2011-07-17Remove volatile qualifier in get_ram_size() callsAlbert ARIBAUD
Checkpatch.pl complains about the volatile qualifier in calls to get_ram_size(). Remove this qualifier in the prototype and in the calls where it is useless, and leave it only in the function body where it is needed. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-07-17TI: TNETV107X Fix Build ErrorChan-Taek Park
This patch provides SDRAM base address and initial stack address to fix build errors. Signed-off-by: Chan-Taek Park <c-park@ti.com>
2011-07-17ARM: add missing CONFIG_SKIP_LOWLEVEL_INIT for armv7Rob Herring
cpu_init_crit can be skipped, but the code is still enabled requiring a platform to supply lowlevel_init. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Albert ARIBAUD <albert.aribaud@free.fr>
2011-07-17arm: add CONFIG_MACH_TYPE setting and documentationIgor Grinberg
CONFIG_MACH_TYPE is used to set the machine type number in the common arm code instead of setting it in the board code. Boards with dynamically discoverable machine types can still set the machine type number in the board code. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2011-07-16arm: add __ilog2 functionRob Herring
Add __ilog2 function for ARM. Needed for ahci.c Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Albert ARIBAUD <albert.aribaud@free.fr>
2011-07-16Timer: Fix misuse of ARM *timer_masked() functions outside arch/armGraeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2011-07-14EfikaMX: Enable EXT2 bootingMarek Vasut
2011-07-14EfikaMX: Add missing CONFIG_SYS_TEXT_BASEJana Rapava
Signed-off-by: Jana Rapava <fermata7@gmail.com>
2011-07-14EfikaMX: Use correct imximage.cfgJana Rapava
2011-07-14MX27: Update to autogenerated asm-offsets.hStefano Babic
On i.MX27, the asm-offsets.h file is not yet generated as it should be. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Matthias Weisser <weisserm@arcor.de>
2011-07-14MX5: Update to autogenerated asm-offsets.hStefano Babic
On i.MX5, the asm-offsets.h file is not yet generated as it should be. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Matthias Weisser <weisserm@arcor.de>
2011-07-14imx: Add support for zmx25 boardMatthias Weisser
zmx25 is a board based on imx25 SoC, 64 Megs of LPDDR, 32 Megs of NOR flash, an optional NAND flash. Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2011-07-14imx: Make imx25 compatible to mxc_gpio driver and fix in tx25Matthias Weisser
Adding support for mxc_gpio driver for imx25 and fix names of registers in tx25 board. Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2011-07-14imx: Add auto generation of asm-offsets.h for imx25Matthias Weisser
Offsets to registers may be needed in asm code. This patch adds automated generation of these offsets form C structures. Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2011-07-14imx: Add support for USB EHCI on imx25Matthias Weisser
Adding support for USB host on imx25 using the internal PHY. Changing the name of base address define for imx31 to get some unification. Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2011-07-14imx: Use correct imx25 reset.cMatthias Weisser
imx25 used the wrong reset.c from imx27 Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2011-07-14imx: Add get_tbclk() function for imx25Matthias Weisser
Need this function for autoboot keyd Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2011-07-14ARM: Update maintainer of board scb9328Torsten Koschorrek
Signed-off-by: Torsten Koschorrek <koschorrek@synertronixx.de>
2011-07-14mx27: Make the UART port number explicitFabio Estevam
mx27_uart_init_pins does the IOMUX setting for UART1 port. Change the function name to make the UART port number explicit. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-07-14build: Add targets for auto gen of asm-offsets.h and use it in imx35Matthias Weisser
asm-offsets.h should be auto generated. This patch adds two rules to rules.mk which makes this possible and removes the rules on imx35. Signed-off-by: Matthias Weisser <weisserm@arcor.de> Acked-by: Stefano Babic <sbabic@denx.de>
2011-07-14mx31pdk: cosmetic: Fix line over 80 charactersFabio Estevam
2011-07-11powerpc/85xx: Add default usb mode and phy type to hwconfigRamneek Mehresh
Move to use hwconfig for usb mode & phy type instead of magic 'usb_phy_type' environment variable on the following platforms: MPC8536DS, P1020RDB, P1020RDB-PC, P1010RDB, P2020RDB, P2020RDB-PC, P2020RDB, P3041DS, P4080DS, & P5020DS. Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/corenet_ds: add back buffer write for NOR flashYork Sun
Enable buffer write for better performance. This platform uses a NOR flash chip which supports write buffer programming. CFI driver can query the buffer size and use it to program the flash for best performance. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/85xx: remove SERDES4 soft-reset work-aroundTimur Tabi
Some P4080 rev1 errata work-arounds, notably erratum SERDES4, required a bank soft-reset after the bank was configured and enabled, even though enabling a bank causes it to reset. Because the reset was required for multiple errata, it was not properly enclosed in an #ifdef, and so was not removed with all the other rev1 errata work-arounds. Erratum SERDES-8 says that the clocks for bank 3 needs to be enabled if bank 2 is enabled, but this was not being done for SERDES protocols 0xF and 0x10. The bank reset also happened to enable bank 3 (apparently an undocumented feature). Simply removing the reset breaks these two protocols. It turns out that every time we call enable_bank(), we do want at least one lane of the bank enabled, either because the bank is supposed to be enabled, or because we need the clock from that bank enabled. For erratum SERDES-A001, we don't want to modify srds_lpd_b[] when we call enable_bank(), because that array is used elsewhere to determine if the bank is available. Note that the side effect of these changes is that the work-arounds for these two errata are now linked. Specifically, if SERDES-A001 is enabled, then we need SERDES-8 enabled as well. Because this was the only SERDES bank soft-reset, there is no need to implement a work-around for erratum SERDES-A003. Also fix an off-by-one error in a printf(). Signed-off-by: Timur Tabi <timur@freescale.com> Acked-by: Ed Swarthout <swarthou@freescale.com> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/mpc8xxx: Allow override DDR read-to-write turnaround timeYork Sun
Add this option to allow boards to override the default read-to-write turnaround time for better performance. Signed-off-by: York Sun <yorksun@freescale.com>
2011-07-11qoriq/p1_p2_rdb: USB device-tree fixups for P1020Ramneek Mehresh
Resolve P1020 second USB controller multiplexing with eLBC - mandatory to mention USB2 in hwconfig string to select it over eLBC, otherwise USB2 node is removed - works only for SPI and SD boot Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/85xx: Specify hwconfig usage for USB controllerRamneek Mehresh
Specify hwconfig usage for USB mode and phy change Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/8xxx: Update USB mode device tree fixupRamneek Mehresh
Modify support for USB mode fixup: - Add common support for USB mode and phy type device tree fix-up for all USB controllers mentioned in hwconfig string - Fetch USB mode and phy type via hwconfig; if not defined in hwconfig, then fetch them from env Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/85xx: Add basic support for P1023RDS boardRoy Zang
The P1023RDS board is the reference board for the P1023 SoC. Add support for booting it from NOR or NAND, with fixed 2G of DDR, PCIe, UART, I2C, etc. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com> Signed-off-by: Lei Xu <B33228@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/mpc85xx: Display a warning for unsupported DDR data ratesYork Sun
If DDR initialziation uses a speed table and the speed is not matched, print a warning message instead of silently ignoring. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/corenet_ds: Fix RCW overriding for RDIMMYork Sun
Allow overriding RCW for all RDIMM, not only quad-rank ones. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/mpc8xxx: fix DDR data width checkingYork Sun
Checking width before setting DDR controller. SPD for DDR1 and DDR2 has data width and primary sdram width. The latter one has different meaning for DDR3. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/mpc8xxx: Adding fallback to raw timing on supported boardsYork Sun
In case of empty SPD or checksum error, fallback to raw timing on supported boards. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/mpc8xxx: Enable calculation for fixed DDR chipsYork Sun
We used to have fixed parameters for soldered DDR chips. This patch introduces CONFIG_SYS_DDR_RAW_TIMING to enable calculation based on timing data from DDR chip datasheet, implemneted in board-specific files or header files. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/85xx: Fix pin muxing for second USB controllerFelix Radensky
On P1022/P1013 second USB controller is muxed with second Ethernet controller. The current code to enable second USB fails to properly clear pinmux bits used by ethernet. As a result, Linux freezes when this controller is used. This patch fixes the problem. Signed-off-by: Felix Radensky <felix@embedded-sol.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11Adding more SPD registersYork Sun
Adding byte 32 and 33 Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/mpc8xxx: Add 16-bit support for DDR3York Sun
Add support for 16-bit DDR bus. Also deal with system using 64- and 32-bit DDR devices. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/mpc8xxx: check SPD length before using part numberYork Sun
Only use DDR DIMM part number if SPD has valid length, to prevent from display garbage in case SPD doesn't cover these fields. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/mpc8xxx: adjust DDR burst length and chop accroding to sdram widthYork Sun
If the bus width is 32-bit, burst chop should be disabled and burst length should be 8. Read from SPD or other source to determine the width. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/86xx: display boot device and bank on the MPC8610 HPCDTimur Tabi
Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/85xx: Add NAND boot support for P3041/P5020DSShaohui Xie
When booting from NAND we get the environment and FMan ucode from NAND. Signed-off-by: Shaohui Xie <b21989@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/85xx: Add P2041 processor supportKumar Gala
The P2041 is similar to P2040, however has a 10G port and backside L2 Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/p2040: Add various p2040 specific informationMingkai Hu
Add P2040 SoC specific information: * LIODN setup * Portal configuration * etc Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/85xx: Fix compile errors if CONFIG_SYS_DPAA_QBMAN isn't setKumar Gala
Add ifdef protection for qp_info and liodn associated with Q/BMan. Also rearrange setting of _tbl_sz variables to utilize existing ifdef protection for things like FMAN. Also add protection around setup_portals() call in corenet_ds board code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11qoriq/p1_p2_rdb: Add Dual Role USB support macro for P1020RDBRamneek Mehresh
Add CONFIG_HAS_FSL_DR_USB macro for P1020RDB Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/85xx: Fix compile errors if CONFIG_SYS_{BR,OR}0_PRELIM aren't setKumar Gala
Add ifdef protection in LBC code to handle the case in which CONFIG_SYS_BR0_PRELIM and CONFIG_SYS_OR0_PRELIM arent defined for a build. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/85xx: Fix compile errors if CONFIG_SYS_{B,Q}MAN_MEM_PHYS aren't setKumar Gala
Add ifdef protection in LAW & TLB code to handle the case in which CONFIG_SYS_BMAN_MEM_PHYS or CONFIG_SYS_QMAN_MEM_PHYS arent defined for a build. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-06MPC83XX: Fix PCI express clock setupBill Cook
On a 8308 based board it was found that the PEX_GLK_RATIO register (programmed in arch/powerpc/cpu/mpc83xx/pcie.c) was getting set to 0, This was tracked to the fact that the pci express clock frequency was not being assigned to the pciexp1_clk entry in the global data structure in file arch/powerpc/cpu/mpc83xx/speed.c. Fix this and a similiar issue in 'do_clocks' command. Signed-off-by: Bill Cook <cook@isgchips.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2011-07-06powerpc/83xx: remove empty board_early_init_f()Timur Tabi
Remove an empty board_early_init_f() from the MPC8323ERD and MPC360ERDK boards. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2011-07-06mpc83xx: Add support for MergerBox boardAndre Schwarz
Includes board config file, documentation, maintainer and boards.cfg entries, and board specific files in vendor dir. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
