Replace CONFIG_P1020 with ARCH_P1020 in Kconfig and clean up
existing macros.
Signed-off-by: York Sun <york.sun@nxp.com>
All boards covered by this group have been converted to their own
targers. Drop TARGET_P1_P2_RDB_PC from Kconfig.
Use TARGET_P2020RDB_PC instead of sharing with P1_P2_RDB_PC to
simplify Kconfig and config macros.
Remove macro CONFIG_P2020RDB.
Use TARGET_P1025RDB instead of sharing with P1_P2_RDB_PC to
Remove macro CONFIG_P1025RDB.
Use TARGET_P1024RDB instead of sharing with TARGET_P1_P2_RDB_PC to
simplify Kconfig and macros.
Remove macro CONFIG_P1024RDB.
Use TARGET_P1021RDB instead of sharing with TARGET_P1_P2_RDB_PC to
Remove macro CONFIG_P1021RDB.
Use TARGET_P1020UTM instead of sharing with TARGET_P1_P2_RDB_PC
to simplify Kconfig and config macros.
Remove macro CONFIG_P1020UTM.
Use TARGET_P1020RDB_PD instead of sharing with P1_P2_RDB_PC
Remove macro CONFIG_P1020RDB_PD.
Use TARGET_P1020RDB_PC instead of sharing with TARGET_P1_P2_RDB_PC
Remove macro CONFIG_P1020RDB_PC.
Use TARGET_P1020MBG instead of sharing with TARGET_P1_P2_RDB_PC to
simplify Kconfig and other macros.
Remove macro CONFIG_P1020MBG.
P1017 is a single-core version of P1023. There is no P1017 target
configured. Drop related macros. P1017 SoC is still supported.
P1014 is a variant of P1010. There is no P1014 target configured.
Drop related macros. P1014 SoC is still supported.
P1013 is a single-core version of P1022. There is no P1022 target
configured. Drop related macros. P1022 SoC is still supported.
P1012 is a single-core version of P1021. There is no P1012 target
configured. Drop related macros. P1012 SoC is still supported.
Replace CONFIG_P1011 with ARCH_P1011 in Kconfig. P1011RDB seems to be in
scrapyard though.
Replace CONFIG_P1023 with ARCH_P1023 in Kconfig and clean up existing
macros.
Use CONFIG_TARGET_P1022DS instead.
Replace CONFIG_P1022 with ARCH_P1022 in Kconfig and clean up existing
macros.
Remove CONFIG_P1010RDB_PA and CONFIG_P1010RDB_PB and split TARGET_P1010RDB
to TARGET_P1010RDB_PA and TARGET_P1010RDB_PB in Kconfig.
Replace CONFIG_P1010 with ARCH_P1010 in Kconfig and clean up existing
macros.
This macro is no longer used.
Use CONFIG_TARGET_MPC8572DS instead.
Replace CONFIG_MPC8572 with ARCH_MPC8572 in Kconfig and clean up existing
macros.
Use CONFIG_TARGET_MPC8569MDS instead.
Replace CONFIG_MPC8569 with ARCH_MPC8569 in Kconfig and clean up existing
macros.
Replace CONFIG_MPC8568 with ARCH_MPC8568 in Kconfig and clean up existing
macros.
Replace CONFIG_MPC8560 with ARCH_MPC8560 in Kconfig and clean up existing
macros.
Use CONFIG_TARGET_MPC8555CDS instead.
Replace CONFIG_MPC8555 with ARCH_MPC8555 in Kconfig and clean up existing
macros.
Replace with CONFIG_TARGET_MPC8541CDS from Kconfig.
Replace CONFIG_MPC8541 with ARCH_MPC8541 in Kconfig and clean up existing
macros.
Replace CONFIG_MPC8540 with ARCH_MPC8540 in Kconfig and clean up existing
macros.
Use CONFIG_TARGET_MPC8536DS instead.
Replace CONFIG_MPC8536 with ARCH_MPC8536 in Kconfig and clean up existing
macros.
Use CONFIG_TARGET_C29XPCIE instead.
Replace CONFIG_PPC_C29X with ARCH_C29X in Kconfig and clean up existing
macros.
Use CONFIG_TARGET_BSC9132QDS from Kconfig option, remove CONFIG_BSC9132QDS
macro.
This macro CONFIG_BSC9131RDB is no longer needed.
Replace CONFIG_BSC9131, CONFIG_BSC9132 with ARCH_BSC9131, ARCH_BSC9132
Kconfig options.
Also drop #ifdef in BSC9131RDB.h since it is redundant.
Use CONFIG_TARGET_MPC8544DS instead.
Replace CONFIG_MPC8544 with ARCH_MPC8544 in Kconfig.
Use CONFIG_TARGET_MPC8548CDS instead.
Replace CONFIG_MPC8548 with ARCH_MPC8548 in Kconfig.
While we move some config macros to Kconfig, kconfig header is needed
to avoid compiling error if not already included.
This option isn't used for anything, so get rid of it.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
[trini: Fix sniper and kc1 migration]
