When Ctrl-C is pressed, just exited quietly. There is no sense in displaying
a stack trace since buildman will always be in the same place: waiting for
threads to complete building all the jobs on the queue.
This serves no real purpose, since when we are not active, we exit. Drop it.
It is annoying that buildman does not respond cleanly to Ctrl-C or SIGINT,
particularly on machines with lots of CPUS. Unfortunately queue.join()
blocks the main thread and does not allow it to see the signal. Use a
separate thread instead,
If patman is installed on the machine (e.g. in the standard dist-packages
directory), it will find libraries from there in preference to our local
libraries. Adjust the order of the path to ensure that local libraries are
found first.
Make it clear when buildman actually starts building. This happens when it
has prepared the threads, working directory and output directories.
When buildman starts, it prepares its output directory by removing any old
build directories which will not be used this time. This can happen if a
previous build left directories around for commit hashes which are no-longer
part of the branch.
This can take quite a while, so print a message to indicate what is going
on.
On a machine with a lot of CPUs this prints a lot of useless lines of the
form:
Cloning repo for thread <n>
Adjust the output so that these all appear on one line, and disappear when
the cloning is complete.
Note: This cloning is actually unnecessary and very wasteful on disk space
(about 3.5GB each time). It would be better to create symlinks.
Output which does not include a newline will not be displayed unless
flushed. Add a flush to ensure that it becomes visible.
Add silicon ID code for AM437x silicon. This can be used to print
the cpu info using CONFIG_DISPLAY_CPUINFO.
Also printing "CPU :" along with cpu name in order to be consistent
with other OMAP platforms.
By default saveenv option is not supported for SPL. This patch
enable the support for save environment variable for SPL build.
Enable save environment support in SPL after setenv. By default
the saveenv option is not provided in SPL, but some boards need
this support in 'Falcon' boot, where SPL need to boot from
different images based on environment variable set by OS. For
example OS may set "reboot_image" environment variable to
"recovery" inorder to boot recovery image by SPL. The SPL read
"reboot_image" and act accordingly and change the reboot_image
to default mode using setenv and save the environemnt.
Signed-off-by: Ravi Babu <ravibabu@ti.com>
Reviewed-by: Simon Glass <sig@chromium.org>
change in v1:
- dropped SUPPORT, use CONFIG_SPL_SAVEENV
- updates the comments in mmc_private.h
Boards where ECs that use a I2C port != 0 specify this in the
devicetree file via the google,remote-bus property.
Previously this was ignored and hardcoded to port 0.
Signed-off-by: Moritz Fischer <moritz.fischer@ettus.com>
Cc: u-boot@lists.denx.de
As a standard practice complex definitions should be protected
with parentheses, as it might fail when used in a complex if
statements.
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
Add DTS support for dra72 evm Rev C which has the following
changes
* Two ethernet ports now instead of the single one in rev B.
* DP83867 ethernet phy instead of DP838865.
Cc: Vignesh R <vigneshr@ti.com>
The normal longjmp command allows for a caller to pass the return value
of the setjmp() invocation. This patch adds that semantic to the arm
implementation of it and adjusts the efi_loader call respectively.
The default lockname is set to /var/lock. This limits the
usage of this application where OS uses different lockfile
location parameter.
For example, In case of android, the default lock
path location is /data.
Hence by providing the command line option to input lockfile
path will be useful to reuse the tool across multiple
operating system.
usage: ./fw_printenv -l <lockfile path>
The SPL size for dra7x platform increased beyond 64K,
increasing the size to 256K to cater for future enhancement.
removing CONFIG_SPL_ENV_SUPPORT defined in header files
due to moved to kconfig option for CONFIG_SPL_ENV_SUPPORT
This reverts commit 82f5279b0cd99a9163d34cfe926d0316d9dc0d37.
The build failure of k2*evm boards was fixed in a different way by
the previous commit. It is nasty to patch generic drivers around
with #ifdef CONFIG_CLK just for the KeyStone's matter.
The KeyStone platform has its own clk_get_rate() but its prototype
is different from that of the common-clk (clk-uclass) framework.
Prefix the KeyStone specific implementation with ks_ in order to
avoid name-space conflict.
Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
Due to clock source restrictions on i.MX6, certain pixel clock rates can
not be supported. Hence default the resolution/frame rate during boot to a
supported value by passing video bootargs 1024x768@60 for
HDMI (Display Port1) and LVDS (Display Port2) on B850v3.
Signed-off-by: Ken Lin <ken.lin@advantech.com.tw>
Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com>
These two functions are neither defined nor referenced.
Our build system still parses ad-hoc CONFIG options in header files
and generates include/autoconf.mk so that Makefiles can reference
them. This gimmick was introduced in the pre-Kconfig days and will
be kept until Kconfig migration is completed.
The include/autoconf.mk is generated like follows:
[1] Preprocess include/common.h with -DDO_DEPS_ONLY and
retrieve macros into include/autoconf.mk.tmp
[2] Reformat include/autoconf.mk.dep into include/autoconf.mk
with tools/scripts/define2mk.sed script
[3] Remove include/autoconf.mk.tmp
Here, include/autoconf.mk.tmp is similar to u-boot.cfg, which is
also generated by preprocessing include/config.h with -DDO_DEPS_ONLY.
In other words, there is much overlap among include/autoconf.mk and
u-boot.cfg build rules.
So, the idea is to split the build rule of include/autoconf.mk
into two stages. The first preprocesses headers into u-boot.cfg.
The second parses the u-boot.cfg into include/autoconf.mk. The
build rules of u-boot.cfg in Makefile and spl/Makefile will be gone.
I do not remember why I wrote the code like this, but let's make it
a bit more readable.
I am going to move the build rule of u-boot.cfg. Before that,
no_new_adhoc_configs_check must be tweaked to not depend on it.
The ad-hoc option check can be done at the end of build, along
with other checks.
The command suggested in this comment block is wrong; it would not
rip off CONFIG options that had already been converted to Kconfig.
Instead, we should use the scripts/build-whitelist.sh tool.
These are not CONFIG options (detected by my eyes).
CONFIG_SPL_BUILD and CONFIG_TPL_BUILD are build options defined only
for building SPL and TPL, respectively.
The others are just mentioned in comment blocks.
Now, scripts/build-whitelist.sh never picks up new options. Once
we kill these false ones, they will never revive.
It is a good practice to drop an option from the whitelist when we
convert it to Kconfig, but we may sometimes forget to do that.
So, it might be a good idea to sync the whitelist from time to time.
This commit was generated by:
Looks like we had a bit progress...
If somebody adds references to new CONFIG options in source files,
they will be added in the whitelist when we sync it. (For example,
if we run scripts/build-whitelist.sh against commit 42f75050667b,
new options CONFIG_SPL_DFU_SUPPORT and CONFIG_USB_XHCI_UNIPHIER will
appear in the list.)
In order to make steady progress of Kconfig migration, we want to
only decrease whitelist options, but never increase.
So, when we update the whitelist, we should create a temporary list,
then take the intersection of the temporary one and the current one.
Commit f225d39d3093 ("vexpress: Check TC2 firmware support before defaulting
to nonsec booting") added support to check if the firmware on TC2 is
configured appropriately before booting in nonsec/hyp mode.
However when booting in non-secure/hyp mode, CCI control must be done in
secure firmware and can't be done in non-secure/hyp mode. In order to
ensure that, this patch disables the cci slave port inteface so that it
is not accessed at all.
Cc: Jon Medhurst <tixy@linaro.org>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Acked-by: Jon Medhurst <tixy@linaro.org>
Tested-by: Jon Medhurst <tixy@linaro.org>
When CONFIG_SILENT_CONSOLE is defined and the default environment has
silent=1 it is not possible for a user to make the console un-silent if
the environment is not available when console_init_f() is called (for
example because the environment is in SPI).
Add a new helper function console_update_silent() and call it from both
console_init_f() and console_init_r().
Signed-off-by: Chris Packham <judge.packham@gmail.com>
Now that fastboot options are available in Kconfig, we can migrate them
from DRA7 header to corresponding DRA7 defconfigs.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
To create the soc environment variable we concatenate two strings
on the stack. So far, strcat has been used for the first string as
well as for the second string. Since the variable on the stack is
not initialized, the first strcat may not start using the first
entry in the character array. This then could lead to an buffer
overflow on the stack.
Enable device tree configuration and specify default device tree
for Toradex Colibri iMX7.
Use the external PMIC Ricoh RN5T567 to reliably restart the system.
Add device tree node for Ricoh RN5T567. Currently we do not need
the individual DC/DC converters or LDO's (and they are also not
yet supported by the driver).
Add device model enabled PMIC driver for Ricoh RN5T567 PMIC used
on Colibri iMX7.
We now use device tree to provide SoC data to the UART driver, there
is no need for the legancy UART platform data.
Remove legancy I2C config and code in favor of upcomming DM/DT
enable I2C support.
Add base device for NXP i.MX 7Solo/7Dual. The two SoC are very
similar and hence can share the same device tree for boot loaders
purpose.
Add pinctrl defines for NXP i.MX 7Solo/7Dual SoC. The pinctrl format
is compatible to the Linux kernel, hence this file is a simple copy
from the Linux kernel (commit 97f5c1817b7e).
It is not usual that drivers announce when they have been initialized.
use dev_dbg to announce device initialization.
Support instatiation through device tree. Also parse the fsl,dte-mode
property to determine whether DTE mode shall be used.
This script looks for env_common.o object file and extracts from it default
u-boot environment, which is afterwards printed on standard output.
Usage example:
get_default_envs.sh > u-boot-env-default.txt
The generated text file can be used as input for mkenvimage.
Signed-off-by: Lukasz Majewski <l.majewski@majess.pl>
Register definitions needed for configuring the
ePWM module.
Signed-off-by: Tomas Melin <tomas.melin@vaisala.com>
Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl>
Override the switch_to_hypervisor function to switch cpu to hypervisor
mode using the available ROM code hook early in the boot phase before
the boot loader checks for HYP mode.
Based on the work done by Jonathan Bergsagel jbergsagel@ti.com.
Cc: beagleboard-x15@googlegroups.com
Signed-off-by: Keerthy <j-keerthy@ti.com>
On some of the SoCs one cannot enable hypervisor mode directly from the
u-boot because the ROM code puts the chip to supervisor mode after it
jumps to boot loader. Hence introduce a weak function which can be
overridden based on the SoC type and switch to hypervisor mode in a
custom way.
Enable Linear Physical Address Extension mode which is a
prerequisite for hypervisor mode.
