2011-04-27arm: Tegra2: Move clk/mux init to board_early_init_f, add GPIO initTom Warren
Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-04-27arm: Tegra2: GPIO: Add basic GPIO definitionsTom Warren
2011-04-27arm: Tegra2: Add missing PLLX initTom Warren
2011-04-27ARM: fix stack pointer adjustment in board_init_f()Eric Cooper
Since addr_sp is a byte address, it should be adjusted by 12 here. Signed-off-by: Eric Cooper <ecc@cmu.edu> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Wolfgang Denk <wd@denx.de>
2011-04-27arm: Tegra2: add support for A9 CPU initTom Warren
2011-04-27ARMV7: OMAP3: Add GPMC_CONFIGx register value definitionsLuca Ceresoli
Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27ARMV7: OMAP3: Fix preprocessor check for CONFIG_OMAP34XXLuca Ceresoli
CONFIG_OMAP34XX must be checked for existence, not value. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.aribaud@free.fr> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27omap3_beagle: enable EHCI and USB storage.Alexander Holler
The reset sequence/configuration for ehci is highly board specific, so this will be done in the source for the board, instead of introducing several CONFIG_* which would be needed to make those few lines in beagle.c usable across different OMAP boards. Signed-off-by: Alexander Holler <holler@ahsoftware.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27OMAP3: Add support for DPLL5 (usbhost)Alexander Holler
2011-04-27OMAP3: Change some USB related MUX valuesAlexander Holler
2011-04-27ARM: OMAP3: Revamp IGEP module default configurationEnric Balletbo i Serra
The default IGEP configuration doesn't do anything useful; using some boot.scr search logic like BeagleBoard is much more useful. Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27ARM: OMAP3: Revamp IGEP v2 defaultEnric Balletbo i Serra
configuration The default IGEP configuration doesn't do anything useful; using some boot.scr search logic like BeagleBoard is much more useful. Signed-off-by: Loïc Minier <loic.minier@linaro.org> Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27Replace obsolete e-mail addressAlbert ARIBAUD
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-04-27a320evb: fix include path of timer fttmr010Macpaul Lin
Fix include path of timer fttmr010 in a320evb. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-04-27fttmr010: move fttmr010 header to include/faradayMacpaul Lin
Move the header file and definitions of fttmr010 power control unit from a320 SoC folder to "include/faraday" folder. This change will let other SoC which also use fttmr010 could share the same header file. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-04-27ftpmu010.h: add asm support used by lowlevel_initMacpaul Lin
Add asm support which is ususally used in lowlevel_init to set power related parameters to sdram controller and static memory controller. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-04-27ftpmu010: fix relocation and enhance featuresMacpaul Lin
1. ftpmu010.h: fix and add definitions Enhanced for more features and asm related support according to datasheet. Note: - FTPMU010_PDLLCR0_HCLKOUTDIS is "incorrect" in datasheet. - FTPMU010_PDLLCR0_DLLFRANG is only 1 bit at bit #19. (not 20-19) - FTPMU010_PDLLCR0_HCLKOUTDIS is 4 bits at bit #20. (not 24-21) 2. ftpmu010.c: enhance features and fix relocation - The following functions is added for pmu features. ftpmu010_mfpsr_select_dev() ftpmu010_sdramhtc_set() - This patch also fix the declare statement for relocation. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-04-27Orion5x: Correct DRAM bank detectionRogan Dawes
2011-04-27I2C: add i2c support for Armada100 platformLei Wen
Add i2c support to aspenite board with Armada100 soc. Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-04-27I2C: mv_i2c: add multi bus supportLei Wen
Add the ability to support multiple i2c bus for mv_i2c Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-04-27I2C: add i2c support for Pantheon platformLei Wen
Add i2c support to dkb board with pantheon soc. Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-04-27mv_i2c: use structure to replace the direclty defineLei Wen
Add i2c_clk_enable in the cpu specific code, since previous platform it, while new platform don't need. In the pantheon and armada100 platform, this function is defined as NULL one. Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-04-27mv_i2c: fix timeout value to be consistent with commentsLei Wen
The original 10000 value would be 100ms, which is not the comments said. Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-04-27pxa: move i2c driver to the common placeLei Wen
For better sharing with other platform other than pxa's, it is more convenient to put the driver to the common place. Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-04-27MX25: tx25: Add _end section on nand_splFabio Estevam
Commit f326cbb (arm: fix incorrect monitor protection region in FLASH) missed to update nand_spl/board/karo/tx25/u-boot.lds. Add the _end section. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-04-27MX31: mx31pdk: fix nand_splStefano Babic
Commit f326cbba98bae21d41df8daac0bd78121d557af1 breaks mx31pdk, as the _end section in u-boot.lds is missing for the nand_spl production. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-04-27ARMV7: Vexpress: Remove config.mkMatt Waddel
Remove obsolete board config.mk. Signed-off-by: Matt Waddel <matt.waddel@linaro.org>
2011-04-27arm: a320: use new ftpmu010 APIPo-Yu Chuang
ftpmu010 related code has been moved to drivers/power/. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com> Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2011-04-27power: ftpmu010: move drivers/power/ftpmu010.h to include/faradayPo-Yu Chuang
Also add API declarations. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com> Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2011-04-27arm: Use optimized memcpy and memset from linuxMatthias Weisser
Using optimized versions of memset and memcpy from linux brings a quite noticeable speed (x2 or better) improvement for these two functions. Here are some numbers for test done with jadecpu | HEAD(1)| HEAD(1)| HEAD(2)| HEAD(2)| | | +patch | | +patch | ---------------------------+--------+--------+--------+--------+ Reset to prompt | 438ms | 330ms | 228ms | 120ms | | | | | | TFTP a 3MB img | 4782ms | 3428ms | 3245ms | 2820ms | | | | | | FATLOAD USB a 3MB img* | 8515ms | 8510ms | ------ | ------ | | | | | | BOOTM LZO img in RAM | 3473ms | 3168ms | 592ms | 592ms | where CRC is | 615ms | 615ms | 54ms | 54ms | uncompress | 2460ms | 2462ms | 450ms | 451ms | final boot_elf | 376ms | 68ms | 65ms | 65ms | | | | | | BOOTM LZO img in FLASH | 3207ms | 2902ms | 1050ms | 1050ms | where CRC is | 600ms | 600ms | 135ms | 135ms | uncompress | 2209ms | 2211ms | 828ms | 828ms | | | | | | Copy 1.4MB from NOR to RAM | 134ms | 72ms | 120ms | 70ms | (1) No dcache (2) dcache enabled in board_init *Does not work when dcache is on Size impact: C version: text data bss dec hex filename 202862 18912 266456 488230 77326 u-boot ASM version: text data bss dec hex filename 203798 18912 266288 488998 77626 u-boot 222712 u-boot.bin Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2011-04-27OMAP3: CM-T35: Add support for CM-T3730Igor Grinberg
CM-T3730 is exactly the same board as CM-T35, but it has TI DM3730 SoC onboard and therefore some changes have to take place Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27OMAP3: CM-T35: enable the green LEDIgor Grinberg
2011-04-27OMAP3: CM-T35: remove redundand i2c initializationIgor Grinberg
2011-04-27OMAP3: CM-T35: fix mmcIgor Grinberg
Use CONFIG_OMAP3_MMC in cm-t35 configuration file. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27OMAP3: CM-T35: add MMC1 pinmuxIgor Grinberg
2011-04-27OMAP3: CM-T35: update MAINTAINERS fileIgor Grinberg
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27OMAP3: CM-T35: update board files header informationIgor Grinberg
2011-04-27OMAP3: CM-T35: update configIgor Grinberg
update config for OMAP3 CM-T35 Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27OMAP3: CM-T35: Move DECLARE_GLOBAL_DATA_PTR to file scopeIgor Grinberg
Move DECLARE_GLOBAL_DATA_PTR to file scop Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27ARMV7: AM3517/05: Add support for CraneBoard.Srinath
It is a low cost reference design based on Sitara AM3517 SoC from Texas Instruments Please refer to <www.craneboard.org> for more details. Signed-off-by: Srinath <srinath@mistralsolutions.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27OMAP3: BeagleBoard: add more expansionboard IDsKoen Kooi
Information on configurations pulled from http://www.elinux.org/BeagleBoardPinMux#Vendor_and_Device_IDs Boards added: * Added BeagleBoardToys WiFi, VGA and LCD boards * Added KBADC Beagle FPGA board * Added Brainmux LCDog and LCDog Touch * Added Liquidware BeagleTouch Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Koen Kooi <koen@dominion.thruhere.net> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27OMAP3: BeagleBoard: add xM rev B to ID tableKoen Kooi
Patch was updated by Jason Kridner <jkridner@beagleboard.org>: * Use tabs to match style of other board revisions * Only include board revisions that exist * Default to the same configuration as the latest revision, but without setting 'beaglerev' Signed-off-by: Koen Kooi <koen@dominion.thruhere.net> Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27OMAP3: BeagleBoard: Enable pullups on i2c2.Steve Kipisz
This allows the reading of EEPROMS on the expansion bus without adding external pull-ups. Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Steve Kipisz <s-kipisz2@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27omap3_beagle: enable the use of a plain text fileAlexander Holler
Using the new env import command it is possible to use plain text files instead of script-images. Plain text files are much easier to handle. E.g. If your boot.scr contains the following: ----------------------------------- setenv dvimode 1024x768-16@60 run loaduimage run mmcboot ----------------------------------- you could create a file named uEnv.txt and use that instead of boot.scr: ----------------------------------- dvimode=1024x768-16@60 uenvcmd=run loaduimage; run mmcboot ----------------------------------- The variable uenvcmd (if existent) will be executed (using run) after uEnv.txt was loaded. If uenvcmd doesn't exist the default boot sequence will be started, therefore you could just use ----------------------------------- dvimode=1024x768-16@60 ----------------------------------- as uEnv.txt because loaduimage and mmcboot is part of the default boot sequence Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27BeagleBoard: Added LED driverJason Kridner
Added LED driver using status_led. USR0 is set to monitor the boot status. USR1 is set to be the green LED. Included adding configuration and command to the default configuration. Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27Add 'led' commandJason Kridner
This patch allows any board implementing the coloured LED API to control the LEDs from the console. led [green | yellow | red | all ] [ on | off ] or led [ 1 | 2 | 3 | all ] [ on | off ] Adds configuration item CONFIG_CMD_LED enabling the command. Partially based on patch from Ulf Samuelsson: http://www.mail-archive.com/u-boot@lists.denx.de/msg09593.html. Updated based on feedback: http://www.mail-archive.com/u-boot@lists.denx.de/msg41847.html https://groups.google.com/d/topic/beagleboard/8Wf1HiK_QBo/discussion * Fixed a handful of style issues. * Significantly reduced the number of #ifdefs and redundant code * Converted redundant code into loops test against a structure * Made use of cmd_usage() * Introduced a str_onoff() function, but haven't yet put it in common * Eliminated trailing newline Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27MX31: drop warnings in get_cpu_revStefano Babic
Drop warnings due to recent commit ARM: mx31: Print the silicon version Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@freescale.com>
2011-04-27MX5: factor out boot cause funciton to common codeJason Liu
factor out boot cause function to common code to avoid the duplicate code in each board support package Signed-off-by: Jason Liu <jason.hui@linaro.org>
2011-04-27ARM: MX31: Fix file name labelFabio Estevam
Commit 5d2c154 (IMX: MX31: Cleanup include files and drop nasty #ifdef in drivers) renamed mx31-imx-regs.h to imx-regs.h. Change the file label accordingly. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-04-27MX31: mx31pdk: Make the board name simpler.Fabio Estevam
