2015-02-12dm: omap3: Move driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config headers and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: tegra: Move driver model CONFIGs to KconfigSimon Glass
2015-02-12dm: x86: Move driver model CONFIGs to KconfigSimon Glass
2015-02-12dm: exynos: Move driver model CONFIGs to KconfigSimon Glass
2015-02-12dm: Move Raspberry Pi driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config header and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: Add CMD_DM and CMD_DEMO to KconfigSimon Glass
Add Kconfig settings for these two options. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-12dm: test: Add a Kconfig fileSimon Glass
Add a file to control driver model test features. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-12dm: Add Kconfig options for driver model SPL supportSimon Glass
The SPL support cannot be enabled yet, but we can add the Kconfig options in preparation for this. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: Expand and complete Kconfig in drivers/Simon Glass
Expand the help messages for each driver. Add missing Kconfig for I2C, SPI flash and thermal. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-12dm: Add Kconfig for driver/demoSimon Glass
Add a suitable Kconfig for this directory. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-12dm: i2c: Make API accessible even without CONFIG_DMSimon Glass
Make the driver model I2C API available always, even if driver model is not enabled. This allows for a 'soft' switch-over, where drivers can use the new structures in code which is compiled but not yet used. This makes migration easier in some cases. Fix up the existing drivers which define their own 'struct i2c_msg'. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-02-12dm: i2c: Add a dm_ prefix to driver model bus speed functionsSimon Glass
As with i2c_read() and i2c_write(), add a dm_ prefix to the driver model versions of these functions to avoid conflicts. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-02-12net: Use new checksum functionsSimon Glass
Drop the old checksum functions in favour of the new ones. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-02-12powerpc: ppc4xx: Enable CONFIG_DISPLAY_BOARDINFOStefan Roese
This also displays the "Board:" line in the bootup text with the generic board support code. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: ppc4xx: Add defaults for DT based booting to really workStefan Roese
These additional nodes need to be provided to get U-Boot to boot correctly on the Canyonlands / Glacier board: - chosen path to the console-uart - reg-shift set to 0 in the uart device nodes Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: ppc4xx: Change from OF_SEPARATE to OF_EMBEDStefan Roese
This is necessary, as ppc4xx has the reset vector located at the end of the U-Boot image. This needs to be flashed to the end of the NOR flash. Adding the dtb to the main U-Boot image will break booting on ppc4xx. This patch now embeds the dtb in the U-Boot image instead. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: Add linkage.h fileSimon Glass
This permits us to use linux/linkage.h on PowerPC machines. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: powerpc: ppc4xx: Move glacier to use driver model for serialSimon Glass
Adjust Kconfig to default to driver model for glacier, canyonlands and arches. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: Add serial driver for driver modelSimon Glass
This uses the ns16550 driver but sets up the clock at run-time. It does not seem to be available in the device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12ppc: amcc: Omit unneeded ns16550 CONFIG if using driver modelSimon Glass
This comes from the device tree or a call to get_uart_clock(). Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: ppc4xx: Use CONFIG_OF_CONTROL for canyonlands boardsSimon Glass
Enable CONFIG_OF_CONTROL so that U-Boot on these three boards uses a device tree for its configuration. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: ppc4xx: Allow the end of u-boot.bin to be foundSimon Glass
Define an _end symbol indicating the end of u-boot.bin. Also add some dummy words into the link script to ensure that u-boot.bin will always extend that far. There may be a better way of doing this. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: ppc4xx: Add a gpio.h header fileSimon Glass
This is required at present for device tree control. The ppc4xx does support GPIOs but does not seem to have a proper driver. So this file is empty. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: ppc4xx: Call board_init_f_mem() for generic boardSimon Glass
Call this function to set up our early memory. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: ppc4xx: dts: Bring in canyonlands device tree filesSimon Glass
The canyonlands.h config file works with canyonlands, glacier and arches boards. Bring in the device tree files for these from Linux 3.17. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: ppc4xx: canyonlands: Move to generic boardSimon Glass
Switch to generic board so that this board will not be broken/removed. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: ppc4xx: Add ramboot config for glacierSimon Glass
Add a new ramboot config for glacier so that it is possible to test U-Boot loaded over Ethernet instead of using JTAG. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: ppc4xx: Move CANYONLANDS/GLACIER/ARCHES to KconfigSimon Glass
Move these options to Kconfig and remove them from the CONFIG files. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: ppc4xx: canyonlands: config: Tidy up CONFIGs and config.mkSimon Glass
Many CONFIG options have an unnecessary value of 1. CONFIG_440 is set in the various board config files. Also simplify the CONFIG_440 check in config.mk Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: Permit device tree control of U-Boot (CONFIG_OF_CONTROL)Simon Glass
Enable this in the Kconfig so that PowerPC boards can use device tree to configure U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12Introduce board_init_f_mem() to handle early memory layoutSimon Glass
At present on some architectures we set up the following before calling board_init_f(): - global_data - stack - early malloc memory Adding the code to support early malloc and global data setup to every arch's assembler start-up is a pain. Also this code is not actually architecture-specific. We can use common code for all architectures and with a bit of care we can write this code in C. Add a new function to deal with this. It should be called after memory is available, with a pointer to the top of the area that should be used before relocation. The function will set things up and return the lowest memory address that it allocated/used. That can then be set as the top of the stack. Note that on some archs this function will use the stack, so the stack pointer should be set to same value as is pased to board_init_f_mem(). A margin of 128 bytes will be left for this stack, so that it is not overwritten. This means that 64 bytes is wasted by this early call. This is not strictly necessary on several more modern archs, so we could remove this at the cost of some arch-dependent code. With this function there is no-longer any need for the assembler code to zero global_data or set up the early malloc pointers. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12malloc_simple: Return NULL on malloc failure rather then calling panic()Hans de Goede
All callers of malloc should already do error checking, and may even be able to continue without the alloc succeeding. Moreover, common/malloc_simple.c is the only user of .rodata.str1.1 in common/built-in.o when building the SPL, triggering this gcc bug: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=54303 Causing .rodata to grow with e.g. 0xc21 bytes, nullifying all benefits of using malloc_simple in the first place. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-02-12i2c: s3c24x0: reduce transmission status timeoutPrzemyslaw Marczak
If no device is connected to I2C bus, the i2c probe command can take a lot of time for probe each address. This commit reduces the busy timeout to 10ms for standard and high speed modes. This doesn't break the transmission an also allow for properly probe the devices. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Changes v3: - new commit, after split the next one Tested-by: Simon Glass <sjg@chromium.org>
2015-02-12gpio: omap: Pass correct argument to _get_gpio_direction()Axel Lin
Pass bank rather than bank->base to _get_gpio_direction(). Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-02-12gpio: at91: Fix getting address of private dataAxel Lin
Use dev_get_priv() rather than dev_get_platdata() to get correct address of private data. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: Prevent "demo hello" and "demo status" segfaultsPeter Tyser
Segfaults can occur when a mandatory argument is not provided to "demo hello" and "demo status". Eg: => demo hello Segmentation fault (core dumped) Add a check to ensure all required arguments are provided. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-02-12RSA depends on DMChris Kuethe
Discovered while experimenting with signature checking on vexpress which doesn't typically use DM. Acked-by: Simon Glass <sjg@chromium.org>
2015-02-11sunxi: configs/sunxi-common.h: Enable CONFIG_CMD_PARTHans de Goede
The recent changes to config_distro_bootcmd.h require CONFIG_CMD_PART to be defined, as the default bootcmd not uses the "part" command. This fixes sunxi boards not booting with v2015.04-rc1. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-11Add linux/compiler-gcc5.h to fix builds with gcc5Hans de Goede
Add linux/compiler-gcc5/h from the kernel sources at: commit 5631b8fba640a4ab2f8a954f63a603fa34eda96b Author: Steven Noonan <steven@uplinklabs.net> Date: Sat Oct 25 15:09:42 2014 -0700 compiler/gcc4+: Remove inaccurate comment about 'asm goto' miscompiles Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-10Merge branch 'master' of git://git.denx.de/u-boot-x86Tom Rini
2015-02-10Merge branch 'master' of git://git.denx.de/u-boot-atmelTom Rini
2015-02-10Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
Conflicts: include/splash.h Signed-off-by: Tom Rini <trini@ti.com>
2015-02-10Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-02-10lcd: split splash code into its own functionNikita Kiryanov
lcd_logo() currently performs tasks well beyond just displaying the logo. It has code which displays splash image, it has logic which determines when the different display features are displayed, and it is coupled with the lcd console because it holds the responsibility of returning the lcd console base address. Make lcd_logo() just about the logo by: * Moving splash image display code into a dedicated function * Moving the logic regarding when various features are displayed to lcd_clear() (which is arguably not the correct name for housing such code either, but it is currently the most fitting location code wise) * Move the responsibility of setting the console base address to lcd_clear() too. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bo Shen <voice.shen@atmel.com> Tested-by: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Simon Glass <sjg@chromium.org> Cc: Anatolij Gustschin <agust@denx.de>
2015-02-10lcd: dt: extract simplefb supportNikita Kiryanov
We now have api functions that can support compiling simplefb code as its own module. Since this code is not part of the display functionality, extract it to its own file. Raspberry Pi is updated to accommodate the changes. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bo Shen <voice.shen@atmel.com> Tested-by: Josh Wu <josh.wu@atmel.com> Cc: Simon Glass <sjg@chromium.org> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stephen Warren <swarren@wwwdotorg.org>
2015-02-10lcd: rename bitmap_plot to better represent its functionalityNikita Kiryanov
The name "bitmap_plot" is misleading because it implies that this is a generic function capable of dealing with any bitmap, but its implementation only works with the logo data. Rename the function to better reflect this. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bo Shen <voice.shen@atmel.com> Tested-by: Josh Wu <josh.wu@atmel.com> Cc: Simon Glass <sjg@chromium.org> Cc: Anatolij Gustschin <agust@denx.de>
2015-02-10lcd: various cleanupsNikita Kiryanov
This cleanup mostly focuses on removing unnecessary whitespace and comments which are superfluous and/or do not conform to the coding style. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bo Shen <voice.shen@atmel.com> Tested-by: Josh Wu <josh.wu@atmel.com> Cc: Simon Glass <sjg@chromium.org> Cc: Anatolij Gustschin <agust@denx.de>
2015-02-10lcd: remove unused includesNikita Kiryanov
Remove unused includes. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bo Shen <voice.shen@atmel.com> Tested-by: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Simon Glass <sjg@chromium.org> Cc: Anatolij Gustschin <agust@denx.de>
2015-02-10lcd: introduce lcd_set_cmapNikita Kiryanov
Reduce the lcd_display_bitmap #ifdef complexity by extracting Atmel-specific code for setting cmap for bitmap images into a new function lcd_set_cmap(). A default version is implemented with the remainder of the code. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bo Shen <voice.shen@atmel.com> Tested-by: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Simon Glass <sjg@chromium.org> Cc: Anatolij Gustschin <agust@denx.de>
2015-02-10lcd: logo: move generic cmap setting to lcd_logo_set_cmap()Nikita Kiryanov
Get rid of platform-specific #ifdefs in bitmap_plot() by moving the generic case of setting cmap into the weak lcd_logo_set_cmap(). Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bo Shen <voice.shen@atmel.com> Tested-by: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Simon Glass <sjg@chromium.org> Cc: Anatolij Gustschin <agust@denx.de>
