2018-08-17dts: Fix typo in OF_LIVE Kconfig helpMichal Simek
Fix typo in Kconfig description. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-08-17kconfig: fix typo 'parition'Simon Goldschmidt
Replaced misspelled words "parition"/"paritioning" (missing 't') in two Kconfig files by correct words "partition"/"partitioning" Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-08-17Merge branch 'master' of git://git.denx.de/u-boot-shTom Rini
2018-08-17Merge branch 'master' of git://git.denx.de/u-boot-socfpgaTom Rini
2018-08-16Kconfig: Migrate CONFIG_NR_DRAM_BANKSRamon Fried
Move CONFIG_NR_DRAM_BANKS from headers to Kconfig. Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
2018-08-16fdt_support: Use CONFIG_NR_DRAM_BANKS if necessaryRamon Fried
If CONFIG_NR_DRAM_BANKS is bigger than the default value (4) define MEMORY_BANKS_MAX as CONFIG_NR_DRAM_BANKS. Fixes: 2a1f4f1758b5 ("Revert "fdt_support: Use CONFIG_NR_DRAM_BANKS if defined"") Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
2018-08-16CONFIG_SYS_GENERIC_BOARD: Finish migrationTom Rini
While we have long since migrated to CONFIG_SYS_GENERIC_BOARD being enabled, we had just a few places left that still referenced or defined it. Update. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-08-15arm: socfpga: Fix SYSMGR_FPGAINTF_EMACx bit maskLey Foon Tan
Bitmask for EMAC should be bit-0, EMAC1 bit-8 and EMAC2 bit-16. Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2018-08-14ARM: rmobile: Enable USB PHY on Gen2Marek Vasut
Enable support for USB PHY on the R-Car Gen2. This allows for both of the USB host ports to be used on such boards. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-08-14phy: rcar: Add R-Car Gen2 PHY driverMarek Vasut
Add a PHY driver for the R-Car Gen2 which allows configuring the mux connected to the EHCI controllers and USBHS controller. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-08-14phy: Fix off-by-one error when parsing DT PHY bindingsMarek Vasut
The code fails to copy the last PHY phandle argument, so it is missing from the adjusted phandle args and the consumer cannot use it to determine what the PHY should do. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Patrice Chotard <patrice.chotard@st.com>
2018-08-13Prepare v2018.09-rc2Tom Rini
2018-08-13configs: Resync with savedefconfigTom Rini
2018-08-13ARM: socfpga: clk: Convert to clock frameworkMarek Vasut
Use clock framework functions to fetch clock information now that there is a clock driver for Arria10, instead of custom coded register parsing. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Ley Foon Tan <ley.foon.tan@intel.com>
2018-08-13mmc: socfpga: Add clock framework supportMarek Vasut
Add support for fetching the clock frequency both using the legacy method in case clock framework is disabled as well as via the clock framework if it is enabled. This allows for migration to the clock framework on platforms which supports it while not breaking legacy platforms. That said, the legacy method must be removed eventually. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Ley Foon Tan <ley.foon.tan@intel.com>
2018-08-13clk: socfpga: Add initial Arria10 clock driverMarek Vasut
Add clock driver for the Arria10, which allows reading the clock frequency from all the clock described in the DT. The driver also allows enabling and disabling the clock. Reconfiguring frequency is not supported thus far. Since the DT bindings for the SoCFPGA clock are massively misdesigned and the handoff DT adds additional incorrectly described entries to the DT, the driver contains workarounds which attempt to rectify all of those problems. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Ley Foon Tan <ley.foon.tan@intel.com>
2018-08-13ARM: dts: socfpga: Add u-boot,dm-pre-reloc to necessary clock nodesMarek Vasut
Add the pre-reloc DT markers to clock nodes needed in SPL and early U-Boot stages. This is required to let the Arria10 clock driver start early and provide clock information for UART and SDMMC. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Ley Foon Tan <ley.foon.tan@intel.com>
2018-08-13ARM: socfpga: clk: Drop unused variables on Arria10Marek Vasut
The variables removed in this patch are never used, they are only ever assigned and then waste precious memory. Drop both the assignment and the variables. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Ley Foon Tan <ley.foon.tan@intel.com>
2018-08-13ARM: socfpga: clk: Make L4SP and MMC clock calculation Gen5 onlyMarek Vasut
The L4SP and MMC clock precalculation is specific to Gen5, it is not needed on Arria10/Stratix10. Isolate it to Gen5 until there is a proper clock driver for Gen5, at which point this will go away completely. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Ley Foon Tan <ley.foon.tan@intel.com>
2018-08-13ARM: socfpga: clk: Obtain handoff base clock via DMMarek Vasut
Bind fixed clock driver to the base clock instantiated in the handoff DT and use DM clock framework to get their clock rate. This replaces the ad-hoc DT parsing present thus far. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Ley Foon Tan <ley.foon.tan@intel.com>
2018-08-13ARM: socfpga: Enable DM ethernet on A10Marek Vasut
Enable DM ethernet framework on Arria10, so that the designware GMAC can be probed from DT as it should be. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Ley Foon Tan <ley.foon.tan@intel.com>
2018-08-13ARM: socfpga: Remove adhoc ethernet reset and configurationMarek Vasut
Remove ad-hoc ethernet syscon registers configuration and reset support. Reset is now handled by the reset framework and the syscon registers are set in the dwmac_socfpga.c driver. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Ley Foon Tan <ley.foon.tan@intel.com>
2018-08-13ARM: socfpga: Zap unused reset codeMarek Vasut
Remove code from the reset manager that is never called. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Ley Foon Tan <ley.foon.tan@intel.com>
2018-08-13net: designware: socfpga: Add Arria10 extrasMarek Vasut
Add wrapper around the designware MAC driver to handle the SoCFPGA specific configuration bits. On Arria10, this is configuration of syscon phy_intf. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Ley Foon Tan <ley.foon.tan@intel.com> Cc: Joe Hershberger <joe.hershberger@ni.com>
2018-08-13ARM: socfpga: Zap all the UART handling complexityMarek Vasut
The UART reset handling is now done via reset framework using the SoCFPGA reset driver. The UART console assignment is done using the DM and console framework. Nuke all this comlexity, since it is just duplicating the same functionality, badly. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org>
2018-08-13ARM: socfpga: Enable DM I2C framework on A10Marek Vasut
Enable the DM I2C framework on Arria10, so that the DM capable Designware I2C driver can handle the reset via DM reset framework. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Ley Foon Tan <ley.foon.tan@intel.com>
2018-08-13ARM: socfpga: Enable DM reset framework on A10Marek Vasut
Enable the DM reset framework and DM reset driver on Arria10 both in U-Boot and in SPL. This lets U-Boot parse reset control from DT. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Ley Foon Tan <ley.foon.tan@intel.com>
2018-08-13ARM: dts: socfpga: Add i2c alias to A10 SoCDKMarek Vasut
The A10 SoCDK is missing the I2C bus alias, so DM I2C cannot assign the I2C bus a bus number. Add the missing alias. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Ley Foon Tan <ley.foon.tan@intel.com>
2018-08-13ARM: dts: socfpga: Add missing I2C resetsMarek Vasut
The I2Cx resets are missing from DT, so the reset manager cannot control them. Add the missing DT reset entries. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Ley Foon Tan <ley.foon.tan@intel.com>
2018-08-13ARM: dts: socfpga: Fix Arria10 GMAC resetsMarek Vasut
Add the GMAC0,1 OCP resets, which must also be ungated for those GMACs to work and add GMAC2 reset and OCP resets which were missing altogether. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Ley Foon Tan <ley.foon.tan@intel.com>
2018-08-13ARM: dts: socfpga: Add missing UART resetsMarek Vasut
The UART0 and UART1 resets are missing from DT, so the reset manager cannot control them. Add the missing DT reset entries. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Ley Foon Tan <ley.foon.tan@intel.com>
2018-08-13ARM: dts: socfpga: Flag reset manager on A10 as pre-relocMarek Vasut
The Altera reset manager block must be available very early on, since it controls ie. UART resets. Flag it as pre-reloc. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Ley Foon Tan <ley.foon.tan@intel.com>
2018-08-13ARM: socfpga: Register the FPGA on A10 in SPL againMarek Vasut
The restructuring of the SPL dropped registration of the FPGA in SPL, readd it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Ley Foon Tan <ley.foon.tan@intel.com> Fixes: c859f2a77d98 ("arm: socfpga: Restructure the SPL file")
2018-08-13arm: socfpga: gen5: combine some init code for SPL and U-BootSimon Goldschmidt
Some of the code for low level system initialization in SPL's board_init_f() and U-Boot's arch_early_init_r() is the same, so let's combine it into a single function called from both. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2018-08-13arm: socfpga: fix device trees to work with DM serialSimon Goldschmidt
Device trees need to have the serial console device available before relocation and require a stdout-path in chosen at least for SPL to have a console. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2018-08-13MAINTAINERS: Update STM32MP fragmentsPatrice Chotard
Add new drivers Add Christophe Kerello and myself as maintainers Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-08-13ARM: dts: stm32f4: Fix DT dtc warningsPatrick Delaunay
This patch fix the following warnings for for stm32f429 evaluation and discovery boards: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-08-13ARM: dts: stm32mp157: Add ADC DT nodePatrice Chotard
Add ADC device tree node. This allows to get analog conversions on stm32mp157. Signed-off-by: Fabrice Gasnier <fabrice.gasnier@st.com> Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-08-13ARM: dts: stm32: remove cd-inverted for stm32f746-discoPatrice Chotard
As cd-inverted property is no more used by arm_pl180_mmci driver, remove it. Update cd-gpios active level accordingly. Reported-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-08-13ARM: dts: stm32: remove cd-inverted for stm32f769-discoPatrice Chotard
2018-08-13ARM: omap3: evm: Enable CONFIG_BLK and misc. cleanupDerald D. Woods
This commit enables CONFIG_BLK and removes USB_STORAGE which is awaiting proper implementation for current U-Boot interfaces. Additionally the console selection is now handled by Kconfig and no longer needs to be in the config header. CONFIG_SYS_MALLOC_F_LEN=0x2000 was added to sync with other boards. CONFIG_SPL_BLK and CONFIG_SPL_DM_MMC are disabled because they currently do not allow the OMAP3-EVM (OMAP34XX) to actually boot. Signed-off-by: Derald D. Woods <woods.technical@gmail.com>
2018-08-13tpm: sandbox: fix wrong assignment with a simplificationMiquel Raynal
The recv variable in sandbox_tpm2_fill_buf() is a pointer on a pointer of a char array. It means accessing *recv is the char array pointer itself while **recv is the first character of that array. There is no need for such indirection here, so simplify the code. Simplifying things will make the last assignment right: "*recv = NULL" is now correct. The issue has been found by the following Coverity Scan report: CID 183371: Incorrect expression (UNUSED_VALUE) Assigning value "4UL" to "*recv" here, but that stored value is overwritten before it can be used. 232 *recv += sizeof(rc); 233 234 /* Add trailing \0 */ 235 *recv = NULL; While at simplifying things, use '\0' instead of NULL when adding an empty char at the end of the buffer. Reported-by: Tom Rini <trini@konsulko.com> Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-08-13tpm: sandbox: fix wrong check on pcr_mapMiquel Raynal
The second check on pcr_map in sandbox_tpm2_xfer() is wrong. It should check for pcr_map not being empty. Instead, it is a pure copy/paste of the first check which is redundant. This has been found thanks to a Coverity Scan report: CID 183370: Memory - illegal accesses (UNINIT) Using uninitialized value "pcr_index". put_unaligned_be32(tpm->pcr_extensions[pcr_index], recv); This is because pcr_index is initialized only if the user input is correct, ie. at least one valid bit is set in pcr_map. Fix the second check and also initialize pcr_index to 0 (which is harmless in case of error) to make Coverity Scan happy. Reported-by: Tom Rini <trini@konsulko.com> Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-08-13MAINTAINERS: Add more sources to Arch SnapdragonRamon Fried
Add scattered driver files around the source tree that belongs to Snapdragon arch. Not sure why they were not included in the first place. Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
2018-08-13db410c: add FIT supportRamon Fried
1. Add FIT support for DB410c defconfig. 2. Don't overwrite bootargs (they're already defined in Linux device tree for DB410c. Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
2018-08-13db410: alter WLAN/BT MAC address fixupRamon Fried
Change the way MAC address fixup is done: 1. Stop using LK handed device-tree and calculate the MAC address our own. 2. Allow overriding the generated MACS with environment variables: "wlanaddr" and "btaddr". Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
2018-08-13snapdragon: added MAC generation functionsRamon Fried
Add support for generation of unique MAC address that is derived from board serial. Algorithm for generation of MAC taken from LK. Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
2018-08-13snapdragon: added msm_board_serial() funcRamon Fried
This commit adds a function to get the board serial number. In snapdragon it's actually the eMMC serial number. Function added in a new file misc.c that will include further snapdragon miscellaneous functions. Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
2018-08-13stm32f7: board: Fix memory initPatrice Chotard
Commit 1473b12ad0b3 ("lib: fdtdec: Update ram_base to store ram start adddress") brings regression on STM32F7 which can't boot. Use fdtdec_setup_mem_size_base() to setup memory base and size. Use fdtdec_setup_memory_banksize() to setup memory bank base and size. Reported-by: Mark Olsson <mark@markolsson.se> Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Cc: Mark Olsson <mark@markolsson.se> Reviewed-by: Vikas Manocha <vikas.manocha@st.com>
