Fix:
sys_info.c: In function 'display_board_info':
sys_info.c:260:16: warning: variable 'db_s' set but not used
[-Wunused-but-set-variable]
Also fix resulting warnings:
sys_info.c:251:7: warning: unused variable 'db_ip' [-Wunused-variable]
sys_info.c:250:7: warning: unused variable 'db_men' [-Wunused-variable]
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Fix:
apollon.c: In function 'dram_init':
apollon.c:188:29: warning: variable 'cpu' set but not used
apollon.c:188:20: warning: variable 'rev' set but not used
apollon.c:187:26: warning: variable 'size1' set but not used
Fix:
yaffs_guts.c: In function 'yaffs_GarbageCollectBlock':
yaffs_guts.c:2761:6: warning: variable 'retVal' set but not used
Here GCC actually detected a bug. The code was always returning OK
instead of the previously set retrun code. Fix that.
Cc: William Juul <wiljuul@cisco.com>
Cc: Scott Wood <scottwood@freescale.com>
Acked-by: William Juul <wiljuul@cisco.com>
Fix:
at91_emac.c: In function 'at91emac_phy_init':
at91_emac.c:244:20: warning: variable 'duplex' set but not used
at91_emac.c:244:13: warning: variable 'speed' set but not used
Use new debug_cond() to fix these warnings. In the result, anumber of
inconsistent printf() formats are detected:
at91_emac.c: In function 'at91emac_read':
at91_emac.c:147:2: warning: format '%x' expects argument of type
'unsigned int', but argument 2 has type 'struct at91_emac_t *'
[-Wformat]
at91_emac.c: In function 'at91emac_write':
at91_emac.c:157:2: warning: format '%x' expects argument of type
[-Wformat]
'unsigned int', but argument 4 has type 'short unsigned int *'
[-Wformat]
at91_emac.c: In function 'at91emac_recv':
at91_emac.c:451:3: warning: format '%d' expects argument of type
'int', but argument 2 has type 'long unsigned int' [-Wformat]
at91_emac.c:451:3: warning: format '%x' expects argument of type
'unsigned int', but argument 4 has type 'long unsigned int' [-Wformat]
Fix these, too.
Cc: Jens Scharsig <js_at_ng@scharsoft.de>
Cc: Andreas Bießmann <andreas.devel@gmail.com>
Cc: Reinhard Meyer <u-boot@emk-elektronik.de>
Fix:
ne2000_base.c: In function 'dp83902a_send':
ne2000_base.c:282:7: warning: variable 'tmp' set but not used
ne2000_base.c: In function 'dp83902a_RxEvent':
ne2000_base.c:376:5: warning: variable 'rsr' set but not used
ne2000_base.c: In function 'dp83902a_TxEvent':
ne2000_base.c:513:5: warning: variable 'tsr' set but not used
ne2000_base.c: In function 'dp83902a_ClearCounters':
ne2000_base.c:550:17: warning: variable 'cnt3' set but not used
ne2000_base.c:550:11: warning: variable 'cnt2' set but not used
ne2000_base.c:550:5: warning: variable 'cnt1' set but not used
* 'master' of git://git.denx.de/u-boot-arm:
M28: Cleanup memsize.o OOT build
i.MX28: Move SPL to arch/arm/cpu/arm926ejs/mx28
M28: Fix typo
M28: Document that units has to be set to sectors on SD bootcard
i.mx: i.mx6q: add the initial support for i.mx6q ARM2 board
i.mx: mxc_gpio: add the i.mx6q support
i.mx: add the initial support for freescale i.MX6Q processor
i.mx: introduce the armv7/imx-common folder
S5PC2XX: Rename S5pc2XX to exynos
tegra2: Don't use board pointer before it is set up
tegra2: Remove unneeded 'dynamic ram size' message
tegra2: Remove unused low-level Tegra2 UART code
tegra2: Remove unneeded config option
tegra2: Remove unneeded boot code
tegra2: Enable instruction cache
arm: Move CP15 init out of cpu_init_crit()
tegra2: Simplify tegra_start() boot path
tegra2: Add arch_cpu_init() to fire up Cortex-A9
tegra2: Use new GPIO APIs in gpio_config_uart()
tegra2: Add support for Ventana
tegra2: Modify MMC driver to handle power and cd GPIOs
tegra2: Move board_mmc_init into board files
* 'agust@denx.de' of git://git.denx.de/u-boot-staging:
Update pci_ids.h from current Linux sources
omap: overo: Use ubifs instead of jffs2 for nand
omap: TWL4030 Bump VMMC1 interface voltage from 3V to 3.15V
* 'master' of git://git.denx.de/u-boot-mpc85xx:
mpc85xx: Add board support for the eXMeritus HWW-1U-1A devices
The current way memsize.c is built just made a symlink into the directory
with SPL and then compiled it like any other file there. This was bad as that
broke the out-of-tree build.
The new way introduced in this patch uses the standard spl/Makefile methods
(CONFIG_SPL_LIBCOMMON_SUPPORT / CONFIG_SPL_LIBGENERIC_SUPPORT) to let files in
common/ be built. Because common/Makefile says memsize.c is always built (SPL
and non-SPL build), this fixes our issue with memsize.c out-of-tree build.
Cc: Detlev Zundel <dzu@denx.de>
This moves SPL to common location so it can be reused by multiple boards. Also,
this commit adjusts M28 SoM to avoid breakage due to the move.
Add the initial support for Freescale i.MX6Q Armadillo2 board
Support: MMC boot from slot 0/1, debug UART(UART4), usdhc.
There is two MMC slots on the boards:
mmc dev 0 -> connect USDHC3 -> the lower slot on the board,
mmc dev 1 -> connect USDHC4 -> the upper slot on the board,
Signed-off-by: Jason Liu <jason.hui@linaro.org>
Tested-by: Dirk Behme <dirk.behme@de.bosch.com>
i.MX6Q is freescale quad core processors with ARM cortex_a9 complex.
This patch is to add the initial support for this processor.
Cc:Stefano Babic <sbabic@denx.de>
In order to support the coming MX6 platform and to reducde
the duplicated code, we had better move some common files
or functions to the imx-common folder for sharing.
This patch does the following:
- move speed.c file from armv7/mx5/speed.c to armv7/imx-common/speed.c
- move armv7/mx5/timer.c to armv7/imx-common/timer.c, no any new feature
added but just fix the checkpatch errors in the old file and remove
the CONFIG_SYS_MX5_CLK32 reference in the file
- create one new file cpu.c file to store the common function with i.mx5/6
As per new naming convention for Samsung SoC's, all Cortex-A9 and Cortex-A15
based SoC's will be classified under the name Exynos. Cortex-A9 and Cortex-A15
based SoC's will be sub-classified as Exynos4 and Exynos5 respectively.
In order to better adapt and reuse code across various upcoming Samsung Exynos
based boards, all uses of s5pc210 prefix/suffix/directory-names are renamed in
this patch. s5pc210 is renamed as exynos4210 and S5PC210/s5pc210 suffix/prefix
are renamed as exynos4/EXYNOS4.
Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
In board_init_f() the gd->bd pointer is not valid when dram_init() is called.
This only avoids dying because DRAM is at zero on Tegra2. The common ARM
routine sets up the banks in the same way anyway, so we can just remove this
code.
Signed-off-by: Tom Warren <twarren@nvidia.com>
This message is not required, since it is followed by an 'official' U-Boot
message.
U-Boot 2011.03-00048-gd7cb0d3 (May 11 2011 - 17:17:23)
TEGRA2
Board: NVIDIA Seaboard
dynamic ram_size = 1073741824
DRAM: 1 GiB
becomes:
TEGRA2
DRAM: 1 GiB
This is a separate commit since it changes behavior.
This was used by the AVP in early boot but is no longer used. Unless we
plan to enable it somehow it is not needed. In any case we should try
to use the ns16550 driver instead as it has the same code.
CONFIG_ENABLE_CORTEXA9 and CONFIG_SKIP_RELOCATE_UBOOT are not needed,
so remove them.
Since we have cache support built in we can remove Tegra's existing cache
initialization code amd other related dead code.
Since low-level init is skipped, the instruction cache is never enabled on
Tegra2. This explicitly calls this initialization as soon as the A9 is
initialized.
Some SOCs have do not start up with their 'main' CPU. The first U-Boot
code may then be executed with a CPU which does not have a CP15, or not a
useful one.
Here we split the initialization of CP15 into a separate call, which can
be performed later if required.
Once the main CPU is running, you should call cpu_init_cp15() to perform
this init as early as possible.
Existing ARMv7 boards which define CONFIG_SKIP_LOWLEVEL_INIT should not
need to change, this CP15 init is still skipped in that case. The only
impact for these boards is that the cpu_init_cp15() will be available
even if it is never used on these boards.
The Tegra2 boot path is more complicated than it needs to be. Since we want
to move to building most of U-Boot with ARMv7 and only a small part with
ARMv4T (for AVP) it should be as simple as possible.
This makes tegra2_start() into a simple function which either does AVP
init or A9 init depending on which core is running it. Both cores now
following the same init path, beginning at _start, and the special Tegra2
boot path code is no longer required.
Only two files need to be built for ARMv4T, and this is handled in the
Tegra2 CPU Makefile.
We want to move away from a special Tegra2 start-up, and just use
arch_cpu_init() instead. However, if we run board_init_f() from boot
we need to build it for ARMv4T, since the Tegra's AVP start-up CPU
does not support ARMv7.
The effect of this is to do the AVP init earlier, and in
arch_cpu_init(), rather that board_early_init_f().
... rather than open-coding the register accesses.
However, gpio_request() typically stores the "label" parameter in a global
data structure. This causes problems when called from gpio_config_uart(),
since the code is running before relocation. To solve this, pass a NULL
string to gpio_request(), and modify gpio_request() not to touch the string
if it's NULL.
Ventana is a board which is very similar to Seaboard. Support it by
re-using board/nvidia/seaboard/seaboard.c with minor run-time conditionals.
v5: Makefile: Use cmd_link_o_target, remove unused clean/distclean targets.
v6: Make gpio_config_uart_seaboard() static.
v7: Add MAINTAINERS entry for Ventana. Tom Warren doesn't have Ventana, so
he asked me to add myself for this board.
Pass the GPIO numbers for power and card detect to tegra2_mmc_init(), and
modify that function to perform all required GPIO initialization. This
removes the need for board files to perform these operations.
Move board_mmc_getcd() into tegra2_mmc.c now that the driver knows which
GPIOs to use.
Update affected call-sites in seaboard.c and harmony.c. Note that this
change should make all SD ports work on Harmony, since the required GPIO
setup is now being performed.
v4: Fix prototype of tegra2_mmc_init() in board.h to match driver change.
Remove prototype of gpio_config_mmc() from board.h
Cc: Andy Fleming <afleming@gmail.com>
Acked-by: Andy Fleming <afleming@freescale.com>
For Seaboard, this is mostly a cut/paste of board_mmc_init() and
pin_mux_mmc() into seaboard.c; pin_mux_mmc() was modified to add some
missing pinmux_tristate_disable calls for the GPIOs.
For Harmony, those functions were modified to configure SDMMC2 (index 2)
instead of SDMMC3 (index 1), since that's what is present on the board.
However, harmony.c is still missing the required GPIO setup, so neither
port is likely to function correctly yet. This will be fixed in the next
change.
v4: Include board.h to prototype tegra2_mmc_init().
This change copies over the pci_ids.h file from Linux verbatim, plus a few
ids that had been added by hand. The last non-merge change hash in that
file in the kernel repository was:
8930c8aa740b12ad69f44a35137bcc39bfa3dc41
and the kernel was at version 2.6.38.
Signed-off-by: Gabe Black <gabeblack@chromium.org>
[agust@denx.de: updated to preserve used PCI IDs]
Signed-off-by: Steve Sakoman <steve@sakoman.com>
Tested-by: Ash Charles <ash@gumstix.com>
MMC interfaces are specified to be 3.3V compatible with an operating
voltage range of 3.1V to 3.5V for SD cards. This change affects
hardware using TWL4030 (TPS6595x) PMICs and should improve the
reliability when communicating with marginally-spec'd MMC devices.
3.15V is the highest possible level for this chip. This patch
has been tested on a Gumstix Overo board.
Signed-off-by: Ash Charles <ash@gumstix.com>
Tested-by: Steve Sakoman <steve@sakoman.com>
The eXMeritus HWW-1U-1A unit is a DO-160-certified 13lb 1U chassis
with 3 independent TEMPEST zones. Two independent P2020 computers may
be found inside each zone. Complete hardware support is included.
High-level hardware overview:
* DO-160 certified for passenger aircraft (noncritical)
* TEMPEST ceritified for RED/BLACK separation
* 3 zones per chassis, 2 computers per zone (total of 6)
* Dual-core 1.066GHz P2020 per computer
* One 2GB DDR2 SO-RDIMM module per computer (upgradable to 4GB)
* Removable 80GB or 160GB Intel X18-M SSD per computer
* Front-accessible dual-port E1000E per computer
* Front-accessible serial console per computer
* Front-accessible USB port per computer
* Internal Gigabit crossover within each TEMPEST zone
* Internal unidirectional fiber links across TEMPEST zones
* Battery-backed DS1339 I2C RTC on each CPU.
Combined, each 13lb 1U chassis contains 12GB RAM, 12 cores @ 1.066GHz,
12 front-accessible Gigabit Ethernet ports and 960GB of solid-state
storage with a total power consumption of ~200W.
Additional notes:
* SPD detection is only known to work with the DO-160-certified DIMMs
* CPU reset is a little quirky due to hardware misfeature. Proper
support for the hardware reset mechanism has been left for a later
patch series to address.
Signed-off-by: Kyle Moffett <Kyle.D.Moffett@boeing.com>
This patch adds support for console output before the console is inited.
The main purpose of this is to deal with a very early panic() which would
otherwise cause a silent hang.
A new board_pre_console_putc() function is added to the board API. If
provided by the board it will be called in the event of console output
before the console is ready. This function should turn on all UARTs and
spray the character out if it possibly can.
The feature is controlled by a new CONFIG_PRE_CONSOLE_PUTC option.
Acked-by: Graeme Russ <graeme.russ@gmail.com>
During the rebase of commit 00b7d6e "USB: Squash checkpatch warnings
in usb_kbd.c" I missed a brace, resulting in a number of build errors.
Fix these.
Fix:
da8xx_gpio.c: In function 'gpio_toggle_value':
da8xx_gpio.c:208:23: warning: variable 'bank' set but not used
Build dbau1550_el only in LIST_au1xx0_el and LIST_mips_el.
Also remove obsolete lists for mips5kc.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Cc: Thomas Lange <thomas@corelatus.se>
Fix:
ep0.c: In function 'ep0_get_descriptor':
ep0.c:187:8: warning: variable 'cp' set but not used
Cc: Remy Bohmer <linux@bohmer.net>
Acked-by: Remy Bohmer <linux@bohmer.net>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Fix:
core.c: In function 'usbd_device_event_irq':
core.c:596:21: warning: variable 'state' set but not used
Fix:
musb_udc.c: In function 'musb_peri_softconnect':
musb_udc.c:166:14: warning: variable 'intrtx' set but not used
musb_udc.c:166:6: warning: variable 'intrrx' set but not used
musb_udc.c:165:5: warning: variable 'intrusb' set but not used
Fix:
ehci-mxc.c: In function 'ehci_hcd_init':
ehci-mxc.c:113:6: warning: variable 'tmp' set but not used
Sorry if this is already fixed somewhere - I could not find it.
This fixes these warnings:
usb_ohci.c: In function 'submit_control_msg':
usb_ohci.c:1081: warning: dereferencing pointer 'data_buf.76' does break strict-aliasing rules
usb_ohci.c:1081: note: initialized from here
usb_ohci.c:1084: warning: dereferencing pointer 'data_buf.76' does break strict-aliasing rules
usb_ohci.c:1084: note: initialized from here
usb_ohci.c:1087: warning: dereferencing pointer 'data_buf.76' does break strict-aliasing rules
usb_ohci.c:1087: note: initialized from here
Cc: Mike Frysinger <vapier@gentoo.org>
Rebased to current code.
This fixes the build of the two sh boards shmin and r7780mp and qemu-mips
which currently fail to build due to dropped pre-CONFIG_NET_MULTI code.
This v2 patch minimizes the number of lines in the diff for easy review
and to eliminate any possible accidential changes resulting from moving
lines of code in the file. This also makes the register function very easy.
Any cleanups and improvements are intentionally deferred to follow-up patches
to keep this patch as simple and as easy to review as possible.
A new driver register function, ne2k_register() calls the existing
one-time setup part of the old init function and calls eth_register().
Changes to shmin, r7780mp and qemu-mips:
- Call the new ne2k_register() from board_eth_init() of the boards.
- Tested using qemu-mips board,
- Tested the two renesas / sh boards r7780mp and shmin to compile again,
and should work.
checkpatch-clean when "--ignore VOLATILE" is added to .checkpatch.conf,
and no warnings introduced in none of the three boards using this driver.
Signed-off-by: Bernhard Kaindl <bernhard.kaindl@gmx.net>
Fix:
inca-ip_sw.c: In function 'inca_switch_init':
inca-ip_sw.c:210:6: warning: variable 'v' set but not used
Fix:
board.c: In function 'board_init_r':
board.c:262:8: warning: unused variable 's' [-Wunused-variable]
(raised for configurations without ethernet support like
vct_premium_small)
Cc: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
Fix all errors and all warnings except for "externs should be avoided"
which could require more extensive changes.
* 'master' of git://git.denx.de/u-boot-nand-flash:
nand_spl/nand_boot.c: Fix build warning
drivers/mtd/nand/nand_spl_load.c: Fix GCC 4.6 warning
drivers/mtd/nand/nand_spl_simple.c: Fix GCC 4.6 warnings
