2019-07-09colibri/apalis tegra: drop DFU supportIgor Opaniuk
We never really added a sensible DFU configuration for platforms based on eMMC. Most of the things one might want to do can also be done with UMS or fastboot, so drop the DFU configuration. Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-07-09colibri_vf: enable DM_VIDEOIgor Opaniuk
Enable DM_VIDEO for Colibri VF. Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-07-09ARM: dts: colibri_vf: Add dcu0 nodeIgor Opaniuk
Add dumb node for NXP Display Control Unit0(DCU), which permits DM_ENABLED converted driver to be probed. Currently no display timings are provided in this node. Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-07-09video: fsl_dcu_fb: add DM_VIDEO supportIgor Opaniuk
Extend the driver to build with DM_VIDEO enabled. DTS files must additionally include 'u-boot,dm-pre-reloc' property in soc and child nodes to enable driver binding to fsl_dcu_fb device. Currently display timings aren't obtained from DT. Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-07-09video: fsl_dcu_fb: refactor init functionsIgor Opaniuk
Move dcu-related code to fsl_dcu_probe_common, keep in video_hw_init() only legacy video stack (filling GraphicPanel struct etc.). Add wrappers for all init functions, that will let to provide struct fb_info as an additional param (needed for further moving it from the global scope to driver private data struct in DM converted driver). Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-07-09imx8: cpu: fix warning for cpu_imx_get_tempIgor Opaniuk
cpu_imx_get_temp() definition is wrapped with a ifdef macro, which leads to warnings if CONFIG_IMX_SCU_THERMAL isn't defined and there are still references to this function, as, for example, in cpu_imx_get_desc(). Drop ifdef as linker will automatically remove the function in case CONFIG_IMX_SCU_THERMAL is not enabled. Fix warning: arch/arm/mach-imx/imx8/cpu.c: In function ‘cpu_imx_get_desc’: arch/arm/mach-imx/imx8/cpu.c:612:40: warning: implicit declaration of function ‘cpu_imx_get_temp’; did you mean ‘cpu_imx_get_desc’? [-Wimplicit-function-declaration] ret = snprintf(buf, size, " at %dC", cpu_imx_get_temp()); ^~~~~~~~~~~~~~~~ cpu_imx_get_desc cpu_imx_get_desc Fixes: 82467cb217 ("imx8: cpu: get temperature when print cpu desc") Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-07-09apalis-imx8: enable hdp firmware loadingMarcel Ziswiler
2019-07-09MLK-17205-3 video: imx: hdp: Adding configs for HDP firmware loadingOliver Brown
Added default environment for hdp loading. Added hdp loading as default for iMX8QM MEK board. Signed-off-by: Oliver Brown <oliver.brown@nxp.com> (cherry picked from downstream commit 432e5b4347841095c3b5a8a0d106f35deadd006e) (cherry picked from downstream commit cb78a32fa8eb8c37932be003ebe4fa1f8c46c1d5)
2019-07-09MLK-17205-2 video: imx: hdp: Adding HDP firmware loading to the buildOliver Brown
Adding the HDP firmware loading to the build. Signed-off-by: Oliver Brown <oliver.brown@nxp.com> (cherry picked from downstream commit d4702582552aa1921fce58329ae40c24481fba3a)
2019-07-09MLK-17205-1 video: imx: hdp: Adding support for HDP firmware loadingOliver Brown
This adds a command to load the HDP firmware and supporting libraries. Signed-off-by: Oliver Brown <oliver.brown@nxp.com> (cherry picked from downstream commit 94c9c7022c5b6cffb74bb2e34336cffc2790d0d8) (cherry picked from downstream commit 21edff320e763585ebc6ab2d997c994561b69292)
2019-07-09apalis-imx8: enable of_system_setupMarcel Ziswiler
2019-07-09MLK-16560-1: imx8: Configure sids based on iommu properties in dtbYe Li
Use streamids specified in dtb because they need to match anyway. This removes the need to rebuild uboot for stream id assignments. Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com> Reviewed-by: Ye Li <ye.li@nxp.com> Acked-by: Peng Fan <peng.fan@nxp.com> (cherry picked from downstream commit 3caa05e6dc973b8710642f27f834bf022fbb65b4)
2019-07-09MLK-16087 imx8qm/qxp: Disable kernel FDT nodes for the resources are not ownedYe Li
Before starting the kernel, need to check if the enabled nodes (resources) in FDT are owned by current partition. If it is not owned, need to disable it because A core can't access it. We use the node's power-domain property to get the PD node which has the SCFW resource id in its reg property. Then we can check it with SCFW. Signed-off-by: Ye Li <ye.li@nxp.com> (cherry picked from downstream commit 358372674b29685788a4007b0944ab03b7fafc13)
2019-07-09apalis-imx8: enable smmu setupMarcel Ziswiler
2019-07-09MLK-14938-8 imx8: Add SMMU setup to Soc codesYe Li
We setup SMMU in arch_preboot_os to avoid breaking u-boot driver. Add a kconfig entry CONFIG_IMX_SMMU to enable it. So far, the USDHC0-USDHC1 and FEC0-FEC1 are added into sid. Signed-off-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Ye Li <ye.li@nxp.com> (cherry picked from downstream commit 7da6345919ee59a26cf65b4bc29072eea2fc0909) (cherry picked from downstream commit 45308e7da90f342c2de7fbec1f8c5b8bd3f1b8e5)
2019-07-09misc: imx8: add sc_rm_set_master_sidMarcel Ziswiler
Add sc_rm_set_master_sid to support setting stream IDs. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2019-07-09imx: imx8dx/qxp: enable thermalPeng Fan
Add thermal dts node Enable thermal in defconfig Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-07-09thermal: add i.MX8 thermal driverPeng Fan
Add i.MX8 thermal driver to support get temperature from SCU. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-07-09misc: imx8: add sc_misc_get_tempPeng Fan
Add sc_misc_get_temp to support get temperature Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-07-08Prepare v2019.07v2019.07Tom Rini
2019-07-08Merge tag 'mips-fixes-for-2019.07' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-mips - mtmips: network stability fixes for gardena-smart-gateway
2019-07-07arm: mediatek: remove arch_misc_initWeijie Gao
The watchdog of mediatek chips is enabled by bootrom before u-boot is running. Previously we choose to enable the wdt driver only to disable the watchdog hardware. Now wdt service is enabled by default. The function arch_misc_init which is only used to disable wdt is no longer needed. Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Ryder Lee <ryder.lee@mediatek.com> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2019-07-07board_r: move initr_watchdog to be called after initr_serialWeijie Gao
The initr_watchdog is currently placed before initr_serial. The initr_watchdog calls printf and printf finally calls ops->putc of a serial driver. However, gd->cur_serial_dev points to a udevice allocated in board_f. The gd->cur_serial_dev->driver->ops->putc points the the code region before relocation. Some serial drivers call WATCHDOG_RESET() in ops->putc. When DM is enabled for watchdog, watchdog_reset() is called. watchdog_reset() calls get_timer to get current timer. On some platforms the timer driver is also a DM driver. initr_watchdog is placed right after initr_dm, which means the timer driver hasn't been initialized. So dm_timer_init() is called. To create a new udevice, calloc is called. However start from ops->putc, u-boot execution flow is redirected into the memory region before relocation (board_f). In board_f, dlmalloc hasn't been initialized. The call to calloc will fail, and this will cause DM to print out an error message, and it will call printf again, causing recursive error outputs. This patch places initr_watchdog after initr_serial to solve this issue. Cc: Stefan Roese <sr@denx.de> Reviewed-by: Ryder Lee <ryder.lee@mediatek.com> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Frank Wunderlich <frank-w@public-files.de> Tested-by: Suniel Mahesh <sunil.m@techveda.org>
2019-07-07Merge tag 'dm-pull-7jul19' of https://gitlab.denx.de/u-boot/custodians/u-boot-dmTom Rini
Fix booting for wandboard
2019-07-07Merge tag 'video-for-2019.07' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-video - fix pwm backlight
2019-07-07imx6: wandboard: allow booting from MMC 2Heinrich Schuchardt
One of the SD-CARD slots on the Wandboard Quad B1 is MMC 2. Enable it as a boot device. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2019-07-07Merge https://gitlab.denx.de/u-boot/custodians/u-boot-usbTom Rini
- DWC and i.MX6 fixes
2019-07-07Merge tag 'rockchip-for-v2019.07-rc5-3' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip
2019-07-06video: backlight: fix pwm inversionMarc Dietrich
set_pwm() will always fail with -ENOSYS if pwm_ops set_invert() is not implemented, leaving the backlight dark. Fix this by returning no error if set_invert() is not implemented and no polarity change is requested. Fixes: 57e7775413 ("video: backlight: Parse PWM polarity cell") Signed-off-by: Marc Dietrich <marvin24@gmx.de>
2019-07-05Merge tag 'rpi-next-2019.07' of https://github.com/mbgg/u-bootTom Rini
- fix complation error for CONFIG_USB - update RPi3 DTBs to v5.1-rc6 state - add defconfig for RPi3 B+ - Fix BCM2835_MBOX_TAG_TEST_PIXEL_ORDER define
2019-07-05mips: mt76xx: Implement new d-cache fix in last_stage_init()Stefan Roese
With commit 06985289d452 ("watchdog: Implement generic watchdog_reset() version") the init sequence has changed in arch_misc_init(), resulting in a re-appearance of the d-cache issue on MT7688 boards (e.g. gardena). When this happens, the first (or sometimes later ones as well) TFTP command hangs and does not complete correctly. This leads to the assumption that the d-cache is not in a clean state once the ethernet driver is called (d-cache is used here for the buffers). The old work- around with the cache flush somehow does not work any more now with the new code change. Unfortunately adding CONFIG_SYS_MALLOC_CLEAR_ON_INIT also did not fix this issue. With v2019.07-rc3 it shows again. The time of accessing the data seems to be very important here. It needs to be "very late" in the boot process. Testing has shown, that copying a 64KiB area in DDR at a very late bootup time, directly before calling into the prompt, fixes this issue. Flushing of the complete d-cache does not seem to necessary, as this copy alone seems to fix this problem. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2019-07-05usb: dwc3: Use UCLASS_NOP instead of UCLASS_MISC for the DWC3 generic glueJean-Jacques Hiblot
dwc3-generic has been broken since MISC uclass has been modified to scan DT sub-nodes after bind. Fixing it by a using the no-op uclass. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-07-05dm: Add a No-op uclassJean-Jacques Hiblot
This uclass is intended for devices that do not need any features from the uclass, including binding children. This will typically be used by devices that are used to bind child devices but do not use dm_scan_fdt_dev() to do it. That is for example the case of several USB wrappers that have 2 child devices (1 for device and 1 for host) but bind only one at a any given time. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-07-05usb: dwc3-generic: remove dm_scan_fdt_dev() from the remove() callbackJean-Jacques Hiblot
There is simply no reason to do that here. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2019-07-05usb: ehci-mx6: Fix bus enumeration for DM caseMarek Vasut
The EHCI iMX6 driver is only partly converted to DT probing and still uses a tremendous amount of hard-coded addresses. Worse, the driver uses hard-coded SoC-model-specific base addresses, which are derived from values protected by SoC-specific macros, hence the driver is also compiled for a specific SoC model. Even worse, the driver depends on specific sequential indexing of the controllers, from which it derives offsets in the PHY and ANATOP register sets. However, when the driver is probed from DT, the indexing is not correct. In fact, each controller has index 0. This patch derives the index for DT probing case from the controller base addresses, which is not the way this should be done, however it is the least intrusive approach, favorable this close to release. The necessary steps to convert this driver fully to DT probing are described inside the patch, however this should be done in the next release and depends on iMX clock driver patches. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Abel Vesa <abel.vesa@nxp.com> Cc: Adam Ford <aford173@gmail.com> Cc: Fabio Estevam <festevam@gmail.com> Cc: Ludwig Zenz <lzenz@dh-electronics.com> Cc: Lukasz Majewski <lukma@denx.de> Cc: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Vagrant Cascadian <vagrant@debian.org>
2019-07-05rockchip: make_fit_atf.py: fix loadables property set errorAndy Yan
Commit b238e4b00ced ("rockchip: Cleanup of make_fit_atf.py.") set firmware = "atf_1"; loadables = "uboot","atf_1","atf_2"; Actually it should be: firmware = "atf_1"; loadables = "uboot","atf_2","atf_3"; Signed-off-by: Andy Yan <andy.yan@rock-chips.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-07-04board: amlogic: add mailing-list to MAINTAINERSNeil Armstrong
Add missing mailing-list to the amlogic boards MAINTAINERS file. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-07-04Merge tag 'u-boot-imx-20190704' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-imx Fixes for 2019.07 ----------------- - Wandboard
2019-07-04wandboard: README: Adjust the U-Boot proper binary nameFabio Estevam
After the conversion to DM the U-Boot proper binary name is 'u-boot-dtb.img', so adjust it accordingly. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-07-04wandboard: Add FIT image supportFabio Estevam
After the transition to DM, only the mx6dl/solo wandboard is supported. Add FIT image support so that all the wandboard variants can be supported, like it was prior to the DM conversion. Successfully booted Linux on mx6q/solo/qp wandboards. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-07-04wandboard: Add mmc0 aliasFabio Estevam
Add a mmc0 alias so that U-Boot proper can associate mmc0 with the boot SD card. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-07-04wandboard: Import extra wandboard devicetree filesFabio Estevam
Import wandboard devicetree files so that the mx6q and mx6qp variants can be properly supported. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-07-04wandboard: Sync with devicetree files from kernel 5.1.9Fabio Estevam
Udate the wandboard devicetree files with the ones from kernel 5.1.9. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-07-04mx6: dts: Move dtbs under SoC levelFabio Estevam
Place dtbs under SoC level rather than board level. imx6q-novena.dtb and imx6dl-wandboard-revb1.dtb were placed under the board config option, so move them to SoC level. This also aligns with the kernel dts Makefile format. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-07-04mx6: dts: Keep dtb entries sortedFabio Estevam
Keep dtb entries sorted to help adding new dtbs in an organized form. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-07-02Merge tag 'rockchip-for-v2019.07-rc5-2' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip - fix for atf bl31_image_info pointer - fix for rockpro64 vdd_log init - fix for tinker-rk3288 SPL size too big
2019-07-02rockchip: rk3288: enable TPL for tinker-boardKever Yang
All the config for TPL has been update, we can enable the TPL. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-07-02rockchip: config: tiner-rk3288: extend CONFIG_SYS_MONITOR_LEN to 600KBKever Yang
The raw u-boot.bin for tinker board has been about 450KB without debug option, and 550KB with all debug on, and the default value is 200KB, which is not enough for run raw u-boot.bin. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-07-02rockchip: config: update config for TPL support on tinker-rk3288Kever Yang
We need to update TEXT BASE for TPL/SPL/U-Boot; SPL no need relocate STACK after enable TPL, so remove it; Don't enable pinctrl names so that SPL can get pinctrl dts; Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-07-02rockchip: dts: rk3288-tinker: enable sdmmc pinctrl node in splKever Yang
rockchip pinctrl driver has update to use dts, so we need to add the pinctrl config in SPL for sdmmc. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
