2015-10-24Revert "ARM: zynq: disable CONFIG_SYS_MALLOC_F to fix MMC boot"Simon Glass
This reverts commit 321f86e18d6aae9f7b7ba3ef1eb0cec769481874. The original bug has been fixed. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-on: Zedboard and ZC706 board Tested-by: Masahiro Yamada <yamada.masahiro@socionext.com> Tested-on: zc702 Tested-by: Michal Simek <michal.simek@xilinx.com>
2015-10-24zynq: Move SPL console init out of board_init_f()Simon Glass
We should not init the console this early since it precludes using driver model for the UART, since it is not set up at the start of board_init_f(). See the README for more information. The debug UART does not have this restriction. If we want to do early init with the console on it can be done in spl_board_init(). Move the preloader_console_init() call from board_init_f() to board_init_r(). Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Masahiro Yamada <yamada.masahiro@socionext.com> Tested-by: Michal Simek <michal.simek@xilinx.com>
2015-10-24microblaze: Add a TODO to call board_init_f_mem()Simon Glass
This C function should be used to do the early memory layout and init. This is beyond my powers, so just add a TODO for the maintainer. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Michal Simek <michal.simek@xilinx.com>
2015-10-24arm: Switch 32-bit ARM to using generic global_data setupSimon Glass
There is quite a bit of assembler code that can be removed if we use the generic global_data setup. Less arch-specific code makes it easier to add new features and maintain the start-up code. Drop the unneeded code and adjust the hooks in board_f.c to cope. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-10-24arm: Switch aarch64 to using generic global_data setupSimon Glass
There is quite a bit of assembler code that can be removed if we use the generic global_data setup. Less arch-specific code makes it easier to add new features and maintain the start-up code. Drop the unneeded code and adjust the hooks in board_f.c to cope. Tested on LS2085ARDB and LS2085AQDS (armv8 SoC). Tested-by: York Sun <yorksun@freescale.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-10-24board_init_f_mem(): Don't create an unused early malloc() areaSimon Glass
Change the #ifdef so that the early malloc() area is not set up in SPL if CONFIG_SYS_SPL_MALLOC_START is defined. In that case it would never actually be used, and just chews up stack space. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-10-24board_init_f_mem(): Don't require memset()Simon Glass
Unfortunately memset() is not always available, so provide a substitute when needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-10-24Move board_init_f_mem() into a common locationSimon Glass
This function will be used by both SPL and U-Boot proper. So move it into a common place. Also change the #ifdef so that the early malloc() area is not set up in SPL if CONFIG_SYS_SPL_MALLOC_START is defined. In that case it would never actually be used, and just chews up stack space. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-10-24fs-test.sh: fix pre-requisite detectionStephen Warren
In the following snippet: if [ ! -x `which $prereq` ]; then When $prereq does not exist, `which $prereq` evaluates to the empty string, which results in *no* argument being passed to the -x operator, which then evaluates to true, which is the equivalent of the prereq having been found. In order for this to fail as expected, we must pass an empty argument, which then causes -x to fail. Do this by wrapping the `` in quotes so there's always an argument to -x, even if the value of the argument is zero-length. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2015-10-24test: fat: add test of non-contiguous file readsStephen Warren
In my patch series to replace fs/fat with "ff.c", I enhanced ff.c to optimize file reading, so that reads of contiguous clusters are submitted to the IO device as a single read. This test attempts to torture-test edge-cases of that enhancement. BTW, the only way I found to validate that this script actually does create non-contiguous files was to manually inspect the FAT bitmap in a hex dump of the FAT image. hdparm --fibmap doesn't work on loop-mounted filesystems. filefrag -v -e seems to lie about files being contiguous when they aren't. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2015-10-24itest: make memory access work under sandboxStephen Warren
itest accesses memory, and hence must map/unmap it. Without doing so, it accesses invalid addresses and crashes. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-10-24distro_bootcmd: Add support for booting from ubifsRoy Spliet
Under the assumptions of having a UBI volume called boot, containing a ubifs filesystem. Signed-off-by: Roy Spliet <rspliet@eclipso.eu> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2015-10-24ubifs: Add generic fs supportHans de Goede
Add generic fs support, so that commands like ls, load and test -e can be used on ubifs. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-10-24ubifs: Add functions for generic fs useHans de Goede
Implement the necessary functions for implementing generic fs support for ubifs. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-10-24ubifs: Modify ubifs u-boot wrapper function prototypes for generic fs useHans de Goede
Modify the ubifs u-boot wrapper function prototypes for generic fs use, and give them their own header file. This is a preparation patch for adding ubifs support to the generic fs code from fs/fs.c. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-10-24disk/part: Only build hostfs special handling when CONFIG_SANDBOX is setHans de Goede
This is not necessary / useful when not building with CONFIG_SANDBOX and with the addition of ubifs support to the generic fs commands it actually gets in the way, since both operate on a fake / NULL blkdev. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2015-10-24Allow imxtract to extract part of script image.Pierre Aubert
Scripts are multi-file images, the imxtract command should handle them in the same manner. Signed-off-by: Pierre Aubert <p.aubert@staubli.com>
2015-10-24Fix bad return value checks (detected with Coccinelle)Thomas Huth
In the "Getting Started with Coccinelle - KVM edition" presentation that has been held by Julia Lawall at the KVM forum 2015 (see the slides at http://events.linuxfoundation.org/sites/events/files/slides/tutorial_kvm_0.pdf), she pointed out some bad return value checks in U-Boot that can be detected with Coccinelle by using the following config file: @@ identifier x,y; identifier f; statement S; @@ x = f(...); ( if (x < 0) S | if ( - y + x < 0) S ) This patch now fixes these issues. Signed-off-by: Thomas Huth <huth@tuxfamily.org>
2015-10-24ARM: rpi: Add CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG supportGuillaume GARDET
Add CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG support and enable it to set 'board_rev' and 'board_name' envs. 'board_rev' can be used in scripts to determine what board we are running on and 'board_name' for pretty printing. Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Cc: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Stephen Warren <swarren@wwwdotorg.org>
2015-10-24allow LED initialization without STATUS_LED_BOOTBernhard Nortmann
For current U-Boot to initialize status LEDs via status_led_init(), it is required to have both CONFIG_STATUS_LED and STATUS_LED_BOOT defined. This may be a particular concern with GPIO LEDs, where __led_init() is required to correctly set up the GPIO (gpio_request and gpio_direction_output). Without STATUS_LED_BOOT the initialization isn't called, which could leave the user with a non-functional "led" command - due to the fact that the LED routines in gpio_led.c use gpio_set_value() just fine, but the GPIO never got set up properly in the first place. I think having CONFIG_STATUS_LED is sufficient to justify a corresponding call to status_led_init(), even with no STATUS_LED_BOOT defined. To do so, common/board_r.c needs call that routine, so it now is exposed via status_led.h. Signed-off-by: Bernhard Nortmann <bernhard.nortmann@web.de> [trini: Add dummy __led_init to pca9551_led.c] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-23add generic stubs for GPIO LEDsBernhard Nortmann
For boards that support LEDs driven via GPIO (CONFIG_GPIO_LED), it may be useful to have some generic stubs (wrapper functions) for the "colored" LEDs. This allows defining STATUS_LED_* values directly to GPIO numbers, e.g.: #define STATUS_LED_GREEN 248 /* = PH24 */ To keep those optional, it's probably best to introduce an additional configuration setting. I've chosen CONFIG_GPIO_LED_STUBS for that. Placing the code in drivers/misc/gpio_led.c also ensures that it automatically depends on CONFIG_GPIO_LED too. Signed-off-by: Bernhard Nortmann <bernhard.nortmann@web.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-10-23dm: keystone: serial: Add driver model supportLokesh Vutla
Add driver model support for keystone serial driver. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-23net: convert altera_tse to driver model and phylibThomas Chou
Convert altera_tse to driver model and phylib. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Marek Vasut <marex@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-10-23nios2: fix virt_to_phys for nios2 with MMUThomas Chou
As the virtual address and physical address mapping of nios2 with MMU are different. Add a check of MMU, and fix the mapping. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Ley Foon Tan <lftan@altera.com>
2015-10-23nios2: add README.nios2Thomas Chou
Add README.nios2 about how to add nios2 boards to u-boot. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Marek Vasut <marex@denx.de>
2015-10-23nios2: zap nios2-generic board dirThomas Chou
As we use device tree to control u-boot now, the generic board can be removed. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2015-10-23nios2: convert dma_alloc_coherent to use malloc_cache_alignedThomas Chou
Convert dma_alloc_coherent to use memalign. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Marek Vasut <marex@denx.de>
2015-10-23nios2: convert copy_exception_trampoline to use dm cpu dataThomas Chou
Convert copy_exception_trampoline() to use dm cpu data. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2015-10-23nios2: convert cache flush to use dm cpu dataThomas Chou
Convert cache flush to use dm cpu data. The original cache flush functions are written in assembly and use CONFIG_SYS_{I,D}CACHE_SIZE... macros. It is difficult to convert to use cache configuration in dm cpu data which is extracted from device tree. The cacheflush.c of Linux nios2 arch uses cpuinfo structure, which is very close to our dm cpu data. So we copy and modify it to arch/nios2/lib/cache.c to replace the old cache.S. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2015-10-23nios2: set default cache configuration in start.SThomas Chou
Set default icache and dcache configuration for start.S. We want to remove the CONFIG_SYS_{I,D}CACHE_SIZE... configuration macros. As we are just barely starting from reset, there is no luxury of device tree. We will set some maximum cache configuration so that it will work for most configurations. This is used only in this start.S. The speed penalty is only once here. After start up, during board initialization, cpu information will be extracted from device tree. Then cache flush operations will have correct cache configurations. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Marek Vasut <marex@denx.de>
2015-10-23nios2: zap initdramThomas Chou
Zap initdram(), as it is not used. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Marek Vasut <marex@denx.de>
2015-10-23nios2: clean up comments style in start.SThomas Chou
Clean up comments style in start.S. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2015-10-23nios2: convert ioremap to use dm cpu dataThomas Chou
Convert ioremap() to use io_region_base in dm cpu global data. Also remove three unused io functions, which have style issue and are replaced by macros already. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2015-10-23nios2: convert do_reset to use dm cpu dataThomas Chou
Convert do_reset to use dm cpu data. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-10-23nios2: remove asm/psr.hThomas Chou
Remove asm/psr.h, which is not used. Also clean up asm/sections.h and unaligned.h. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Marek Vasut <marex@denx.de>
2015-10-23nios2: convert altera sysid to driver modelThomas Chou
Convert altera sysid to driver model with misc uclass. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Chin Liang See <clsee@altera.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-10-23dm: implement a Miscellaneous uclassThomas Chou
Implement a Miscellaneous uclass with generic read or write operations. This class is used only for those do not fit other more general classes. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-23serial: remove altera serial initializationsThomas Chou
Both altera_jtag_serial_initialize() and altera_serial_initialize() are no longer used after they are converted to driver model. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de>
2015-10-23nios2: convert altera timer to driver modelThomas Chou
Convert altera timer to driver model. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Chin Liang See <clsee@altera.com>
2015-10-23timer: start a new timer after relocationThomas Chou
Start a new timer after relocation, just in case the timer has been used in per-relocation. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-23dm: implement a Timer uclassThomas Chou
Implement a Timer uclass to work with lib/time.c. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-23nios2: convert nios2 cpu to driver modelThomas Chou
Convert nios2 cpu to driver model. The cpu parameters are extracted from device tree and saved to global data structure. We will use them to replace the custom_fpga.h . Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-10-23nios2 : convert altera_pio to driver modelThomas Chou
Convert altera_pio to driver model. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Chin Liang See <clsee@altera.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-10-23nios2: add clear and set bits macrosThomas Chou
These macros can be used to clear and set multiple bits in a register using a single call. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Marek Vasut <marex@denx.de> Acked-by: Chin Liang See <clsee@altera.com>
2015-10-23spi : convert altera_spi to driver modelThomas Chou
Convert altera_spi to driver model Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-10-23nios2: convert altera_uart to driver modelThomas Chou
Convert altera_uart to driver model. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de>
2015-10-23nios2: convert altera_jtag_uart to driver modelThomas Chou
Convert altera_jtag_uart to driver model. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-10-23nios2: map physical address to uncached virtual addressThomas Chou
Add ioremap() to map physical address to uncached virtual address. We need this to convert the reg address from the device tree. The order of headers inclusion in interrupts.c is changed because common.h will include board header that contains IO_REGION_BASE. In the future, the IO_REGION_BASE should be decided from the device tree. tree Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-10-23nios2: enable malloc() pool before relocationThomas Chou
Enable malloc() pool before relocation, because this is needed to use serial uclass. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Marek Vasut <marex@denx.de>
