2018-04-07configs: Finish migration of CONFIG_ATMEL_SPITom Rini
With the previous temporary reverts, we need to re-complete the migration of CONFIG_ATMEL_SPI here now. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-07Revert "spi: atmel: Drop non-dm code"Tom Rini
As we aren't quite able to convert some platforms with a very small size limit in SPL yet, we need to revert this for now. This reverts commit 7b0947787358c6b277431d6b76ce043d8bec641d. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-07Revert "spi: atmel: Drop atmel_spi.h"Tom Rini
As we aren't quite able to convert some platforms with a very small size limit in SPL yet, we need to revert this for now. This reverts commit 37434db29be495ef41f204a97b8bf13b1418f97d. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-06cmd: Add command for calculating binary operationsMario Six
This patch adds a command that enables the calculation of bit operations (AND, OR, XOR) on binary data from the command line. Memory locations as well as the contents of environment variables are eligible as sources and destination of the binary data used in the operations. The possible applications are manifold: Setting specific bits in registers using the regular read-OR-write pattern, masking out bits in bit values, implementation of simple OTP encryption using the XOR operation, etc. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-04-06cmd: ximg: Respect cache line size for flushingMario Six
Make sure that the cache line size if respected when flushing the cache. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-04-06gpio: uclass: Fix debug stringMario Six
A debug string still has the old name of a function being called; update it. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-06watchdog: Fix Kconfig alignment for WDT_SANDBOXMichal Simek
Fix Kconfig alignment which should be <tab><space><space>. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-06image: fit: Show information about OS type in firwmare case tooMichal Simek
SPL ATF implementation requires FIT image with partitions where the one is Firmware/ATF and another one Firmware/U-Boot. OS field is used for recording that difference that's why make sense to show values there for Firmware types. For example: Image 0 (atf) Description: ATF bl31.bin Created: Mon Mar 26 15:58:14 2018 Type: Firmware Compression: uncompressed Data Size: 51152 Bytes = 49.95 KiB = 0.05 MiB Architecture: ARM OS: ARM Trusted Firmware Load Address: 0xfffe0000 Hash algo: md5 Hash value: 36a4212bbb698126bf5a248f0f4b5336 Image 1 (uboot) Description: u-boot.bin Created: Mon Mar 26 15:58:14 2018 Type: Firmware Compression: uncompressed Data Size: 761216 Bytes = 743.38 KiB = 0.73 MiB Architecture: ARM OS: U-Boot Load Address: 0x08000000 Hash algo: md5 Hash value: f22960fe429be72296dc8dc59a47d566 Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jun Nie <jun.nie@linaro.org>
2018-04-06image: fit: Show firmware configuration property if presentMichal Simek
SPL ATF support requires to have firmware property which should be also listed by mkimage -l when images is created. The patch is also using this macro in spl_fit to match keyword. When image is created: Default Configuration: 'config' Configuration 0 (config) Description: ATF with full u-boot Kernel: unavailable Firmware: atf FDT: dtb Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jun Nie <jun.nie@linaro.org> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-04-06configs: am43xx_evm_qspiboot_defconfig: Move to DMVignesh R
Move am43xx_evm_qspiboot_defconfig to DM. This is required as SPI core and TI QSPI driver no longer supports non DM interfaces. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-04-06ARM: dts: Add new "generic" am4372 device tree file.Vignesh R
With U-boot runtime board detect for DTB selection a "default" dtb needs to be created. This will be used temporarily until the "proper" dtb is selected. Also, add -u-boot.dtsi for AM437x SK and IDK to enable I2C for board detection via DM_I2C. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-04-06board: ti: am43xx: Define embedded_dtb_select for runtime DTB selection in ↵Vignesh R
U-boot AM437x QSPI boot is a single stage boot and hence needs runtime DTB selection to support AM437x-SK and AM437x-IDK with DM enabled. This is required to move am43xx_evm_qspiboot_defconfig to use DM/DT. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-04-06env: Properly check for BLK supportSjoerd Simons
Use CONFIG_IS_ENABLED to see if CONFIG_BLK is enabled. Otherwise SPL compilation breaks on boards which do have CONFIG_BLK enabled but not DM_MMC for the SPL as follows: env/mmc.c: In function ‘init_mmc_for_env’: env/mmc.c:164:6: warning: implicit declaration of function ‘blk_get_from_parent’; did you mean ‘efi_get_ram_base’? [-Wimplicit-function-declaration] if (blk_get_from_parent(mmc->dev, &dev)) ^~~~~~~~~~~~~~~~~~~ efi_get_ram_base env/mmc.c:164:29: error: ‘struct mmc’ has no member named ‘dev’ if (blk_get_from_parent(mmc->dev, &dev)) ^~ Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-06configs: k2hk_hs_evm: Resync defconfig with non-HS defconfigAndrew F. Davis
Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Lokesh vutla <lokeshvutla@ti.com>
2018-04-06configs: k2e_hs_evm: Resync defconfig with non-HS defconfigAndrew F. Davis
2018-04-06configs: k2g_hs_evm: Resync defconfig with non-HS defconfigAndrew F. Davis
2018-04-06rtc: rx8025: remove redundant code in rtc_resetChris Packham
As of commit 1a1fa2406689 ("rtc: Set valid date after reset") the command "date reset" will set the date/time to 2000-01-01 0:00:00 after calling rtc_reset(). This means that the rx8025 implementation of rtc_reset() does not need to call rtc_set(). Signed-off-by: Chris Packham <judge.packham@gmail.com>
2018-04-06rtc: rs5c372: remove redundant code in rtc_resetChris Packham
As of commit 1a1fa2406689 ("rtc: Set valid date after reset") the command "date reset" will set the date/time to 2000-01-01 0:00:00 after calling rtc_reset(). This means that the rs5c372 implementation of rtc_reset() does not need to call rtc_set(). Signed-off-by: Chris Packham <judge.packham@gmail.com>
2018-04-06rtc: mx27rtc: remove redundant code in rtc_resetChris Packham
As of commit 1a1fa2406689 ("rtc: Set valid date after reset") the command "date reset" will set the date/time to 2000-01-01 0:00:00 after calling rtc_reset(). This means that the mx27rtc implementation of rtc_reset() can be an empty stub function. Signed-off-by: Chris Packham <judge.packham@gmail.com>
2018-04-06rtc: ds1374: remove redundant code in rtc_resetChris Packham
As of commit 1a1fa2406689 ("rtc: Set valid date after reset") the command "date reset" will set the date/time to 2000-01-01 0:00:00 after calling rtc_reset(). This means that the ds1374 implementation of rtc_reset() doesn't need to call rtc_set(). Signed-off-by: Chris Packham <judge.packham@gmail.com>
2018-04-06rtc: ds1307: remove redundant code in rtc_resetChris Packham
As of commit 1a1fa2406689 ("rtc: Set valid date after reset") the command "date reset" will set the date/time to 2000-01-01 0:00:00 after calling rtc_reset(). This means that the ds1307 implementation of rtc_reset() doesn't need to call rtc_set(). Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-06bootvx: use program header for loadingChristian Gmeiner
The section header address is a VMA whereas the address found in the program header is a physical one. With this change it is possible to load and start a vx7 intel generic based image. $ readelf -l /tmp/vx7 Elf file type is EXEC (Executable file) Entry point 0x408000 There are 2 program headers, starting at offset 52 Program Headers: Type Offset VirtAddr PhysAddr FileSiz MemSiz Flg Align LOAD 0x001000 0x00408000 0x00408000 0x04000 0x04000 RWE 0x1000 LOAD 0x005000 0xe040c000 0x0040c000 0x583a84 0x5ccc70 RWE 0x1000 Section to Segment mapping: Segment Sections... 00 .text.locore .data.locore 01 .text .eh_frame .wrs_build_vars .data .tls_data .tls_vars .bss $ readelf -S /tmp/vx7 There are 13 section headers, starting at offset 0x588af8: Section Headers: [Nr] Name Type Addr Off Size ES Flg Lk Inf Al [ 0] NULL 00000000 000000 000000 00 0 0 0 [ 1] .text.locore PROGBITS 00408000 001000 00011e 00 AX 0 0 16 [ 2] .data.locore PROGBITS 00409000 002000 003000 00 WA 0 0 4096 [ 3] .text PROGBITS e040c000 005000 4802a0 00 WAX 0 0 32 [ 4] .eh_frame PROGBITS e088c2a0 4852a0 0a1ed0 00 A 0 0 4 [ 5] .wrs_build_vars PROGBITS e092e170 527170 000190 00 Ax 0 0 1 [ 6] .data PROGBITS e092f000 528000 060a70 00 WA 0 0 4096 [ 7] .tls_data PROGBITS e098fa70 588a70 000004 00 A 0 0 4 [ 8] .tls_vars PROGBITS e098fa78 588a78 00000c 00 WA 0 0 4 [ 9] .bss NOBITS e098faa0 588a84 0491d0 00 WA 0 0 32 [10] .shstrtab STRTAB 00000000 588a84 000074 00 0 0 1 [11] .symtab SYMTAB 00000000 588d00 056ee0 10 12 9758 4 [12] .strtab STRTAB 00000000 5dfbe0 05f48a 00 0 0 1 Key to Flags: W (write), A (alloc), X (execute), M (merge), S (strings) I (info), L (link order), G (group), T (TLS), E (exclude), x (unknown) O (extra OS processing required) o (OS specific), p (processor specific) For completeness here are the same information for an old vx5 based image. After this change it is possible to boot vx5 and vx7 (intel generic) images. $ readelf -l /tmp/vx5 Elf file type is EXEC (Executable file) Entry point 0x308000 There are 1 program headers, starting at offset 52 Program Headers: Type Offset VirtAddr PhysAddr FileSiz MemSiz Flg Align LOAD 0x000060 0x00308000 0x00308000 0x3513a0 0x757860 RWE 0x20 Section to Segment mapping: Segment Sections... 00 .text .data .bss [christian@chgm-pc ~]$ readelf -S /tmp/vx5 There are 12 section headers, starting at offset 0x356580: Section Headers: [Nr] Name Type Addr Off Size ES Flg Lk Inf Al [ 0] NULL 00000000 000000 000000 00 0 0 0 [ 1] .text PROGBITS 00308000 000060 319b10 00 WAX 0 0 32 [ 2] .data PROGBITS 00621b20 319b80 037880 00 WA 0 0 32 [ 3] .bss NOBITS 006593a0 351400 4064c0 00 WA 0 0 16 [ 4] .debug_aranges PROGBITS 00000000 351400 000060 00 0 0 1 [ 5] .debug_pubnames PROGBITS 00000000 351460 00018b 00 0 0 1 [ 6] .debug_info PROGBITS 00000000 3515eb 003429 00 0 0 1 [ 7] .debug_abbrev PROGBITS 00000000 354a14 000454 00 0 0 1 [ 8] .debug_line PROGBITS 00000000 354e68 0016a4 00 0 0 1 [ 9] .shstrtab STRTAB 00000000 35650c 000071 00 0 0 1 [10] .symtab SYMTAB 00000000 356760 0440e0 10 11 8574 4 [11] .strtab STRTAB 00000000 39a840 03e66c 00 0 0 1 Key to Flags: W (write), A (alloc), X (execute), M (merge), S (strings) I (info), L (link order), G (group), T (TLS), E (exclude), x (unknown) O (extra OS processing required) o (OS specific), p (processor specific) Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2018-04-06stm32mp: handle SYSRESETPatrick Delaunay
Add support of sysreset with generic driver "syscon-reboot" provided by RCC, for U-boot and for SPL. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-04-06stm32mp: add syscon for STGENPatrick Delaunay
Add STGEN as SYSCON device: allow access to device address defined in device tree Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-04-06stm32mp1: change STGEN clock source to HSEPatrick Delaunay
No more use static frequency HSI = 64MHz for STGEN clock but HSE (with higher accurency) by default. Need to remove CONFIG_SYS_HZ_CLOCK as arch timer frequency is provided at boot by BootRom and cp15 cntfrq and modified during clock tree initialization if needed. When HSI is no more used by any device, this internal oscillator can be switched off to reduce consumption. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-04-06clock: stm32mp1: add stgen clock source change supportPatrick Delaunay
The STGEN is the clock source for the Cortex A7 arch timer. So after modification of its frequency, CP15 cntfreq is updated and a new timer init is performed. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-04-06arm: timer: get frequency for arch timer armv7 in cp15 cntfrqPatrick Delaunay
Manage dynamic value for armv7 arch clock timer, when CONFIG_SYS_HZ_CLOCK is not defined. Get frequency from CP15 cntfrq information, initialized for example by first boot stage, clock driver or by BootRom. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-04-06Allow providing default environment from fileRasmus Villemoes
Modifying the default environment via CONFIG_EXTRA_ENV_SETTINGS is somewhat inflexible, partly because the cpp language does not allow appending to an existing macro. This prevents reuse of "environment fragments" for different boards, which in turn makes maintaining that environment consistently tedious and error-prone. This implements a Kconfig option for allowing one to define the entire default environment in an external file, which can then, for example, be generated programmatically as part of a Yocto recipe, or simply be kept in version control separately from the U-boot repository. Tested-by: Sean Nyekjaer <sean.nyekjaer@prevas.dk> Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2018-04-06stm32mp1: select boot device and partitionPatrick Delaunay
Bootrom loads SPL from SDCARD or eMMC according BootPin selection. Then SPL loads U-Boot on the same mmc device with the following predefined GPT partitioning: on SDCARD: gpt partitioning 1: SPL 2: SPL#2 3: U-Boot 4: bootable partition on eMMC: The 2 boot partitions are used for SPL (2 copy) boot1: SPL boot2: SPL#2 The user partition use gpt partitioning 1: U-Boot 2: bootable partition This patch select the correct SPL partition (3 for SDCARD on mmc0 and 1 for eMMC on mmc1) according the BootRom information saved in TAMP register and based on configuration flasg: - CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION => for BOOT_DEVICE_MMC1 or mmc 0 in U-Boot - CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION_MMC2 (new) => for BOOT_DEVICE_MMC2 or mmc 1 in U-Boot And the correct boot_targets is selected according the environment variables boot_device and boot_instance, with preboot command, to search the bootable partition with kernel on this device (generic distro support). Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-04-06stm32mp1: get boot mode from BootRomPatrick Delaunay
SPL copy BootRom boot mode information in TAMP register 21. This TAMP register information is used after relocation to set 2 env variables - boot_device - boot_instance Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-04-06stm32mp1: add eMMC support for ED1Patrick Delaunay
Add command GPT support Add EMMC boot support Add the 2 other SDMMC instances for ED1: - SDMMC2 = mmc 1, eMMC on the ED1 board - SDMMC3 = extension connector, deactivated by default Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-04-06spl: spl_mmc: provide one weak function spl_boot_partitionPatrick Delaunay
The spl_boot_partition function has been added in order to have the possibility to boot on a same binary from different mmc devices with different partitions. By default keep the current behavior, SPL use the partition defined by CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Signed-off-by: Christophe KERELLO <christophe.kerello@st.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2018-04-06rtc: rewrite isl1208 to support DMKlaus Goger
Adds devicemodel support to the ISL1208 driver. This patch drops the non-dm API as no board was using it anyway. Also add it to Kconfig. Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-06stm32mp: add check of cpu identifierPatrick Delaunay
Add support of DBGMCU_IDC for cpu identifier and revision Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-04-06stm32mp: cleanup cpu.cPatrick Delaunay
Move all defines at the beginning of the file Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-04-06tools/mxsimage: Support building with LibreSSLHauke Mehrtens
The mxsimage utility fails to compile against LibreSSL version < 2.7.0 because LibreSSL says it is OpenSSL 2.0, but it does not support the complete OpenSSL 1.1 interface. LibreSSL defines OPENSSL_VERSION_NUMBER with 0x20000000L and therefor claims to have an API compatible with OpenSSL 2.0, but it implements EVP_MD_CTX_new(), EVP_MD_CTX_free() and EVP_CIPHER_CTX_reset() only starting with version 2.7.0, which is not yet released. OpenSSL implements this function since version 1.1.0. This commit will activate the compatibility code meant for OpenSSL < 1.1.0 also for LibreSSL version < 2.7.0. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Reviewed-by: Jonathan Gray <jsg@jsg.id.au>
2018-04-06regulator: pbias: don't evaluate variable before assignmentHeinrich Schuchardt
We should not evaluate the value of reg before its value is set. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-06omap3_logic: Fix FDT ADDR for ramdisk bootingAdam Ford
The boot scripts for booting from ramdisk are using ${fdtimage} when they really should be using ${fdtaddr} This patch will fix it so the RAMdisk bootscripts operate correctly. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-04-06input: Drop PS/2 keyboard supportSimon Glass
This is not used by any current board and has not been converted to driver model. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-04-06fs: btrfs: Remove unused debug code left from developmentMarek Behún
Signed-off-by: Marek Behun <marek.behun@nic.cz>
2018-04-06ARM: am33xx: Inhibit re-initialization of DDR during RTC-onlyRuss Dill
This inhibits the re-inititialization of DDR during an RTC-only resume. If this is not done, an L3 NOC error is produced as the DDR gets accessed before the re-init has time to complete. Tested on AM437x GP EVM. Signed-off-by: Russ Dill <Russ.Dill@ti.com> [j-keerthy@ti.com Ported to Latest Master branch] Signed-off-by: Keerthy <j-keerthy@ti.com>
2018-04-06am43xx: Do not allow EMIF to control DDR_RESET in rtconly configDave Gerlach
Prevent EMIF control of DDR_RESET line on DDR3 am43xx platforms for am43xx_evm_rtconly_config. Without this DDR is unstable and can become corrupted after multiple iterations of RTC+DDR mode. Signed-off-by: Dave Gerlach <d-gerlach@ti.com> [j-keerthy@ti.com Ported to latest master branch] Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-04-06ARM: AM43xx: Add support for RTC only + DDR in self-refresh modeTero Kristo
Kernel stores information to the RTC_SCRATCH0 and RTC_SCRATCH1 registers for wakeup from RTC-only mode with DDR in self-refresh. Parse these registers during SPL boot and jump to the kernel resume vector if the device is waking up from RTC-only modewith DDR in Self-refresh. The RTC scratch register layout used is: SCRATCH0 : bits00-31 : kernel resume address SCRATCH1 : bits00-15 : RTC magic value used to detect valid config SCRATCH1 : bits16-31 : board type information populated by bootloader During the normal boot path the SCRATCH1 : bits16-31 are updated with the eeprom read board type data. In the rtc_only boot path the rtc scratchpad register is read and the board type is determined and correspondingly ddr dpll parameters are set. This is done so as to avoid costly i2c read to eeprom. RTC-only +DRR in self-refresh mode support is currently only enabled for am43xx_evm_rtconly_config. This is not to be used with epos evm builds. Signed-off-by: Tero Kristo <t-kristo@ti.com> [j-keerthy@ti.com Rebased to latest u-boot master branch] Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-04-06drivers: serial: remove nonexisting initialisation functionsChristophe Leroy
This patch removes call of serial initialisation functions that are not implemented anymore. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2018-04-06am335x: am335x_evm_usbspl_defconfig: NETCONSOLEJason Kridner
Enable NETCONSOLE by default. Still requires changes to the boot environment to enable on the platform. Signed-of-by: Jason Kridner <jdk@ti.com> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-04-06Handle NETCONSOLE and SPL enabledJason Kridner
NETCONSOLE isn't compiled in with SPL, so the include file needs to recognize that. Signed-off-by: Jason Kridner <jdk@ti.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-04-06Add support for BeagleBoard.org PocketBeagleJason Kridner
Texas Instruments AM3358 based low-cost board using Octavo Systems OSD3358 SIP with built-in TPS65217 PMIC and 512MB DDR3. Board features small 35mm x 55mm size, high-speed USB OTG, microSD and 72 0.1" expansion header pins with 2xSPI, 2xI2C, 2xUART, USB, 8xADC, up-to-44 GPIO, PRU pins and much more. https://beagleboard.org/pocket This was tested using the am335x_evm_usbspl_defconfig. Note that MII pins are enabled despite not having Ethernet on this board. This avoids an issue where otherwise many timeout errors would be generated. See https://e2e.ti.com/support/arm/sitara_arm/f/791/t/298976 for some related discussion. Signed-off-by: Jason Kridner <jdk@ti.com> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-04-06Migrate CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSCAlex Kiernan
This converts CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-04-06powerpc: mpc8xx: move watchdog into drivers/watchdogChristophe Leroy
In preparation of DM watchdog, move basic actions into drivers/watchdog Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
