Since PLLP can be set to two different values, make it a parameter
to the function that sets up the PLLs.
BUG=chromium-os:23496
TEST=build and boot on Seaboard, T33, Kaen
Change-Id: I81ccc1cc3356796793ec2dd4ab22ed7fbd52f01d
Reviewed-on: https://gerrit.chromium.org/gerrit/12245
Commit-Ready: Simon Glass <sjg@chromium.org>
This is using the latest patch recommendation from Dilan at Nvidia, we adjust
the ordering to clear bypass earlier and remove the delay.
This patch was run successfully for over 2000 reboots.
BUG=chrome-os-partner:6145
TEST=Manual
Signed-off-by: Bernie Thompson <bhthompson@chromium.org>
Change-Id: I9ef2f12d5c8abae86791f50b0f5e0e5a4249d947
Reviewed-on: https://gerrit.chromium.org/gerrit/12385
Reviewed-by: Micah Catlin <micahc@google.com>
Commit-Ready: Bernie Thompson <bhthompson@chromium.org>
Tested-by: Bernie Thompson <bhthompson@chromium.org>
This function is better off in architecture code than board code.
This is quite an invasive change unfortunately.
Change-Id: I17764b134c25b684666d2c0fae2d255ac80e61b1
Reviewed-on: https://gerrit.chromium.org/gerrit/12244
Reviewed-by: Che-Liang Chiou <clchiou@chromium.org>
This adds a setting for the required PLLP clock frequency.
Change-Id: I02ab35fcd496d4ac4cfa6b732fdd9a9b7eb2cc88
Reviewed-on: https://gerrit.chromium.org/gerrit/12242
Reviewed-by: Doug Anderson <dianders@chromium.org>
This reads the frequency of a named clock from the fdt.
Change-Id: Ib35bf7ef749f51862644218b1015057ca4e25203
Reviewed-on: https://gerrit.chromium.org/gerrit/12243
CONFIG_SYS_PLLP_BASE_IS_408MHZ is meant only for T30 builds.
Don't override to 216MHZ if not Tegra3 && not 408MHZ
BUG=chromium-os:23521
TEST=built Seaboard, Waluigi and tested Waluigi. x86 build in queue.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Change-Id: If9517c473e76b8a1a49c6ff81891946cdb263a44
Reviewed-on: https://gerrit.chromium.org/gerrit/12219
Commit-Ready: Doug Anderson <dianders@chromium.org>
Tested-by: Doug Anderson <dianders@chromium.org>
Reviewed-by: Vadim Bendebury <vbendeb@chromium.org>
intermittent hang
Currently with 200uS delay after PLL for stability.
TEST=None
Originaly-Reviewed-on: https://gerrit.chromium.org/gerrit/11091
Originaly-Reviewed-by: Bernie Thompson <bhthompson@chromium.org>
Originaly-Tested-by: Bernie Thompson <bhthompson@chromium.org>
Originaly-Commit-Ready: Katie Roberts-Hoffman <katierh@chromium.org>
Originaly-Reviewed-by: Katie Roberts-Hoffman <katierh@chromium.org>
Signed-off-by: Doug Anderson <dianders@chromium.org>
Change-Id: Idcb95d4698ea856785be8a8232c08c89309af887
Reviewed-on: https://gerrit.chromium.org/gerrit/12158
BUG=chromium-os:21033
TEST=built Seaboard & Waluigi OK. Booted my Waluigi to cmd prompt OK.
MMC, SPI and I2C still work fine, as does UART.
More can be done at a later date to cleanup AP20.c for T30 (and
rename/move it, since AP20 is a T2x name) and use new T30 V/W clock
enables/resets/sources/etc.
Change-Id: Ia3a86c519481fffde6926e1fece1dcf898d199c9
Reviewed-on: https://gerrit.chromium.org/gerrit/11911
Tested-by: Tom Warren <twarren@nvidia.com>
This change finishes plumbing the initrd support built into the zboot
mechanism out to the command interface.
It also fixes a bug in the command declaration where the kernel size could
be passed as an optional second parameter but not enough arguments were
allowed.
BUG=chrome-os-partner:6715
TEST=Built and booted on a Lumpy with the U-Boot command line exposed. Used
the Linux kernel in the system partition and the initramfs used for recovery
to boot the system. Observed that the recovery scripts in the initramfs ran.
The hardest part about implementing this change was testing because it took
many attempts to build/find an initrd/initramfs and command line that would
actually work. I'm confident the problems I had were from not knowing how to
set up or use an initramfs properly, not from the U-Boot support itself.
Signed-off-by: Gabe Black <gabeblack@google.com>
Change-Id: Iccc5ff62e170e738dfb429a6b0ef9e27f0e7d8a9
Reviewed-on: https://gerrit.chromium.org/gerrit/12027
Tested-by: Gabe Black <gabeblack@chromium.org>
This reverts commit fab63e9aacc49a3d224df47b6d0e23dc6b73de40.
Change-Id: I4ce3622871374baa7da19263cbe38603b4f9e356
Reviewed-on: https://gerrit.chromium.org/gerrit/11943
There is barely enough space for U-Boot in the 2MB SPI flash. We are moving
to eMMC firmware anyway, so for now let's remove the second-stage U-Boot
from the image.
This only affects Seaboard, not Kaen.
BUG=chromium-os:19724
TEST=emerge chromeos-bootimage on Seaboard
Change-Id: I6e3cadc2521b473cbea4ebbfeea2606780392fdb
Reviewed-on: https://gerrit.chromium.org/gerrit/11942
Reviewed-by: Tom Wai-Hong Tam <waihong@chromium.org>
Apply memoization to cc-option macro by caching the results of the
gcc calls. This macro is called very often so using cached results
leads to faster compilation times.
This feature can be enabled by setting CACHE_CC_OPTIONS=y in the
environment.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
(cherry picked from commit f5fd7cd17552daf41677f6aa1c9eef48055c98a8)
Change-Id: I76d9d6ccab7ba2aefc1e63a5f5e16c8a7aeadef7
Reviewed-on: https://gerrit.chromium.org/gerrit/11807
U-Boot Makefiles contain a number of tests for compiler features etc.
which so far are executed again and again. On some architectures
(especially ARM) this results in a large number of calls to gcc.
This patch makes sure to run such tests only once, thus largely
reducing the number of "execve" system calls.
Example: number of "execve" system calls for building the "P2020DS"
(Power Architecture) and "qong" (ARM) boards, measured as:
-> strace -f -e trace=execve -o /tmp/foo ./MAKEALL <board>
-> grep execve /tmp/foo | wc -l
Before: After: Reduction:
P2020DS 20555 15205 -26%
qong 31692 14490 -54%
As a result, built times are significantly reduced, typically by
30...50%.
Change-Id: I6e8c7c37cd13c56cb64d0a410514f2b9dc2d5adb
Cc: Andy Fleming <afleming@gmail.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Albert Aribaud <albert.aribaud@free.fr>
cc: Graeme Russ <graeme.russ@gmail.com>
cc: Mike Frysinger <vapier@gentoo.org>
(cherry picked from commit 77d94d2d86c055f015734cc4cd972a5de30fc5a2)
Reviewed-on: https://gerrit.chromium.org/gerrit/11806
This was missed at the time.
BUG=chrome-os-partner:6585, chromium-os:22528
TEST=build and boot on Kaen, see that it doesn't cold reboot now
Change-Id: Ied4f08a5078312dbee4ae4b0715e5c02d55f159a
Reviewed-on: https://gerrit.chromium.org/gerrit/11879
Move the malloc() out of fdt_decode_alloc_region() and rename it
accordingly. This makes the code somewhat cleaner and allows us
to print a sensible error message.
BUG=chromium-os:17062
Change-Id: I8edc8809baa42578e74c5e42cf47494b31b774e7
Reviewed-on: https://gerrit.chromium.org/gerrit/11878
TEST=Built and booted OK on my Waluigi. UART is OK, mmc, spi, i2c OK.
Note that this is only valid with CONFIG_SYS_PLLP_BASE_IS_408MHZ.
No affect on Tegra2. Seaboard builds fine, BTW.
Change-Id: I05a367afd1e78a2170d7308a658ce64017850ca0
Reviewed-on: https://gerrit.chromium.org/gerrit/11811
Commit-Ready: Che-Liang Chiou <clchiou@chromium.org>
Perhaps due to a toolchain change or the recent TFTP changes, U-Boot
no longer fits in the space available. This removes NAND support
to give us time to expand the space and/or fix the toolchain.
TBR=U-Boot suddenly grew for no immediately obvious reason, quick fix.
http://build.chromium.org/p/chromiumos/builders/tegra2%20seaboard%20full/builds/924/steps/cbuildbot/logs/stdio
TEST=build U-Boot and see that it is about 40KB smaller.
Change-Id: Iec02cc4da57cac7e79355714000f3e5d31c326c4
Reviewed-on: https://gerrit.chromium.org/gerrit/11895
Reviewed-by: Yasuhiro Matsuda <mazda@chromium.org>
This adds the tftpput command to U-Boot.
(cherry picked from commit 2d46cf291eae29a42bb5ca3d280d2b136339686b)
Change-Id: I7d0dc1fd78d9269ed932899cb1c301771ee24fbf
Reviewed-on: https://gerrit.chromium.org/gerrit/11802
This adds logic to tftp.c to implement the tftp 'put' command, and
updates the README.
(cherry-picked from 1fb7cd4)
Change-Id: I01fc2ca4d974416083e913597791676bbd0934ae
Reviewed-on: https://gerrit.chromium.org/gerrit/11801
We need something akin to load_addr to handle saving data.
(cherry picked from commit 1aec244acf9daf0d4dad80fe86b2c2b7404251d6)
Change-Id: I56c586abb3e075f0ab422c833637a3160d7e2a5f
Reviewed-on: https://gerrit.chromium.org/gerrit/11800
TftpStart should support starting either a get or a put.
(cherry-picked from 58f317d)
Change-Id: Ic221520a1c7cb00536a42d3ab531efbcaba35bf6
Reviewed-on: https://gerrit.chromium.org/gerrit/11799
This code is required for tftpput, so move it into separate functions.
(cherry picked from commit e4cde2f70d2377fdf484cbbc1729b188f81b8ec8)
Change-Id: Ie0398e05b13ea56dea70b270a812fe6dbbbe4bb4
Reviewed-on: https://gerrit.chromium.org/gerrit/11798
We want to show block markers on completion of get and put, so
move this common code into separate functions.
(cherry-picked from f5329bb)
Change-Id: I579a0db0e088ecd947bdfbf3049ec94a930fbed6
Reviewed-on: https://gerrit.chromium.org/gerrit/11797
This is a better name for this protocol. Also remove the typedef to keep
checkpatch happy, and move zeroing of NetBootFileXferSize a little
earlier since TFTPPUT will need to change this.
(cherry-picked from e4bf0c5)
Change-Id: I90d03045de0231553a693f7119bdcc67a908e3c9
Reviewed-on: https://gerrit.chromium.org/gerrit/11796
The Winbond W25X40 is now being used in the IP02 (and possibly IP04).
Tested and working on the actual device.
(cherry picked from commit ad8e3bd65766f670007bc5ae7c19b64e69e3dceb)
Change-Id: I0e395dc6c10086a330d2a32e8f7601afe1a1792d
Reviewed-on: https://gerrit.chromium.org/gerrit/11864
Reviewed-by: Taylor Hutt <thutt@chromium.org>
Tested-by: Taylor Hutt <thutt@chromium.org>
ICMP packets can tell you when there is no server at the other end. It
is useful for tftp to figure this out, so that a quick error can be
displayed, rather than pointlessly retrying.
This adds an ICMP packet handler to the net interface.
(cherry picked from commit 4793ee6522f10a3d108de7e47adbcf5f15eb3f46)
Change-Id: I02bbd41b3852b92b06210db160a06c62f5bf414f
Reviewed-on: https://gerrit.chromium.org/gerrit/11795
This is a small clean-up patch.
Tested-by: Eric Bénard <eric@eukrea.com>
(cherry picked from commit 093498669e77597635a24f326f11efeab213d394)
Change-Id: Ib052e50e7e520c9d5c8c5344e94a4404b2ba0d30
Reviewed-on: https://gerrit.chromium.org/gerrit/11793
NetReceive() is a very long function with a lot of indent. Before adding
code to the ICMP bit, split it out.
(cherry picked from commit 8f79bb17a4251ec096a7184d1eaf6f5dea3d2623)
Change-Id: Ic5599c5c7eedc7f00fc5d5aecdd051418e5c2e40
Reviewed-on: https://gerrit.chromium.org/gerrit/11794
It seems we put numbers and addresses into environment variables a lot.
We should have some functions to do this.
(cherry picked from commit d67f10c)
Change-Id: I922e72a7db872f26774459a6dc074a80016ef904
Reviewed-on: https://gerrit.chromium.org/gerrit/11792
This function is generally useful and shouldn't hide away in hush. It
has been moved as is.
(cherry picked from commit 3cce8a5496452285e1828984ad3945417205cfc3)
Change-Id: I014f58e901e6b035b5eeb694c62e6e881a7b75c2
Reviewed-on: https://gerrit.chromium.org/gerrit/11791
BUG=none
TEST=Built Waluigi AOK, ran OK to cmd prompt
Change-Id: I18ad5386958f456bf9bc819de5affc4cb5bae267
Reviewed-on: https://gerrit.chromium.org/gerrit/11716
Reviewed-by: Tom Warren <twarren@nvidia.com>
BUG=none
TEST=built Seaboard and Waluigi AOK
Change-Id: Ia860abf5ef3af66b3a39d4c57192455986b7a4f4
Reviewed-on: https://gerrit.chromium.org/gerrit/11704
TEST=run `sf erase, write` and `sf read` on Waluigi
verify the data it reads from SPI flash matches that it writes to
Change-Id: Ibeefd3183e4fa367d68d0035a818e1c166e6d59d
Reviewed-on: https://gerrit.chromium.org/gerrit/11473
Tested-by: Che-Liang Chiou <clchiou@chromium.org>
TEST=run `sf erase, write` and then `sf read` on seaboard
Change-Id: I1b04afa4b54738cd93be29b70f428bdc3e6b234f
Reviewed-on: https://gerrit.chromium.org/gerrit/11472
TEST=emerge-{tegra2_seaboard,waluigi} chromeos-u-boot
Change-Id: Icee2c26f36937e96c24318979179ba3a0cbfc09c
Signed-off-by: Che-Liang Chiou <clchiou@chromium.org>
Reviewed-on: https://gerrit.chromium.org/gerrit/11597
BUG=none
TEST=built Seaboard and Waluigi OK. Booted Waluigi OK.
Change-Id: I1bfbe03945d7dae44e0840349b9698fc08cef07d
Reviewed-on: https://gerrit.chromium.org/gerrit/11504
BUG=none
TEST=build Seaboard and Waluigi AOK
Change-Id: Id8e7227de7898bb9d117bf8d0f293ee5da7dc501
Reviewed-on: https://gerrit.chromium.org/gerrit/11506
Based on Tegra3 TRM, once E_18V bits in PMC are programmed, all IO_RESETs
need to be cleared on LV blocks. If not, GPIO settings on related LV pins
will always be set to low even if it is set to high. Specifically, it is
observed that when IO_RESET bit is not cleared in VI_D4 pinmux register,
the output of GPIO on VI_D4 (PL.02) is always low. That causes LVDS shutdown
all the time. Also needed for SDMMC4 pins when booting from SPI.
BUG=none
TEST=built and booted on Waluigi, read/write SD/MMC data OK
Signed-off-by: Jimmy Zhang <jimmzhang@nvidia.com>
Change-Id: Iaf84dc39375a49ceb3284dd1d48a8af3a0145175
Reviewed-on: https://gerrit.chromium.org/gerrit/11495
Set CPU clock initially to 312Mhz; once CPU voltage is
raised, CPU clock will then be raied to 1.2GHz (for T25)
or 1.0GHz (for T20).
BUG=chrome-os-partner:5914
TEST=Build and test on Seaboard
Change-Id: I0c95a1df6b87c896daca8c03c9dc33b245764621
Reviewed-on: https://gerrit.chromium.org/gerrit/11199
Tested-by: Yen Lin <yelin@nvidia.com>
The U-boot spi interface uses Software Sequencing and handles
write transactions in three distinct steps:
1) issue Write Enable op
2) issue Page Program op
3) poll Read Status Reg for completion
However in an Intel 6-series chipset the Management Engine is
also issuing a lot of transactions through the same controller
to the same chip. It is possible for an ME transaction to
occur between the U-boot issuing WREN and sending the actual
data, resulting in the host WREN being lost and the data not
actually being written to the chip.
This change intercepts WREN opcode and instead applies it as
a prefix operator for the next issued transaction, ensuring
that the two are issued back-to-back to the SPI chip.
Unfortunately this register is not writable when the SPI
contoller is locked down, so it is not always applicable.
BUG=chrome-os-partner:6690
TEST=repeated manual testing on lumpy with boot/suspend/resume
Change-Id: I75e353942fd6148a93be561ff422e37dfc6dc8c4
Signed-off-by: Duncan Laurie <dlaurie@chromium.org>
Reviewed-on: https://gerrit.chromium.org/gerrit/11625
Reviewed-by: Stefan Reinauer <reinauer@chromium.org>
TEST=build seaboard successfully
Change-Id: Idbfbdbf0bdb1070f4a2b5f8205c1caff6ef0c811
Reviewed-on: https://gerrit.chromium.org/gerrit/11471
On X86 systems the hardware maps the bootprom SPI flash chip into the
top of memory address range. This could be used for accessing all
information in the SPI flash.
The vboot-reference code requires access to FMAP sections containing
cryptographic information, and as of today, u-boot reads the whole
sections, which are 64 KB in size, even though the actual areas
accessed by vboot-reference are much smaller.
A much faster way of accessing this information would be just passing
around pointers to the appropriate memory areas. This would eliminate
one copy, and also would make sure that only the areas actually
accessed get fetched from SPI flash.
This patch provides this ability trying to keep code changes to a
minimum.
New feature is enabled by defining CONFIG_HARDWARE_MAPPED_SPI. The
firmware storage API for file reads changes when the new configuration
option is set: a pointer to pointer to buffer is passed to the
read_spi() function instead of a pointer to buffer. When the new
feature is enabled the read_spi() function sets the pointer value to
point to the requested data instead of copying the data into the
buffer.
A new data type is introduced (read_buf_type), which is set to be a
(void *) if the new feature is not enabled, or (void **) otherwise.
This type is used as the buffer pointer in the spi_read() function.
Code allocating/freeing buffers used to keep data read from SPI flash
is now conditionally compiled.
Call sites for the spi_read() function are modified to adjust the
buffer pointer parameter (pass the address of the parameter instead of
the parameter, when the new feature is enabled).
gbb field access functions can be aliased to gbb_init(), as they all
in fact do the same - read a certain section of the gbb area.
This change does not benefit the ARM implementations, and makes the
code more complicated that it should be. Some u-boot rearchitecture
along with vboot_reference API enhancements could address this. A
tracking issue
(http://code.google.com/p/chromium-os/issues/detail?id=22528) has been
opened for that.
TEST=manual
. build a new stumpy firmware image
. boot the stumpy, observe it start up chromeos.
. assess the boot timing using the cbmem.py utility (this
modification shaves in excess of 100ms off the boot time).
. disable the new feature, build a stumpy image, observe that is
still boots chromeOs.
. run emerge-terga2_kaen chromeos-u-boot to confirem that ARM
version builds cleanly.
Change-Id: I4e6ab530d24f5771b5a86a48d3f3135101b469a6
Signed-off-by: Vadim Bendebury <vbendeb@chromium.org>
Reviewed-on: https://gerrit.chromium.org/gerrit/11152
This adds pinmux config settings for a generic T30 board.
This is just an example - real code should do pinmux setting in the
driver which is the only thing that can know what the settings should
be.
TEST=build and boot on Seaboard, Waluigi
Change-Id: Ia56fcfc55e6cce8ac8b75c31d0618182aaa16bf6
Reviewed-on: https://gerrit.chromium.org/gerrit/8705
With this set of config options we can now boot the kernel. With
the kernel I have, it doesn't work yet, but at least it prints out
some messages to the UART.
BUG=chromium-os:21540
TEST=If I have a reasonable kernel in MMC1, I see that it can boot
quite a ways into the kernel w/ autoboot.
Change-Id: I5918fff3d48f2ff9f2bac9261c84e08e60a1560a
Reviewed-on: https://gerrit.chromium.org/gerrit/10675
This cleans up the rom caching optimization implemented in coreboot (and
needed throughout u-boot runtime.
Signed-off-by: Stefan Reinauer <reinauer@google.com>
TEST=boot coreboot on stumpy
Change-Id: I7242c9c2b0546c633be8fb8ebc815ed6e6fda4d1
Reviewed-on: https://gerrit.chromium.org/gerrit/11138
Tested-by: Stefan Reinauer <reinauer@chromium.org>
Reviewed-by: Duncan Laurie <dlaurie@chromium.org>
All memory operations (except the "safe ones") live in the firmware
so the fast operations can be used. Except Memset. This CL changes that
problem.
There is another CL for this issue (removing the function from
vboot_reference)
BUG=chrome-os-partner:6313
TEST=run coreboot/u-boot on Stumpy
Change-Id: Ic2ee5970d2ee9df64a9eda261a4348341cb4b31a
Reviewed-on: https://gerrit.chromium.org/gerrit/10992
Reviewed-by: Bill Richardson <wfrichar@chromium.org>
Reviewed-by: Randall Spangler <rspangler@chromium.org>
TEST=Able to use mmc.
Change-Id: I1d566f08f9dd115b5be1a05ffa0ff07b508e0cee
Reviewed-on: https://gerrit.chromium.org/gerrit/10663
The MMC reader looks like a USB device, so we don't need to support generic
MMC devices directly.
TEST=Built and booted on Stumpy.
Change-Id: Id5729cd9d51e0c4cb2570b9b452f96bd23764b85
Reviewed-on: https://gerrit.chromium.org/gerrit/10755
Commit-Ready: Gabe Black <gabeblack@chromium.org>
Reviewed-by: Gabe Black <gabeblack@chromium.org>
We aren't currently planning to have network support in production firmware. If
we need it at some point, we can easily turn that support back on.
Change-Id: Iad265bb2bbae5360135eaa8577cc6dfde95045f9
Reviewed-on: https://gerrit.chromium.org/gerrit/10754
Disable it by default since we're using the SCSI interface now. Being able to
turn IDE back on later might be necessary if we haven't gotten AHCI support
working on a new platform yet.
Change-Id: I07e80dc2673529f3f2ec52431e1c0958511539b0
Reviewed-on: https://gerrit.chromium.org/gerrit/10753
