2010-11-17tx25: fix linker file for newer ld supportAlbert Aribaud
older ld emitted all ELF relocations in input sections named .rel.dyn, whereas newer ld uses names of the form .rel*. The linker script only collected .rel.dyn input sections. Rewrite to collect all .rel* input sections. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2010-11-17ARM: fix linker file for newer ld supportAlbert Aribaud
2010-11-13Merge branch 'master' of git://git.denx.de/u-boot-tiWolfgang Denk
2010-11-12Merge branch 'at91' of git://git.denx.de/u-boot-atmelWolfgang Denk
2010-11-12Merge branch 'master' of /home/wd/git/u-boot/masterWolfgang Denk
2010-11-04armv7, beagle: Second SDRAM bank don;t workHeiko Schocher
since commit 3667cbeed5e3c4067e624e52a916b1ebb02c8f05 on beagle board the second sdram bank didn;t longer work. Since this patch sdram settings just get copied from bank a, but CMD_NOP, CMD_PRECHARGE, CMD_AUTOREFRESH are not executed and after that mr register is also not updated. This patch adds this for the bank b. Signed-off-by: Heiko Schocher <hs@denx.de> cc: Steve Sakoman <steve@sakoman.com> cc: Sandeep Paulraj <s-paulraj@ti.com> cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04omap3evm: Fix mechanism to identify board revisionSanjeev Premi
Function omap3_evm_get_revision() - to identify the board revision was called at end of setup_net_chip(). Board revision can be ascertained only by identifying the Ethernet chipset - but combining setup operations with revision detection isn't a good idea. So, moved the function after call to setup_net_chip(). Function setup_net_chip() should be ideally be called only when CONFIG_CMD_NET is defined. But this leaves the board revision "undetected". This patch allows static definition of revision or default fallback to the latest revision. Signed-off-by: Sanjeev Premi <premi@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04omap3evm: Wrap function under CONFIG_USB_OMAP3Sanjeev Premi
The function omap3_evm_need_extvbus() is required only when USB support is configured. Wrapped this function in #ifdef CONFIG_USB_OMAP3. Signed-off-by: Sanjeev Premi <premi@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04omap3evm: Support relocationSanjeev Premi
This patch adds relocation support for omap3evm. Content of the patch is based on changes for Beagleboard. Signed-off-by: Sanjeev Premi <premi@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04ARMV7: OMAP3: Use generic mmc driver on OMAP3 IGEP moduleEnric Balletbo i Serra
This patch switches from the legacy mmc driver to the new generic mmc driver Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04ARMV7: OMAP3: Use generic mmc driver on IGEP v2Enric Balletbo i Serra
2010-11-04mmc: Add multi-block read support to the generic mmc driverAlagu Sankar
This patch adds multi-block read support for the generic MMC driver. Large reads are broken into chunks of 65535 blocks to ensure that the code works with controllers having a 16 bit block counter. This patch results in a significant performance improvement. Time to read a 45 MB file went from 36 seconds to 9 seconds on Overo Signed-off-by: Steve Sakoman <steve.sakoman@linaro.org> Tested-by: Steve Sakoman <steve.sakoman@linaro.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04mmc: Clean up generic mmc driver multi-block write functionsSteve Sakoman
The current mmc write implementation is type ulong, but returns int values. Some of the printf's are terminated with /n/r, one has none. This patch fixes these issues and also removes some unnecessary local variables. Signed-off-by: Steve Sakoman <steve.sakoman@linaro.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04ARMV7: OMAP: Fix build after introduction of GENERATED_GBL_DATA_SIZESteve Sakoman
This patch fixes the issue by defining and using CONFIG_SYS_INIT_RAM_SIZE and CONFIG_SYS_INIT_RAM_ADDR. Based on an email discussion with Wolfgang Denk and Heiko Schocher. Signed-off-by: Steve Sakoman <steve.sakoman@linaro.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04ARMV7: OMAP3: Add expansion board detection for BeagleKoen Kooi
Beagle expansion boards contain an i2c eeprom to identify themselves. This patch adds code to read and parse the eeprom contents. It prints the expansion board name and revision and modifies environment variables as appropriate. This patch is based on the Overo expansion board code. Signed-off-by: Koen Kooi <k-kooi@ti.com> Signed-off-by: Steve Sakoman <steve.sakoman@linaro.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04ARMV7: OMAP3: Add expansion board detection for OveroSteve Sakoman
Overo expansion boards contain an i2c eeprom to identify themselves. This patch adds code to read and parse the eeprom contents. It prints the expansion board name and revision and modifies environment variables as appropriate. Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04ARMV7: Fix build for non-OMAP3 boardsSteve Sakoman
Commit c3d3a54 uses CONFIG_ARMV7 to determine whether to call the v7_flush_cache_all function. This breaks the build for all non-OMAP3 boards (like Panda and OMAP4430SDP) since there is only a v7_flush_cache_all implementation for OMAP3. This patch uses CONFIG_OMAP3XXX instead of CONFIG_ARMV7 so that only boards with a v7_flush_cache_all will make the call. Tested on Beagle, Overo, Panda, and OMAP4430SDP Signed-off-by: Steve Sakoman <steve.sakoman@linaro.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04ARMV7: OMAP3: IGEP: Rename TEXT_BASESteve Sakoman
Commit 14d0a02a "Rename TEXT_BASE into CONFIG_SYS_TEXT_BASE" missed the IGEP boards since they were just added. Signed-off-by: Steve Sakoman <steve.sakoman@linaro.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-02AT91: add header file for the Shutdown ControllerReinhard Meyer
and SHDWN address entry in at91sam9260.h Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-30AT91: add 2nd SPI to 9260/9XE/9G20Reinhard Meyer
2010-10-29Merge branch 'master' of git://git.denx.de/u-boot-marvellWolfgang Denk
Conflicts: include/configs/km_arm.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-29Merge branch 'master' of git://git.denx.de/u-boot-imxWolfgang Denk
2010-10-29Merge branch 'master' of git://git.denx.de/u-boot-samsungWolfgang Denk
2010-10-29Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
2010-10-29Merge branch 'for-wd-master' of git://git.denx.de/u-boot-pxaWolfgang Denk
2010-10-29Drop support for CONFIG_SKIP_RELOCATE_UBOOTWolfgang Denk
For ARM systems, before ELF relocation was introduced, CONFIG_SKIP_RELOCATE_UBOOT coul be used to prevent *COPYING* the U-Boot image from whereever it was loaded to it's link address (CONFIG_SYS_TEXT_BASE). The name was badly chosen, as no relocation was performed at all, it was just a memcpy(). With ELF relocation, this does not work like that any more, and related boards need to be fixed anyway. So don't keep this relict any longer. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-29Drop support for CONFIG_SYS_ARM_WITHOUT_RELOCWolfgang Denk
When this define was introduced, the idea was to provide a soft migration path for ARM boards to get adapted to the new relocation support. However, other recent changes led to a different implementation (ELF relocation), where this no longer works. By now CONFIG_SYS_ARM_WITHOUT_RELOC does not only not help any more, but it actually hurts because it obfuscates the actual code by sprinkling it with lots of dead and non-working debris. So let's make a clean cut and drop CONFIG_SYS_ARM_WITHOUT_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-29Replace CONFIG_RELOC_FIXUP_WORKS by CONFIG_NEEDS_MANUAL_RELOCWolfgang Denk
By now, the majority of architectures have working relocation support, so the few remaining architectures have become exceptions. To make this more obvious, we make working relocation now the default case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-28Kirkwood: bugfix: DRAM size initializationTanmay Upadhyay
If start of any DRAM bank is greater than total DDR size, remaining DDR banks' start address & size were left un-initialized in dram_init function. This could break other functions who uses array 'gd->bd->bi_dram'. Kirkwood network driver is one example. This also stops Linux kernel from booting. v2 - Set start address also to 0. Without this Linux kernel couldn't boot up Signed-off-by: Tanmay Upadhyay <tanmay.upadhyay@einfochips.com>
2010-10-28kirkwood: get rid of config.mk filesPrafulla Wadaskar
After moving the definition of CONFIG_SYS_TEXT_BASE to the respective board config files, all Marvell kirkwood board have just a single and common entry in their config.mk files: KWD_CONFIG = $(SRCTREE)/board/$(BOARDDIR)/kwbimage.cfg Replace the only reference to KWD_CONFIG in the top level Makefile by an equivalent setting, and remove all kirkwood config.mk files. Signed-off-by: Wolfgang Denk <wd at denx.de> Cc: Prafulla Wadaskar <prafulla at marvell.com> Cc: Siddarth Gore <gores at marvell.com> Cc: Simon Kagstrom <simon.kagstrom at netinsight.net> Cc: Heiko Schocher <hs at denx.de> Cc: Eric Cooper <ecc at cmu.edu> Acked-by: Wolfgang Denk <wd at denx.de> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2010-10-28kirkwood: guruplug: Relocate NAND environment areaGray Remlin
Current default options increase u-boot size to overlap the location of the environment in NAND, move environment higher up Signed-off-by: Gray Remlin <g_remlin@rocketmail.com>
2010-10-28mx51evk: support new relocation schemeShawn Guo
This patch is to fix build breakage and support new relocation scheme for mx51evk. - Correct IRAM base address and add size definition The IRAM starts from 0x1FFE0000 on final revsion i.mx51 than 0x1FFE8000 which is for older revision. - Include imx-regs.h in mx51evk.h Definitions like CSD0_BASE_ADDR and IRAM_BASE_ADDR can be referred to. - Define CONFIG_SYS_INIT_RAM_ADDR and CONFIG_SYS_INIT_RAM_SIZE They are used to define init RAM layout. - Remove comment for CONFIG_SYS_GBL_DATA_SIZE which has been buried by Wolfgang's commit below 25ddd1fb: Replace CONFIG_SYS_GBL_DATA_SIZE by auto-generated value Signed-off-by: Shawn Guo <shawn.gsc@gmail.com>
2010-10-28mx51evk: consolidate env for mmcboot and netbootShawn Guo
This patch is to consolidate default mx51evk env for two primary boot modes, mmcboot and netboot. It also cleans some unused env like netdev, uboot and redundant env like loadaddr since CONFIG_LOADADDR already defines it. Signed-off-by: Shawn Guo <shawn.gsc@gmail.com>
2010-10-28mx51evk: Fix 2 hours reset issueShawn Guo
The mx51evk u-boot has an issue that system will get reset every 2 hours. MC13892 has an inside charge timer which expires in 120 minutes. If ICHRG and CHGAUTOB are not set properly, this timer expiration will get system power recycled. Since mx51evk has no Li-Ion battery on board, the patch sets ICHRG in externally powered mode and sets CHGAUTOB bit to avoid automatic charging, so that system will not get reset by this timer expiration. The patch also corrects the bit field definition of register 48 (Charger 0) per latest MC13892 Reference Manual. Signed-off-by: Shawn Guo <shawn.gsc@gmail.com>
2010-10-28MX51: remove warning in clock.cStefano Babic
The patch removes the warning: clock.c:291: warning: initialization from incompatible pointer type after constification of args[] Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-10-28imx25: Fix resetMatthias Weisser
This patch fixes the reset command on imx25. The watchdog registers are 16 bits in size and not 32. This patch also adds the service register codes as constants. Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2010-10-28MX5:use common u-boot.lds of cpu layerJason Liu
Remove u-boot.lds from mx5 and use the common u-boot.lds of cpu layer. This patch also fix the building errors: arch/arm/cpu/armv7/start.o: In function `_rel_dyn_start_ofs': arch/arm/cpu/armv7/start.S:283: undefined reference to `__rel_dyn_start' arch/arm/cpu/armv7/start.o: In function `_rel_dyn_end_ofs': arch/arm/cpu/armv7/start.S:283: undefined reference to `__rel_dyn_end' arch/arm/cpu/armv7/start.o: In function `_dynsym_start_ofs': arch/arm/cpu/armv7/start.S:283: undefined reference to `__dynsym_start' Signed-off-by: Jason Liu <r64343@freescale.com>
2010-10-28MX51: add CONFIG_SYS_TEXT_BASE to vision2 board, use general ld scriptStefano Babic
Recent patch changed TEXT_BASE to CONFIG_SYS_TEXT_BASE and vision2 board was not updated. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-10-28Add generic support for samsung s3c2440C Nauman
This patch adds generic support for the Samsung s3c2440 processor. Global s3c24x0 changes to struct members converting from upper case to lower case. Signed-off-by: Craig Nauman <cnauman@diagraph.com> Cc: kevin.morfitt@fearnside-systems.co.uk Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2010-10-27Blackfin: config.mk: drop manual stripping of config varsMike Frysinger
Now that the common code takes care of stripping away quotes and such from numeric options, we no longer need to do so ourselves. So drop the custom code we have in the Blackfin config.mk. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-27Blackfin: fix building after asm-offsets.h introMike Frysinger
Since some of the defines in our config.h use the generated defines, we need to include the generated header. This fixes building of the Blackfin start.S file (where the stack is setup). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-27arm/pxa: remove unused arch-pxa/macro.hMikhail Kshevetskiy
Signed-off-by: Mikhail Kshevetskiy <mikhail.kshevetskiy@gmail.com>
2010-10-27Prepare v2010.12-rc1v2010.12-rc1Wolfgang Denk
2010-10-27Coding Style cleanupWolfgang Denk
2010-10-27cmd_onenand.c: Fix command usage help.Enric Balletbo i Serra
Running the onenand command without arguments does nothing, with this patch shows the command usage. Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
2010-10-27mmc: seperate block number into small parts for multi-write cmdLei Wen
Constraint the mmc framework to only send no more than 65535 blocks in one go during the multi-write command. This constraint comes due to the limitation of 16bit width block counter register at some hardware. Signed-off-by: Lei Wen <leiwen@marvell.com> Cc: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-27Merge branch 'master' of git://git.denx.de/u-boot-sparcWolfgang Denk
2010-10-27env_sf: updated to the new environment codeStefano Babic
Functions to store/retrieve the environment from a SPI flash was not updated to the new environment code. The non-redundant case was not working correctly, reporting ""Environment SPI flash not initialized" and the code was not compiled clean in the redundant case. The patch fixes these issue and makes the code more coherent with other environment storage (nand, flash). Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-10-27Makefile: fix dependencies for building NAND_SPLWolfgang Denk
Building of NAND based boards failed sometimes (especially on MP systems) because of incorrect / missing dependencies. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de>
2010-10-27make-asm-offsets: fix sed scriptWolfgang Denk
When copying the "sed" script to generate the asm-offsets.h file from the Linux Kbuild script into the make-asm-offsets file I missed the fact that the former runs in a "make" context and thus uses double "$$" to escape a single "$", while the latter is a shell script, where this must not be done. Unfortunately the problem did not show up during the initial tests on Power Architecture systems, but on ARM the generated asm-offsets.h was not correct. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
