- EPDC Splash support for MX6DL/S Sabre SD
- EPDC Splash support for MX6DL/S ARM2
- Currently, splash screen consists of a simple black border
around a white screen. Done this way to save in memory footprint.
Signed-off-by: Danny Nold <dannynold@freescale.com>
Fix the PAD_LVE implementation used on MX6SL.
Signed-off-by: Mahesh Mahadevan <mahesh.mahadevan@freescale.com>
- move recovery.h to common inlcude place.
- move supported_reco_envs to soc related, not board related,
- user can change this via configure header,
don't needs this in every board file.
- pass build for all mx5/mx6 android configs.
Signed-off-by: Zhang Jiejing <jiejing.zhang@freescale.com>
- add android build config for mx6sl_arm2 board.
- add gpio support for mx6sl
- add boot image support
- add android recovery support
- add fastboot support, but fastboot cannot transfer file.
Signed-off-by Zhang Jiejing <jiejing.zhang@freescale.com>
Add support for MX6SL mfgtools firmware support
Signed-off-by: Frank Li <Frank.Li@freescale.com>
cleanup android fastboot and udc build warnnings.
Add generic gpio interface in uboot.
Seems more and more gpio operation invoke in uboot,
without RAW register operation, we should
use generic gpio interface.
you should define the CONFIG_MXC_GPIO
use generic gpio interface:
gpio_request,
gpio_direction_output,
gpio_direction_input,
gpio_set_value,
gpio_get_value, etc.
Test on MX6Q, MX6DL.
Other MX6X should also define this config.
Original pad configuration don't provide enough bitfield width to hold
all necessary information. For MX6Sololite, a "PAD_CTL_LVE" is needed
to be configed for many pins.
iomux_v3_cfg_t is re-orgnized to address this issue. PAD_CTRL is
extended by 1 bit to hold the "PAD_CTL_LVE". Which is mapped to proper
bit location when configure the PAD config register.
Signed-off-by: Mahesh Mahadevan <r9aadq@freescale.com>
set IPU AXI-id0 Qos=0xf(bypass) and AXI-id1 Qos=0x7,
mx6q use AXI-id0 for IPU display channel, it should has
highest priority(bypass), and AXI-id1 for other IPU channel,
it has high priority.
Signed-off-by: Wayne Zou <b36644@freescale.com>
In order to support one uImage for the i.mx6 soc family, the bootloader
must need fix up the load/entry address by adding the offset 0x70000000
for MX6SL parts due to the ddr physical address start from 0x80000000 on
MX6SL,but 0x10000000 for the soc other than i.mx6sl
Signed-off-by: Jason Liu <r64343@freescale.com>
1. add check asrc register to enter recovery mode,
rather then check the file.
2. fix the boot.img can not fastboot flash function.
3. consolidate and cleanup fastboot code.
4. clean up many build warnning message.
align vid, pid to let windows fastboot driver can be install.
This issue have been found in mx53_smd(ENGR00163704), and found in sabresd
if accessing pfuze while system reboot or reset, I2C bus will be blocked
even if reboot,then pfuze will be failed to be probed, all device driver
which use pfuze regulator will be impacted. In u-boot, we can check the
SDA line low or high, if low, generate SCL and STOP signal to tell I2C
device release I2C bus. Please check ENGR00163704
Signed-off-by: Robin Gong <B38343@freescale.com>
fix mx6dl usb init issue, due to leak of reset phy,
it was only called on MX6Q.
Signed-off-by: Shi Make <make.shi@freescale.com>
1.fix build error :
mx6q_sabresd.c: In function 'setup_i2c':
mx6q_sabresd.c:382: error: expected ')' before ';' token
mx6q_sabresd.c:393: error: expected ';' before '}' token
mx6q_sabresd.c: In function 'setup_pmic_voltages':
mx6q_sabresd.c:399: warning: unused variable 'val'
make[1]: *** [mx6q_sabresd.o] Error 1
2.modify mx6dl_sabresd_config to support pfuze on mx6dl sabresd board
add pfuze and I2C support, support cpu internal LDO bypass which can be
enabled by CONFIG_MX6_INTER_LDO_BYPASS
Set default boot to SD Card
Signed-off-by: Prabhu Sundararaj <b36876@freescale.com>
Since FEC_RX_ER is not connected with PHY(LAN8720A), we need
either configure FEC_RX_ER PAD to other mode than FEC_RX_ER,
or configure FEC_RX_ER PAD to FEC_RX_ER but need pull it down,
otherwise, FEC MAC will report CRC error always. We configure
FEC_RX_ER PAD to GPIO mode here and remove the SW hack which
ignore the CRC error in fec driver
This patch is to add the initial support for i.mx6sl ARM2 board, the patch does:
- implemention of LPDDR2 init script
- Plug-in/DCD mode support to do DDR initialization
- Debug UART(UART1) support
- SPI-NOR(M25P32, 4MB) flash support
- FEC support, PHY(LAN8720A, RMII mode)
- SD/MMC card support, SD1/SD2/SD3
Signed-off-by: Fugang Duan <B38611@freescale.com>
Signed-off-by: Terry Lv <r65388@freescale.com>
Signed-off-by: Nancy Chen <Nancy.Chen@freescale.com>
Signed-off-by: Eric Sun <jian.sun@freescale.com>
Add EPDC splash screen support for U-Boot
This patch is to add the initial support for Freescale i.mx6sl chip.
i.mx6sl is the SoloLite verison of Freescale i.mx6 family.
The patch does:
- memory layout support,
- iomux support,
- clock support,
Signed-off-by: Ryan QIAN <b32804@freescale.com>
add fastboot function back in MX6Q_SABERSD board.
the MX6DL_SABERSD have usb init related issue which will
keep RESET, but left as later developement.
The MC13892 is a Power Controller used with processors
of the family MX.51. The file adds definitions to be used to setup
the internal registers via SPI.
IMX processors has a slightly different interface
to access GPIOs and do not make use of the provided GPIO
framework. The patch substitutes mxc_ specific
functions and make use of the API in asm/gpio.h
Since we want want to have a standard GPIO interface, this adds a definition
for this into include/asm-generic/gpio.h.
This fixes write access to PMIC registers, the bug was
introduced partly in commit 64aac65099 and in commit c9fe76dd91.
It was tested on an i.mx31 with a mc13783.
Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
Instead of using directly the i2c_set_bus() function,
the I2C_SET_BUS macro must be used to avoid build
errors for targets without multibus I2C.
I2C or SPI PMIC devices can be accessed.
Separate files: pmic_i2c.c and pmic_spi.c are responsible
for handling transmission over I2C or SPI bus.
New flags:
CONFIG_PMIC - enable PMIC general device.
CONFIG_PMIC_I2C/SPI - specify the interface to be used.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
The patch add supports for the Freescale's Power
Management Controller (known as Atlas) used together with i.MX31/51
processors. It was tested with a MC13783 (MX31) and
MC13892 (MX51).
For example: The soc rev on i.mx6dl rev 1.0 not print correctly:
CPU: Freescale i.MX 6 family 0.0V at 792 MHz
This patch help u-boot print out the SOC revision correctly:
CPU: Freescale i.MX6 family TO1.0 at 792 MHz
This patch will add the splash screen support for the
i.mx6q/dl splash screen support.
In order to enable the splash screen, you need make sure
the following env variable has been set correctly:
splashimage=0x30000000
splashpos=m,m
lvds_num=0
The splash screen is default OFF, to enable it, please add:
on i.mx6dq sabresd platform:
define CONFIG_SPLASH_SCREEN in include/configs/mx6q_sabresd.h
or on i.mx6dl sabresd platform:
define CONFIG_SPLASH_SCREEN in include/configs/mx6dl_sabresd.h
Remove the dead definiton which never used by iomux-v3 framework
And move the SION bit definiton to arch-mx6/iomux-v3.h for sharing
NO_PAD_I/NO_PAD_MUX not defined correctly, which will cause build error.
And According to iomux-v3.h, the NO_PAD_I/NO_PAD_MUX should be 0 for the
pins which does not have PAD/MUX config.
Need set Power Supply Glitch to 0x41736166 and clear Power Supply Glitch
Detect bit when POR or reboot or power on, otherwise system could not be
power off anymore, it will power up auto agian. These steps may be move to
ROM code or fix by soc team in the future(PDM ticket number:TKT104835),
anyway,u-boot fix the issue firsly.
Signed-off-by: Robin Gong <b38343@freescale.com>
-Added u-boot config CONFIG_CMD_WEIMNOR for MX6Solo/Quad SABREAUTO to
support WEIM NOR.
- CONFIG_FLASH_HEADER_OFFSET is 0x1000 for WEIM NOR.
-SPI NOR and WEIM NOR has pin conflicts, either one can be enabled.
- mx6q_sabreauto_config, mx6solo_sabreauto_config configured default
for SPI NOR.
-In order to enable the read/write commands and to boot from WEIM NOR,
need to enable the CONFIG_CMD_WEIMNOR. This will disable SPI-NOR
Before running authentication on uImage in DDR, u-boot first check if
SEC_CONFIG[1] (OTP_CFG5[1]) is burned. If so, it means the chip is in
secure configuration, the authentication continues; if not, the chip
in not in secure configuration, just bypass the authentication
* In RevB boards a steer logic circuit enables the
route path of I2C3_SDA signal and is controlled by
EIM_A24__GPIO_5_4 pad.
* Configure GPIO_5_4 as as output and enable steer logic
circuit.
Signed-off-by: Adrian Alonso <aalonso@freescale.com>
Security boot need to use fuse item. Thus it should not be enabled as
default.
authenticate_image is called to verify uImage when excecuting "bootm", the
uImage togehter with its CSF data should has been located in DDR.
The new uImage layout is as the following:
+------------+ 0x0 (0x10800000) \
| Header | |
+------------+ 0x40 |
| Image Data | |
. | > Stuff to be authenticated ------+
| Fill Data | | |
+------------+ 0x003F_DFE0 | |
| IVT | | |
+------------+ 0x003F_E000 / |
| CSF DATA | <--------------------------------------------------------+
| Fill Data |
+------------+ 0x0040_0000
The first stage of High Assurance Boot (HAB) is the authentication of
U-boot. A CST tool is used to generate the CSF data, which include
public key, certificate and instruction of authentication process. Then
it is attached to the original u-boot.bin
The IVT should be modified to contain a pointer to the CSF data. The original
u-boot.bin is with size between 0x27000 to 0x28000. For convinence, we first
extend the u-boot.bin to 0x2F000 (with fill 0xFF). Then concatenate it with
the CSF data. The combined image is again extend to a fixed length (0x31000),
which is used as the IVT size parameter.
The new memory layout is as the following.
U-Boot Image
| Blank |
|-------------| 0x400
| IVT |-----------------------+
|Remaining UB | | CSF pointer
| Fill Data | |
|-------------| 0x2F000 <-------------+
| CSF Data |
| Fill Data |
+-------------+ 0x31000
HAB APIs are ROM implemented, the entry table is located in a fixed
location in the ROM. We export them so that during the HAB we can
have some information about the secure boot process. For convinience
some wrapper API is implemented based on the HAB APIs.
- get_hab_status : used to dump information of authentication result
- authenticate_image : used by u-boot to authenticate uImage
For security hardware to function, CAAM related clock (CG0[4~6]) must
be open. They are default closed in the original U-boot.
"hab_caam_clock_enable" and "hab_caam_clock_disable" are created to
open and close these clock gates.
The generation of CSF data is not in the scope of this patch. CST tool
will be used for this purpose. The procedure will be introduced in
another document.
- Enable below macro define for all chip. Firstly, the marcos
will be used in later version for later i.MX. Secondly, fix
the build error in the former i.MX series chip before i.MX6.
#define PHY_MIPSCR_LINK_UP (0x1 << 10)
#define PHY_MIPSCR_SPEED_MASK (0x3 << 14)
#define PHY_MIPSCR_1000M (0x2 << 14)
#define PHY_MIPSCR_100M (0x1 << 14)
#define PHY_MIPSCR_FULL_DUPLEX (0x1 << 13)
- Different chip will include different head file, so add macro
define to limit the use range.
This patch is used to integrate DDR3 script V1.1 of mx6solo
sabreauto MX6DL_init_DDR3_400MHZ_32bit_sabre_1_1.inc under
http://compass.freescale.net/livelink/livelink?func=ll&objid
=225128962&objAction=browse&sort=name
Signed-off-by: Lily Zhang <r58066@freescale.com>
Add "nosmp arm_freq=800" options for mx6solo sabreauto board
by default
add android config file;
support booti fastboot command and etc.
Signed-off-by: Lin Fuzhen <fuzhen.lin@freescale.com>
As per JEDEC document JESD84-A441 (page 105) response for CMD7
(MMC_CMD_SELECT_CARD) response should be R1 instead of R1b. In uboot we
never take MMC to disconnected state and on powerup its always ideal
state which later goes to stand-by state.
from document footnote:
R1 while selecting from Stand-By State to Transfer State; R1b while
selecting from Disconnected State to Programming State.
Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
Remove MMDC1 setting from DDR script of mx6solo sabreauto
if it's not used.
SPI NOR flash(m25p32-vmw6tg) not probed and function as expected, this
due to the lack of iomux pad config and incorrect CS line.
This patch fix the above issue and also fix the mfg config file
(For the code readable, I intent to omit the following checkpatch warning:
in the iomux/mx6_pins.h WARNING: line over 80 characters)
- i.mx6q sabresd revA ethernet phy addr is 0 (PHYADDRESS1-PHYADDRESS0:00)
, but revB ethernet phy address is 0x1 (PHYADDRESS1-PHYADDRESS0:01).
To avoid to change hardware, add auto discover phy address configuration.
