2014-04-17board: sandpoint: delete an unused source fileMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Jim Thompson <jim@musenki.com>
2014-04-17board: ppmc8260: delete an unused source fileMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Brad Kemp <Brad.Kemp@seranoa.com>
2014-04-17powerpc: mpc8xx: delete an unused source fileMasahiro Yamada
References to the wireless keyboard should also be removed from README.console. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2014-04-17board: altera: delete unused source filesMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Scott McNutt <smcnutt@psyent.com>
2014-04-17board: evb64260: delete an unused source fileMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Nye Liu <nyet@zumanetworks.com>
2014-04-17board: samsung: delete unused source filesMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Mateusz Zalega <m.zalega@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Mateusz Zalega <m.zalega@samsung.com>
2014-04-17floppy: delete unused filesMasahiro Yamada
2014-04-17mtd: delete unused filesMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Scott Wood <scottwood@freescale.com>
2014-04-17board: esd: remove remainders of dead boardsMasahiro Yamada
Commit 99bcad18 deleted ADCIOP and DASA_SIM board support but missed to delete board/esd/adciop and board/esd/dasa_sim. It also missed to add entries to doc/README.scrapyard. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Stefan Roese <sr@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2014-04-17cosmetic: README.scrapyard: fix false removed date and commitMasahiro Yamada
Describe removed date in the form of YYYY-MM-DD, not YYYY-DD-MM. And wrong commit hash also should be fixed. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Marek Vasut <marex@denx.de> Acked-by: Marek Vasut <marex@denx.de>
2014-04-17cosmetic: README.scrapyard: sort in reverse chronological orderMasahiro Yamada
2014-04-17Merge branch 'next'Tom Rini
2014-04-17Start the deprecation process for generic boardSimon Glass
We should move forward to remove the old board init code. Add a prominent message to encourage maintainers to get started on this work. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-04-14Prepare v2014.04v2014.04Tom Rini
2014-04-14arm: kzm9g: Add CONFIG_SYS_GENERIC_BOARDTetsuyuki Kobayashi
Add CONFIG_SYS_GENERIC_BOARD to use common/board_[fr].c for kzm9g. Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp> Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-04-14i2c: sh_i2c: bugfix: i2c probe command does not workTetsuyuki Kobayashi
This is regression of commit 2035d77d i2c: sh_i2c: Update to new CONFIG_SYS_I2C framework Before commit 2035d77d, i2c probe command works properly on kzm9g board. KZM-A9-GT# i2c probe Valid chip addresses: 0C 12 1D 32 39 3D 40 60 After commit 2035d77d, i2c probe command does not work. KZM-A9-GT# i2c probe Valid chip addresses: 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 10 11 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F 20 21 22 23 24 25 26 27 28 29 2A 2B 2C 2D 2E 2F 30 31 32 33 34 35 36 37 38 39 3A 3B 3C 3D 3E 3F 40 41 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F 50 51 52 53 54 55 56 57 58 59 5A 5B 5C 5D 5E 5F 60 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 7B 7C 7D 7E 7F sh_i2c_probe() calls sh_i2c_read(), but read length is 0. So acutally it does not read device at all. This patch prepares dummy buffer and read data into it. Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp> Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-04-11board:tricorder: fixup SPL OOB layoutAndreas Bießmann
Commit d016dc42cedbf6102e100fa9ecb58462edfb14f8 changed the layout of BCH8 SW on omap3 boards. We need to adopt the ecc layout for the nand_spl_simle driver to avoid wrong ecc errors. Signed-off-by: Andreas Bießmann <andreas.biessmann@corscience.de> Cc: Thomas Weber <thomas.weber@corscience.de> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-04-11board:tricorder: enable omap_gpio clocksAndreas Bießmann
2014-04-11board:tricorder: always work with valid eeprom dataAndreas Bießmann
Commit 890880583d84607e36b52a785a96b167728bbf73 introduced EEPROM parsing and board detection but faild to return a valid tricorder_eeprom struct for backup case. When pressing S200 while reading EEPROM we ignore the value. We returned falsely a tricorder_eeprom struct with uninitialized data which is just garbage. Initialize it by zeroing the whole structure. Signed-off-by: Andreas Bießmann <andreas.biessmann@corscience.de> Cc: Thomas Weber <thomas.weber@corscience.de> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-04-11arm:board:trats2:FIX: Clear INFORM4 and INFORM5 registers at correct bootŁukasz Majewski
During switch to device tree, commit 1ecab0f has removed this code. INFORM4 and INFORM5 registers are used by TRATS2 first stage bootloader for providing recovery. For normal operation, those two must be cleared out. This error emerges when one force reset from u-boot's command line for three times. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2014-04-11kbuild: fix a bug in regeneration of linker scriptsMasahiro Yamada
In some use cases, SPL linker script was not updated even when it should be. For instance, $ make tricoder_config all [ build complete ] ... modify include/configs/tricoder.h $ make spl/u-boot-spl.lds should be updated in this case, but it wasn't. To fix this problem, linker scripts generation should be handled by $(call if_changed_dep,...) rather than by $(call if_changed,...). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reported-by: Andreas Bießmann <andreas.devel@googlemail.com> Tested-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-04-08Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile include/configs/trats.h include/configs/trats2.h include/mmc.h
2014-04-08arm64 patch: gicv3 supportDavid Feng
This patch add gicv3 support to uboot armv8 platform. Changes for v2: - rename arm/cpu/armv8/gic.S with arm/lib/gic_64.S - move smp_kick_all_cpus() from gic.S to start.S, it would be implementation dependent. - Each core initialize it's own ReDistributor instead of master initializeing all ReDistributors. This is advised by arnab.basu <arnab.basu@freescale.com>. Signed-off-by: David Feng <fenghua@phytium.com.cn>
2014-04-07bootstage: arm: fix fdt stashing codeMela Custodio
The conditional is using a variable that is not defined. Signed-off-by: Rommel G Custodio <sessyargc+u-boot@gmail.com>
2014-04-07ARMv8: fix bug for flush data cache by set/wayLeo Yan
When flush the d$ with set/way instruction, it need calculate the way's offset = log2(Associativity); but in current uboot's code, it use below formula to calculate the offset: log2(Associativity * 2 - 1), so finally it cannot flush data cache properly. Signed-off-by: Leo Yan <leoy@marvell.com>
2014-04-07armv8: Flush dcache before switching to EL2York Sun
For ARMv8, U-boot has been running at EL3 with cache and MMU enabled. Without proper setup for EL2, cache and MMU are both disabled (out of reset). Before switching, we need to flush the dcache to make sure the data is in the main memory. Signed-off-by: York Sun <yorksun@freescale.com> Acked-by: David.Feng <fenghua@phytium.com.cn>
2014-04-07arm: vf610: fix double iomux configuration for vf610twr boardMarcel Ziswiler
Get rid of double VF610_PAD_DDR_A15__DDR_A_15 iomux configuration. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2014-04-07arm: vf610: add enet1 supportMarcel Ziswiler
This patch contains several changes required for second Ethernet (enet1/RMII1) port on vf610 - ANADIG PLL5 control definitions required for Ethernet RMII1 clock - Secondary Ethernet (enet1) MAC RMII1 base address definition - RMII1 iomux definitions - VF610_PAD_PTA6__RMII0_CLKOUT iomux definition required for internal (e.g. crystal-less) Ethernet clocking. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> [stefan@agner.ch: regrouped patch] Signed-off-by: Stefan Agner <stefan@agner.ch>
2014-04-07arm: vf610: add uart0 clock/iomux definitionsMarcel Ziswiler
Add CCM_CCGR0_UART0_CTRL_MASK clock definition and add TX/RX iomux definitions for UART0 (aka. SCI0). Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> [stefan@agner.ch: regrouped patch] Signed-off-by: Stefan Agner <stefan@agner.ch>
2014-04-07arm: vf610: fix anadig register structMarcel Ziswiler
The anadig_reg structure started at the wrong offset (fixed by adding reserved_0x000[4]), was missing some reserved field required for alignment purpose (reserved_0x094[3] between pll4_denom and pll6_ctrl) and further contained a too short reserved field causing further miss- alignment (reserved_0x0C4[7]). Also, rename all the reserved fields and using a memory offset based scheme for. Discovered and tested by temporarily putting the following debug instrumentation into board_init(): struct anadig_reg *anadig = (struct anadig_reg *)ANADIG_BASE_ADDR; printf("&anadig->pll3_ctrl=0x%p\n", &anadig->pll3_ctrl); printf("&anadig->pll5_ctrl=0x%p\n", &anadig->pll5_ctrl); Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> [stefan@agner.ch: regrouped patch] Signed-off-by: Stefan Agner <stefan@agner.ch>
2014-04-07build:arm: Remove setting of CROSS_COMPILE environment variableŁukasz Majewski
After Kbuild introduction, the CROSS_COMPILE environment variable has been set to some default value (prefix arm-linux-). This shall be removed since it breaks building u-boot for native arm target (like qemu ARM). Moreover not all compilers have arm-linux- prefix. Additionally the u-boot cross compiles with CROSS_COMPILE= set explicitly- e.g.: CROSS_COMPILE=/ .... /arm-v7a-linux-gnueabi- make Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-04-07Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-04-07MX6: Enable ARM errata workaround 794072 and 761320Nitin Garg
Since MX6 is Cortex-A9 r2p10, enable software workaround for errata 794072 and 761320. Signed-off-by: Nitin Garg <nitin.garg@freescale.com>
2014-04-07ARM: Add workaround for Cortex-A9 errata 761320Nitin Garg
Full cache line writes to the same memory region from at least two processors might deadlock the processor. Exists on r1, r2, r3 revisions. Signed-off-by: Nitin Garg <nitin.garg@freescale.com> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-04-07ARM: Add workaround for Cortex-A9 errata 794072Nitin Garg
A short loop including a DMB instruction might cause a denial of service on another processor which executes a CP15 broadcast operation. Exists on r1, r2, r3, r4 revisions. Signed-off-by: Nitin Garg <nitin.garg@freescale.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
2014-04-07armv8/cache: Change cache invalidate and flush functionYork Sun
When SoC first boots up, we should invalidate the cache but not flush it. We can use the same function for invalid and flush mostly, with a wrapper. Invalidating large cache can ben slow on emulator, so we postpone doing so until I-cache is enabled, and before enabling D-cache. Signed-off-by: York Sun <yorksun@freescale.com> CC: David Feng <fenghua@phytium.com.cn>
2014-04-07armv8/cache: Flush D-cache, invalidate I-cache for relocationYork Sun
If D-cache is enabled, we need to flush it, and invalidate i-cache before jumping to the new location. This should be done right after relocation. Signed-off-by: York Sun <yorksun@freescale.com> CC: David Feng <fenghua@phytium.com.cn>
2014-04-07armv8/cache: Consolidate setting for MAIR and TCRYork Sun
Move setting for MAIR and TCR to cache_v8.c, to avoid conflict with sub-architecture. Signed-off-by: York Sun <yorksun@freescale.com> CC: David Feng <fenghua@phytium.com.cn>
2014-04-07arm: Handle .gnu.hash section in ldscriptsAndreas Färber
Avoids "could not find output section .gnu.hash" ld.bfd errors on openSUSE. Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Signed-off-by: Andreas Färber <afaerber@suse.de> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-04-07socfpga: Adding Clock Manager driverChin Liang See
Clock Manager driver will be called to reconfigure all the clocks setting based on user input. The input are passed to Preloader through handoff files Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> CC: Pavel Machek <pavel@denx.de> Cc: Dinh Nguyen <dinguyen@altera.com> Acked-by: Pavel Machek <pavel@denx.de>
2014-04-04Revert "Start the deprecation process for generic board"Tom Rini
We've run into a non-trivial conversion to CONFIG_SYS_GENERIC_BOARD so we'll postpone this notice until right after v2014.04 is out. This reverts commit 36c4b1d98059244c34ec3327d9cc9f3c552fd01b. Signed-off-by: Tom Rini <trini@ti.com>
2014-04-04arm: mxs: Add support for generating signed BootStreamMarek Vasut
This patch adds the groundwork for generating signed BootStream, which can be used by the HAB library in i.MX28. We are adding a new target, u-boot-signed.sb , since the process for generating regular non-signed BootStream is much easier. Moreover, the signed bootstream depends on external _proprietary_ _binary-only_ tool from Freescale called 'cst', which is available only under NDA. To make things even uglier, the CST or HAB mandates a kind-of circular dependency. The problem is, unlike the regular IVT, which is generated by mxsimage, the IVT for signed boot must be generated by hand here due to special demands of the CST. The U-Boot binary (or SPL binary) and IVT are then signed by the CST as a one block. But here is the problem. The size of the entire image (U-Boot, IVT, CST blocks) must be appended at the end of IVT. But the size of the entire image is not known until the CST has finished signing the U-Boot and IVT. We solve this by expecting the CST block to be always 3904B (which it is in case two files, U-Boot and the hand-made IVT, are signed in the CST block). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2014-04-04Merge branch 'master' of git://git.denx.de/u-boot-arm into masterStefano Babic
Conflicts: arch/arm/cpu/arm926ejs/mxs/mxsimage.mx23.cfg arch/arm/cpu/arm926ejs/mxs/mxsimage.mx28.cfg Signed-off-by: Stefano Babic <sbabic@denx.de>
2014-04-04Revert "arm: mxs: Add support for generating signed BootStream"Stefano Babic
This reverts commit 53e6b14e037c9f72e6d03244c32d8d597e2e0234. Patch does not merge anymore with u-boot-arm and must be rebased. Signed-off-by: Stefano Babic <sbabic@denx.de>
2014-04-02trats/trats2: enable CONFIG_RANDOM_UUIDPrzemyslaw Marczak
This change enables automatically uuid generation by command gpt. In case of updating partitions layout user don't need to care about generate uuid manually. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Piotr Wilczek <p.wilczek@samsung.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: trini@ti.com
2014-04-02cmd:gpt: randomly generate each partition uuid if undefinedPrzemyslaw Marczak
Changes: - randomly generate partition uuid if any is undefined and CONFIG_RAND_UUID is defined - print debug info about set/unset/generated uuid - update doc/README.gpt Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Piotr Wilczek <p.wilczek@samsung.com> Cc: Tom Rini <trini@ti.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Lukasz Majewski <l.majewski@samsung.com>
2014-04-02new commands: uuid and guid - generate random unique identifierPrzemyslaw Marczak
Those commands basis on implementation of random UUID generator version 4 which is described in RFC4122. The same algorithm is used for generation both ids but string representation is different as below. char: 0 9 14 19 24 36 xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx UUID: be be be be be GUID: le le le be be Commands usage: - uuid [<varname>] - guid [<varname>] The result is saved in environment as a "varname" variable if argument is given, if not then it is printed. New config: - CONFIG_CMD_UUID Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: trini@ti.com
2014-04-02lib: uuid: add functions to generate UUID version 4Przemyslaw Marczak
This patch adds support to generate UUID (Universally Unique Identifier) in version 4 based on RFC4122, which is randomly. Source: https://www.ietf.org/rfc/rfc4122.txt Changes: - new configs: - CONFIG_LIB_UUID for compile lib/uuid.c - CONFIG_RANDOM_UUID for functions gen_rand_uuid() and gen_rand_uuid_str() - add configs dependency to include/config_fallbacks.h for lib uuid. lib/uuid.c: - add gen_rand_uuid() - this function writes 16 bytes len binary representation of UUID v4 to the memory at given address. - add gen_rand_uuid_str() - this function writes 37 bytes len hexadecimal ASCII string representation of UUID v4 to the memory at given address. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Lukasz Majewski <l.majewski@samsung.com> [trini: Add CONFIG_EFI_PARTITION to fallbacks] Signed-off-by: Tom Rini <trini@ti.com>
2014-04-02lib: uuid: code refactor for proper maintain between uuid bin and stringPrzemyslaw Marczak
Changes in lib/uuid.c to: - uuid_str_to_bin() - uuid_bin_to_str() New parameter is added to specify input/output string format in listed functions This change allows easy recognize which UUID type is or should be stored in given string array. Binary data of UUID and GUID is always stored in big endian, only string representations are different as follows. String byte: 0 36 String char: xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx string UUID: be be be be be string GUID: le le le be be This patch also updates functions calls and declarations in a whole code. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: trini@ti.com
2014-04-02part_efi: move uuid<->string conversion functions into lib/uuid.cPrzemyslaw Marczak
This commit introduces cleanup for uuid library. Changes: - move uuid<->string conversion functions into lib/uuid.c so they can be used by code outside part_efi.c. - rename uuid_string() to uuid_bin_to_str() for consistency with existing uuid_str_to_bin() - add an error return code to uuid_str_to_bin() - update existing code to the new library functions. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: trini@ti.com
