When mainline kernels reboot TK1 they use SW_RESET,
that reset mode does not reset PMIC. Some rails
need to be off for RAM Re-repair to work correctly.
Currently $loadaddr and $fdt_addr_r point to the same address. This
might be not ideal for some distro boot scripts which make use of
$loadaddr after loading the device tree.
Make sure the two variables point to two different addresses. Moving
$loadaddr is not entirly trivial since it is defined in mx6_common.h.
Move $fdt_addr_r and $ramdisk_addr_r by 1MiB, which should be enough
for scripts.
In case of Tezi recovery do not stop regular auto booting but rather
load the tezi.itb which got put at a fixed offset of 1M from the
regular loadaddr.
Modify configuration for Tezi:
- Use distroboot by default
- Boot from external SD cards by default
- Disable USB PID from config block (otherwise recovery mode download
in U-Boot stage fails)
regular loadaddr.
- Enable SDP in U-Boot
- Enable FDT relocation (in-place is causing issues with FIT images)
Modify configuration for Tezi unified recovery mode:
- Remove video output
- Currently only for recovery (no flash/eMMC support)
- Boot from external SD cards using distroboot first by default
For faster test time shorten the alternative memory test to
only do the stuck address/data line tests instead of full
memory write pattern tests.
- Enable SDP in SPL and U-Boot
Allow setting Toradex Easy Installer aka Tezi specific configuration
options like not enabling SATA, directly continuing with the SDP command
upon recovery, distrobooting otherwise or not storing the environment.
Use the external SD interface for legacy SD update instead of eMMC.
Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com>
Invoking tegra124_ram_repair() before powerup_cpus() is being
invoked to avoid race-conditions if arises further.
(based on downstream: fe1c9e4d523d6727afb62f03ef9fa5c0f04e7859)
Using CPU temperature grading as a discriminator if the Wi-Fi /
Bluetooth chip is populated is no longer possible due to upcoming
SKUs. Set variant to -wifi only if a valid config block is present
and the product id mentions a SKU with Wi-Fi / Bluetooth.
Use CONFIG_TARGET_... at compile time to differentiate between
Apalis iMX6, Colibri iMX6 and Colibri iMX6ULL. Avoid code
duplication by moving question about Wi-Fi / Bluetooth before
IT/non-IT decision.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
Tested on Colibri iMX7 1GB aka eMMC V1.1A
The DDR validation tool (which is part of Processor Expert) allows
to evaluate leveling parameters for CR105/CR106/CR110. Several
runs have been made with Colibri VF50 and VF61 and it seems to
evaluate very similar values. Use this values by default.
Note: The newly evaluated parameters seem to require CTLUPD_AREF
to be enabled!
Note 2: The tool also evaluated 6 as a new value for PHY02/18
GATE_CFG (Coarse adjust of gate open time). However, this seems
not to work in practise.
Using the DDR Validation tool in Processor Expert uncovered two
timing inconsistencies. Since those timings are related to the
suspend mode they do not affect or change regular memory behavior.
The current value CTLUPD_AREF(0) is the reset value of the register,
so there is no need to write a value. If needed, the register can be
written using board specific CR settings.
According to the data sheet bits 10-8 are PHYDRAM_CK_EN. Fix mask
to allow setting PHYDRAM_CK_EN correctly.
The CR80 register has multiple interrupt bits, the code is supposed
to check bit 8 but instead uses a logical and. In most cases this
probably did not affect real operations since at that stage typically
none of the other bits are set.
Add support for Vybrid's UART2 (Colibri UART_B).
RGMII_RD1 pin (active high, GPIO6_IO27) is triggered on reboot during
the SPL phase. This asserts (active low) nReset_Out from the PMIC.
Only V1.1 and later Colibri iMX6 modules implement this in hw. Previous
versions do not use this pin, so it is safe to leave it enabled at all
times.
When using static volumes, the file size stored in the volume is
determined at runtime. Currently the ubi command prints the file
size specified on the console, which leads to a rather confusing
series of messages:
# ubi read ${fdt_addr_r} testvol
Read 0 bytes from volume testvol to 82000000
No size specified -> Using max size (179924992)
Make sure to print the actual size read in any case:
Read 179924992 bytes from volume testvol to 82000000
After a successful read of a UBI volume, the variable filesize is set
to the number of read bytes. To boot linux with a raw initramfs/initrd,
you must specify the exact size of the initramfs/initrd image in boot
command. If the initramfs/inird is read from UBI volume, $filesize is
required to access the number of read bytes.
Example:
ubi read ${loadaddr} kernelvol
ubi read ${fdtaddr} dtbvol
ubi read ${initrd_addr} initrdvol
bootz ${loadaddr} ${initrd_addr}:${filesize} ${fdt_addr}
Signed-off-by: Holger Dengler <dengler@linutronix.de>
(cherry picked from commit 985fa93e61706a78fad130b006aefa1c098145de)
[backported to 2016.11]
Use GPIO 0 of instance GPIO5 which is used as card detect on
Colibri iMX6ULL. This fixes SD card detection.
Change usb_port_owner_info to 3 in defargs to allow for USB 3.0
SuperSpeed functionality on USBO1 in host mode.
Set the ASR bit to enable auto self refresh for RAM in mode register 2.
In ASR the refresh rate is dynamically adjusted to temperature
which is more power efficient in suspend to RAM.
Signed-off-by: Sven Guggisberg <sven.guggisberg@toradex.com>
Fix toradex_modules array off by one issue potentially leading to
spurious printout during boot e.g.
Model: Toradex V1.2A,
instead of
Model: Toradex UNKNOWN MODULE V1.2A.
T20 uses different addresses for its EHCI controllers which I missed.
Fix this.
Use device tree to set MAC address of the Ethernet chip.
Use device tree to set MTD partitions of the NAND chip.
Treat the first equal sign as a key/value separation too. This makes
the script files compatible with mkenvimage input file format. It
won't support variables with equal signs anymore, but this seems not
really like a loss.
The white spaces after the zero string terminator are applied to
the following environment entry. This is not what was intended.
Remove the superfluous white spaces.
This commit fixes several issues:
- Use ${OBJCOPY} if available, fallback to system default's objcopy if not
present.
- Extend the script to accept different build directory than current one.
It is extremely handy with OE usage, where source code is separated from
build.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Tested-by: Alex Kiernan <alex.kiernan@gmail.com>
[Backported to 2016.11]
(cherry picked from commit 0778e7c50ba1904943a1d6b5194c29d1fee33334)
This allows to change U-Boots default UART by simply changing
stdout-path in the device tree.
Switch to the generic compressed Kernel image type (zImage) instead of
the U-Boot specific uImage format.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
The i.MX 6UL/ULL feature a Cortex-A7 CPU which suppor the ARM
generic timer. This change makes use of the ARM generic timer in
U-Boot.
This is crucial to make the ARM generic timers usable in Linux since
timer_init() initalizes the system counter module, which is necessary
to use the generic timers CP15 registers.
Introduce a new config symbol to select the i.MX
General Purpose Timer (GPT).
In upstream Linux the GPMI NAND node of i.MX 6UL/6ULL uses
"fsl,imx6q-gpmi-nand" as compatible string. Add both to make
sure U-Boot fixups the MTD partitions for downstream and upstream
kernels.
The pad SAI1_RX_DATA can be used as second chip select for dual-die
NAND. However, with an assembly option the pad is available as GPIO
on SODIMM 169. All current version of Colibri iMX7 modules have the
pad available as GPIO hence do not mux the pin so that it is available
as GPIO by default.
This follows a similar commit in Linux ("arm: dts: imx7: mux pad of
SODIMM 169 as GPIO")
Disabling ASPM fixes incompatibilities with some PCIe cards
