SCIF of lager use external clock mode.
This enables external clock mode on lager board.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
The clock of SCIF (serial port) of lager is supplied from External
Clock. And value of clock is 14.7456MHz.
The single file conflict below is actually trivial.
board/boundary/nitrogen6x/nitrogen6x.c
Removed settings in unsupported register fields. They didn’t
do anything, and in most cases, were not documented in the
reference manual.
Changed register settings to comply with JEDEC required values.
Changed timing parameters because they included full clock
periods that were doing nothing.
Signed-off-by: Anthony Felice <tony.felice@timesys.com>
[rebased on v2014.10-rc2]
Signed-off-by: Stefan Agner <stefan@agner.ch>
Support reading/writing ext4 partitions.
Signed-off-by: Kevin Mihelich <kevin@archlinuxarm.org>
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
Enable 'fastboot' command.
This is currently enabled but not yet functional. Including it in the
configuration will ease further testing and development as discussed
on the mailing list.
Enable the 'gpio' command to allow reading and toggling of GPIO
pins.
Some users (QNX and Windows CE users in particular) have asked
to disable the Penguin shown on the display at boot time.
Increase the maximum number of arguments allowed by the Hush parser.
This prevents errors when users or scripts aren't quoting parameters
when setting the "bootargs" variable et al.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
Enable the "i2c edid" command to query data from an attached
HDMI monitor.
Usage is typically this:
U-Boot > i2c dev 1
U-Boot > i2c edid 0x50
Enable the 'mtest' command on Nitrogen6x and SABRE Lite boards.
Enable the use of USB keyboards on SABRE Lite and Nitrogen6x boards.
If no boot script was found, expose internal storage over the
USB mass storage gadget to allow easy programming.
This is especially useful when SD cards are inaccessible or when
loading SATA drives.
More details are available in this blog post:
http://boundarydevices.com/u-boot-usb-mass-storage-gadget/
Support RAM disks by setting initrd_high. See commit 7e9603e
Remove the individual attempts to load using ext2 and fat, replace with the
generic load command supporting available filesystem types.
This patch enables boot to USB storage devices by expanding on the list
of boot devices.
Because the USB startup currently takes a long time, it places USB at
the end of the list of supported devices.
You can over-ride the boot order using the bootdevs environment variable.
For instance, this will make USB the first (highest priority) device:
U-Boot > setenv bootdevs usb mmc sata
U-Boot > saveenv
Signed-off-by: Diego Rondini <diego.rondini@kynetics.it>
Add support for the USB mass storage to enable access to on-board
storage (especially eMMC and SATA).
Details at:
The HPD pin and RX_SENSE registers have proven to be less reliable
than using I2C on the EDID pins for detection of an HDMI monitor.
In particular, when the HDMI output is reset through a "reboot"
cycle, the detect_hdmi() routine often bounces, resulting in
a failure to detect a connected monitor.
Add support for WVGA (800x480) panels using VESA GTF timings over
LVDS.
No auto-detection is supported, so you must configure this panel
manually through the 'panel' environment variable:
U-Boot > setenv panel svga
U-Boot > saveenv && reset
Add support for an Ampire 1024x600 LVDS panel with integrated Ilitek
capacitive touch screen.
Auto-detection is enabled, so no explicit configuration is needed.
Add support for 800x600 18-bit RGB displays using VESA GTF timings.
Add support for the Touch Revolution Fusion7 display: 800x480 RGB
with a custom F0710A resistive touch controller.
Auto-detection of this panel is supported so no configuration is
required.
This patch adds support for LVDS WXGA displays that use the SPWG encoding
standard instead of JEIDA.
No auto-detection is enabled and you must explicitly set the 'panel'
U-Boot > setenv panel LDB-WXGA-S
Add support for LG 9.7" LVDS panel (1024x768) with integrated eGalax
touch screen.
Note that this panel differs only slightly from the Hannstar XGA panel
(margins).
No auto-detection is available because it shares the same touch controller
as the Hannstar-XGA display, so you'll need to configure it through the
U-Boot > setenv panel LG-9.7
Add support for a 1/4 VGA panel with a 24-bit RGB interface.
No auto-detection is enabled, so you must configure the 'panel'
environment variable to use this display:
U-Boot > setenv panel qvga
Add support for Boundary Devices 7" and 10.1" 1280x800 displays with
integrated FocalTech ft5x06 10-point touch controller.
Because they share the touch controller with the 1024x600 displays,
auto-detection is disabled and you must explicitly set the 'panel'
Signed-off-by: Robert Winkler <robert.winkler@boundarydevices.com>
Include declarations of board_ehci callbacks to prevent compiler warnings
and enforce function prototypes.
Testing shows that the Micrel PHY may not be completely out
of reset if accessed immediately.
Declare locally-used data structures and functions as
static and pull in header files to prevent compiler warnings
of "Should it be static?" when building with "make C=1".
Configure CLKO outputs for SGTL5000, CSI camera.
The sys_mclk output for the SGTL500 in particular prevents
Windows CE from properly driving audio.
Ensure that cameras and USB OTG power are in a stable (reset)
state at reset by configuring their pads and toggling GPIOs.
Pads SD2_CLK/CMD/DAT0-3 are connected to an SDIO WiFi device on
Nitrogen and unconnected on BD-SL-i.MX6 (sabre lite).
Configure them as SDIO pins to prevent them from being in a state
that confuses the WiFi part.
The same logic applies to both SD card slots, only with different
GPIOs and the code should make that easier to see.
Several customers have asked to leave the display quiet during
boot, so allow the user to express this request by the presence
of environment variable "novideo".
This patch adds support for the OT1200 series of devices.
Following components are used in u-boot:
+ ethernet
+ i2c
+ emmc
+ gpio
For more details see README.
Changes v1 > v2
- make use of enable_cspi_clock(..)
- fix usage of OUTPUT_40OHM define
- added README
Changes v2 > v3
- improve spelling in README
- added own copy of mx6q_4x_mt41j128.cfg
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Remove this tab from env, since it's useless, just use spaces.
Update DDR calibration settings based on a larger test set.
The initial values were gathered on a small number of boards,
and have been found to fail on some boards under load.
PERST_GPIO and POWER_GPIO are currently swapped.
Fix the GPIO assignments as per the board schematics.
Besides converting the LS-XHL and LS-CHLv2 to generic board, fix a typo
which accidentally reverted the bootsource to 'hdd' although the default
bootsource should be 'legacy'.
Cc: Tom Rini <trini@ti.com>
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Signed-off-by: Michael Walle <michael@walle.cc>
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Acked-by: Michal Simek <monstr@monstr.eu>
This commit allows to build Panasonic UniPhier family:
PH1-LD4, PH1-Pro4, PH1-sLD8
These are used by Panasonic UniPhier SoC family.
The driver for on-chip UART used on Panasonic UniPhier platform.
The SPL-mode driver for Denali(Cadence) NAND Flash Memory Controller IP.
This driver requires two CONFIG macros:
- CONFIG_SPL_NAND_DENALI
Define to enable this driver.
- CONFIG_SYS_NAND_BAD_BLOCK_POS
Specify bad block mark position in the oob space. Typically 0.
Cc: Chin Liang See <clsee@altera.com>
Cc: Scott Wood <scottwood@freescale.com>
Commit 3eb3e72a3f66 (nand/denali: Adding Denali NAND driver support)
introduced some new options, and some of them were documented by
commit f9860cf081ef (nand/denali: Document CONFIG symbols).
This commit allows users to enable/disable them via Kconfig
with more detailed help docs.
This patch add HUSH command parser
Signed-off-by: Gerald Kerma <drEagle@doukki.net>
Changes in v1:
- add HUSH command parser
This patch redefine MTDPARTS
Changes in v1:
- redefine MTDPARTS
