This parameter should also be supported.
Tested-by: Ajay Kumar <ajaykumar.rs@samsung.com>
Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
The SPI transaction delay is supposed to be measured from the end of one
transaction to the start of the next. The code does not work that way, so
fix it.
An incorrect message version is passed to the EC in some cases and the
parameters of one function are switched.
Fix these problems.
It's usually a common pattern to free() the memory that we allocated.
Implement this here to stop leaking memory.
Cc: Michal Simek <michal.simek@xilinx.com>
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig.
Remove the redundant definition in config headers.
CONFIG_${CPU} is defined by Kconfig.
CONFIG_${ARCH} is defined by Kconfig.
Use "make <board>_defconfig" instead of "make <board>_config".
Invoke tools/genboardscfg.py to generate boards.cfg when it is missing.
- Use "make <board>_defconfig" instead of "make <board>_config".
- Invoke tools/genboardscfg.py to generate boards.cfg when it is
missing.
- Show "Building ${BOARD_NAME} board..." message.
(Prior to Kconfig, instead, mkconfig script displayed
"Configuring for ${BOARD_NAME} board..." but it was removed.)
Without this message, we cannot know which board is currently
being built.
- Do not show "# configuration written to .config".
This message is useless and just annoying for MAKEALL.
The old configuration script is no longer necessary.
Nor is boards.cfg a primary database.
We can generate it with the genboardscfg.py tool
based on the latest Kconfig, defconfig and MAINTAINERS.
Now the primary data for each board is in Kconfig, defconfig and
MAINTAINERS.
It is true boards.cfg is needed for MAKEALL and buildman and might be
useful to brouse all the supported boards in a single database.
But it would be painful to maintain the boards.cfg in sync.
So, this is the solution.
Add a tool to generate the equivalent boards.cfg file based on
We can keep all the functions of MAKEALL and buildman with it.
The best thing would be to change MAKEALL and buildman for not
depending on boards.cfg in the future, but it would take some time.
We have switched to Kconfig and the boards.cfg file is going to
be removed. We have to retrieve the board status and maintainers
information from it.
The MAINTAINERS format as in Linux Kernel would be nice
because we can crib the scripts/get_maintainer.pl script.
After some discussion, we chose to put a MAINTAINERS file under each
board directory, not the top-level one because we want to collect
relevant information for a board into a single place.
TODO:
Modify get_maintainer.pl to scan multiple MAINTAINERS files.
Suggested-by: Tom Rini <trini@ti.com>
This commit enables Kconfig.
Going forward, we use Kconfig for the board configuration.
mkconfig will never be used. Nor will include/config.mk be generated.
Kconfig must be adjusted for U-Boot because our situation is
a little more complicated than Linux Kernel.
We have to generate multiple boot images (Normal, SPL, TPL)
from one source tree.
Each image needs its own configuration input.
Usage:
Run "make <board>_defconfig" to do the board configuration.
It will create the .config file and additionally spl/.config, tpl/.config
if SPL, TPL is enabled, respectively.
You can use "make config", "make menuconfig" etc. to create
a new .config or modify the existing one.
Use "make spl/config", "make spl/menuconfig" etc. for spl/.config
and do likewise for tpl/.config file.
The generic syntax of configuration targets for SPL, TPL is:
<target_image>/<config_command>
Here, <target_image> is either 'spl' or 'tpl'
<config_command> is 'config', 'menuconfig', 'xconfig', etc.
When the configuration is done, run "make".
(Or "make <board>_defconfig all" will do the configuration and build
in one time.)
For futher information of how Kconfig works in U-Boot,
please read the comment block of scripts/multiconfig.py.
By the way, there is another item worth remarking here:
coexistence of Kconfig and board herder files.
Prior to Kconfig, we used C headers to define a set of configs.
We expect a very long term to migrate from C headers to Kconfig.
Two different infractructure must coexist in the interim.
In our former configuration scheme, include/autoconf.mk was generated
for use in makefiles.
It is still generated under include/, spl/include/, tpl/include/ directory
for the Normal, SPL, TPL image, respectively.
We are about to switch to Kconfig in the next commit.
But there are something to get done beforehand.
In Kconfig, include/generated/autoconf.h defines boolean
CONFIG macros as 1.
CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1.
Otherwise, when switching to Kconfig, the build log
would be sprinkled with warning messages like this:
warning: "CONFIG_SPL" redefined [enabled by default]
This commit adds more Kconfig files, which were written by hand.
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
Import
- scripts/kconfig/*
- include/linux/kconfig.h
from Linux 3.16-rc7.
Change-Id: I8e72b942b8816726773d5407ce405d68a1594389
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Add back the maintainers entries for Altera's SOCFPGA platform.
Signed-off-by: Dinh Nguyen <dinguyen@altera.com>
Signed-off-by: Chin Liang See <clsee@altera.com>
Add a whitespace between the name and the email address.
When switching to Kconfig, the first version of MAINTAINERS files
will be generated based on the boards.cfg file.
So, the maintainers field should be corrected even if it is a really
minor fix.
Acked-by: Bo Shen <voice.shen@atmel.com>
Since the command name 'make' may not be GNU Make on some platforms
such as FreeBSD, buildman should call scripts/show-gnu-make to get
the command name for GNU MAKE (and error out if it is not found).
Tested-by: Jeroen Hofstee <jeroen@myspectrum.nl>
such as FreeBSD, MAKEALL should call scripts/show-gnu-make to get
The GNU Make should be searched after parsing options because we want
to allow "MAKEALL -h" even if GNU Make is missing on the system.
U-Boot is expected to be built on various platforms.
We should keep in mind that the command 'make' is not always GNU Make,
while all the makefiles are written for GNU Make.
For example, on Linux, people generally do:
make <board>_config; make
But FreeBSD folks do
gmake <board>_config; gmake
(The command 'make' on FreeBSD is BSD Make, not GNU Make)
It is not a good idea to hard-code the command name 'make'
in MAKEALL or buildman.
They should call this helper script and get the command name
for GNU Make.
Having a form of whitelist to check if we know of a CPU core
and and obtain CBAR is a bit silly.
It doesn't scale (how about A12, A17, as well as other I don't know
about?), and is actually a property of the SoC, not the core.
So either it works and everybody is happy, or it doesn't and
the u-boot port to this SoC is providing the real address via
a configuration option.
The result of the above is that this code doesn't need to exist,
is thus forcefully removed.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
Generate the PSCI node in the device tree.
Also add a reserve section for the "secure" code that lives in
in normal RAM, so that the kernel knows it'd better not trip on
it.
Some architecture needs extra device tree setup. Instead of adding
yet another hook, convert arch_fixup_memory_node to be a generic
FDT fixup function.
[maz: collapsed 3 patches into one, rewrote commit message]
Signed-off-by: Ma Haijun <mahaijuns@gmail.com>
Allow the switch to a second stage secure monitor just before
switching to non-secure.
This allows a resident piece of firmware to be active once the
kernel has been entered (the u-boot monitor is dead anyway,
its pages being reused).
Implement core support for PSCI. As this is generic code, it doesn't
implement anything really useful (all the functions are returning
Not Implemented).
The current non-sec switching code suffers from one major issue:
it cannot run in secure RAM, as a large part of u-boot still needs
to be run while we're switched to non-secure.
This patch reworks the whole HYP/non-secure strategy by:
- making sure the secure code is the *last* thing u-boot executes
before entering the payload
- performing an exception return from secure mode directly into
the payload
- allowing the code to be dynamically relocated to secure RAM
before switching to non-secure.
This involves quite a bit of horrible code, specially as u-boot
relocation is quite primitive.
In anticipation of refactoring the HYP/non-secure code to run
from secure RAM, add a new linker section that will contain that
code.
Nothing is using it just yet.
In order to be able to use the various mode constants (far more
readable than random hex values), add the missing HYP and A
values.
Also update arm/lib/interrupts.c to display HYP instead of an
unknown value.
Before switching to non-secure, make sure that CNTVOFF is set
to zero on all CPUs. Otherwise, kernel running in non-secure
without HYP enabled (hence using virtual timers) may observe
timers that are not synchronized, effectively seeing time
going backward...
A CP15 instruction execution can be reordered, requiring an
isb to be sure it is executed in program order.
Having the switch to non-secure in the "prep" phase is causing
all kind of troubles, as that stage can be called multiple times.
Instead, move the switch to non-secure to the last possible phase,
when there is no turning back anymore.
If Series-to tag is missing, Patman exits with a message
"No recipient".
This is just annoying for those who had already added
sendemail.to configuration.
I guess many developers have
[sendemail]
to = u-boot@lists.denx.de
in their .git/config because the 'To: u-boot@lists.denx.de' field
should always be added when sending patches.
That seems more reasonable rather than adding
'Series-to: u-boot@lists.denx.de' to every patch series.
Patman should exit only when both Series-to tag and sendemail.to
configuration are mising.
At present buildman always builds out-of-tree, that is it uses a separate
output directory from the source directory. Normally this is what you want,
but it is important that in-tree builds work also. Some Makefile changes may
break this.
Add a -i option to tell buildman to use in-tree builds, so that it is easy
to test this feature.
Normally buildman wil try to configure U-Boot for a particular board on the
first commit that it builds in a series. Subsequent commits are built
without reconfiguring which normally works. Where it doesn't, buildman
automatically reconfigures and retries.
To fully emulate the way MAKEALL works, we should have an option to disable
this optimisation.
Add a -C option to cause buildman to always reconfigure on each commit.
This patch moves some board specific NAND configs:
- TO: individual board config files using these configs.
So that each board can independently set the value as per its design.
Following configs are affected in this patch:
CONFIG_SYS_NAND_U_BOOT_OFFS: <refer doc/README.nand>
CONFIG_CMD_SPL_NAND_OFS: <refer doc/README.falcon>
CONFIG_SYS_NAND_SPL_KERNEL_OFFS: <refer doc/README.falcon>
CONFIG_CMD_SPL_WRITE_SIZE: <refer doc/README.falcon>
This patch also updates documentation for few of above NAND configs.
Signed-off-by: Pekon Gupta <pekon@ti.com>
PISMO_xx macros were used to define 'Platform Independent Storage MOdule'
related GPMC configurations. This patch
- Replaces these OMAP3 specific macros with generic CONFIG_xx macros as provided
by current u-boot infrastructure.
- Removes unused redundant macros, which are no longer required after
merging of common platform code in following commit
commit a0a37183bd75e74608bc78c8d0e2a34454f95a91
ARM: omap: merge GPMC initialization code for all platform
| Macro | Reason for removal |
| PISMO1_NOR_BASE | duplicate of CONFIG_SYS_FLASH_BASE |
| PISMO1_NAND_BASE| duplicate of CONFIG_SYS_NAND_BASE |
| PISMO1_ONEN_BASE| duplicate of CONFIG_SYS_ONENAND_BASE |
| PISMO1_NAND_SIZE| GPMC accesses NAND device via I/O mapped registers so |
| | configuring GPMC chip-select for smallest allowable |
| | segment (GPMC_SIZE_16M) is enough. |
| PISMO1_ONEN_SIZE| OneNAND uses a fixed GPMC chip-select address-space of |
| | 128MB (GPMC_SIZE_128M) |
| PISMO1_NOR | Unused Macros |
| PISMO1_NAND | |
| PISMO2_CS0 | |
| PISMO2_CS1 | |
| PISMO1_ONENAND | |
| PISMO2_NAND_CS0 | |
| PISMO2_NAND_CS1 | |
| PISMO1_NOR_BASE | |
| PISMO1_NAND_BASE| |
| PISMO2_CS0_BASE | |
Fixes commit a0a37183bd75e74608bc78c8d0e2a34454f95a91
1) NAND device are not directly memory-mapped to CPU address-space, they are
indirectly accessed via following GPMC registers:
- GPMC_NAND_COMMAND_x
- GPMC_NAND_ADDRESS_x
- GPMC_NAND_DATA_x
Therefore from CPU's point of view, NAND address-map can be limited to just
above register addresses. But GPMC chip-select address-map can be configured
in granularity of 16MB only.
So this patch uses GPMC_SIZE_16M for all NAND devices.
2) NOR device are directly memory-mapped to CPU address-space, so its
address-map size depends on actual addressable region in NOR FLASH device.
So this patch uses CONFIG_SYS_FLASH_SIZE to derive GPMC chip-select address-map
size configuration.
The errata is applicable on all OMAP4 (4430 and 4460/4470) and OMAP5
ES 1.0 devices. The current revision check erroneously implements this
on all DRA7 varients and with DRA722 device (which has only 1 EMIF instance)
infact causes an asynchronous abort and ends up masking it in CPSR,
only to be uncovered once the kernel switches to userspace.
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Signed-off-by: Sricharan R <r.sricharan@ti.com>
This patch adds Keystone2 k2e_evm evaluation board support.
Signed-off-by: Hao Zhang <hzhang@ti.com>
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
Keystone2 K2E SoC has slightly different spl pll settings then
K2HK, so correct this.
Acked-by: Murali Karicheri <m-karicheri2@ti.com>
