- now the Flash ST M29W040B is supported (not tested)
- fix the "led" command
- fix compile error, if BUILD_DIR is used
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
Signed-off-by: Niklaus Giger <niklaus.giger@nestal.com>
- Add optional ECC generation routine to preserve existing
RAM values. This is needed for the Linux log-buffer support
- Add optional DDR2 setup with CL=4
- GPIO50 not used anymore
- Lime register setup added
Signed-off-by: mushtaq khan <mushtaqk_921@yahoo.co.in>
This patch prints the DDR status registers upon machine check
interrupt on the 440EPx/GRx. This can be useful especially when
ECC support is enabled.
I added some small changes to the original patch from Niklaus to
make it compile clean.
This patch fixes the problem to assemble cpu/ppc4xx/start.S
experienced last week where building failed having specified
O=../build.sequoia.
This patch removes the CFG_PCI_PRE_INIT option completely, since
it's not needed anymore with the patch from Matthias Fuchs with
the "weak" pci_pre_init() implementation.
-add pci_pre_init() for pci interrupt fixup code
-disable phy sleep mode via reset_phy() function
-use correct io accessors
-cleanup
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
This patch adds support for calling a plattform dependant
pci_pre_init() function for 405 boards. This can be used to
move the current pci_405gp_fixup_irq() function into the
board code.
This patch also makes the CFG_PCI_PRE_INIT define obsolete.
A default function with 'weak' attribute is used when
a board specific pci_pre_init() is not implemented.
A new environment variable, "logversion", selects the log buffer
behaviour. If it is not set or set to a value other than 2, then the
old, Linux 2.4.4, behaviour is selected.
Signed-off-by: Igor Lisitsin <igor@emcraft.com>
Added memory, CPU, UART, I2C and SPR POST tests for PPC440.
- Show on the Status LEDs, some States of the board.
- Get the MAC addresses from the EEProm
- use PREBOOT
- use the CF on the board.
- check the U-Boot image in the Flash with a SHA1
checksum.
- use dynamic TLB entries generation for the SDRAM
The recently extended program_tlb() function had a problem when
multiple TLB's had to be setup (for example with 512MB of SDRAM). The
virtual address was not incremented. This patch fixes this issue
and is tested on Katmai with 512MB SDRAM.
- adapt to the more generic EXCEPTION_PROLOG and CRIT_EXCEPTION macros
- minor 4xx cleanup
This patch adds a board command to configure the I2C bootstrap EEPROM
values. Right now 533 and 667MHz are supported for booting either via NOR
or NAND FLASH. Here the usage:
=> bootstrap 533 nor ;to configure the board for 533MHz NOR booting
=> bootstrap 667 nand ;to configure the board for 667MHz NNAND booting
The latest changes showed a problem with the location of the NAND-SPL
image in the OCM and the init-data area (incl. cache). This patch
fixes this problem.
Now CONFIG_440 has to be defined in all PPC440 board config files.
- Introduced dedicated switches for building 440 and 405 images required
for 440-specific machine instructions like 'rfmci' etc.
- Exception vectors moved to the proper location (_start moved away from
the critical exception handler space, which it occupied)
- CriticalInput now serviced (with default handler)
- MachineCheck properly serviced (added a dedicated handler and return
subroutine)
- Overall cleanup of exceptions declared with STD_EXCEPTION macro (unused,
unhandled and those not relevant for 4xx were eliminated)
- Eliminated Linux leftovers, removed dead code
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
This patch adds initial support for the Liebherr lwmon5 board euqipped
with an AMCC 440EPx PowerPC.
The board config array CFG_440_GPIO_TABLE for the ppc440 GPIO setup
is extended with the default GPIO output state (level).
Now program_tlb() allows to program a TLB (or multiple) with
different virtual and physical addresses. With this change, now one
physical region (e.g. SDRAM) can be mapped 2 times, once with caches
diabled and once with caches enabled.
Most prominently this changes 'erase' to be non-repeatable.
Signed-off-by: Detlev Zundel <dzu@denx.de>
Signed-off-by: Jan Wrobel <wrr@semihalf.com>
Acked-by: Bartlomiej Sieka <tur@semihalf.com>
Set the correct value in GPIOx_TCR when configuring the gpio
with CFG_440_GPIO_TABLE.
Signed-off-by: Benoit Monin <bmonin@adeneo.eu>
This patch adds NAND booting support for the AMCC Acadia eval board.
Please make sure to configure jumper J7 to position 2-3 when booting
from NOR, and to position 1-2 when booting for NAND.
I also added a board command to configure the I2C bootstrap EEPROM
values. Right now only 267MHz is support for booting either via NOR
=> bootstrap 267 nor ;to configure the board for 267MHz NOR booting
=> bootstrap 267 nand ;to configure the board for 267MHz NNAND booting
e600 does not have a bootpg restriction.
Move the version string to beginning of image at fff00000.
Resetvec.S is not needed.
Update flash copy instructions.
Add tftpflash env variable
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
The attached patch is mainly cosmetic, allowing u-boot to
display the correct bootstrap option letter according to the
datasheets.
The original patch was extended with 405EZ support by Stefan
Roese.
