2015-01-14sun7i: Add defconfig for MSI Primo73 tabletSiarhei Siamashka
This patch uses the same DRAM settings as in the pre-installed Android firmware. The LCD display is supported too. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-14sun6i: Add defconfig for MSI Primo81 tabletSiarhei Siamashka
This patch uses the same ZQ and DRAM clock settings as in the pre-installed Android firmware. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-14sunxi: Fix CONFIG_UART0_PORT_F build and add it to menuconfigSiarhei Siamashka
The CONFIG_UART0_PORT_F option has been supported since http://git.denx.de/?p=u-boot.git;a=commit;h=ff2b47f6a9cc1025 This option is primarily useful only for low level u-boot debugging on tablets, where normal UART0 is difficult to access and requires device disassembly and/or soldering. This patch now allows it to be selected from menuconfig. A dependency on SPL_FEL is added because u-boot does not support booting from NAND yet and also booting from SD card is impossible when a MicroSD breakout board is plugged into the SD slot. Additionally a compilation problem is fixed: common/spl/built-in.o: In function `spl_mmc_load_image': /tmp/u-boot-sunxi/common/spl/spl_mmc.c:94: undefined reference to `mmc_initialize' /tmp/u-boot-sunxi/common/spl/spl_mmc.c:96: undefined reference to `find_mmc_device' /tmp/u-boot-sunxi/common/spl/spl_mmc.c:104: undefined reference to `mmc_init' scripts/Makefile.spl:206: recipe for target 'spl/u-boot-spl' failed Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-14sun8i: Add defconfig for Ippo_q8h v1.2Hans de Goede
We need separate defconfigs for the v5 and v1.2 versions of this board, as they use different DRAM parameters. Note they also use different dtb files, as the wifi is different too. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun8i: Ippo_q8h_v5_defconfig: Enable SPL supportHans de Goede
Now that we've sun8i dram-init support we can enable the SPL for sun8i boards. While at it also replace CONFIG_DEFAULT_DEVICE_TREE with CONFIG_FDTFILE, the former is for u-boot's own fdt usage, which we do not use (yet), the later specifies the fdt to pass to the kernel, which is the one we want. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun8i: Add dram initialization supportHans de Goede
Based on the register / dram_para headers from the Allwinner u-boot / linux sources + the init sequences from boot0. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: Use memcmp for mctl_mem_matchesHans de Goede
Use memcmp for mctl_mem_matches instead of DIY. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: Fill memory before comparing it when doing dram init on sun6iHans de Goede
The sun8i boot0 code fills the DRAM with a "random" pattern before comparing it at different offsets to do columns, etc. detection. The sun6i boot0 code does not do it, instead relying on the memory contents being random enough to begin with for the memcmp to properly detect the wrap-around address, iow it is working purely by chance. Since our sun6i dram code was modelled after the boot0 code it contained the same issue. This commit fixes this by filling the memory with a unique, distinct pattern. The new mctl_mem_fill function this introduces is added as an inline helper in dram.h, so that it can be shared with the sun8i dram code. While at it move mctl_mem_matches to dram.h for re-use in sun8i too. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: Move await_completion dram helper to dram.hHans de Goede
The await_completion helper is already copy pasted between the sun4i and sun6i dram code, and we need it for sun8i too, so lets make it an inline helper in dram.h, rather then adding yet another copy. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun6i: clock_set_pll5: Calculate k and m rather then hardcoding themHans de Goede
Our old hardcoded k and m values are based on PLL5 being configured in steps of 48 MHz, which is correct for sun6i where the DRAM PLL runs at twice the DRAM CLK, which is usually configured in 24 MHz step. But on the A23 (sun8i) the PLL5 runs at half the DRAM CLK, so we require 12 MHz steps. This commit adjusts clock_set_pll5 to automatically select the best k and m depending on the requested clk rate. Suggested-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun6i: Add a sigma_delta_enable paramter to clock_set_pll5()Hans de Goede
The sun8i dram code sometimes wants to enable sigma delta mode, add a parameter to allow this. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: axp221: Disable dcdc4 on sun8i (A23)Hans de Goede
dcdc4 is not used on sun8i, disable it. While at it also add comments to the other fixed voltages to document what they are used for. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: axp221: Explicitly turn off unused voltagesHans de Goede
Explicitly turn off unused voltages, rather then leaving them as is. Likewise explictly enabled the dcdc convertors, rather then assuming they are already enabled at boot. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: axp221: Make dcdc1 voltage configurableHans de Goede
The dcdc1 voltage is typically used as generic 3.3V IO voltage for things like GPIO-s, sdcard interfaces, etc. On most boards this is undervolted to 3.0V to safe battery, but not on all, make it configurable so that we can use the same settings as the original firmware on all boards. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: axp221: Add Kconfig help and sane defaults for typical ldo usageHans de Goede
Some of the ldo-s of the axp221 are used in the same way on most boards, add comments to the Kconfig help text to reflect this, and give them defaults matching their typical usage. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: axp221: Add axp223 supportHans de Goede
The axp223 appears to be the same as the axp221, except that it uses the rsb to communicate rather then the p2wi. At least all the registers we use are 100% the same. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: Add support for the rsb (Reduced Serial Bus)Hans de Goede
sun8i (A23) introduces a new bus for communicating with the pmic, the rsb, the rsb is also used to communicate with the pmic on the A80, and is documented in the A80 user manual. This commit adds support for this based on the rsb driver from the allwinner u-boot sources. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun6i: s/SUNXI_*P2WI*/SUN6I_*P2WI*/Hans de Goede
The p2wi interface is only available on sun6i, adjust the gpio pinmux and base address defines for it to reflect this. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14mmc: sunxi: Fix misuse of gpio_direction_input()Axel Lin
It does not make sense to make gpio_direction_input() return the gpio input status. The return value of gpio_direction_input() is inconsistent if CONFIG_DM_GPIO is defined. And we don't need to call gpio_direction_input() int sunxi_mmc_getcd(). Just init the gpio once in mmc_resource_init() is enough. Signed-off-by: Axel Lin <axel.lin@ingics.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: Align PSCI stack calculation to commentJan Kiszka
0x400 is true 1K. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun6i: Add new board Merrii Hummingbird A31Chen-Yu Tsai
The Merrii Hummingbird A31 is a A31 based development board with 1G RAM, 8G NAND, AP6210 WiFi+BT, gigabit ethernet, USB OTG, 2 USB 2.0 ports connected to a USB hub chip, HDMI, VGA, TV and stereo in/out. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-14sunxi: Add sunxi_get_sid helper functionHans de Goede
On sun6i the SID is stored in the pmic, rather then in the SoC itself, add a helper function to abstract this away. This makes our MAC address generation code also work on sun6i. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun6i: axp221: Add axp221_get_sid functionHans de Goede
For sun6i the SID is stored in the pmic, rather then in the SoC itself, add a function to retreive the sid. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: mmc: Properly setup mod-clk and clock sampling phasesHans de Goede
The sunxi mmc controller has both an internal clock divider, as well as the divider in the mod0-clk for the mmc controller. The internal divider cannot be used, as it conflicts with the setting of clock sampling phases which is done in the mod0-clk, so it must be set to 0 (divide by 1). For some reason while the kernel has had this correct from day one, the u-boot sunxi mmc code has been using a fixed mod0-clk and setting its internal divider depending on the desired speed. This is something which we've inherited from the original Allwinner u-boot sources, but while this has been fixed in Allwinner's own u-boot code at least for the A23 and later upstream u-boot was still doing this wrong. This commit fixes this, thereby also fixing mmc support not working reliable on the A23 (which seems more sensitive to this) and possible also fixes some other sunxi mmc issues. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun6i: Update Colombus defconfig settingsHans de Goede
The Colombus defconfig settings are missing a number of settings for recently added features, because we did not know exactly how things were hooked up. Maxime Ripard has run various tests to get us the necessary details, this commit updates the defconfig with this info. This commit also updates the dram clk and zq values with values verified by Maxime to be the ones used by the original firmware for this board. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun6i: Add new CSQ_CS908 boardHans de Goede
The CSQ CS908 is an A31s based top-set box, with 1G RAM, 8G NAND, rtl8188etv usb wifi, 2 USB A receptacles (1 connected through the OTG controller), ethernet, 3.5 mm jack with a/v out and hdmi out: http://www.geekbuying.com/item/CS908-Allwinner-A31S-Quad-Core-1-2GHz-Android-4-4-Mini-TV-Box-HDMI-HDD-Player-1G-8G-WIFI-Miracast---Black-333395.html Note it has no sdcard slot and therefore can only be fel booted. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun6i: dram: Do not try to initialize a second dram chan on A31sHans de Goede
The A31s only has one dram channel, so do not bother with trying to initialize a second channel. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun6i: Add sunxi_get_ss_bonding_id() functionHans de Goede
Add a sunxi_get_ss_bonding_id() function, and use it to differentiate between the A31s and the A31. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun6i: Make dram clk and zq value Kconfig optionsHans de Goede
It turns out that there is a too large spread between boards to handle this with a default value, turn this into Kconfig options, and set the values the factory images are using for the Colombus and Mele_M9 boards. Note this changes the ZQ default when not overriden through defconfig from 120 to 123, as that is what most boards seem to actually use. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-13Merge git://git.denx.de/u-boot-x86Tom Rini
2015-01-13x86: Remove CONFIG_DISPLAY_CPUINFO in chromebook_link.hBin Meng
CONFIG_DISPLAY_CPUINFO is already defined in x86-common.h, so remove it to avoid duplication. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: Update README.x86 for coreboot supportBin Meng
Update README.x86 to include new build instructions for U-Boot as the coreboot payload and testing considerations with coreboot. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: coreboot: Configure pci memory regionsBin Meng
Configure coreboot pci memory regions so that pci device drivers could work correctly. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: coreboot: Wrap cros_ec initializationBin Meng
cros_ec_board_init() should be called only when CONFIG_CROS_EC is enabled. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: Make chromebook_link the default board for corebootBin Meng
Change SYS_CONFIG_NAME and DEFAULT_DEVICE_TREE to chromebook_link which is currently the only real board officially supported to run U-Boot loaded by coreboot. Note the symbolic link file chromebook_link.dts is deleted and link.dts is renamed to chromebook_link.dts. To avoid multiple definition of video_hw_init, the CONFIG_VIDEO_X86 define needs to be moved to arch/x86/cpu/ivybridge/Kconfig. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: Remove include/configs/coreboot.hBin Meng
Since we already swtiched to use the new mechanism for building U-Boot for coreboot, coreboot.h is no longer needed so remove it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: Move CONFIG_SYS_CAR_xxx to KconfigBin Meng
Move CONFIG_SYS_CAR_ADDR and CONFIG_SYS_CAR_SIZE to Kconfig so that we don't need them in the board configuration file thus the same board configuratoin file can be used to build both coreboot version and bare version. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: coreboot: Move coreboot-specific defines from coreboot.h to KconfigBin Meng
There are many places in the U-Boot source tree which refer to CONFIG_SYS_COREBOOT, CONFIG_CBMEM_CONSOLE and CONFIG_VIDEO_COREBOOT that is currently defined in coreboot.h. Move them to arch/x86/cpu/coreboot/Kconfig so that we can switch to board configuration file to build U-Boot later. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: coreboot: Make SYS_CONFIG_NAME and DEFAULT_DEVICE_TREE configurableBin Meng
In theory U-Boot built for coreboot is supposed to run as a payload to be loaded by coreboot on every board that coreboot supports. The U-Boot build process uses SYS_CONFIG_NAME and DEFAULT_DEVICE_TREE which are hardcoded in board defconfig and Kconfig files. For better support of coreboot, we want to make these two options configurable so that we can easily change them during 'make menuconfig' so that the generated U-Boot image for coreboot is board configuration aware. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: Hide ROM chip size when CONFIG_X86_RESET_VECTOR is not selectedBin Meng
When CONFIG_X86_RESET_VECTOR is not selected, specifying the ROM chip size is meaningless, hence hide it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: Move CONFIG_X86_RESET_VECTOR and CONFIG_SYS_X86_START16 to KconfigBin Meng
Convert CONFIG_X86_RESET_VECTOR and CONFIG_SYS_X86_START16 to Kconfig options so that we can remove them from board configuration file. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: Allow a hardcoded TSC frequency provided by KconfigBin Meng
By default U-Boot automatically calibrates TSC running frequency via MSR and PIT. The calibration may not work on every x86 processor, so a new Kconfig option CONFIG_TSC_CALIBRATION_BYPASS is introduced to allow bypassing the calibration and assign a hardcoded TSC frequency CONFIG_TSC_FREQ_IN_MHZ. Normally the bypass should be turned on in a simulation environment like qemu. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: coreboot: Set up timer base correctlyBin Meng
If coreboot is built with CONFIG_COLLECT_TIMESTAMPS, use the value of base_time in coreboot's timestamp table as our timer base, otherwise TSC counter value will be used. Sometimes even coreboot is built with CONFIG_COLLECT_TIMESTAMPS, the value of base_time in the timestamp table is still zero, so we must exclude this case too (this is currently seen on booting coreboot in qemu). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: fsp: Drop get_hob_type() and get_hob_length()Bin Meng
These two are not worth having separate inline functions as they are really simple, so drop them. Also changed 'type' parameter of fsp_get_next_hob() from u16 to uint. Suggested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: Add an 'mtrr' command to list and adjust MTRRsSimon Glass
It is useful to be able to see the MTRR setup in U-Boot. Add a command to list the state of the variable MTRR registers and allow them to be changed. Update the documentation to list some of the available commands. This does not support fixed MTRRs as yet. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-01-13x86: ivybridge: Update microcode early in bootSimon Glass
At present the normal update (which happens much later) does not work. This seems to have something to do with the 'no eviction' mode in the CAR, or at least moving the microcode update after that causes it not to work. For now, do an update early on so that it definitely works. Also refuse to continue unless the microcode update check (later in boot) is successful. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: Disable CAR before relocation on platforms that need itSimon Glass
For platforms with CAR we should disable it before relocation. Check if this function is available and call it if so. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: ivybridge: Add a way to turn off the CARSimon Glass
Cache-as-RAM should be turned off when we relocate since we want to run from RAM. Add a function to perform this task. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: Commit the current MTRRs before relocationSimon Glass
Once we stop running from ROM we should set up the MTTRs to speed up execution. This is only needed for platforms that don't have an FSP. Also in the Coreboot case, the MTRRs are set up for us. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: ivybridge: Request MTRRs for DRAM regionsSimon Glass
We should use MTRRs to speed up execution. Add a list of MTRR requests which will dealt with when we relocate and run from RAM. We set RAM as cacheable (with write-back) and registers as non-cacheable. Signed-off-by: Simon Glass <sjg@chromium.org>
