Signed-off-by: Wolfgang Grandegger <wg@denx.de>
Cc: Remy Bohmer <linux@bohmer.net>
Cc: Wolfgang Grandegger <wg@denx.de>
Cc: Jason Liu <r64343@freescale.com>
This is useful for USB Transceivers init etc.
It's derived from ehci-mxc and uses the header files of the
ehci-fsl interface. The callback board_ehci_hcd_init() has
been introduced to allow for board-specific setup when USB
is started.
CC: Stefano Babic <sbabic@denx.de>
CC: Remy Bohmer <linux@bohmer.net>
V2: Fix spacing in crm_regs.h
This commit enables support for USB Gadgets on the GONI
reference target.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
This commit provides UDC driver support for Samsung's SoC
family of processors.
According to EHCI specification v1.0, the controller should stabilize
the power on a port at most 20 ms after the port power bit transition.
So, we put this setting in the virtual descriptor corresponding field,
(bPwrOn2PwrGood = 10 => 10 x 2ms = 20ms), this saves about 500ms at each
controller initialization/enumeration.
Signed-off-by: Vincent Palatin <vpalatin@chromium.org>
Signed-off-by: Veli-Pekka Peltola <veli-pekka.peltola@bluegiga.com>
The usb_endpoint_descriptor struct is 7 bytes large and is
defined as an array (ep_desc[USB_MAXENDPOINTS])
in the usb_interface struct in include/usb.h
This fact will result in that every odd index in that
array will start at an uneven address, this in
turn makes accesses to u16 wMaxPacketSize unaligned.
Such accesses are illegal on the OpenRISC architecture
(as well as other architectures) and will render a bus error.
Setting the aligned(2) attribute on usb_endpoint_descriptor
will force wMaxPacketSize to a 16-bit boundary.
Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
On some usb device controllers (pxa) the endpoint configuration must be programmed prior to enable it.
Signed-off-by: Stefan Herbrechtsmeier <sherbrec@cit-ec.uni-bielefeld.de>
CC: Marek Vasut <marek.vasut@gmail.com>
The pxa27x has 3 usb host ports. Activate all by default.
According to the EHCI specification the Capability Register Length
has a size of 8 bits.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Signed-off-by: Lei Wen <leiwen@marvell.com>
* Support dynamic allocation of devices
* Passing data via usb device privptr
* Reorder functions to avoid forward declarations
* Introduce generic polling mechanism to fix musb and ehci-hcd breakage
due to using "extern new;" to access keyboard driver data!
This allows the keyboard to avoid requests via Interrupt Endpoint altogether and
run all requests via Control Endpoint. This uses the Get_Report request.
Rebased on current code.
Signed-off-by: Remy Bohmer <linux@bohmer.net>
Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
Cc: Tom Rini <trini@ti.com>
Dave Peverley <dpeverley@mpc-data.co.uk>
Acked-by: Tom Rini <trini@ti.com>
Fix:
flash.c: In function 'flash_get_offsets':
flash.c:122:10: warning: variable 'pOrgDef' set but not used
[-Wunused-but-set-variable]
flash.c: In function 'flash_erase':
flash.c:263:6: warning: variable 'flag' set but not used
flash.c: In function 'write_data':
flash.c:439:6: warning: variable 'flag' set but not used
Cc: Dave Peverley <dpeverley@mpc-data.co.uk>
Cc: Kshitij Gupta <kshitij@ti.com>
Fix:
flash.c:139:10: warning: variable 'pOrgDef' set but not used
flash.c:280:6: warning: variable 'flag' set but not used
flash.c:456:6: warning: variable 'flag' set but not used
Fix:
edminiv2.c: In function 'reset_phy':
edminiv2.c:98:2: warning: implicit declaration of function
'mv_phy_88e1116_init' [-Wimplicit-function-declaration]
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Acked-by: Simon Guinot <simon.guinot@sequanux.org>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Fix:
sys_info.c: In function 'display_board_info':
sys_info.c:260:16: warning: variable 'db_s' set but not used
Also fix resulting warnings:
sys_info.c:251:7: warning: unused variable 'db_ip' [-Wunused-variable]
sys_info.c:250:7: warning: unused variable 'db_men' [-Wunused-variable]
Fix:
apollon.c: In function 'dram_init':
apollon.c:188:29: warning: variable 'cpu' set but not used
apollon.c:188:20: warning: variable 'rev' set but not used
apollon.c:187:26: warning: variable 'size1' set but not used
Fix:
yaffs_guts.c: In function 'yaffs_GarbageCollectBlock':
yaffs_guts.c:2761:6: warning: variable 'retVal' set but not used
Here GCC actually detected a bug. The code was always returning OK
instead of the previously set retrun code. Fix that.
Cc: William Juul <wiljuul@cisco.com>
Cc: Scott Wood <scottwood@freescale.com>
Acked-by: William Juul <wiljuul@cisco.com>
Fix:
at91_emac.c: In function 'at91emac_phy_init':
at91_emac.c:244:20: warning: variable 'duplex' set but not used
at91_emac.c:244:13: warning: variable 'speed' set but not used
Use new debug_cond() to fix these warnings. In the result, anumber of
inconsistent printf() formats are detected:
at91_emac.c: In function 'at91emac_read':
at91_emac.c:147:2: warning: format '%x' expects argument of type
'unsigned int', but argument 2 has type 'struct at91_emac_t *'
[-Wformat]
at91_emac.c: In function 'at91emac_write':
at91_emac.c:157:2: warning: format '%x' expects argument of type
[-Wformat]
'unsigned int', but argument 4 has type 'short unsigned int *'
[-Wformat]
at91_emac.c: In function 'at91emac_recv':
at91_emac.c:451:3: warning: format '%d' expects argument of type
'int', but argument 2 has type 'long unsigned int' [-Wformat]
at91_emac.c:451:3: warning: format '%x' expects argument of type
'unsigned int', but argument 4 has type 'long unsigned int' [-Wformat]
Fix these, too.
Cc: Jens Scharsig <js_at_ng@scharsoft.de>
Cc: Andreas Bießmann <andreas.devel@gmail.com>
Cc: Reinhard Meyer <u-boot@emk-elektronik.de>
Fix:
ne2000_base.c: In function 'dp83902a_send':
ne2000_base.c:282:7: warning: variable 'tmp' set but not used
ne2000_base.c: In function 'dp83902a_RxEvent':
ne2000_base.c:376:5: warning: variable 'rsr' set but not used
ne2000_base.c: In function 'dp83902a_TxEvent':
ne2000_base.c:513:5: warning: variable 'tsr' set but not used
ne2000_base.c: In function 'dp83902a_ClearCounters':
ne2000_base.c:550:17: warning: variable 'cnt3' set but not used
ne2000_base.c:550:11: warning: variable 'cnt2' set but not used
ne2000_base.c:550:5: warning: variable 'cnt1' set but not used
* 'master' of git://git.denx.de/u-boot-arm:
M28: Cleanup memsize.o OOT build
i.MX28: Move SPL to arch/arm/cpu/arm926ejs/mx28
M28: Fix typo
M28: Document that units has to be set to sectors on SD bootcard
i.mx: i.mx6q: add the initial support for i.mx6q ARM2 board
i.mx: mxc_gpio: add the i.mx6q support
i.mx: add the initial support for freescale i.MX6Q processor
i.mx: introduce the armv7/imx-common folder
S5PC2XX: Rename S5pc2XX to exynos
tegra2: Don't use board pointer before it is set up
tegra2: Remove unneeded 'dynamic ram size' message
tegra2: Remove unused low-level Tegra2 UART code
tegra2: Remove unneeded config option
tegra2: Remove unneeded boot code
tegra2: Enable instruction cache
arm: Move CP15 init out of cpu_init_crit()
tegra2: Simplify tegra_start() boot path
tegra2: Add arch_cpu_init() to fire up Cortex-A9
tegra2: Use new GPIO APIs in gpio_config_uart()
tegra2: Add support for Ventana
tegra2: Modify MMC driver to handle power and cd GPIOs
tegra2: Move board_mmc_init into board files
* 'agust@denx.de' of git://git.denx.de/u-boot-staging:
Update pci_ids.h from current Linux sources
omap: overo: Use ubifs instead of jffs2 for nand
omap: TWL4030 Bump VMMC1 interface voltage from 3V to 3.15V
* 'master' of git://git.denx.de/u-boot-mpc85xx:
mpc85xx: Add board support for the eXMeritus HWW-1U-1A devices
The current way memsize.c is built just made a symlink into the directory
with SPL and then compiled it like any other file there. This was bad as that
broke the out-of-tree build.
The new way introduced in this patch uses the standard spl/Makefile methods
(CONFIG_SPL_LIBCOMMON_SUPPORT / CONFIG_SPL_LIBGENERIC_SUPPORT) to let files in
common/ be built. Because common/Makefile says memsize.c is always built (SPL
and non-SPL build), this fixes our issue with memsize.c out-of-tree build.
Cc: Detlev Zundel <dzu@denx.de>
This moves SPL to common location so it can be reused by multiple boards. Also,
this commit adjusts M28 SoM to avoid breakage due to the move.
Add the initial support for Freescale i.MX6Q Armadillo2 board
Support: MMC boot from slot 0/1, debug UART(UART4), usdhc.
There is two MMC slots on the boards:
mmc dev 0 -> connect USDHC3 -> the lower slot on the board,
mmc dev 1 -> connect USDHC4 -> the upper slot on the board,
Signed-off-by: Jason Liu <jason.hui@linaro.org>
Tested-by: Dirk Behme <dirk.behme@de.bosch.com>
i.MX6Q is freescale quad core processors with ARM cortex_a9 complex.
This patch is to add the initial support for this processor.
Cc:Stefano Babic <sbabic@denx.de>
In order to support the coming MX6 platform and to reducde
the duplicated code, we had better move some common files
or functions to the imx-common folder for sharing.
This patch does the following:
- move speed.c file from armv7/mx5/speed.c to armv7/imx-common/speed.c
- move armv7/mx5/timer.c to armv7/imx-common/timer.c, no any new feature
added but just fix the checkpatch errors in the old file and remove
the CONFIG_SYS_MX5_CLK32 reference in the file
- create one new file cpu.c file to store the common function with i.mx5/6
As per new naming convention for Samsung SoC's, all Cortex-A9 and Cortex-A15
based SoC's will be classified under the name Exynos. Cortex-A9 and Cortex-A15
based SoC's will be sub-classified as Exynos4 and Exynos5 respectively.
In order to better adapt and reuse code across various upcoming Samsung Exynos
based boards, all uses of s5pc210 prefix/suffix/directory-names are renamed in
this patch. s5pc210 is renamed as exynos4210 and S5PC210/s5pc210 suffix/prefix
are renamed as exynos4/EXYNOS4.
Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
In board_init_f() the gd->bd pointer is not valid when dram_init() is called.
This only avoids dying because DRAM is at zero on Tegra2. The common ARM
routine sets up the banks in the same way anyway, so we can just remove this
code.
Signed-off-by: Tom Warren <twarren@nvidia.com>
This message is not required, since it is followed by an 'official' U-Boot
message.
U-Boot 2011.03-00048-gd7cb0d3 (May 11 2011 - 17:17:23)
TEGRA2
Board: NVIDIA Seaboard
dynamic ram_size = 1073741824
DRAM: 1 GiB
becomes:
TEGRA2
DRAM: 1 GiB
This is a separate commit since it changes behavior.
