Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
Check for scancodes for arrow keys and map them to ^F/^B, ^N/^P.
Control characters are used instead of ANSI sequence because the
queueing code in usb_kbd doesn't handle the data increase when one
keypress generates 3 keycodes. The real fix is to convert this driver
to use the input subsystem and queue, but this allows arrow keys to
work until this driver is converted.
Signed-off-by: Allen Martin <amartin@nvidia.com>
Enable USB keyboard for seaboard and ventana
Move environment settings for stdin/stdout/stderr to
tegra-common-post.h and generate them automaticaly based on input
device selection.
Change usb_kbd driver to obey alignment requirements for USB DMA on
the buffer used for data transfer. This is necessary for
architectures that enable dcache and enable USB DMA.
CONFIG_EHCI_DCACHE was removed by commit b8adb12
"USB: Drop cache flush bloat in EHCI-HCD". Remove the defines from
the boards configs as well.
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
cc: Marek Vasut <marex@denx.de>
cc: Stefan Roese <sr@denx.de>
cc: Tom Rini <trini@ti.com>
cc: Wolfgang Denk <wd@denx.de>
cc: Thierry Reding <thierry.reding@avionic-design.de>
cc: Tom Warren <twarren@nvidia.com>
cc: Stephen Warren <swarren@nvidia.com>
cc: Stefano Babic <sbabic@denx.de>
The inclusion of LCD patch into mx53loco breaks the build when
CONFIG_VIDEO is disabled. Fix this by splitting the video
related stuff to a new file.
Also rename the function lcd_iomux to setup_iomux_lcd to make the
namings aligned with the other iomux functions.
Signed-off-by: Vikram Narayanan <vikram186@gmail.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
The inclusion of LCD patch into mx51evk breaks the build when
CONFIG_VIDEO is disabled. Fix this by splitting the video related
This patch adds time measurement and throughput calculation for
all supported load commands.
The output of ext2load changes from
---8<---
1830666 bytes read
--->8---
to
---8<---
1830666 bytes read in 237 ms (7.4 MiB/s)
--->8---
[agust: rebased and revised commit log]
the upcoming sunxi (allwinner a10/a13) platform enables zfs
by default, and using linaro's hf -msoft-float makes the build
fail because this u64 division.
Signed-off-by: Alejandro Mery <amery@geeks.cl>
if a board uses the vcxk driver option CONFIG_SYS_VCXK_DOUBLEBUFFERD,
compilier shows warnings. This patch will fix it.
Signed-off-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de>
- update clock settings for higher perfomance
- change standard baud rate to 115200
- fix flash base address
- remove unused defines
- add I2C support
- switch form board dependent flash to cfi
- remove board dependent flash code
- use sdram bank 0 instead of bank 1 on boot
- enable on board frame buffer instead external
- remove fake mac address form config
- add watchdog support
- add status led support
[agust: fixed small style issues and build warning]
PMIC framework
Move pmic_init() function call from board_init() to power_init_board()
to work with new PMIC/POWER framework.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Rename CONFIG_DIALOG_PMIC to CONFIG_DIALOG_POWER
Rename all CONFIG_PMIC* defines to CONFIG_POWER*
Rename pmic/power related files at ./drivers/power directory
Two extra commands:
"pmic name bat state" and "pmic name bat charge" has been added to
pmic framework. Those provides state display and charge capabilities
to named batteries.
The pmic_core.c file has been refactored to more consistent name scheme.
The battery connected to Samsung's Trats development board is now
charged when voltage drops below threshold.
When charging battery is necessary, the development board needs to
be turned into low power mode for better efficiency.
Support for MAX8997 built-in charger.
Support for TRATS battery has been added. It is treated as a "normal"
power related device and thereof controlled by pmic/power subsystem.
FG IC built into the MAX8997 device (compliant to MAX17042) is enabled
at TRATS.
MUIC IC built into the MAX8997 device is enabled at TRATS.
Default PMIC (MAX8997) initialization for Samsung's TRATS development board.
Function for calculating LDO internal register value from passed micro
Volt.
Support for MAX17042 fuel-gauge (FG), which is built into the MAX8997
power management device.
Special file - fg_battery_cell_params.h with cells characteristics
added.
The FG device will work with redesigned PMIC framework.
Support for MUIC (Micro USB Integrated Circuit) built into the MAX8997
The MUIC device will work with redesigned PMIC framework.
Trats battery is now treated in the same way as other power related
devices. This approach allows for more unified handling of all devices
responsible for power management.
Now it is possible to provide specific function per PMIC/power
device instance.
The PMIC framework has been moved to its more natural place
./drivers/power from ./drivers/misc directory.
New power_chrg.h file has been added to "bind" together common
information about charging battery available in the system.
Enable support for power_board_init() method at TRATS board.
It is necessary to introduce a new system wide function- power_init_board()
It turns out, that power initialization must be done as early as possible.
In the case of PMIC framework redesign, which aims to support multiple
instances of PMIC devices the initialization shall be performed just
after malloc configuration.
The power_init_board function is a weak function with default implementation.
The PMIC framework has been extended to support multiple instances of
the variety of devices responsible for power management.
This change allows supporting of e.g. fuel gauge, charger, MUIC (Micro USB
Interface Circuit).
Power related includes have been moved to ./include/power directory.
This is a first of a series of patches - in the future "pmic" will be
replaced with "power".
Two important issues:
1. The PMIC needs to be initialized just after malloc is configured
2. It uses list to hold information about available PMIC devices
PMIC MAX8997 is now ready to work with single and multibus soft I2C
implementation.
Since the pmic_reg_read is the u32 value, the order in which bytes
are placed to form u32 value is important.
Support for big and little sensor endianess is added.
Moreover calls to [leXX|beXX]_to_cpu have been added to support
little and big endian SoCs.
This patch adds support for proper handling of a PMIC I2C transmission
comprising of two bytes.
Commit 97b24d3d51a92cb8c0c1e1a74abf22fe1a1807a3 "common: Add symbol
handling for generic lists into Makefile" introduced build errors in many
nand_spl targets, complaining of a missing u-boot.lst. When not doing an
out-of-tree build, $(obj) expands to nothing, so GCC ended up being given
-I with no argument (or rather, -ansi was the argument). The failure
didn't show up during a -j1 build because it was picking up the non-SPL
version of u-boot.lst.
Often a particular patch may change only for some versions of a series.
For versions where there is no change, issue a change log indicating
that (for example 'Changes in v4: None').
For such lines, don't add a blank line afterwards, to conserve space.
Use list.insert() instead of list = [item] + list.
Tested-by: Stefan Roese <sr@denx.de>
implement the common api lcd_setcolreg in include/lcd.h
Signed-off-by: Bo Shen <voice.shen@atmel.com>
[agust: fixed commit log and gcc 4.6 -Wparentheses warnings]
The file has a wrong inline keyword of __led_toggle(), which causes
compilation error. And its content is defined in common status_led.h.
So define CONFIG_BOARD_SPECIFIC_LED in board config files and remove
this header file.
The commit 51926d5ee0be029fb45f10f42756df97279f8ad3
COMMON: Use __stringify() instead of rest of implementations
forgot to update the wrctl funtion, and causes compilation error.
But there are builtin functions for control registers access in
nios2 comipiler. It is convenient to use them instead.
commit 199adb601ff34bdbbd0667fac80dfe0a87bffc2b "common/misc: sparse
fixes" broke the help command trying to fix the sparse error
"command.c:44:38: error: bad constant expression".
As Henrik points out, the fix was bad because the commit used
CONFIG_SYS_MAXARGS whereas the code intended to use the maximum
number of commands (not arguments to a command).
Revert command.c changes to the original code as asked by Wolfgang.
Reported-by: Henrik Nordström <henrik@henriknordstrom.net>
Microblaze platform can use CONFIG_OF_EMBED option
but also it is necessary to support boards
which don't want to use this option.
U-Boot doesn't compile dts/libdts.o for #undef CONFIG_OF_EMBED
case that's why it should be guarded by ifdef.
