2015-12-01dm: pci: Disable PCI compatibility functions by defaultSimon Glass
We eventually need to drop the compatibility functions for driver model. As a first step, create a configuration option to enable them and hide them when the option is disabled. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-12-01dm: pci: Convert 'pci' command to driver modelSimon Glass
Adjust this command to use the correct PCI functions, instead of the compatibility layer. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-12-01pci: Move PCI header output code into its own functionSimon Glass
We want to share this code with the driver model version, so put it in a separate function. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-12-01pci: Use a separate 'dev' variable for the PCI deviceSimon Glass
In the 'pci' command, add a separate variable to hold the PCI device. When this code is converted to driver model, this variable will be used to hold a struct udevice instead. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-12-01pci: Use common functions to read/write configSimon Glass
Currently we use switch() and access PCI configuration via several functions, one for each data size. Adjust the code to use generic functions, where the data size is a parameter. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-12-01pci: Tidy up function comments in cmd_pci.cSimon Glass
The function comments use an old style and some are incorrect. Update them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-12-01dm: pci: Reorder functions in cmd_pci.cSimon Glass
Before converting this to driver model, reorder the code to avoid forward function declarations. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-12-01dm: pci: Move common auto-config functions to a common fileSimon Glass
Some functions will be used by driver model and legacy PCI code. To avoid duplication, put these in a separate, shared file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-12-01dm: pci: Rename pci_auto.c to pci_auto_old.cSimon Glass
This file should not be used with driver model as it has lots of legacy/ compatibility functions. Rename it to make this clear. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-12-01dm: pci: Add a comment about how to find struct pci_controllerSimon Glass
With driver mode, struct pci_controller is stored as uclass-private data. Add a comment to that effect. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-12-01pci: Refactor the pciinfo() functionSimon Glass
This function uses macros to output data. It seems better to use a table of registers rather than macro-based code generation. It also reduces the code/data size by 2KB on ARM. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-12-01pci: Use a separate variable for the bus numberSimon Glass
At present in do_pci(), bdf can either mean a bus number or a PCI bus number. Use separate variables instead to reduce confusion. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-12-01pci: Use a common return in command processingSimon Glass
Adjust the commands to return from the same place. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-12-01dm: tegra: pci: Convert tegra boards to driver model for PCISimon Glass
Adjust the Tegra PCI driver to support driver model and move all boards over at the same time. This can make use of some generic driver model code, such as the range-decoding logic. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2015-12-01dm: pci: Add a function to find the regions for a PCI busSimon Glass
This function looks up the controller and returns a pointer to each region type. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2015-12-01dm: pci: Add a function to get the controller for a busSimon Glass
A PCI bus may be a bridge device where the controller is the bridge's parent. Add a function to return the controller device, given a PCI device. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2015-12-01dm: pci: Add functions to emulate 8- and 16-bit accessSimon Glass
Provide a few functions to support using 32-bit access to emulate 8- and 16-bit access. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2015-12-01dm: pci: Support decoding ranges with duplicate entriesSimon Glass
At present we add a new resource entry for every range entry. But some range entries refer to configuration regions. To make this work, avoid adding two regions of the same type. The later ranges will overwrite the earlier (configuration) ones. There does not seem to be a way to distinguish the configuration ranges other than by ordering (as per the device tree binding). We could perhaps instead just store one region of each type in a simple array. Once we are sure that we don't need to support multiple regions, we could change this. It would be easier to do it when all drivers are converted to use driver model for PCI. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2015-12-01dm: pci: Set up the SDRAM mapping correctlySimon Glass
SDRAM doesn't always start at 0. Adjust the region mapping so that it works on platforms where SDRAM is somewhere else. This needs testing on other platforms. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2015-12-01dm: pci: Avoid a driver model build error with CONFIG_CMD_PCI_ENUMSimon Glass
This is not supported with driver model, so print a message instead of generating a build error. Rescanning PCI is not yet implemented. This function will be implemented later once some additional PCI driver model improvements are merged. It was confirmed on the mailing list that no one on the tegra side will miss this feature, so it is disabled for tegra. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2015-12-01dm: tegra: pci: Move CONFIG_PCI_TEGRA to KconfigSimon Glass
Move this option to Kconfig and fix up all users. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2015-12-01ARM: tegra: refactor common Kconfig optionsStephen Warren
This makes it easier to select common options in a single place, rather than having to add them separately for different SoCs or architectures. The lists of select statements are now also sorted for easy searching. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01x86: tsc: Move tsc_timer.c to drivers/timerBin Meng
To group all dm timer drivers together, move tsc timer to drivers/timer directory. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01x86: tsc: Remove legacy timer codesBin Meng
Now that we have converted all x86 boards to use driver model timer, remove these legacy timer codes in the tsc driver. Note this also removes the TSC_CALIBRATION_BYPASS Kconfig option, as it is not needed with driver model. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01x86: Convert to use driver model timerBin Meng
Convert all x86 boards to use driver model tsc timer. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01dm: timer: Avoid using timer before it is readySimon Glass
At present bootstage will try to read the timer very early after relocation. When driver model is used to provide the timer, we cannot read it until driver model is ready. Correct this by adding a separate stage for the post-relocation bootstage init. This fixes booting on chromebook_link. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com>
2015-12-01x86: tsc: Add driver model timer supportBin Meng
This adds driver model timer support to x86 tsc timer driver. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01x86: tsc: Use notrace from <linux/compiler.h>Bin Meng
Replace __attribute__((no_instrument_function)) with notrace from <linux/compiler.h>. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01x86: Remove MIN_PORT80_KCLOCKS_DELAYBin Meng
This is not referenced anywhere. Remove it, as well as tsc_base_kclocks and tsc_prev in the global data. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Fix 'Reomve' typo: Signed-off-by: Simon Glass <sjg@chromium.org>
2015-12-01dm: timer: Support 64-bit counterBin Meng
There are timers with a 64-bit counter value but current timer uclass driver assumes a 32-bit one. Modify timer_get_count() to ask timer driver to always return a 64-bit counter value, and provide an inline helper function timer_conv_64() to handle the 32-bit/64-bit conversion automatically. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-12-01timer: sandbox: Use device tree to pass the clock frequencyBin Meng
We should use device tree to pass the clock frequency of the timer instead of hardcoded in the driver codes. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01timer: altera: Remove the codes to get clock frequencyBin Meng
Since we have timer uclass to get clock frequency for us, remove the custom version in the altera timer driver. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01dm: timer: Implement pre_probe()Bin Meng
Every timer device needs to have a valid clock frequency and it can be specified in the device tree. Use pre_probe() to get this in the timer uclass driver. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01dm: timer: Fix several nitsBin Meng
This changes 'Timer' to 'timer' at several places. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-11-30Merge branch 'master' of git://git.denx.de/u-boot-atmelTom Rini
2015-11-30arm: at91/spl: atmel_sfr: move saic redirect to separate fileWenyou Yang
To make saic redirect code sharing with other SoCs, move the saic redirect code from SAMA5D4 particular file, mach-at91/armv7/sama5d4_devices.c to a separate file, mach-at91/atmel_sfr.c Move ATMEL_SFR_AICREDIR_KEY definition to sama5d4.h, because each SoC has its own value. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-11-30arm: at91/spl: matrix: use matrix slave id macrosWenyou Yang
To make matrix initialization code sharing with others, use the matrix slave id macros, instead of hard-coding. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-11-30arm: at91/spl: matrix: remove security peripheral select codeWenyou Yang
Remove the security peripheral select code, keep the default value in these registers, that is, the peripheral address space is configured as "Secured" access, it is suitable for SPL. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-11-30arm: at91/spl: matrix: remove matrix write protection codeWenyou Yang
On processor reset, the matrix write protection is disabled, so no need to disable/enable write protection when writing the matrix registers. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-11-30arm: at91/spl: matrix: move matrix init to separate fileWenyou Yang
To make the matrix initialization code sharing with other SoCs, move it from SAMA5D4 particular file, mach-at91/armv7/sama5d4_devices.c to a separate file, mach-at91/matrix.c Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-11-30arm: atmel: Add SAMA5D2 Xplained boardWenyou Yang
The board supports following features: - Boot media support: SD card/e.MMC/SPI flash, - Support LCD display (optional, disabled by default), - Support ethernet, - Support USB mass storage. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> [fix checkpatch warnings] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-11-30gpio: atmel: Add the PIO4 driver supportWenyou Yang
The PIO4 is introduced from SAMA5D2, as a new version for Atmel PIO controller. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
2015-11-30Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2015-11-30armv8: fsl-layerscape: Fix early MMU table for nand bootYork Sun
The early MMU table doesn't enable all addresses. Unused addresses are marked as invalid, as introduced by commit 9979922. An entry was missing for NAND flash space, causing nand boot failure. Signed-off-by: York Sun <yorksun@freescale.com> CC: Alison Wang <alison.wang@freescale.com> CC: Prabhakar Kushwaha <prabhakar@freescale.com>
2015-11-30armv8: ls2080a: Define CONFIG_ENV_OVERWRITE to overwrite serial and ethaddrAlison Wang
As the environment variables "serial#" and "ethaddr" need to be overwriten by the users, CONFIG_ENV_OVERWRITE is defined to disable the write protection. Anybody can change or delete these parameters. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-11-30net: phy: added aquantia PHY AQR405 supportShaohui Xie
The phy can share driver with other aquantia PHYs, so we only add PHY ID. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-11-30armv8: ls2085a: Add workaround of errata A009635Prabhakar Kushwaha
If the core runs at higher than x3 speed of the platform, there is possiblity about sev instruction to getting missed by other cores. This is because of SoC Run Control block may not able to sample the EVENTI(Sev) signals. Configure Run Control and EPU to periodically send out EVENTI signals to wake up A57 cores. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-11-30board/ls2080qds: Fix typo in README for QSGMII riser cardPrabhakar Kushwaha
DPMACx to PHY mapping for SGMII is mentioned as QSGMII. So fix typo in README for QSGMII rise card. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> [York Sun: Change from ls2085aqds to ls2080aqds] Reviewed-by: York Sun <yorksun@freescale.com>
2015-11-30arm: ls102xa: Update fdt_high and initrd_high for LS1021AQDS boardAlison Wang
As 3G/1G user/kernel memory split is used on LS1021A, the Linux kernel fails to access the device tree blob on boot. The reason is that u-boot relocates the device tree blob into high memory when booting the kernel and the kernel is unable to access the blob. To avoid this issue, fdt_high is set to the value of 0xffffffff. The device tree blob will not get relocated and is still in low memory to make it accessible to the kernel. For the same reason, initrd_high is set to the value of 0xffffffff too. This patch is to update fdt_high and initrd_high for LS1021AQDS board. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-11-30armv8: fsl-layerscape: Fix "cpu release" commandYork Sun
When one core is released, other cores may not have valid entry address. Those cores are trapped by "wfe" and wait for further instruction. When their address is set, they need to be kicked off by "sev". Signed-off-by: York Sun <yorksun@freescale.com>
