sys_eeprom.c:82:9: warning: unknown escape sequence '\/'
These replace direct structure references for IMMR sections.
Remove the "#undef DEBUG" line from all Freescale 83xx board header files.
The inclusion of this line makes it impossible to enable debug code in
other source files, because "#define DEBUG" typically needs to be defined
before any header files are included.
Move the flat device tree setup for QE related devices into
a common file shared between 83xx & 85xx platforms that have QE's.
Signed-off-by: John Rigby <jrigby@freescale.com>
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
Changes to match 5121 device tree going mainline in 2.6.25.
Change OF_SOC from "soc5121" to plain "soc".
Remove unneeded "ref-frequency" fixups.
Remove "address" enetaddr fixup.
Add bus-frequency fixup for old OF_SOC so old
kernels with old device trees will work with new
u-boot with 66MHz IPS clock
Recommended frequency is 66MHz
Change divider from 4 to 3.
missing migration from "Cleanup of some init functions"
in c837dcb1a316745092567bfe4fb266d0941884ff
Signed-off-by: Larry Johnson <lrj@acm.org>
allow to use a different server as set in serverip
add CONFIG_TFTP_FILE_NAME_MAX_LEN to configure the file name length
if not defined the max length will be at 128
According to the OMAP5912 Serial Interfaces Reference Guide (see
http://focus.ti.com/lit/ug/spru760c/spru760c.pdf, page 150), the
FIFO_EN enable bit in the FIFO Control Register (FCR) can only be
changed when the baud clock is not running, i. e. when both DLL and
DLH are set to 0.
Thus make sure that DLL and DLH are 0 when writing the FCR.
This patch adds NAND support to the S3C24x0 SoC code in u-boot
Signed-off-by: Harald Welte <laforge@openmoko.org>
This patch adds support for CONFIG_SERIAL_MULTI on s3c24x0 CPU's
This patch allows us to use the 'gd' pointer (and thus environment
and everything else associated with it) from interrupt context on
arm920t.
This patch adds a IRQ demultiplexer callback to the arm920 cpu core code,
plus a stub implementation of it for the S3C2410.
The purpose is to allow arm920t implementations such as the s3c24x0 to
implement interrupt handlers in u-boot without having to touch core
arm920t code.
Add ifdef to bdinfo command to display ethernet information
only if CONFIG_CMD_NET is defined for arm modules.
Signed-off-by: K R Gururaja Hebbar <gururajakr@sanyo.co.in>
Adds I2C init func call to init sequence for ARM boards. This is
present in ppc,blackfin and other processor init sequence.
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Remove nowhere used struct bd_info_ext, remove trailing whitespaces, fix
indentation.
Somewhere during development of U-Boot-1.1.3 CONFIG_BOOTBINFUNC was
renamed into CONFIG_INIT_CRITICAL which was 04 Apr 2005 replaced
with CONFIG_SKIP_LOWLEVEL_INIT and CONFIG_SKIP_RELOCATE_UBOOT.
However CONFIG_SKIP_LOWLEVEL_INIT has oposite meaning to
CONFIG_BOOTBINFUNC, so fix configuration to reflect this fact.
I'm sending this patch 4th (!) time in hope it produces at least some
reaction.
Fix at91rm9200dk base and environment address.
MMC support for X_Scale PXA is broken and does not work.
Mainly, the mmc_init() function cannot recognize current SD/MMC cards.
There were already some patches around the world but none of them was
merged into the official u-boot tree.
This patch makes order fixing this issue. Resubmit after code cleanup.
Applied and tested on PXA 270 (TrizepsIV module).
Fix gcc4 issue. With some toolchain, a previous patch that fixes gcc4
issues generates wrong code.
(Problem was reported with gcc-4.0.2-glibc-2.3.6/arm-softfloat-linux-gnu).
This patch fixes the problem and solves the gcc-4 issues as the linux
kernel does.
Signed-off-by: Dmitry Ivanov <ivadmitry@gmail.com>
Signed-off-by: Jens Gehrlein <sew_s@tqs.de>
Bit).
This driver should only compile if CONFIG_MPC8XXX_SPI is set
This fixes a demo app link failure on platforms configured with CONFIG_PANIC_HANG.
Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
This fixes a build breakage with CONFIG_API enabled, which appeared after
the recent changes in the U-Boot build system.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
This can be used for debug, and will be used by board code
to help implement reginfo.
This includes mpc8610hpcd, mpc8641hpcn, and sbc8641d.
Adds the support code in cpu/mpc86xx for the new law setup code
recently created fsl_law.c, and changes the MPC8641HPCN config
to use this code.
* split the BAT initialization so that only 2 BATs (for the boot page
and stack) are programmed very early on. The rest are initialized later.
* Move other BAT setup, ccsrbar setup, and law setup later in the code
after translation has been enabled.
These changes will facilitate the moving of law and BAT initialization
to C code, and will aid with 36-bit physical addressing support.
