The omap3_evm board does not boot when commit:
a47ca2cf67 ("ARM: omap3: evm: Add kernel image loading from UBIFS and EXT4")
is applied after commit:
3dde8f2037 ("Merge git://git.denx.de/u-boot-mmc")
This commit reduces the CONFIG_EXTRA_ENV_SETTINGS size and better
leverages the existing distro bootcmd infrastructure.
- Use updated UBIFS support from config_distro_bootcmd.h
- Use LEGACY_MMC naming found in am335x_evm.h and ti_omap4_common.h
- Remove extra environment content that is no longer needed
[MMC(0:1)/extlinux/extlinux.conf]
---8<-------------------------------------------------------------------
default omap3-evm-mmc-fat
label omap3-evm-mmc-fat
kernel /zImage
fdt /omap3-evm.dtb
append console=ttyO0,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait
[MMC(0:2)/boot/extlinux/extlinux.conf]
default omap3-evm-mmc-ext4
label omap3-evm-mmc-ext4
kernel /boot/zImage
fdt /boot/omap3-evm.dtb
[NAND(ubi0:rootfs)/boot/extlinux/extlinux.conf]
default omap3-evm-nand-ubifs
label omap3-evm-nand-ubifs
kernel /boot/zImage
append console=ttyO0,115200n8 root=ubi0:rootfs rw ubi.mtd=rootfs noinitrd rootfstype=ubifs rootwait
Fixes: a47ca2cf67 ("ARM: omap3: evm: Add kernel image loading from UBIFS and EXT4")
Signed-off-by: Derald D. Woods <woods.technical@gmail.com>
This commit allows overriding the default assumption that the boot UBI
MTD partition is named 'UBI' and the UBI volume is 'boot'. A board
desiring to use a legacy or alternative NAND layout can now define the
following two extra environment variables:
bootubipart=<some_ubi_partition_name>
bootubivol=<some_ubi_volume_name>
EXAMPLE:
[include/configs/some_board.h]
#include <config_distro_defaults.h>
#define MEM_LAYOUT_ENV_SETTINGS \
DEFAULT_LINUX_BOOT_ENV
#define BOOT_TARGET_DEVICES(func) \
func(UBIFS, ubifs, 0)
#include <config_distro_bootcmd.h>
#define CONFIG_EXTRA_ENV_SETTINGS \
"bootubivol=rootfs\0" \
"bootubipart=rootfs\0" \
BOOTENV
SPL and TPL may not always need spl_board_init() at the same time.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Loading files stored with lzo compression from a btrfs filesystem was
producing unaligned memory accesses, which were causing a data abort
and a reset on an Orange Pi Zero.
The change in hash.c is not triggered by any error but follows the
same pattern. Please confirm.
Fixed according to doc/README.unaligned-memory-access.txt
Signed-off-by: Alberto Sánchez Molero <alsamolero@gmail.com>
Tested-by: Robert Nelson <robertcnelson@gmail.com>
PLLSAIP divider uses 2 bits (bits 16 and 17) into RCC_PLLSAICFGR
register, available combination are :
00: PLLSAIP = 2
01: PLLSAIP = 4
10: PLLSAIP = 6
11: PLLSAIP = 8
Previously, the divider value was incorrectly set to 6.
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
hw_data_init() is called before relocation to initialise hardware data.
Since ctrl is initialized to OMAP_SRAM_SCRATCH_SYS_CTRL in
arch/arm/mach-omap2/am33xx/hw_data.c, the pointer *ctrl will not be
updated during relocation and will hold a stale value.
Therefore call hw_data_init() again after relocation to
reinitialize *ctrl.
Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
Since 7e0ed13 ("Convert ARCH_OMAP2PLUS boards' CONFIG_SYS_TEXT_BASE to
Kconfig"), a default SYS_TEXT_BASE was set for all ARCH_OMAP2PLUS devices.
CONFIG_ISW_ENTRY_ADDR is used to set SYS_TEXT_BASE in qspi boot.
Simplify this by directly assigning SYS_TEXT_BASE in the defconfig.
Remove unused ret from fw_env_flush.
Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl>
Move SYSCFG clock setup into configure_clocks() instead of calling
clock_setup() from board file.
As this clock is only needed in case of ethernet enabled and as
both stm32f4 and stm32f7 are using the Designware ethernet IP,
we use CONFIG_ETH_DESIGNWARE to only enable this clock if needed.
Move the RMII setup from board_early_init_f() to board_init()
to insure that RMII bit is set only when clock driver is initialized.
Thanks to 'commit ba1f96672522 ("net: designware: add clock support")'
we don't need anymore to setup the STMMAC clock in board.
Reviewed-by: Vikas Manocha <vikas.manocha@st.com>
Add ETHMAC, ETHMACRX and ETHMACTX clocks for STMMAC.
Several inline functions in this file reference undefined functions in
U-Boot. For example:
atomic-long.h:73:9: warning: implicit declaration of function
'atomic64_sub_and_test'
atomic-long.h:80:9: warning: implicit declaration of function
'atomic64_dec_and_test'
atomic-long.h:87:9: warning: implicit declaration of function
'atomic64_inc_and_test'
Handle this the same as the 32 bit build by wrapping these functions in
a __UBOOT__ check.
Signed-off-by: Bradley Bolen <bradleybolen@gmail.com>
_ Add gpio compatible and aliases for stm32f469
_ Add FMC sdram node
_ Add "u-boot,dm-pre-reloc" for rcc, fmc, fixed-clock, pinctrl,
pwrcfg and gpio nodes.
This DT file comes from kernel v4.15, this board offers :
_ STM32F429NIH6 microcontroller
_ 4.3” color TFT LCD with resistive touchscreen (480 x 272 pixels)
_ Six 5 V power supply options:
Power jack
ST-LINK/V2 USB connector
User USB HS connector
User USB FS1 connector
User USB FS2 connector
Daughterboard
_ SAI Audio DAC, stereo audio jack which supports headset with
microphone
_ Stereo digital microphone, audio terminal connector used to connect
external speakers
_ 2 GBytes (or more) SDIO interface MicroSD card
_ RF EEPROM on I2 C compatible serial interface
_ RS-232 communication
_ IrDA transceiver
_ JTAG/SWD and ETM trace debug support, ST-LINK/V2 embedded
_ IEEE-802.3-2002 compliant Ethernet connector
_ Camera module
_ 8M x 32-bit SDRAM, 1M x 16-bit SRAM and 8M x 16-bit NOR Flash
_ Joystick with 4-directional control and selector
_ Reset, Wakeup and Tamper buttons
_ 4 color user LEDs
_ Extension connectors & memory connectors for daughterboard or
wrapping board
_ USB OTG HS and FS with Micro-AB connectors
_ RTC with backup battery
_ CAN2.0A/B compliant connection
_ Potentiometer
_ Motor control connector
Add stm32f429-evaluation board support.
For more information, please visit:
http://www.st.com/en/evaluation-tools/stm32429i-eval.html
As clk_stm32f driver is able to retrieve HSE frequency from DT,
CONFIG_STM32_HSE_HZ becomes useless.
All current STM32F4 supported boards uses a 8MHz external oscillator.
All current STM32F7 supported boards uses a 25MHz external oscillator.
In order to introduce the new stm32f429-evaluation board which uses a
25MHz external oscillator without creating a dedicated struct
stm32_clk_info for this board, retrieve the external oscillator
frequency from DT and set pll_m accordingly to obtain 1MHz for the VCO.
In order to retrieve the clk_hse fixed clock phandle in clk_stm32f driver,
add "u-boot,dm-pre-reloc" property in Uboot specific DT file.
compiling U-Boot with bosch_mpcxxxxd_sd_defconfig
drops warning:
arch/arm/lib/bootm-fdt.c: In function ‘arch_fixup_fdt’:
arch/arm/lib/bootm-fdt.c:37:6: warning: unused variable ‘ret’ [-Wunused-variable]
int ret = 0;
Fix it.
When in early SPL we make some secure ROM calls that can effect
DRAM, due to this it is more stable to store the args for these
calls in SRAM, but uninitialized and zero'd globals are placed
in BSS, located in DRAM. Force our args into the data section
which is in SRAM during SPL.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Fix some style violations in the board_r file.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Fix some style violations in the board_f file.
Clarify the computation precedence in two ternary operator
constructions.
There are some typos in the documentation of some functions in read.h;
fix those.
Make the MPC8xxx GPIO driver compatible with a live device tree.
Finally, make the mpc8xxx driver capable of handling more GPIO devices;
this entails adding a special case for the MPC5121 SoC, and adding a set
of new compatible strings.
Rename the Kconfig option, structures (and their members), as well as
functions of the mpc85xx driver to include mpc8xxx to reflect the more
generic usage.
In preparation to making the MPC85xx GPIO driver useable for a broader
range of SoCs, rename the driver file.
Fix some style violations in the MPC85XX GPIO driver.
Make the pca953x_gpio driver compatible with a live device tree.
Fix some style violations in the pca953x_gpio driver.
The call to hash_block in passwd_abort fails with error ENOSPC on some
systems. The reason is that the variable which specifies the size of the
buffer to contain the computed hash does not get initialized.
This patch initializes the variable with the size of the buffer.
Signed-off-by: Martin Etnestad <martin.etnestad@appeartv.com>
The variable hcd_name is unsued, drop.
Cc: Chris Brandt <chris.brandt@renesas.com>
The isp116x-hcd driver is extremely long unused, so just remove it.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Convert the R8A7791 Porter board to DM and DT. This implies mostly
enabling the necessary configuration options and plucking out the
ad-hoc configuration from the board file. Moreover, the pre-reloc
malloc size was increased to allow the clock driver to start up
early without running out of malloc space and the early stack was
moved further up in the DRAM to avoid rewriting U-Boot itself.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Since the DTs are now in place, enable OF control so that they get
bundled into the U-Boot.
Add U-Boot DT extras for each SoC and board. This marks the required
nodes with u-boot,dm-pre-reloc to start clock and PRR early on while
avoiding modification of the DTs imported from Linux.
The Stout board is not supported in Linux, so add a rudimentary DTS
for H2 Stout as a placeholder for when a proper DTS is available.
NOTE: The Stout is already being shipped over, so proper DTS for both
U-Boot and Linux will happen once it's delivered :-)
Import the Renesas R8A7794 DTS and headers from upstream Linux kernel v4.15-rc8,
commit bebc6082da0a9f5d47a1ea2edc099bf671058bd4 .
Import the Renesas R8A7793 DTS and headers from upstream Linux kernel v4.15-rc8,
Import the Renesas R8A7792 DTS and headers from upstream Linux kernel v4.15-rc8,
Import the Renesas R8A7791 DTS and headers from upstream Linux kernel v4.15-rc8,
Import the Renesas R8A7790 DTS and headers from upstream Linux kernel v4.15-rc8,
Add DM capable code into the SH ethernet driver and support probing
both from DT and pdata. The legacy non-DM, non-DT support is retained
as there are still systems in the tree which are not DM or DT capable.
