2014-05-13fpga: xilinx: Simplify load/dump/info function handlingMichal Simek
Connect FPGA version with appropriate operations to remove huge switch-cases for every FPGA family. Tested on Zynq. Spartan2/Spartan3/Virtex2 just compile test. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-13fpga: xilinx: Fix the rest of CamelCasesMichal Simek
No functional changes. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-13fpga: xilinx: Avoid CamelCase for in Xilinx_descMichal Simek
2014-05-13fpga: virtex2: Avoid CamelCaseMichal Simek
2014-05-13fpga: spartan3: Avoid CamelCaseMichal Simek
2014-05-13fpga: spartan2: Avoid CamelCaseMichal Simek
2014-05-12kbuild: Fix trailing whitespacesMichal Simek
Trivial fix. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-12net/designware: call phy_connect_dev() to properly setup phylib deviceIan Campbell
This sets up the linkage from the phydev back to the ethernet device. This symptom of not doing this which I noticed was: <NULL> Waiting for PHY auto negotiation to complete.... rather than: dwmac.1c50000 Waiting for PHY auto negotiation to complete.... Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Cc: Alexey Brodkin <Alexey.Brodkin@synopsys.com>
2014-05-12boards.cfg: Keep entries sortedFabio Estevam
Run "tools/reformat.py -i -d '-' -s 8 <boards.cfg >boards0.cfg && mv boards0 in order to keep the entries sorted. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-05-12fs/fat: correct FAT16/12 file finding in root dirWu, Josh
When write a file into FAT file system, it will search a match file in root dir. So the find_directory_entry() will get the first cluster of root dir content and search the directory item one by one. If the file is not found, we will call get_fatent_value() to get next cluster of root dir via lookup the FAT table and continue the search. The issue is in FAT16/12 system, we cannot get root dir's next clust from FAT table. The FAT table only be use to find the clust of data aera in FAT16/12. In FAT16/12 if the clust is in root dir, the clust number is a negative number or 0, 1. Since root dir is located in front of the data area. Data area start clust #2. So the root dir clust number should < 2. This patch will check above situation before call get_fatenv_value(). If curclust is < 2, include minus number, we just increase one on the curclust since root dir is in continous cluster. The patch also add a sanity check for entry in get_fatenv_value(). Signed-off-by: Josh Wu <josh.wu@atmel.com>
2014-05-12fs: fat_write: fix the incorrect last cluster checkingWu, Josh
In fat_write.c, the last clust condition check is incorrect: if ((curclust >= 0xffffff8) || (curclust >= 0xfff8)) { ... ... } For example, in FAT32 if curclust is 0x11000. It is a valid clust. But on above condition check, it will be think as a last clust. So the correct last clust check should be: in fat32, curclust >= 0xffffff8 in fat16, curclust >= 0xfff8 in fat12, curclust >= 0xff8 This patch correct the last clust check. Signed-off-by: Josh Wu <josh.wu@atmel.com>
2014-05-12fs/fat: add fat12 cluster checkWu, Josh
2014-05-12fs:ext4:write:fix: Reinitialize global variables after updating a fileŁukasz Majewski
This bug shows up when file stored on the ext4 file system is updated. The ext4fs_delete_file() is responsible for deleting file's (e.g. uImage) data. However some global data (especially ext4fs_indir2_block), which is used during file deletion are left unchanged. The ext4fs_indir2_block pointer stores reference to old ext4 double indirect allocated blocks. When it is unchanged, after file deletion, ext4fs_write_file() uses the same pointer (since it is already initialized - i.e. not NULL) to return number of blocks to write. This trunks larger file when previous one was smaller. Lets consider following scenario: 1. Flash target with ext4 formatted boot.img (which has uImage [*] on itself) 2. Developer wants to upload their custom uImage [**] - When new uImage [**] is smaller than the [*] - everything works correctly - we are able to store the whole smaller file with corrupted ext4fs_indir2_block pointer - When new uImage [**] is larger than the [*] - theCRC is corrupted, since truncation on data stored at eMMC was done. 3. When uImage CRC error appears, then reboot and LTHOR/DFU reflashing causes proper setting of ext4fs_indir2_block() and after that uImage[**] is successfully stored (correct uImage [*] metadata is stored at an eMMC on the first flashing). Due to above the bug was very difficult to reproduce. This patch sets default values for all ext4fs_indir* pointers/variables. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2014-05-12fs:ext4:cleanup: Remove superfluous codeŁukasz Majewski
Code responsible for handling situation when ext4 has block size of 1024B can be ordered to take less space. This patch does that for ext4 common and write files. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2014-05-12disk: part_efi: add support for the Backup GPTSteve Rae
Check the Backup GPT table if the Primary GPT table is invalid. Renamed "Secondary GPT" to "Backup GPT" as per: UEFI Specification (Version 2.3.1, Errata A) Signed-off-by: Steve Rae <srae@broadcom.com>
2014-05-12common/board_f: Fix size variableYork Sun
DRAM size should use 64-bit variable when the size could be more than 4GB. Caught and verified on P4080DS with 4GB DDR. Signed-off-by: York Sun <yorksun@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-05-12common/board_f: Initialized global data for generic boardYork Sun
Some platforms (tested on mpc85xx, mpc86xx) use global data before calling function baord_inti_f(). The data should not be cleared later. Any arch which uses global data in generic board board_init_f() should define CONFIG_SYS_GENERIC_GLOBAL_DATA. Signed-off-by: York Sun <yorksun@freescale.com> CC: Scott Wood <scottwood@freescale.com> CC: Simon Glass <sjg@chromium.org> CC: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Simon Glass <sjg@chromium.org>
2014-05-12Trivial fix to .gitignore for spl/MakefileRalph Siemsen
Trivial fix to .gitignore for spl/Makefile According to the gitignore man page: "An optional prefix "!" which negates the pattern; any matching file excluded by a previous pattern will become included again." ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ So the directory exclude "/spl/*" must come before the exception for spl/Makefile otherwise it has no effect. Signed-off-by: Ralph Siemsen <ralphs@netwinder.org> Tested-by: Masahiro Yamada <yamada.m@jp.panasonic.com> [on git v1.7.9.5 / v1.8.3.2]
2014-05-12cmd_bootm.c: Only say XIP image when load is image_startTom Rini
We say we have an XIP (in this case, image loaded at desired execution address) when the image header has been offset in the load. It's possible that in some cases executing the header is non-fatal but that's not true in many other cases. Signed-off-by: Tom Rini <trini@ti.com>
2014-05-12tools: env: Add aes.c placeholderMarek Vasut
Add missing aes.c placeholder which includes lib/aes.c . Without this one, tools/env/ will fail to build. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Alexey Brodkin <Alexey.Brodkin@synopsys.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Alexey Brodkin <abrodkin@synopsys.com> Tested-by: Heiko Schocher <hs@denx.de>
2014-05-12nand_spl: remove unused linker scripts u-boot-nand.ldsMasahiro Yamada
Commit 345b77ba removed some nand_spl boards but it missed to delete linker scripts. These linker scripts are not used now. And one more fix: amcc/acadia does not support nand_spl anymore, so remove #if !defined(CONFIG_NAND_U_BOOT) ... #endif Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Stefan Roese <sr@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2014-05-12config: remove platform CONFIG_SYS_HZ definition part 4Masahiro Yamada
Some new boards define CONFIG_SYS_HZ again! Remove. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Bo Shen <voice.shen@atmel.com>
2014-05-12cosmetic: delete misleading comment /* CONFIG_BOARDDIR */Masahiro Yamada
CONFIG_BOARDDIR is not referenced in these linker scripts. The comment /* CONFIG_BOARDDIR */ is misleading. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-05-12hush shell: Avoid string write overflow when entering max cmd lengthKristian Otnes
console_buffer array is defined to be CONFIG_SYS_CBSIZE + 1 long, whereas the_command array only CONFIG_SYS_CBSIZE long. Subsequent use of strcpy(the_command, console_buffer) will write final \0 terminating byte outside the_command array when entering a command of max length. Signed-off-by: Kristian Otnes <kotnes <at> cisco <dot> com>
2014-05-12kbuild: allow null board for spl buildMasahiro Yamada
Commit 33a02da0 supported "<none>" for the board field of boards.cfg. But it missed to modify spl/Makefile. This commit provides the flexibility so we can use "<none>" board in SPL too.
2014-05-12tps6586x: staticize funtionsManish Badarkhe
Make funtions static which are locally used in file. Signed-off-by: Manish Badarkhe <badarkhe.manish@gmail.com>
2014-05-12doc: README.generic-board: Fix typoFabio Estevam
Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-05-12lib/sha256: fix compile on some hostsAndreas Bießmann
Commit 2842c1c24269a05142802d25520e7cb9035e456c introduced lib/sha256 into mkimage. Since then it will be compiled with HOSTCC which may produce errors on some systems. Most BSD systems (like OS X for me) do not ship a linux/string.h which will lead to take the U-Boot provided include/linux/string.h in the end. This header howver is completely wrong here. Just take the string.h if compiling with HOSTCC and linux/string.h when not. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher<hs@denx.de>
2014-05-12kbuild: build with -Werror=date-time if the compiler supports itMasahiro Yamada
Using __DATE__, __TIME__ would make the build non-deterministic. If the code needs to refer to build date/time, use U_BOOT_DATE and U_BOOT_TIME in include/generated/timestamp_autogenerated.h instead. This commit has been imported from Linux Kernel, which should be applied to U-Boot too: commit fe7c36c7bde12190341722af69358e42171162f3 Author: Josh Triplett <josh@joshtriplett.org> Date: Mon Dec 23 13:56:06 2013 -0800 Makefile: Build with -Werror=date-time if the compiler supports it GCC 4.9 and newer have a new warning -Wdate-time, which warns on any use of __DATE__, __TIME__, or __TIMESTAMP__, which would make the build non-deterministic. Now that the kernel does not use any of those macros, turn on -Werror=date-time if available, to keep it that way. The kernel already (optionally) records this information at build time in a single place; other kernel code should not duplicate that. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-05-12fs: ubifs: drop __DATE__ and __TIME__Masahiro Yamada
__DATE__ and __TIME__ makes the build non-deterministic. Drop the debug message using them. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-05-12blackfin: replace bfin_gen_rand_mac() with eth_random_addr()Masahiro Yamada
bfin_gen_rand_mac() uses __DATE__ as the seed for random ethernet address. This makes the build non-deterministic. In the first place, it should not be implemented as a Bfin-specific function. Use eth_random_addr() instead. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Sonic Zhang <sonic.zhang@analog.com>
2014-05-12net: rename and refactor eth_rand_ethaddr() functionMasahiro Yamada
Some functions in include/net.h are ported from include/linux/etherdevice.h of Linux Kernel. For ex. is_zero_ether_addr() is_multicast_ether_addr() is_broadcast_ether_addr() is_valid_ether_addr(); So, we should use the same function name as that of Linux Kernel, eth_rand_addr(), for consistency. Besides, eth_rand_addr() has been implemented as an inline function. So it should not be surrounded by #ifdef CONFIG_RANDOM_MACADDR. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2014-05-12rand: do not surround function declarations by #ifdefMasahiro Yamada
2014-05-12cmd_time: do not show ticksMasahiro Yamada
The command "time" shows the execution time of the command given to the argument, like this: time: 45.293 seconds, 45293 ticks Since we adopted CONFIG_SYS_HZ = 1000 for all boards, we always have a simple formula: "1 tick = 0.0001 second". Showing ticks looks almost redundant. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-05-12net/phy: enable get_phy_id redefinableShengzhou Liu
As some PHYs have non-standard PHY ID registers, PHY Id can't be read correctly by current get_phy_id function, so we enable get_phy_id redefinable to permit specific PHY driver having own specific get_phy_id function. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
2014-05-12AR8035/phy: Enable autonegotiation function for ar8035Xiaobo Xie
Function "genphy_parse_link()" used "if (mii_reg & BMSR_ANEGCAPABLE)" before, but used "if (phydev->supported & SUPPORTED_Autoneg)" now. So assign "phydev->supported" to "phydev->drv->features" for ar8035 to enable autonegotiation. Then removed the genphy_config_aneg() function. Signed-off-by: Xie Xiaobo <X.Xie@freescale.com>
2014-05-12serial: nsl16550: add hw flow control supportKaricheri, Muralidharan
keystone serial hw support hw flow control. This patch enables hw flow control for keystone EVMs as an optional feature based on CONFIG_SERIAL_HW_FLOW_CONTROL. Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
2014-05-12fs: fat: Fix cache align error message in fatwriteNobuhiro Iwamatsu
Use of malloc of do_fat_write() causes cache error on ARM v7 platforms. Perhaps, the same problem will occur at any other CPUs. This replaces malloc with memalign to fix cache buffer alignment. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Yoshiyuki Ito <yoshiyuki.ito.ub@renesas.com> Tested-by: Hector Palacios <hector.palacios@digi.com>
2014-05-12bd_info: remove bi_barudrate member from struct bd_infoMasahiro Yamada
gd->bd->bi_baudrate is a copy of gd->baudrate. Since baudrate is a common feature for all architectures, keep gd->baudrate only. It is true that bi_baudrate was passed to the kernel in that structure but it was a long time ago. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Simon Glass <sjg@chromium.org> Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de> Acked-by: Michal Simek <monstr@monstr.eu> (For microblaze)
2014-05-12Prepare v2014.07-rc1v2014.07-rc1Tom Rini
2014-05-09Merge branch 'tom' of git://git.denx.de/u-boot-x86Tom Rini
2014-05-09sandbox: ignore sandbox.dtbMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2014-05-09sandbox: move source files from board/ to arch/sandbox/Masahiro Yamada
Prior to commit 33a02da0, all boards must have board/${BOARD}/ or board/${VENDOR}/${BOARD}/ directory. Now this rule is obsolete. It looks weird that sandbox defines "vendor" and "board" just for meeting the old U-Boot directory structure. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org>
2014-05-09patman: Avoid duplicate sign-offsSimon Glass
Keep track of all Signed-off-by tags in a commit and silently suppress any duplicates. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-09patman: Deal with 'git apply' failures correctlySimon Glass
This sort of failure is rare, but the code to deal with it is wrong. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-09sandbox: Update and expand the READMESimon Glass
Now that sandbox has a good base of features, the README is quite out of date. Update it, and document the new features. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-09sandbox: Provide a build option to avoid using SDLSimon Glass
Some machines do not have SDL libraries installed, and it is still useful to build sandbox without LCD/keyboard support. Add an option for this, used as follows: make sandbox_config all NO_SDL=1 Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-09Make 'run' use run_command_list() instead of run_command()Simon Glass
In the case where an environment variable spans multiple lines, we should use run_command_list() so that all lines are executed. This shold be backwards compatible with existing behaviour for existing scripts. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-09sandbox: Support 'env import' and 'env export'Simon Glass
Adjust the code for these commands so that they work on sandbox. Signed-off-by: Simon Glass <sjg@chromium.org> (Adjusted to fix minor merge comflict, when applied) Change-Id: I987dee6194cd5c83f82604caf894fc85e4eb71a8
2014-05-09Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
