around is to set some bits in the SerDes
TTLCR0 register for lanes configured as XAUI, SGMII, SRIO, or AURORA. The
current code does this only for XAUI, so extend it to the other protocols.
The work-around for P4080 erratum SERDES-8 requires all lanes of banks two
and three to be disabled (powered down) in the RCW. Display a warning
message if this is not the case.
SerDes PLL bandwidth default setting is incorrect when no lanes are
configured as PCI Express.
Add the 'pixis_reset dump' command, which displays the contents of the PIXIS
registers. This command is only available if DEBUG is defined.
Remove an empty board_early_init_f() from the MPC8641HPCN board.
A lot of boards set FT_FSL_PCI_SETUP directly in their board code
and don't check to see if CONFIG_PCI is actually defined. This
will cause the board compilation to fail if CONFIG_PCI is not
defined. The p1022ds board is one such example.
Instead of fixing every board this patch wraps FT_FSL_PCI_SETUP
around CONFIG_PCI so we can remove CONFIG_PCI and boards will
still build properly.
Signed-off-by: Matthew McClintock <msm@freescale.com>
versioned SEC properties changed names during development, so
for now search and update LIODNs for both "secX.Y" and
"sec-vX.Y" based properties.
The workaround for ESDHC111 should also be applied on
P2040/P3041/P5010/P5020 SoCs.
Signed-off-by: Lei Xu <B33228@freescale.com>
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
The P2040, P3041, P5010, and P5020 all have internal USB PHYs that we
need to enable for them to function.
The P3041DS & P5020DS boards are almost identical (except for the
processor in them). Additionally they are based on the P4080DS board
design so we use the some board code for all 3 boards.
Some ngPIXIS (FPGA) registers where reserved on P4080DS and now have
meaning on P3041DS/P5020DS. We utilize some of these for SERDES clock
configuration.
Additionally, the P3041DS/P5020DS support NAND.
Signed-off-by: Emil Medve <Emilian.Medve@Freescale.com>
Rework and add some new APIs to the fsl_corenet_serdes code for use by
erratum and drivers.
* Rename serdes_get_bank() to serdes_get_bank_by_lane()
* Add serdes_get_first_lane returns which SERDES lane is used by device
This patch fixes a wrong address define in corenet_ds.h (used by
P4080DS.h, P3041DS.h, P5020DS.h).
Since board/Freescale/corenet_ds/tlb.c does not use the
CONFIG_SYS_PCIE3_MEM_VIRT define (uses CONFIG_SYS_PCIE1_MEM_VIRT with a
fix offset instead) this has no effect to the functionality. But it may
be important for changes in the future?
Signed-off-by: Ralf Trübenbach <ralf.truebenbach@men.de>
Cc: Andy Fleming <afleming@gmail.com>
Fix fdt bportal to pass the bman revision number to kernel via device tree.
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
Second USB controller only works for SPI and SD boot because of pin muxing
Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
Signed-off-by: Dipen Dudhat <Dipen.Dudhat@freescale.com>
To make sure that machine change operation work successfully, change
timing parameters first before changing machine for chip select on IFC.
If we boot from a SD card use it for the environment as well.
Signed-off-by: Poonam Aggrwal <Poonam.Aggrwal@freescale.com>
u-boot environments, esp. when boards are shared across multiple
users, can get pretty large and time consuming to visually parse.
The grepenv command this patch adds can be used in lieu of printenv
to facilitate searching. grepenv works like printenv but limits
its output only to environment strings (variable name and value
pairs) that match the user specified substring.
the following examples are on a board with a 5313 byte environment
that spans multiple screen pages:
Example 1: summarize ethernet configuration:
=> grepenv eth TSEC
etact=FM1@DTSEC2
eth=FM1@DTSEC4
ethact=FM1@DTSEC2
eth1addr=00:E0:0C:00:8b:01
eth2addr=00:E0:0C:00:8b:02
eth3addr=00:E0:0C:00:8b:03
eth4addr=00:E0:0C:00:8b:04
eth5addr=00:E0:0C:00:8b:05
eth6addr=00:E0:0C:00:8b:06
eth7addr=00:E0:0C:00:8b:07
eth8addr=00:E0:0C:00:8b:08
eth9addr=00:E0:0C:00:8b:09
ethaddr=00:E0:0C:00:8b:00
netdev=eth0
uprcw=setenv ethact $eth;setenv filename p4080ds/R_PPSXX_0xe/rcw_0xe_2sgmii_rev2_high.bin;setenv start 0xe8000000;protect off all;run upimage;protect on all
upuboot=setenv ethact $eth;setenv filename u-boot.bin;setenv start eff80000;protect off all;run upimage;protect on all
upucode=setenv ethact $eth;setenv filename fsl_fman_ucode_P4080_101_6.bin;setenv start 0xef000000;protect off all;run upimage;protect on all
usdboot=setenv ethact $eth;tftp 1000000 $dir/$bootfile;tftp 2000000 $dir/initramfs.cpio.gz.uboot;tftp c00000 $dir/p4080ds-usdpaa.dtb;setenv bootargs root=/dev/ram rw console=ttyS0,115200 $othbootargs;bootm 1000000 2000000 c00000;
Example 2: detect unused env vars:
=> grepenv etact
etact=FM1@DTSEC2
Example 3: reveal hardcoded variables; e.g., for fdtaddr:
=> grepenv fdtaddr
fdtaddr=c00000
nfsboot=setenv bootargs root=/dev/nfs rw nfsroot=$serverip:$rootpath ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off console=$consoledev,$baudrate $othbootargs;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr - $fdtaddr
ramboot=setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootargs;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr
=> grep $fdtaddr
fdtaddr=c00000
my_boot=bootm 0x40000000 0x41000000 0x00c00000
my_dtb=tftp 0x00c00000 $prefix/p4080ds.dtb
nohvboot=tftp 1000000 $dir/$bootfile;tftp 2000000 $dir/$ramdiskfile;tftp c00000 $dir/$fdtfile;setenv bootargs root=/dev/ram rw ramdisk_size=0x10000000 console=ttyS0,115200;bootm 1000000 2000000 c00000;
This patch also enables the grepenv command by default on
corenet_ds based boards (and repositions the DHCP command
entry to keep the list sorted).
Cc: Kumar Gala <kumar.gala@freescale.com>
Cc: Andy Fleming <afleming@freescale.com>
commit 560d424b6d7cd4205b062ad95f1b104bd4f8bcc3 "env: re-add
support for auto-completion" fell short of its description -
the 'used' logic in hmatch_r was reversed - 'used' is 0 if
the hash table entry is not used, or -1 if deleted. This
patch makes hmatch_r actually match on valid ('used') entries,
instead of skipping them and failing to match anything.
typing 'printenv tft' and hitting 'tab' now displays valid
choices for variable names.
Tested-by: Mike Frysinger <vapier@gentoo.org>
call flash_protect_default() to protect default sectors.
- rev5 board has phy addr 1 -> adapt CONFIG_PHY_ADDR define
in board config file.
- also fixup the phy addr entry in dts, before booting
Linux.
Acked-by: Detlev Zundel <dzu@denx.de>
If neither CONFIG_CMD_PING or CONFIG_CMD_SNTP are defined but
CONFIG_CMD_DNS is, a compile-time error will occur due to the
absence of a goto label.
Signed-off-by: Gray Remlin <gryrmln@gmail.com>
This patch fixes problems in the handling of redundant environment in env_sf.c
The major problem are double calls of free() on the allocated buffers,
which damages the internal data of malloc and crashes on next call.
In addition, the selection of the active environment had errors and compiler
warnings, which are corrected by this patch.
Signed-off-by: Thomas Langer <thomas.langer@lantiq.com>
If FB address is defined specific address then don't grab memory for LCD
Cc: Albert Aribaud <albert.aribaud@free.fr>
Cc: Stefan Roese <sr@denx.de>
Cc: Kim Phillips <kim.phillips@freescale.com>
Signed-off-by: Alessandro Rubini <rubini@unipv.it>
Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
This patch defines all the needed symbols in the header file
and removes the now-unused config.mk in board directory.
Changes to board C file as requested.
Signed-off-by: Alessandro Rubini <rubini@gnudd.com>
This source file, which I got by the vendor in their own port,
was not actually executing because lib-based compilation
didn't call lowlevel_init (we have CONFIG_SKIP_LOWLEVEL_INIT).
With the change to object-based linking, an undefined symbol in
this file started hitting in the final link.
- fix board support following relocation changes
- switch to boards.cfg
- disable i2c to keep size under 128kiB (1 sector)
Signed-off-by: Eric Bénard <eric@eukrea.com>
Move the header file and definitions of ftsmc020
static memory control unit from a320 SoC folder to
"drivers/mtd" folder.
This change will let other SoC which also use ftsmc020
could share the same header file.
Signed-off-by: Macpaul Lin <macpaul@andestech.com>
Move the header file "ftsdmc020.h" (SDRAM Controller)
to "include/faraday" folder.
This change will let other SoC which also use ftsdmc020
- update to new relocation code
- get rid of LEGACY (still a little hack in .h to compile)
- add nand boot configuration
- boot tested for the following configurations :
9260 (64MB RAM & nor boot)
9260_nand (64MB RAM & nand boot)
9G20_128M (128MB RAM & nor boot)
9G20_nand_128M (128MB RAM & nand boot)
(nor boot is using lowlevel init)
Fix the nand_spl build for the hawkboard
Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com>
Board support for the DIG297 board manufactured by Comelit Group SpA.
It is a custom board based on the BeagleBoard <http://beagleboard.org/> by
Texas Instruments.
The board support is based on the BeagleBoard implementation.
Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it>
Cc: Sandeep Paulraj <s-paulraj@ti.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Removed boot_flash_* extern variables.
boot_flash_type was totally unused. The other ones were actually constants, so
they have been replaced with #defines in the board config files.
Signed-off-by: Tom Warren <twarren@nvidia.com>
