The PPA binary may be stored on QSPI flash instead of NOR.
So, deprecated CONFIG_SYS_LS_PPA_FW_IN_NOR in favour of
CONFIG_SYS_LS_PPA_FW_IN_XIP to prevent fragmentation of code
by addition of a new QSPI specific flag.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
Signed-off-by: Abhimanyu Saini <abhimanyu.saini@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
Appended the compatible strings of old version PSCI to the latest
version supported. And there are some psci functions' property must
be added to DT only for psci version 0.1, including cpu_on, cpu_off,
cpu_suspend, migrate.
Note, ARMv8 Secure Firmware Framework doesn't support PSCI ver 0.1.
Identify the PSCI node only by its name, so removed the code finding
it by compatible string.
Commit 5605dc6 tried to fix wr_lat bit in timing_cfg_2, but the
change was wrong. wr_lat has 5 bits with MSB at [13] and lower
4 bits at [9:12], in big-endian convention.
Signed-off-by: York Sun <york.sun@nxp.com>
Reported-by: Thomas Schaefer <Thomas.Schaefer@kontron.com>
Update maintainers for secure boot targets.
Enable pxe command for ls1043ardb and ls1043aqds.
Signed-off-by: Wenbin Song <wenbin.song@nxp.com>
Refresh cycle value must be selected based on the frequency
of DDR. tREFI = 7.8 us as per JEDEC. The value for MDREF[REF_CNT]
should be based on round up (tREFI/tCK) formula. For 500MHz, mdref
value should be 0x0f3c8000.
Signed-off-by: Calvin Johnson <calvin.johnson@nxp.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Enable DDR row-bank-column decoding to decode DDR address as
row-bank-column instead of bank-row-column for improving
performance of serial data transfers.
qixis_reset altbank usagge ~QIXIS_LBMAP_MASK in code. So define
inverse value QIXIS_LBMAP_MASK.
Also, update QIXIS_RST_CTL_RESET value to keep RST_CTL[REQ_MOD]
as 0b11 i.e. PORESET during qixis_reset
Update blob cmd to accept 64bit source, key modifier and destination
addresses. Also correct output result print format for fsl specific
implementation of blob cmd.
Signed-off-by: Sumit Garg <sumit.garg@nxp.com>
Warnins log:
drivers/spi/fsl_qspi.c: In function ‘qspi_ahb_read’:
drivers/spi/fsl_qspi.c:400:16: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
memcpy(rxbuf, (u8 *)(priv->cur_amba_base + priv->sf_addr), len);
Signed-off-by: Yunhui Cui <yunhui.cui@nxp.com>
Update erratum workaround for A006379 to set register CPCHDBCR0
with value 0x001e0000, replacing the old value 0x003c0000.
Reported-by: Dave Liu <dave.liu@nxp.com>
With the recent bug fixes for the sun8i_emac driver all known issues
are resolved, so we can re-enable the driver.
While at it, also enable the emac on the Orange Pi One.
Cc: Chen-Yu Tsai <wens@csie.org>
Cc: Corentin LABBE <clabbe.montjoie@gmail.com>
Cc: Amit Singh Tomar <amittomer25@gmail.com>
Acked-by: Ian Campbell <ijc@hellion.org.uk>
Acked-by: Jagan Teki <jteki@openedev.com>
This fixes the following CACHE warnings when using sun8i_emac:
=> dhcp
BOOTP broadcast 1
BOOTP broadcast 2
CACHE: Misaligned operation at range [7bf594a8, 7bf59628]
BOOTP broadcast 3
CACHE: Misaligned operation at range [7bf59c90, 7bf59e10]
CACHE: Misaligned operation at range [7bf5a478, 7bf5a5f8]
DHCP client bound to address 10.42.43.80 (1009 ms)
Note this commit also changes the max rx size from 2024 to 2044,
matching what the kernel driver uses.
It seems that bytes 13-14 of the SID / bytes 1-2 from word 3 of the SID
are always 0 on H3 making it a poor candidate to use as source for the
serialnr / mac-address, and the other non constant words (1 and 2) also
have quite a few bits which are the same for some boards,
This commits switches to using the crc32 of words 1 - 3 to get a
more unique value for the mac-address / serialnr.
On 2 of my H3 boards bytes 13-15 of the SID are all 0 leading to
the NIC specific bytes of the mac all being 0, which leads to the
boards not getting an ipv6 address from the dhcp server.
This commits adds a check to ensure this does not happen.
MACPWR was used to bring the Ethernet PHY out of reset. The designware
driver now supports the phy reset gpio binding, so this is no longer
needed. In fact in requesting the same GPIO, it makes the designware
driver fail to probe.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
sunxi uses a 2 cell phandle for gpio bindings. Also there are no
seperate nodes for each pin bank.
Add a custom .xlate function to map gpio phandles to the correct
pin bank device. This fixes gpio_request_by_name usage.
Fixes: 7aa974858422 ("dm: sunxi: Modify the GPIO driver to support driver
model")
PopMetal is a rockchip rk3288 based board made by ChipSpark, which has
many interface such as HDMI, VGA, USB, micro-SD card, WiFi, Audio and
Gigabit Ethernet.
Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com>
Fennec is a RK3288-based development board with 2 USB ports, HDMI,
micro-SD card, audio and WiFi and Gigabit Ethernet. It also includes
on-board 8GB eMMC and 2GB of SDRAM. Expansion connectors provides access
to display pins, I2C, SPI, UART and GPIOs.
The 'evb-rk3288' is not a vendor name, change it to 'rockchip' which is
the real vendor name.
CONFIG_SYS_LOAD_ADDR is absolutely safe to store image for
fastboot.
CONFIG_DOS_PARTITION and CONFIG_EFI_PARTITION are already included in
config_distro_defaults.h, and we don't need them in SPL stage.
Reduce compilation time for SPL.
Boot Rom wouldn't initialize sdmmc while booting from eMMC. We need to
setup sdmmc gpio, otherwise we will hit an error below:
=>mmc info
blk_get_device: if_type=6, devnum=0: dwmmc@ff0c0000.blk, 6, 0
uclass_find_device_by_seq: 0 -1
uclass_find_device_by_seq: 0 0
- -1 -1
- -1 0
- found
uclass_find_device_by_seq: 0 1
- -1 -1
- -1 0
- not found
fdtdec_get_int_array: interrupts
get_prop_check_min_len: interrupts
Buswidth = 1, clock: 0
Buswidth = 1, clock: 400000
Sending CMD0
dwmci_send_cmd: Timeout on data busy
This reverts commit 6efeeea79c880d3dd262e0dca9da2687f0ab68c9.
Revise config to CONFIG_ROCKCHIP_RK3288_PINCTRL.
Signed-off-by: Ziyuan Xu <jk.kernel@gmail.com>
Add an extra byte so that this data is not byteswapped.
Bank 0 is the "PMU GPIO" bank which is controlled by the PMU registers
rather than the GRF registers. In the GRF the top half of the register
is used as a mask so that some bits can be updated without affecting the
others, but in the PMU this feature is not provided and the top half of
the register is reserved.
Take the same approach as the Linux driver to update the value via
read-modify-write but setting the mask for only the bits that have
changed. The PMU registers ignore the top 16 bits so this works for
both GRF and PMU iomux registers.
Signed-off-by: John Keeping <john@metanate.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
RK3399 needs reserve 0x200000 at the beginning of DRAM, for ATF bl31.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Update MAINTAINER files for kylin_rk3036, evb_rk3036.
The CONFIG_ROCKCHIP_COMMON and CONFIG_SPL_ROCKCHIP_COMMON are no use now,
remove them.
Not like the mmc-legacy which the devnum starts from 1, it starts from 0
in mmc-uclass, so the device number should be (devnum + 1) in get_mmc_num().
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
This patch is style-related only, to reformat all the start.S code,
actually not following a coherent style inside single files and
between different cpu start.S files.
Linux format has been respected, as
- max line width at 80 columns
- one 8 cols tab between asm instructions and operands
- inline comments, where any, fixed at col 41
Signed-off-by: Angelo Dureghello <angelo@sysam.it>
AM571x IDK and AM572x IDK EVMs have spansion s25fl256s QSPI flash on the
board connected to TI QSPI IP over CS0. Therefore enable QSPI support.
Signed-off-by: Vignesh R <vigneshr@ti.com>
Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com>
Reviewed-by: Jagan Teki <jteki@openedev.com>
AM571x and AM572x IDK have a spansion s25fl256s QSPI flash on the board
connected to TI QSPI over CS0. Hence, add QSPI and flash slave
DT nodes.
AM437x SK and AM437x IDK EVMs have 64MB flash, therefore enable
CONFIG_SPI_FLASH_BAR to access flash regions above 16MB.
According to AM572x DM SPRS953A, QSPI max bus speed is 76.8MHz.
Therefore update the spi-max-frequency value of QSPI node for DRA74 and
DRA72 evm. This increase flash read speed by ~2MB/s.
Now that QSPI driver can support 76.8MHz, update the
CONFIG_SF_DEFAULT_SPEED to the same value.
According to AM572x DM SPRS953A, QSPI bus speed can be 76.8MHz, update
the driver to use the same.
According to AM572x DM SPRS953A, QSPI bus speed can be 76.8MHz, hence
update QSPI input clock divider value (DPLL_PER_HS13) to provide 76.8MHz
clock, so that driver can use the same.
Add AT25DF321 flash support.
Fix AT25DF321A device name.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
As per commit b545a98f5dc563 ("spi: ti_qspi: Add delay
for successful bulk erase) says its added to meet bulk erase timing
constraints. But bulk erase is a cmd to flash and delay in read path
does not make sense. Morever, testing on DRA74/DRA72 evm has shown that
this delay is no longer required.
clk_div is uninitialized at the beginning of ti_spi_set_speed(), move
debug() print after clk_div calculation to avoid compiler warning and to
have proper value of clk_div printed during debugging.
Populating QSPI_RD_SNGL bit(0x1) in priv->cmd means that value
QSPI_INVAL (0x4) is not written to CMD field of QSPI_SPI_CMD_REG in
ti_qspi_cs_deactivate(). Therefore CS is never deactivated between
successive READ ID which results in sf probe to fail.
Fix this by not populating priv->cmd with QSPI_RD_SNGL and OR it wih
priv->cmd as required (similar to the convention followed in the
driver).
This commit adds support in the spi-nor driver for the
N25Q016A, a 16Mbit SPI NOR flash from Micron.
Signed-off-by: Moritz Fischer <moritz.fischer@ettus.com>
Pass the board/freescale/*mx*/ path as files maintained by Stefano
Babic.
While this is not ideal and does not cover all the i.MX board cases,
it gives at least a better hint for the /scripts/get_maintainer.pl
tool.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Add an entry for the mx7dsabresd_secure_defconfig target.
