The ARM ABI requires that the stack be aligned to 8 bytes as it is noted
in Procedure Call Standard for the ARM Architecture:
http://infocenter.arm.com/help/topic/com.arm.doc.ihi0042d/index.html
Unaligned SP also causes the problem with variable-length arrays
allocation when VLA address becomes less than stack pointer during
aligning of this address, so the next 'push' in the stack overwrites
first 4 bytes of VLA.
Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
Move it inside the #ifdef CONFIG_NET_MULTI to avoid
eth.c:64: warning: 'eth_mac_skip' defined but not used
messages from a number of old, non-CONFIG_NET_MULTI boards.
TFTP'ing a file of size 1747851 bytes with CONFIG_IP_DEFRAG and
CONFIG_TFTP_BLOCKSIZE set to 4096 fails with a timeout, because
the last fragment is not taken into account. This patch fixes
IP fragments having less than 8 bytes of payload.
Signed-off-by: Stephane Fillod <stephane.fillod@grassvalley.com>
Acked-by: Alessandro Rubini <rubini@gnudd.com>
messages from anumber of old, non-CONFIG_NET_MULTI boards.
Cc: Ben Warren <biggerbadderben@gmail.com>
Commit 37566090 "compiler.h: unify system ifdef cruft here" added both
a "#include <errno.h>" and a "extern int errno;" to include/compiler.h
which is causing build warnings for some systems, for example for the
"netstar" board:
In file included from /home/wd/git/u-boot/work/lib/crc32.c:15:
include/compiler.h:28: warning: function declaration isn't a prototype
The declaration of "errno" should be redundant, as <errno.h> is
supposed to provide a correct declaration, so drop it.
Cc: Mike Frysinger <vapier@gentoo.org>
The push / pop instructions used in this file are available only with
more recent tool chains:
cache.S: Assembler messages:
cache.S:133: Error: bad instruction `push {r0,r1,r2,lr}'
cache.S:160: Error: bad instruction `pop {r1,r2,r3,pc}'
cache.S:164: Error: bad instruction `push {r0,r1,r2,lr}'
cache.S:191: Error: bad instruction `pop {r1,r2,r3,pc}'
Change push/pop into stmfd/ldmfd instructions to support older
versions of binutils as well.
I verified that the modified source code generates exactly the same
binary code.
Cc: Sandeep Paulraj <s-paulraj@ti.com>
Cc: Tom Rix <tom@bumblecow.com>
CONFLICT (rename/add): Rename
board/davinci/da830evm/Makefile->board/ti/tnetv107xevm/Makefile
in 89b765c7f6ddfde07ba673dd4adbeb5da391a81b.
board/ti/tnetv107xevm/Makefile added in HEAD
But files were identical, so no problem.
This patch adds support for the LaCie ED Mini V2 product
which is based on the Marvell Orion5x SoC.
Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
This patch provides access to the 16550-compatible
serial device of the Orion5x SoC.
This patch adds support for the Marvell Orion5x SoC.
It has no use alone, and must be followed by a patch
to add Orion5x support for serial, then support for
the ED Mini V2, an Orion5x-based product from LaCie.
Acked-by: Tom <Tom@bumblecow.com>
This patch adds support for the Samsung Goni board (S5PC110 SoC)
When set to PULL_NONE, gpio_set_pull function is returned without write the register.
This patch fixed it.
Part of this patch is by: Mikhail Kshevetskiy.
Stack must be aligned to 8 bytes on PXA (possibly all armv5te) for LDRD/STRD
instructions. In case LDRD/STRD is issued on an unaligned address, the behaviour
is undefined.
The issue was observed when working with the NAND code, which was rendered
disfunctional. Also, the vsprintf() function had serious problems with printing
64bit wide long longs. After aligning the stack, this wrong behaviour is no
longer present.
Tested on:
Marvell Littleton PXA310 board
Toradex Colibri PXA320 board
Aeronix Zipit Z2 PXA270 handheld
Voipac PXA270 board
Provides initial support for TI OMAP-L138/DA850 SoC devices on
a Logic PD EVM board.
Provides:
Initial boot and configuration.
Support for i2c.
UART support (console).
Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Acked-by: Ben Gardiner <bengardiner@nanometrics.ca>
Reviewed-by: Wolfgang Denk <wd@denx.de>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
DA850/OMAP-L138 is a new SoC from Texas Instruments
(http://focus.ti.com/docs/prod/folders/print/omap-l138.html).
This SoC is similar to DA830/OMAP-L137 in many aspects. Hence
rename the da830 specific files and folders to da8xx to
accommodate DA850/OMAP-L138.
TI's DA850/OMAP-L138 platform is similar to DA830/OMAP-L137
in many aspects. So instead of repeating the same code in
multiple files, move the common code to a different file
and call those functions from the respective da830/da850
files.
Acked-by: Nick Thompson <nick.thompson@ge.com>
Pandora has a capacitor connected as backup battery, which allows
retaining RTC for some time while main battery is removed. Enable backup
battery charge function to charge that capacitor.
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
I have updated this patch based on the comments [1] by Wolfgang Denk and
removed unused variables.
[1][http://lists.denx.de/pipermail/u-boot/2010-May/071728.html]
Reduce the number of reads per byte transferred on the BUF register from 2 to 1 and
take advantage of the TX buffer in the SPI module. On LogicPD OMAP-L138 EVM,
SPI read throughput goes up from ~0.8Mbyte/s to ~1.3Mbyte/s. Tested with a 2Mbyte image file.
Remove unused variables in the spi_xfer() function.
Signed-off-by: Delio Brignoli <dbrignoli@audioscience.com>
Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
This patch adds support for the EMIF4 interface
available in the AM35x processors.
Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com>
Signed-off-by: Sanjeev Premi <premi@ti.com>
This patch adds basic support for the AM3517EVM.
It includes:
- Board files (.c and .h)
- Default configuration file
- Updates for Makefile
Consolidated SDRC related functions into one file - sdrc.c
And also replaced sdrc_init with generic memory init
function (mem_init), this generalization of omap memory setup
is necessary to support the new emif4 interface introduced in AM3517.
initialized for CS1
The patch makes sure that size for SDRC CS1 gets calculated
only when the CS1 SDRC is initialized.
The EVMS have been shipping with NAND (instead of OneNAND) as default.
So, this patch sets NAND as default.
To choose OneNAND, define CMD_ONENAND instead of CMD_NAND in the
config file omap3_evm.h.
TNETV107X is a Texas Instruments SoC based on an ARM1176 core, and with a
bunch on on-chip integrated peripherals. This patch adds support for the
TNETV107X EVM board.
Signed-off-by: Cyril Chemparathy <cyril@ti.com>
bunch on on-chip integrated peripherals. This is an initial commit with
basic functionality, more commits with drivers, etc. to follow.
The current ARM1176 CPU specific code is too specific to the SMDK6400
architecture. The following changes were necessary prerequisites for the
addition of other SoCs based on ARM1176.
Existing board's (SMDK6400) configuration has been modified to keep behavior
unchanged despite these changes.
1. Peripheral port remap configurability
The earlier code had hardcoded remap values specific to s3c64xx in start.S.
This change makes the peripheral port remap addresses and sizes configurable.
2. U-Boot code relocation support
Most architectures allow u-boot code to run initially at a different
address (possibly in NOR) and then get relocated to its final resting place
in RAM. Added support for this capability in ARM1176 architecture.
3. Disable TCM if necessary
If a ROM based bootloader happened to have initialized TCM, we disable it here
to keep things sane.
4. Remove unnecessary SoC specific includes
ARM1176 code does not really need this SoC specific include. The presence
of this include prevents builds on other ARM1176 archs.
5. Modified virt-to-phys conversion during MMU disable
The original MMU disable code masks out too many bits from the load address
when it tries to figure out the physical address of the jump target label.
Consequently, it ends up branching to the wrong address after disabling the
MMU.
It includes:
initialized for CS1
MMU.
Add the new board PM9G45 from Ronetix GmbH.
* AT91SAM9G45 MCU at 400Mhz.
* 128MB DDR2 SDRAM
* 256MB NAND
* 10/100 MBits Ethernet DP83848
* Serial number chip DS2401
The board is made as SODIMM200 module.
For more info www.ronatix.at or info@ronetix.at.
Signed-off-by: Asen Dimov <dimov@ronetix.at>
This patch changed the SICRL_USBDR define to reflect the 4 different bit
settings for this two-bit field. The four different options are '00', '01',
'10', and '11'. This patch also corrects the config file for SIMPC8313 and
MPC8313ERDB for the appropriate fields. This change only affects the MPC8313
cpu.
Signed-off-by: Ron Madrid <ron_madrid@sbcglobal.net>
The ARM1136 cache_flush() function uses the "mcr p15, 0, rn, c7, c7, 0"
instruction which means "Invalidate Both Caches" when in fact the intent
is to clean and invalidate all caches. So add an "mcr p15, 0, %0, c7,
c10, 0" instruction to "Clean Entire Data Cache" prior to the "Invalidate
Both Caches" instruction to insure that memory is consistent with any
dirty cache lines.
Also fix a couple of "flush v*" comments in ARM1136 cpu_init_crit() so
that they correctly describe the actual ARM1136 CP15 C7 Cache Operations
used.
Signed-off-by: George G. Davis <gdavis@mvista.com>
Add sec3.1 h/w geometry for fdt node fixups.
Also, technically, whilst SEC v3.3 h/w honours the tls_ssl_stream descriptor
type, it lacks the ARC4 algorithm execution unit required to be able
to execute anything meaningful with it. Change the node to agree with
the documentation that declares that the sec3.3 really doesn't have such
a descriptor type.
Reported-by: Haiying Wang <Haiying.Wang@freescale.com>
The ngPIXIS is a board-specific FPGA, but the definition of the registers
is mostly consistent. On boards where it matter, register 9 is called
'brdcfg1' instead of 'dma', so rename the variable in the ngpixis_t
definition.
Add the 'clkdvdr' and 'pmuxcr2' registers to the 85xx definition of
struct ccsr_gur.
