Sinlinx SinA33 has a USB OTG port, but VBUS is controlled manually from
a jumper pad.
Enable OTG in gadget mode, as well as the download gadget and related
functions.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Sinlinx SinA33 has 1 USB host port. Enable EHCI_HCD support for it.
Also enable USB mass storage support so we can access USB sticks.
Sinlinx SinA33 uses PB4 for mmc0 card detect.
The NanoPi NEO is a simple h3 board with 512MB RAM, ethernet, one usb
and one usb OTG connector.
Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl>
With sunxi-musb musb_lowlevel_init() can fail when a charger; or no cable
is plugged into the otg port.
To avoid leaking the struct musb allocated by musb_init_controller()
on repeated musb_usb_probe() calls, we were caching its result.
But musb_init_controller() does more, such as calling sunxi_musb_init()
which enables the clocks.
Not calling sunxi_musb_init() causes the musb controller to stop working
after a "usb reset" since that calls musb_usb_remove() which disables the
clocks.
This commit fixes this by removing the caching of the struct returned
from musb_init_controller(), it replaces this by free-ing the allocated
memory in musb_usb_remove() and calling musb_usb_remove() on
musb_usb_probe() errors to ensure proper cleanup.
While at it also make musb_usb_probe() and musb_usb_remove() static.
The Linux kernel musb driver expects VBUS to be off while initializing
musb. Having it on results in a repeating string of warnings, followed
by an unusable peripheral. The peripheral is only usable after
physically removing the OTG adapter, letting musb reset its state.
This partially reverts commit c9f8947e6604 ("sunxi: usb-phy: Never
power off the usb ports")
When cold-booting the ldoio0/1 regulators are always off / the
gpios are always at tristate. But when re-booting from android these
are sometimes on. Disable them at axp_init time (iow as early as possible)
to remove this difference between a cold boot and a reboot.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
New CONFIG options should be added via Kconfig. To help prevent new ad-hoc
CONFIGs from being added, give a build error when these are detected.
Add a list of ad-hoc CONFIG options that don't use Kconfig. This can be used
to check that new ones are not being added.
Convert CONFIG_SPL_YMODEM_SUPPORT to Kconfig
Move this option to Kconfig and tidy up existing uses.
This option is not used. Drop it.
CONFIG_SPL_NET_VCI_STRING
There are a few options which use lower case. We should use upper case for
all CONFIG options.
[trini: Add usbtty/nand hunk to include/configs/spear3xx_evb.h]
A few boards define this in a header file which is incorrect. It means that
Kconfig options that rely on this cannot be used. Move it.
Note that quite a few boards defined this options but do not appear to
actually use SPL:
BSC9132QDS_NOR_DDRCLK100_SECURE
BSC9132QDS_NOR_DDRCLK133_SECURE
BSC9132QDS_SDCARD_DDRCLK100_SECURE
BSC9132QDS_SDCARD_DDRCLK133_SECURE
BSC9132QDS_SPIFLASH_DDRCLK100_SECURE
BSC9132QDS_SPIFLASH_DDRCLK133_SECURE
C29XPCIE_NOR_SECBOOT
P1010RDB-PA_36BIT_NAND_SECBOOT
P1010RDB-PA_36BIT_SPIFLASH_SECBOOT
P1010RDB-PA_NAND_SECBOOT
P1010RDB-PA_NOR_SECBOOT
P1010RDB-PB_36BIT_NOR_SECBOOT
P1010RDB-PB_36BIT_SPIFLASH_SECBOOT
P1010RDB-PB_NAND_SECBOOT
P1010RDB-PB_NOR_SECBOOT
P3041DS_SECURE_BOOT
P4080DS_SECURE_BOOT
P5020DS_NAND_SECURE_BOOT
P5040DS_SECURE_BOOT
T1023RDB_SECURE_BOOT
T1024QDS_DDR4_SECURE_BOOT
T1024QDS_SECURE_BOOT
T1024RDB_SECURE_BOOT
T1040RDB_SECURE_BOOT
T1042D4RDB_SECURE_BOOT
T1042RDB_SECURE_BOOT
T2080QDS_SECURE_BOOT
T2080RDB_SECURE_BOOT
T4160QDS_SECURE_BOOT
T4240QDS_SECURE_BOOT
ls1021aqds_nor_SECURE_BOOT
ls1021atwr_nor_SECURE_BOOT
ls1043ardb_SECURE_BOOT
For these boards CONFIG_SPL_DM will no-longer be defined in SPL. But since
they apparently don't have an SPL, this should not matter.
Some of the SPL options have TPL equivalents. Add these to Kconfig so that
we can convert these options over to work from Kconfig.
There are a lot of SPL options in U-Boot to enable various features and
drivers. Currently these do not use Kconfig. Add them to Kconfig along
with suitable help, and drop them from the README.
At present TPL uses the same options as SPL support. In a few cases the board
config enables or disables the SPL options depending on whether
CONFIG_TPL_BUILD is defined.
With the move to Kconfig, options are determined for the whole build and
(without a hack like an #undef in a header file) cannot be controlled in this
way.
Create new TPL options for these and update users. This will allow Kconfig
conversion to proceed for these boards.
