2015-03-13mx6sabre_common.h: remove deprecated mmc open/closemaxin.john@enea.com
Replace "mmc open/close" with "mmc dev" in mx6sabre_common.h as those commands were removed with this commit: 614b2bf1c9bf80dbad24f5e5ce1d115bf24a831d cmd_mmc.c: Drop open/close mmc sub-commands Signed-off-by: Maxin B. John <maxin.john@enea.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2015-03-13warp: Add a README fileFabio Estevam
Provide instructions on how to upgrade U-boot in the eMMC. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2015-03-13warp: Add Device Firmware Upgrade supportFabio Estevam
Device Firmware Upgrade (DFU) is a very convenient mechanism to upgrade U-boot on the eMMC. Add support for it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2015-03-13novena: Use the default CONFIG_SYS_PBSIZEFabio Estevam
Entering the maximum number of characters defined by CONFIG_SYS_CBSIZE into the console and hitting enter afterwards, causes a hang in the system because CONFIG_SYS_PBSIZE is not capable of storing the extra characters of the error message: "Unknown command '' - try 'help'". Use the default CONFIG_SYS_PBSIZE definition from config_fallbacks.h to solve this problem. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marex@denx.de>
2015-03-13warp: Use the default CONFIG_SYS_PBSIZEFabio Estevam
Entering the maximum number of characters defined by CONFIG_SYS_CBSIZE into the console and hitting enter afterwards, causes a hang in the system because CONFIG_SYS_PBSIZE is not capable of storing the extra characters of the error message: "Unknown command '' - try 'help'". Use the default CONFIG_SYS_PBSIZE definition from config_fallbacks.h to solve this problem. Cc: Otavio Salvador <otavio@ossystems.com.br> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2015-03-13nitrogen6x: Use the default CONFIG_SYS_PBSIZEFabio Estevam
Entering the maximum number of characters defined by CONFIG_SYS_CBSIZE into the console and hitting enter afterwards, causes a hang in the system because CONFIG_SYS_PBSIZE is not capable of storing the extra characters of the error message: "Unknown command '' - try 'help'". Use the default CONFIG_SYS_PBSIZE definition from config_fallbacks.h to solve this problem. Cc: Eric Nelson <eric.nelson@boundarydevices.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-03-13hummingboard: Use the default CONFIG_SYS_PBSIZEFabio Estevam
Entering the maximum number of characters defined by CONFIG_SYS_CBSIZE into the console and hitting enter afterwards, causes a hang in the system because CONFIG_SYS_PBSIZE is not capable of storing the extra characters of the error message: "Unknown command '' - try 'help'". Use the default CONFIG_SYS_PBSIZE definition from config_fallbacks.h to solve this problem. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-03-13wandboard: Use the default CONFIG_SYS_PBSIZEFabio Estevam
2015-03-13mxs: Use the default CONFIG_SYS_PBSIZEFabio Estevam
2015-03-13mx25pdk: Use the default CONFIG_SYS_PBSIZEFabio Estevam
2015-03-13mx31pdk: Use the default CONFIG_SYS_PBSIZEFabio Estevam
Entering the maximum number of characters defined by CONFIG_SYS_CBSIZE into the console and hitting enter afterwards, causes a hang in the system because CONFIG_SYS_PBSIZE is not capable of storing the extra characters of the error message: "Unknown command '' - try 'help'". Use the default CONFIG_SYS_PBSIZE definition from config_fallbacks.h to solve this problem. Cc: Magnus Lilja <lilja.magnus@gmail.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Magnus Lilja <lilja.magnus@gmail.com>
2015-03-13mx35pdk: Use the default CONFIG_SYS_PBSIZEFabio Estevam
Entering the maximum number of characters defined by CONFIG_SYS_CBSIZE into the console and hitting enter afterwards, causes a hang in the system because CONFIG_SYS_PBSIZE is not capable of storing the extra characters of the error message: "Unknown command '' - try 'help'". Use the default CONFIG_SYS_PBSIZE definition from config_fallbacks.h to solve this problem. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2015-03-13mx51evk: Use the default CONFIG_SYS_PBSIZEFabio Estevam
2015-03-13mx53loco: Use the default CONFIG_SYS_PBSIZEFabio Estevam
Entering the maximum number of characters defined by CONFIG_SYS_CBSIZE into the console and hitting enter afterwards, causes a hang in the system because CONFIG_SYS_PBSIZE is not capable of storing the extra characters of the error message: "Unknown command '' - try 'help'". Use the default CONFIG_SYS_PBSIZE definition from config_fallbacks.h to solve this problem. Cc: Jason Liu <r64343@freescale.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Jason Liu <r64343@freescale.com>
2015-03-13mx6qarm2: Use the default CONFIG_SYS_PBSIZEFabio Estevam
2015-03-13mx6slevk: Use the default CONFIG_SYS_PBSIZEFabio Estevam
2015-03-13mx6sxsabresd: Use the default CONFIG_SYS_PBSIZEFabio Estevam
2015-03-05Merge branch 'master' of git://git.denx.de/u-bootStefano Babic
2015-03-05mx5: fix get_reset_causeStefano Babic
commit d9f43c8f5c1d7ed27c99a06be85a4bb64b2c73fb sets get_reset_cause() as static, but this conflicts with mx5 where its prototype is in sys_proto.h. Drop it from sys_proto.h and drop print_cpuinfo from mx53_loco, factorizing the call for this board. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Jason Liu <jason.hui@linaro.org>
2015-03-04ti: armv7: Move SPL SDRAM init to the right place, drop unused CONFIG_SPL_STACKSimon Glass
Currently in some cases SDRAM init requires global_data to be available and soon this will not be available prior to board_init_f(). Adjust the code paths in these cases to be correct. In some cases we had the SPL stack be in DDR as we might have large stacks (due to Falcon Mode + Environment). In these cases switch to CONFIG_SPL_STACK_R. In other cases we had simply been setting CONFIG_SPL_STACK into SRAM. In these cases we no longer need to (CONFIG_SYS_INIT_SP_ADDR is used and is also in SRAM) so drop those lines. Signed-off-by: Simon Glass <sjg@chromium.org> Tested on Beagleboard, Beagleboard xM Tested-by: Matt Porter <mporter@konsulko.com> Tested on Beaglebone Black, AM43xx GP EVM, OMAP5 uEVM, OMAP4 Pandaboard Tested-by: Tom Rini <trini@konsulko.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-03-04Make export interface support CONFIG_SYS_MALLOC_SIMPLESimon Glass
When CONFIG_SYS_MALLOC_SIMPLE is defined, free() is a static inline. Make sure that the export interface still builds in this case. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-03-04arm: spl: Allow board_init_r() to run with a larger stackSimon Glass
At present SPL uses a single stack, either CONFIG_SPL_STACK or CONFIG_SYS_INIT_SP_ADDR. Since some SPL features (such as MMC and environment) require a lot of stack, some boards set CONFIG_SPL_STACK to point into SDRAM. They then set up SDRAM very early, before board_init_f(), so that the larger stack can be used. This is an abuse of lowlevel_init(). That function should only be used for essential start-up code which cannot be delayed. An example of a valid use is when only part of the SPL code is visible/executable, and the SoC must be set up so that board_init_f() can be reached. It should not be used for SDRAM init, console init, etc. Add a CONFIG_SPL_STACK_R option, which allows the stack to be moved to a new address before board_init_r() is called in SPL. The expected SPL flow (for CONFIG_SPL_FRAMEWORK) is documented in the README. Signed-off-by: Simon Glass <sjg@chromium.org> For version 1: Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Bo Shen <voice.shen@atmel.com> Acked-by: Bo Shen <voice.shen@atmel.com> Acked-by: Heiko Schocher <hs@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-03-04dm: tegra: Enable driver model in SPL and adjust the GPIO driverSimon Glass
Use the full driver model GPIO and serial drivers in SPL now that these are supported. Since device tree is not available they will use platform data. Remove the special SPL GPIO function as it is no longer needed. This is all in one commit to maintain bisectability. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-03-04arm: spl: Avoid setting up a duplicate global data structureSimon Glass
This is already set up in crt0.S. We don't need a new structure and don't really want one in the 'data' section of the image, since it will be empty and crt0.S's changes will be ignored. As an interim measure, remove it only if CONFIG_DM is not defined. This allows us to press ahead with driver model in SPL and allow the stragglers to catch up. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-03-04arm: Reduce the scope of lowlevel_init()Simon Glass
This function has grown into something of a monster. Some boards are setting up a console and DRAM here in SPL. This requires global_data which should be set up in one place (crt0.S). There is no need for SPL to use s_init() for anything since board_init_f() is called immediately afterwards. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-03-04Merge branch 'master' of git://git.denx.de/u-boot-samsungTom Rini
2015-03-04Odroid U3: use common code for dram reservationPrzemyslaw Marczak
This commit removes the dram reservation from board file, because it is done in a common code. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-03-04Odroid-XU3: enable the last dram bank and reserve 22MiBPrzemyslaw Marczak
This commit enables the last DRAM bank and reserves the last 22 MiB of it, for the secure firmware. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Akshay Saraswat <akshay.s@samsung.com> Cc: Hyungwon Hwang <human.hwang@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-03-04board: samsung: reserve memory for the secure firmwarePrzemyslaw Marczak
Since more than one board requires memory reservation for the secure firmware, the reservation code can be made in a common code. Now, to reserve some part of the the last bank, board config should define: - CONFIG_TZSW_RESERVED_DRAM - len in bytes - CONFIG_NR_DRAM_BANKS - number of memory banks Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Akshay Saraswat <akshay.s@samsung.com> Cc: Hyungwon Hwang <human.hwang@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-03-04samsung: board: fix: Define loop iterator as an unsigned int to suppress gcc ↵Łukasz Majewski
4.8 warning This patch suppress following warning: board/samsung/common/board.c:95:32: warning: iteration 4u invokes undefined behavior [-Waggressive-loop-optimizations] addr = CONFIG_SYS_SDRAM_BASE + (i * SDRAM_BANK_SIZE); ^ board/samsung/common/board.c:94:2: note: containing loop about possible signed integer overflow at gcc 4.8.2 (odroid board) Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-03-03Prepare v2015.04-rc3v2015.04-rc3Tom Rini
2015-03-02mpc837xerdb: "fix Calling __hwconfig without a buffer" warningSinan Akman
Signed-off-by: Sinan Akman <sinan@writeme.com>
2015-03-02Merge branch 'xnext/zynqmp' of git://www.denx.de/git/u-boot-microblazeTom Rini
2015-03-02arm64: Add Xilinx ZynqMP supportMichal Simek
Add basic Xilinx ZynqMP arm64 support. Serial and SD is supported. It supports emulation platfrom ep108 and QEMU. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-03-02atngwmkii: convert to generic boardAndreas Bießmann
2015-03-02kconfig: remove unneeded U-Boot extension codeMasahiro Yamada
This code was introduced to support the multiple .config configuration in U-Boot. We do not need it any more. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-03-02serial: ns16550: Fix build error due to a typoAxel Lin
Fix trivial typo. Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Axel Lin <axel.lin@ingics.com>
2015-03-02MAINTAINERS, git-mailrc: Update my email addressTom Rini
2015-03-02armv7.h: Add <asm/io.h>Tom Rini
With a389531 we now call readl() from this file so add <asm/io.h> so that we have a prototype for the function. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-03-02Merge git://git.denx.de/u-boot-usbTom Rini
2015-03-02Merge git://git.denx.de/u-boot-pxaTom Rini
2015-03-02warp: Select BOUNCE_BUFFER and CMD_EXT optionsFabio Estevam
Add EXT2/EXT4 and BOUNCE_BUFFER support. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2015-03-02warp: Add USB Mass Storage supportFabio Estevam
With UMS support we are able to flash the eMMC from U-boot, which is very convenient. Add UMS support to make the eMMC flashing process easier. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2015-03-02mx6slevk: Provide a proper pad configuration for OTG1_ID pinFabio Estevam
Pass the same pad configuration as done in the kernel so that OTG1_ID pin can properly work in device mode. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-03-02MAINTAINERS: Add F: drivers/usb/gadget to DFU custodian responsibilityLukasz Majewski
After discussion during the last u-boot mini summit with USB maintainer - Marek Vasut - it has been decided, that gadget development should be coordinated by DFU custodian. Such patch formalizes current development status. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2015-03-02pxa: colibri_pxa270: integrate latest validated register settingsMarcel Ziswiler
Integrate latest validated register settings from Toradex WinCE BSP 4.2 working accross all module versions from early V1.x, V1.2D, V2.2B to V2.4A. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2015-03-02pxa: colibri_pxa270: remove CONFIG_ENV_ADDR_REDUNDMarcel Ziswiler
Usually not required for NOR flash. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2015-03-02pxa: colibri_pxa270: fix wrong comment about voipac ethernet chipMarcel Ziswiler
2015-03-02pxa: colibri_pax270: fix CONFIG_BOOTCOMMANDMarcel Ziswiler
While 'mmc init' is no longer required the address to bootm the kernel from NOR flash was wrong. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2015-03-02pxa: colibri_pxa270: avoid overwriting factory configuration blockMarcel Ziswiler
Specify a CONFIG_BOARD_SIZE_LIMIT of 256 KB in order to avoid overwriting the factory configuration block located at offset 0x40000 in NOR flash. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
