Update the README for DDR ECC, change the name
to README.mpc83xx.ddrecc.
Signed-off-by: Dave Liu <daveliu@freescale.com>
Remove the duplicated source code of ecc command on the <board>.c,
for reused, move these code to cpu/mpc83xx directory.
The burst length should be 4 for DDR2 with 32 bits bus
MPC8323E based board with 64MB fixed SDRAM, 16MB flash,
five 10/100 ethernet ports connected via an ICPlus IP175C
switch, one PCI slot, and serial. Features not supported
in this patch are SD card interface, 2 USB ports, and the
two phone ports.
Signed-off-by: Michael Barkowski <michael.barkowski@freescale.com>
add libfdt support to the generic 83xx pci code
..and not the global fdt. Rename local fdt vars to blob so as not to
be confused with the global var with the same three-letter name.
Several node strings were not correct (trailing slashes and properties
in the strings)
Added setting of the timebase-frequency.
Improved error messages and use debug() instead of printf().
Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
The new name matches more closely the kernel's name, which is also
a much better description.
These are the mpc83xx changes made necessary by the function name change.
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
Acked-by: Gerald Van Baren <vanbaren@cideas.com>
83xx processor family has many reset sources, such as
power on reset, software hard reset, software soft reset,
JTAG, bus monitor, software watchdog, check stop reset,
external hard reset, external software reset.
sometimes, to figure out the fault of system, we need to
know the cause of reset early before the prompt of
u-boot present.
According to the latest user manual, the SDMA temporary
buffer base address must be 4KB aligned.
When the rev2.x silicon mount on the MPC8360EMDS baord,
and if you are using the u-boot version after the commit
3fc0bd159103b536e1c54c6f4457a09b3aba66ca.
to make the ethernet interface usable, we have to setup
the jumpers correctly.
The i2c_init() function in fsl_i2c.c programs the two I2C busses differently.
The second I2C bus has its slave address programmed incorrectly and is
missing a 5-us delay.
Update the cpu_init_f() function in cpu/mpc83xx/cpu_init.c to program the
bitfields for all 83xx processors. The code to update some bitfields was
compiled only on some processors. Now, the bitfields are programmed as long
as the corresponding CFG_SCCR option is defined in the board header file.
This means that the board header file should not define any CFG_SCCR macros
for bitfields that don't exist on that processor, otherwise the SCCR will be
programmed incorrectly.
Remove irritating #undef DEBUG
Signed-off-by: Martin Krause <martin.krause@tqs.de>
MPC83xx: Fix the Makefile config sections to generate the include/config.h
file in the build directory instead of the source directory.
Signed-off-by: David Saada <david.saada@ecitele.com>
This change adds 8360 silicon revision 2.1 support to u-boot.
Signed-off-by: Lee Nipper <lee.nipper@freescale.com>
Add $(obj) to LIB avoiding objects be built in the source dir
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
This patch fix the compile issue on the board that did not enable the bios emulator
The change entitled "Reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECx"
broke multiple PHY support in tsec.c. This fixes it.
Signed-off-by: Zach Sadecki <Zach.Sadecki@ripcode.com>
Allow the address of the Ten Bit Interface (TBI) to be changed in the
event of a conflict with another device.
Signed-off by: Joe Hamman <joe.hamman@embeddedspecialties.com>
[pointed out by Roderik Wildenburg]
The bios emulator in the MAI board can not pass compile
and have a lot of crap in it. remove it and will have a
clean and small bios emulator in the drivers directory
which can be uesed for every board.
This patch add definition of the BIOS emulator and the ATI framebuffer
driver for MPC8641HPCN board.
Signed-off-by: Zhang Wei <wei.zhang@freescale.com>
ATI video card BIOS. and can be used for x86 code emulation by some
modifications.
X300, X700, X800 ATI video cards.
Additionally export the following fuctions (to make trab_config build again):
- simple_strtol()
- strcmp()
Also bump the ABI version to reflect this change
All of the PCI/PCI-Express driver and initialization code that
was in the MPC8641HPCN port has now been moved into the common
drivers/fsl_pci_init.c. In a subsequent patch, this will be
utilized by the 85xx ports as well.
Common PCI-E IMMAP register blocks for FSL 85xx/86xx are added.
Also enable the second PCI-Express controller on 8641
by getting its BATS and CFG_ setup right.
Fixed a u16 vendor compiler warning in AHCI driver too.
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
Add the ability for modules from the Schindler cm5200 family to use a
single U-Boot image:
- rename cm1_qp1 to cm5200
- add run-time module detection
- parametrize SDRAM configuration according to the module we are running on
Few minor, board-specific fixes included in this patch:
- better MAC address handling
- updated default environment ('update' command uses +{filesize} now)
- improved error messages in the auto-update code
- allow booting U-Boot from RAM (CFG_RAMBOOT)
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
Signed-off-by: Piotr Kruszynski <ppk@semihalf.com>
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
CHANGELOG
fs/fat/fat.c
include/configs/MPC8560ADS.h
include/configs/pcs440ep.h
net/eth.c
The following MPC5121e subsystems are supported:
- low-level CPU init
- NOR Boot Flash (common CFI driver)
- DDR SDRAM
- FEC
- I2C
- Watchdog
Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
Signed-off-by: Jan Wrobel <wrr@semihalf.com>
