2003-02-14Add "pcidelay" environment variable (in ms, enabled via CONFIG_PCI_BOOTDELAY).stroese
2003-02-11Cleanup: remove trailing white spacewdenk
2003-02-10Add support for 4MB and 128MB onboard SDRAM (cpu/ppc4xx/sdram.c)stroese
2003-02-10Added 4MByte and 128MByte onboard SDRAMstroese
2003-01-17* Add dual ethernet support on PM826wdenk
* Add support for LXT971 PHY on PM826 * Patch by Tord Andersson, 16 Jan 2003: Fix flash sector count for TQM8xxL * Fix I2C EEPROM problem on ICU862 board (would only write the first 16 bytes out of each 32 byte block)
2003-01-13Add support for V37 boardLABEL_2003_01_14_0055wdenk
(patch by Jón Benediktsson, 11 Dec 2002)
2003-01-11* Restrict baudrate settings on LWMON to higher speedsLABEL_2003_01_11_1050wdenk
when watchdog is on * Update baudrate in bd_info when it gets changed * Add watchdog trigger points while waiting for serial port (so far only 8xx -- needed on LWMON with 100ms watchdog) * Improve command line tool to access the U-Boot's environment (figuration of the utility, using a config file)
2003-01-02Patch by Detlev Zundel, 30 Dec 2002:wdenk
Add single quote support for (old) command line parser
2002-12-28Adjust LWMON environment to current requirementsLABEL_2002_12_28_1700wdenk
2002-12-20* Switch LWMON board default config from FRAM to EEPROM;LABEL_2002_12_21_0040wdenk
in POST, EEPROM shows up on 8 addresses
2002-12-17*** empty log message ***U-Boot-0_2_0wdenk
2002-12-17Prepare for release of version 0.2.0wdenk
2002-12-17* Use 1-byte-read instead of -write for iprobe() functionwdenk
Add i2c commands to PM826 config * extend I2C POST code: check for list on known addresses
2002-12-08* Improve log buffer code; use "loglevel" to decide which messageswdenk
to log on the console, too (like in Linux); get rid of "logstart"
2002-12-07* Patch by Hans-Joerg Frieden, 06 Dec 2002LABEL_2002_12_07_0120wdenk
Fix misc problems with AmigaOne support * Patch by Chris Hallinan, 3 Dec 2002: minor cleanup to the MPC8245 EPIC driver * Patch by Pierre Aubert , 28 Nov 2002 Add support for external (SIU) interrupts on MPC8xx * Patch by Pierre Aubert , 28 Nov 2002 Fix nested syscalls bug in standalone applications * Patch by David Müller, 27 Nov 2002: fix output of "pciinfo" command for CardBus bridge devices. * Fix bug in TQM8260 board detection - boards got stuck when board ID was not readable
2002-12-04Add LED indication for IDE activity on KUP4K boardwdenk
2002-12-03* Fix startup problems with VFD display on TRABLABEL_2002_12_03_2230wdenk
* Patch by Pierre Aubert, 20 Nov 2002 Add driver for Epson SED13806 graphic controller. Add support for BMP logos in cfb_console driver.
2002-11-21* Added support for both PCMCIA slots (at the same time!) on MPC8xxLABEL_2002_11_22_0015wdenk
* Patch by Rod Boyce, 21 Nov 2002: fix PCMCIA on MBX8xx board * Patch by Pierre Aubert , 21 Nov 2002 Add CFG_CPM_POST_WORD_ADDR to make the offset of the bootmode word in DPRAM configurable
2002-11-19* Patch by Daniel Engström, 18 Nov 2002:wdenk
Fixes for x86 port (mostly strings issues) * Patch by Ken Chou, 18 Nov 2002: Fix for natsemi NIC cards (DP83815) * Patch by Pierre Aubert, 19 Nov 2002: fix a bug for the MII configuration, and some warnings
Add code for AmigaOne board (preliminary merge to U-Boot, still WIP)
2002-11-18* Patch by Daniel Engström, 13 Nov 2002:LABEL_2002_11_18_0115wdenk
Add support for i386 architecture and AMD SC520 board * Patch by Pierre Aubert, 12 Nov 2002: Add support for DOS filesystem and booting from DOS floppy disk
2002-11-11* Patch by Jim Sandoz, 07 Nov 2002:LABEL_2002_11_11_2211wdenk
Increase number of network RX buffers (PKTBUFSRX in "include/net.h") for EEPRO100 based boards (especially SP8240) which showed "Receiver is not ready" errors when U-Boot was processing the receive buffers slower than the network controller was filling them. * Get rid of obsolete include/mpc74xx.h
2002-11-11* Patch by Andreas Oberritter, 09 Nov 2002:wdenk
Change behaviour of NetLoop(): return -1 for errors, filesize otherwise; return code 0 is valid an means no file loaded - in this case the environment still gets updated! * Patches by Jon Diekema, 9 Nov 2002: - improve ADC/DAC clocking on the SACSng board to align the failing edges of LRCLK and SCLK - sbc8260 configuration tweaks - add status LED support for 82xx systems - wire sspi/sspo commands into command handler; improved error handlering - add timestamp support and alternate memory test to the SACSng configuration
2002-11-10* Vince Husovsky, 7 Nov 2002:LABEL_2002_11_10_2310wdenk
Add "-n" to linker options to get rid of "Not enough room for program headers" problem * Patch by David Müller, 05 Nov 2002 Rename CONFIG_PLL_INPUT_FREQ to CONFIG_SYS_CLK_FREQ so we can use an already existing name * Patch by Pierre Aubert, 05 Nov 2002 Hardware related improvements in FDC boot code * Patch by Holger Schurig, 5 Nov 2002: Make the PXA really change it's frequency * Patch by Pierre Aubert, 05 Nov 2002 Add support for slave serial Spartan 2 FPGAs * Fix uninitialized memory (MAC address) in 8xx SCC/FEC ethernet drivers
2002-11-05Quick & Dirty fix for log buffer problem when environment is not setwdenk
Trigger watchdog when reading the env - this might take a while. Set debugging baud rate for KUP4K board
2002-11-05* Add support for log buffer which can be passed to Linux kernel'sLABEL_2002_11_05_1735wdenk
syslog mechanism; used especially for POST results. * Patch by Klaus Heydeck, 31 Oct 2002: Add initial support for kup4k board
2002-11-05* Patch by Robert Schwebel, 04 Nov 2002:LABEL_2002_11_05_0120wdenk
- use watchdog to reset PXA250 systems - added progress callbacks to (some of the) ARM code - update for Cogent CSB226 board * Add support for FPS860 board
2002-11-04Patch by Guillaume Alexandre,, 04 Nov 2002:wdenk
Improve PCI access on 32-bits Compact PCI bus Adjust VFD initialization on TRAB Cleanup RRvision video code
2002-11-03* Fix mdelay() on TRAB - this was still the debugging version withwdenk
seconds instead of ms. * Patch by Robert Schwebel, 1 Nov 2002: XScale related cleanup (affects all ARM boards) * Cleanup of names, warnings and README.
seconds instead of ms. * Patch by Robert Schwebel, 1 Nov 2002: XScale related cleanup (affects all ARM boards) * Cleanup of names, warnings, and README.
2002-11-01Initial revisionwdenk
2002-10-31Initial revisionwdenk
