On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
Patch queue for efi in 2018.03 - 2018-02-10
This time we have a few important bug fixes. Most noticable are:
- Fix OpenBSD loader with CONFIG_BLK=n
- Fix builds on various circumstances
- Add missing stubs so callers don't call NULL
- Bump UEFI revision to 2.7
efi_disk_register should return as status code (efi_status_t).
Disks with zero blocks should be reported as 'not ready' without throwing
an error.
This patch solves a problem running OpenBSD on system configured with
CONFIG_BLK=n (e.g. i.MX6).
Reported-by: Jonathan Gray <jsg@jsg.id.au>
Tested-by: Jonathan Gray <jsg@jsg.id.au>
Add stubs for UpdateCapsule, QueryCapsuleCapabilities, and
QueryVariableInfo.
README.efi describes two different concepts:
* U-Boot exposing the UEFI API
* U-Boot running on top of UEFI.
This patch splits the document in two.
Religious references are removed.
The separation of the concepts makes sense before detailing the internals
of U-Boot exposing the UEFI API in a future patch.
Change the return type of efi_driver_init() to efi_status_t.
efi_driver_init() calls efi_add_driver() which returns an efi_status_t
value. efi_driver_init() should not subject this value to a conversion to
int losing high bits on 64bit systems.
Currently the UEFI revision number in the system table header is set to
2.0.5. This version number does not refer to any existing version of the
UEFI standard.
Set the revision number to 2.7.
Reviewed-by: Mark Kettenis <kettenis@openbsd.org>
Currently we set the function pointer for the CreateEventEx boot service
to NULL. When called this would lead to an immediate failure.
A function stub is provided which handles the case that the boot service
is called without an event group and returns EFI_UNSUPPORTED otherwise.
For EFI binaries we need special CFLAGS.
They were specified for an object file that since has been replaced.
The bootefi command is missing in the online help for
bootefi bootmgr.
Before the patch an undefined constant EFI_SUBSYSTEM was used in the
crt0 code. The current version of binutils does not swallow the error.
https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=888403
The necessary constant IMAGE_SUBSYSTEM_EFI_APPLICATION is already
defined in pe.h. So let's factor out asm-generic/pe.h for the
image subsystem constants and use it in our assembler code.
IMAGE_SUBSYSTEM_SAL_RUNTIME_DRIVER does not exist in the specification
let's use IMAGE_SUBSYSTEM_EFI_ROM instead.
The include pe.h is only used in code maintained by Alex so let him be the
maintainer here too.
Reported-by: Andre Przywara <andre.przywara@arm.com>
Tested-by: Vagrant Cascadian <vagrant@debian.org>
config_fallbacks.h has some logic that sets HAVE_BLOCK_DEVICE
based on a list of enabled options. Moving HAVE_BLOCK_DEVICE to
Kconfig allows us to drastically shrink the logic in
config_fallbacks.h
[trini: Rename HAVE_BLOCK_DEVICE to CONFIG_BLOCK_DEVICE]
Migrate the base and sub-options to Kconfig. Note that we only enable
this in the base sandbox config now.
Cc: Alexey Brodkin <alexey.brodkin@gmail.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Is this driver still used anywhere? It's fishy that it's only enabled
in sandbox anymore.
config_fallback.h has some logic that checks a variety of options
and selects LIB_UUID if it hasn't already been selected. This
will all LIB_UUID in Kconfig and select this option for the list
of options to allow us to remove the logic from fallbacks
config_fallbacks.h had some logic to automatically select
LIB_RAND if RANDOM_UUID or CMD_UUID were set if LIB_HW_RAND wasn't
already selected. By migrating LIB_HW_RAND to Kconfig, we can
remove this check from config_fallbacks.h and put it into Kconfig
Reviewed-by: Lukasz Majewski <lukma@denx.de>
[trini: Turn into a choice, add NET_RANDOM_ETHADDR]
CONFIG_APBH_DMA
CONFIG_APBH_DMA_BURST
CONFIG_APBH_DMA_BURST8
Reviewed-by: Stefan Agner <stefan.agner@toradex.com>
[trini: Add in MMC as well]
There is no reason to unconditially select network commands as distro
defaults without networking enable.
There is no value to enable phylib without networking support.
Distro default configuration contains also dhcp and pxe setting which
can't working without enabling CONFIG_NET.
EFI is not required that's why it is not enabled.
Enable CONFIG_ENV_VARS_UBOOT_CONFIG for all STM32 boards
It allows to retrieve the SoC name into the "soc" environment
variable.
Signed-off-by: Christophe Priouzeau <christophe.priouzeau@st.com>
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
Reviewed-by: Vikas Manocha <vikas.manocha@st.com>
This converts CONFIG_NAND_MXS to Kconfig.
Simplify SPL_LDSCRIPT config by using the new arch Kconfig
configurations ARCH_MX23 and ARCH_MX28.
The motivation for moving MX28 selection to Kconfig is to be able
to better handle NAND MXS selection through Kconfig.
This selection method also aligns with the way other i.MX SoCs are
selected in U-Boot.
The motivation for moving MX23 selection to Kconfig is to be able
selected in U-Boot.
CONFIG_MXC_GPIO
Since CONFIG_PHY_SMSC was already in Kconfig, move this from
header file to defconfig
Since CONFIG_MXC_UART is already in Kconfig, move this from
the header to imx6q_logic_defconfig
Reviewed-by: Stefano Babic <sbabic@denx.de>
This commit cleans up the README.watchdog by removing the reminescent of
ADI's Blackfin architecture removed some time ago.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
This commit removes an attempt to workaround a previous compilation
warning that is is now fixed in "include/configs/ti_omap3_common.h".
Signed-off-by: Derald D. Woods <woods.technical@gmail.com>
This commit fixes the following compiler warnings when DM_SERIAL is
enabled.
---8<-------------------------------------------------------------------
CC spl/board/ti/evm/evm.o
In file included from /solution/scm/u-boot-master/board/ti/evm/evm.c:16:0:
/solution/scm/u-boot-master/include/ns16550.h:31:0: warning: "CONFIG_SYS_NS16550_REG_SIZE" redefined
#define CONFIG_SYS_NS16550_REG_SIZE (-1)
In file included from /solution/scm/u-boot-master/include/configs/omap3_evm.h:22:0,
from include/config.h:5,
from /solution/scm/u-boot-master/include/common.h:21,
from /solution/scm/u-boot-master/board/ti/evm/evm.c:14:
/solution/scm/u-boot-master/include/configs/ti_omap3_common.h:33:0: note: this is the location of the previous definition
# define CONFIG_SYS_NS16550_REG_SIZE (-4)
LD spl/board/ti/evm/built-in.o
CC spl/drivers/serial/ns16550.o
In file included from /solution/scm/u-boot-master/drivers/serial/ns16550.c:11:0:
from /solution/scm/u-boot-master/drivers/serial/ns16550.c:7:
LD spl/drivers/serial/built-in.o
The goal of this patch is to clean up the code related to choosing SPL
MMC boot mode.
The spl_boot_mode() now is called only in spl_mmc_load_image() function,
which is only compiled in if CONFIG_SPL_MMC_SUPPORT is enabled.
To achieve the goal, all per mach/arch implementations eligible for
unification has been replaced with one __weak implementation.
Acked-by: Michal Simek <michal.simek@xilinx.com> (For ZynqMP)
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
K2G ICE has a s25fl256s1 QSPI NOR flash connected to QSPI at CS0. Add DT
entries for the same.
Signed-off-by: Vignesh R <vigneshr@ti.com>
Add pinmux for QSPI pins on K2G ICE board.
Check if ns before and not after dereferencing it.
Indicated by cppcheck.
Commit ff98cb90514d ("part: extract MBR signature from partitions")
blindly switched allocated by ALLOC_CACHE_ALIGN_BUFFER buffer type from
"unsigned char" to "legacy_mbr" which caused allocation of size =
(typeof(legacy_mbr) * dev_desc->blksize) instead of just space enough
for "legacy_mbr" structure.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Rob Clark <robdclark@gmail.com>
Cc: Peter Jones <pjones@redhat.com>
Cc: Alexander Graf <agraf@suse.de>
Follow bootz's pattern by moving the booti_setup to arch/arm/lib.
This allows to use booti_setup in other paths, e.g booting
an Android image containing Image format.
Note that kernel relocation is move out of booti_setup and it is the
caller's responsibility to do it and allows them do it differently. say,
cmd/booti.c just do a manually, while in the bootm path, we can use
bootm_load_os(with some changes).
Signed-off-by: Bin Chen <bin.chen@linaro.org>
The second area of android image was intended to put a 2nd stage
bootloader but in practice were rarely used (in my knowledge).
An proposal was made to the AOSP to (re)use the second area as the dtb[1],
This patch itself doesn't depend on that proposal being accepted but it won't
be that helpful as well if that proposal won't be accepted. But don't do
any harm as well.
[1] https://android-review.googlesource.com/#/c/417447/
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
On detach UBI attempts to update fastmap after closing user interfaces
but at this point UBI volumes have already been free()'ed and fastmap
can no longer access these data structures.
Signed-off-by: Martin Townsend <mtownsend1973@gmail.com>
Cc: hs@denx.de
Cc: kmpark@infradead.org
Cc: richard@sigma-star.at
For '#ifndef CONFIG_DM_I2C' twsi_i2c_init() passes NULL as
4th parameter to __twsi_i2c_init().
Identified with cppcheck.
Simplify the driver logic by extracting a common send_buffer method.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Make the ihs_i2c driver DM-compatible; for legacy boards, the old functions are
retained within #ifdefs.
No board uses the new DM driver yet; this patch only lays the foundation for
future support.
Prepare the function interface of the ihs_i2c driver for DM conversion
in a future patch.
While we're at it, fix some style violations, and make the code more readable.
Make the fsl_i2c driver compatible with a live device tree.
Some functions in the fsl_i2c driver are declared as inline, even though
they are quite large, which needlessly increases the size of the
resulting binary.
This patch removes the inline declarations.
Fix some style violations in the fsl_i2c I2C driver, and use shorter
type names for variables in some cases.
'default' on a choice refers to the symbol selected by default, not to
the choice mode, so 'default n' is meaningless.
No functional changes. Optional choices implicitly default to n mode
(and there is no way to make them default to another mode).
Discovered in Kconfiglib (https://github.com/ulfalizer/Kconfiglib),
which prints the following warning:
warning: the default selection n (undefined) of <choice> (defined at drivers/usb/ulpi/Kconfig:3) is not contained in the choice
I've added a corresponding warning to the C tools too, which is
currently in linux-next: https://patchwork.kernel.org/patch/9983667/
Signed-off-by: Ulf Magnusson <ulfalizer@gmail.com>
There is no EMMC symbol in the "enable different boot versions for the
shc board" choice. SHC_EMMC was probably intended.
No functional changes. Kconfig choices fall back on using the first
(visible) symbol in the choice as the default if the default symbol is
not visible.
warning: the default selection EMMC (undefined) of <choice> (defined at board/bosch/shc/Kconfig:15) is not contained in the choice
