Move the clock-rate dumping code into the cpu/.../davinci area
where it should have been, enabled by CONFIG_DISPLAY_CPUINFO,
updating the format and showing the DSP clock (where relevant).
Switch boards to use the cpuinfo() hook for this stuff.
Remove a few now-obsolete PLL #defines.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
These legacy NAND defines are no longer needed by this target.
Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
This document describes the u-boot status LED API.
This allows common u-boot commands to use a board's leds to
provide status for activities like booting and downloading files.
There is exiting support for red,yellow,green but no blue.
The main LED on the zoom2 is a blue LED.
actually the timer init use the interrupt_init as init callback
which make the interrupt and timer implementation difficult to follow
so now rename it as int timer_init(void) and use interrupt_init for interrupt
btw also remane the corresponding file to the functionnality implemented
as ixp arch implement two timer - one based on interrupt - so all the timer
related code is moved to timer.c
Reformat COBJS handling.
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
Remove duplicated interrupt code. Original, identical code can be found
in lib_arm/interrupts.c
Add some basic declarations for DaVinci DM355/DM350/DM335 support,
keyed on CONFIG_SOC_DM355. (DM35X isn't quite right because the
DM357 is very different; while the DM355 is like a DM355 without
the MPEG/JPEG coprocessor).
These have different peripherals than the DM6446, and some of
the peripherals are at different addresses. Notably for U-Boot,
there's no EMAC, and the NAND controller address is different
Fix two buglets in the dm644x support: don't set two must-be-zero
bits in the UART management register; and only include the I2C hooks
if the I2C driver is being included.
Split out DaVinci DM6446-specific bits from more generic bits:
- Add a CONFIG_SOC_DM644X. All current boards use DM6446 chips;
DM6443 and DM6441 chips differ in available peripherals.
- Move most DM644X-specific bits from psc.c to a new dm644x.c file,
which is conditionally built. It provides device-specific setup.
Plus minor coding style and comment updates with respect to the PSC.
Update cpu/arm926ejs/davinci/Makefile to use COBJ-y type syntax.
Add the first conditional: for EMAC driver support. Not all
chips have an EMAC; and boards might not use it, anyway.
This doesn't touch PHY configuration; that should eventually
become conditional too.
Move DaVinci PSC support from board/* to cpu/* where it belongs.
The PSC module manages clocks and resets for all DaVinci-family
SoCs, and isn't at all board-specific.
Don't needlessly include lowlevel init code; that's only really
needed with boot-from NOR (not boot-from-NAND). The 2nd stage
loader (UBL) handles that before it loads U-Boot.
Chips without the EMAC controller won't need the utilities
it uses to read an Ethernet address from EEPROM; so don't
include them needlessly.
Use is_valid_ether() to validate the address from EEPROM.
All-zero addresses aren't the only invalid addresses.
A fully erased EEPROM returns all-ones, also invalid...
Switch those Ethernet utilities to use "%pM" for printing
MAC addresses; and not say ROM when they mean EEPROM.
Acked-by: Ben Warren <biggerbadderben@gmail.com>
This patch moves the malloc initialization before calling flash_init().
Upcoming changes to the NOR FLASH common CFI driver with optional
MTD infrastructure and MTD concatenation support will call malloc().
And nothing really speaks against enabling malloc just a little earlier
in the boot stage. Some architectures already enable malloc before
calling flash_init() so they don't need any changes here.
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Scott McNutt <smcnutt@psyent.com>
Cc: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Cc: Daniel Hellstrom <daniel@gaisler.com>
Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Cc: John Rigby <jcrigby@gmail.com>
This patch adds another build target for the AMCC Sequoia PPC440EPx
eval board. This RAM-booting version is targeted for boards without
NOR FLASH (NAND booting) which need a possibility to initially
program their NAND FLASH. Using a JTAG debugger (e.g. BDI2000/3000)
configured to setup the SDRAM, this debugger can load this RAM-
booting image to the target address in SDRAM (in this case 0x1000000)
and start it there. Then U-Boot's standard NAND commands can be
used to program the NAND FLASH (e.g. "nand write ...").
Here the commands to load and start this image from the BDI2000:
440EPX>reset halt
440EPX>load 0x1000000 /tftpboot/sequoia/u-boot.bin
440EPX>go 0x1000000
Please note that this image automatically scans for an already
initialized SDRAM TLB (detected by EPN=0). This TLB will not be
cleared. This TLB doesn't need to be TLB #0, this RAM-booting
version will detect it and preserve it. So booting via BDI2000
will work and booting with a complete different TLB init via
U-Boot works as well.
The --binary option to envcrc can be used to export the embedded env as a
binary blob so that it can be manipulated/examined/whatever externally.
All in-tree PPC4xx boards now use CONFIG_NET_MULTI
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
This patch removes the cpld binary bitstream that is
used by esd's cpld command on DP405 boards.
Because u-boot with an external cpld bitstream may not
take more space in flash than before the u-boot binary is
shrinked a little bit. Some unused featues have been
removed therefore.
used by esd's cpld command on VOM405 boards.
used by esd's cpld command on PMC405 boards.
used by esd's cpld command on CMS700 boards.
removed therefore.
This patch adds support for an address parameter to esd's
cpld command. This is in preparation to remove compiled-in
binary cpld (xsvf) bitstreams.
When CONFIG_I2C_MUX was defined the output of 'help i2c' was not
correct, eg:
=> help i2c
i2c bus [muxtype:muxaddr:muxchannel] - add a new bus reached over muxes.
speed [speed] - show or set I2C bus speed
i2c dev [dev] - show or set current I2C bus
It has been changed to:
i2c speed [speed] - show or set I2C bus speed
argc and argv should only be modified once instead of once for
every i2c sub-command
The individual i2c commands imd, imm, inm, imw, icrc32, iprobe, iloop,
and isdram are no longer available so all references to them have been
updated to the new form of "i2c <cmd>".
The following individual I2C commands have been removed: imd, imm, inm,
imw, icrc32, iprobe, iloop, isdram.
The functionality of the individual commands is still available via
the 'i2c' command.
This change only has an impact on those boards which did not have
CONFIG_I2C_CMD_TREE defined.
New default, weak i2c_get_bus_speed() and i2c_set_bus_speed() functions
replace a number of architecture-specific implementations.
Also, providing default functions will allow all boards to enable
CONFIG_I2C_CMD_TREE. This was previously not possible since the
tree-form of the i2c command provides the ability to display and modify
the i2c bus speed which requires i2c_[set|get]_bus_speed() to be
present.
Add "_test" to cm5200's function test command names to prevent
overlap with common, global function names. Originally, the
"do_i2c" function test command interfered with
common/cmd_i2c.c's "do_i2c" when CONFIG_I2C_CMD_TREE was defined.
The functions were also made static as they are not globally accessed.
Add the i2c_init() function so that the tsi108_i2c.c driver fits
U-Boot's standard I2C API which is utilized by cmd_i2c.c
Add standard CONFIG_SYS_I2C_SPEED define for the mpc7448hpc2 so that
it can use the common 'i2c speed' command. Note that the I2C controller
utilized by the mpc7448hpc2 has a fixed speed and cannot be changed
dynamically.
The following changes were made, primarily to bring the Marvell i2c
driver in line with U-Boot's current I2C API:
- Made i2c_init() globally accessible
- Made i2c_read() and i2c_write() return an integer
- Updated i2c_init() calls to pass in CONFIG_SYS_I2C_SLAVE in the
offhand chance someone adds slave support in the future
The following changes were made, primarily to bring the cpci750 i2c
Many boards/controllers/drivers don't support an I2C slave interface,
however CONFIG_SYS_I2C_SLAVE is used in common code so provide a
default
The ddr code computes most things as 64-bit quantities and had some places
in the middle that it was using phy_addr_t and phys_size_t.
Instead we use unsigned long long through out and only at the last stage of
setting the LAWs and reporting the amount of memory to the board code do we
truncate down to what we can cover via phys_size_t.
This has the added benefit that the DDR controller itself is always setup
the same way regardless of how much memory we have. Its only the LAW
setup that limits what is visible to the system.
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
MPC8569 UART1 signals are muxed with PortF bit[9-12], we need to define
those pins before using UART1.
Signed-off-by: Yu Liu <Yu.Liu@freescale.com>
- Increase the size of malloc to 512KB because MPC8569MDS needs more memory for
malloc to support up to eight Ethernet interfaces.
- Move Environment address out of uboot thus the saved environment variables
will not be erased after u-boot is re-programmed.
MPC8569 has 128K bytes MURAM.
Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
