Remove "boot" and "enable" from some configs' name.
Affacted configs:
mx6q_sabreauto_boot_weimnor
mx6q_sabreauto_mfg_enable_weimnor
mx6solo_sabreauto_boot_weimnor
mx6solo_sabreauto_mfg_enable_weimnor
mx6q_sabreauto_mfg_enable_spi-nor
mx6solo_sabreauto_mfg_enable_spi-nor
mx6q_sabreauto_nand_boot
Currently, various u-boot are built in nightlybuild, to make it easier,
we naming u-boot binary name and config as
<soc_name>_<board_type>_<ddr_type>_<boot_device>.
Then it is easier to be parsed, also easier to be maintained in
nightlybuild and u-boot git.
Signed-off-by: Terry Lv <r65388@freescale.com>
From IC spec:
Two configuration files were included to suppoort spi-nor
on the manufacturing tool. Basically these files send the
parameter "spi-nor" to the kernel, so the SPI interface can be setup.
Files included are:
mx6q_sabreauto_mfg_enable_spi-nor.h --> For Quad
mx6solo_sabreauto_mfg_enable_spi-nor.h --> For solo
Signed-off-by: Alejandro Sierra <b18039@freescale.com>
- configure SD1 to support 8bit on evk
Signed-off-by: Ryan QIAN <b32804@freescale.com>
Added two new board files for Solo and Quad which allow uboot
to be booted from WEIM NOR. Also amended the word “weim-nor” in
both mfg configuration files which allow to erase/write u-boot
and uImage in Parallel nor using the mfg tool. Lastly just added
a label in the regular board files indicating that another config
file has to be used in the case of NOR boot.
Modified files:
Makefile
common/env_common.c
include/configs/mx6q_sabreauto.h
include/configs/mx6q_sabreauto_boot_weimnor.h
include/configs/mx6q_sabreauto_mfg_enable_weimnor.h
include/configs/mx6solo_sabreauto.h
include/configs/mx6solo_sabreauto_boot_weimnor.h
include/configs/mx6solo_sabreauto_mfg_enable_weimnor.h
Signed-off-by: Francisco Munoz <francisco.munoz@freescale.com>
Set the default clock to 20MHz. The 11Mhz is too slow.
Signed-off-by: Huang Shijie <b32955@freescale.com>
If tell the real correcting infomation to the upper layer of
MTD, the torture thread of UBIFS will do the torture test in
a very often frequency. This will eat up all the reservation blocks
of the UBIFS.
So tell the real correcting infomation only when the failure occured,
or the corrected times nearly reached the ECC threshold.
Set 0x500 to the busy_timeout in HW_GPMI_TIMING1.
If we do not set this busy_timeout, the gpmi may become unstable.
Rewrite the code for calculate the ecc strength.
Use the same code as in the gpmi driver.
Use the latest gpmi_reset_block(), and remove the old gpmi_nfc_reset_block().
Abandon our nand chip database, use the community's database.
update nand_get_flash_type() to the latest code.
Also add the support of ONFI nand.
add a new config for NAND boot in the mx6q-ard board.
Modify ODT values for Solo AI. Some Solo boards did not passed the "mtest"
from uboot using the previous configuration.
Old configuration:
MXC_DCD_ITEM(76, MMDC_P0_BASE_ADDR + 0x818, 0x00000007)
MXC_DCD_ITEM(77, MMDC_P1_BASE_ADDR + 0x818, 0x00000007)
MXC_DCD_ITEM(67, MMDC_P0_BASE_ADDR + 0x818, 0x00000007)
MXC_DCD_ITEM(68, MMDC_P1_BASE_ADDR + 0x818, 0x00000007)
New configuration:
MXC_DCD_ITEM(76, MMDC_P0_BASE_ADDR + 0x818, 0x00011117)
MXC_DCD_ITEM(77, MMDC_P1_BASE_ADDR + 0x818, 0x00011117)
MXC_DCD_ITEM(67, MMDC_P0_BASE_ADDR + 0x818, 0x00011117)
MXC_DCD_ITEM(68, MMDC_P1_BASE_ADDR + 0x818, 0x00011117)
Add mx6sl evk board support
- copied from ARM2 board support
- added a new board revision
- removed unused boot device detection
Signed-off-by: Robby Cai <R63905@freescale.com>
1.Considering pfuze tolerance and IR drop and board ripple, need rise from
1.375V to 1.425V. Only for Sabresd.
2.workaround pfuze1.0 ER1, set all buck regulator except SW1C to PWM mode.
now for mx6sl_arm2 and mx6_sabresd.
Signed-off-by: Robin Gong <B38343@freescale.com>
in fastboot mode, if usb cable re-connectted, the fastboot feature will
fail. This issue is caused by logic control oversight.
Signed-off-by: LiGang <b41990@freescale.com>
1. enable fastboot feature on mx6q-arm2 board
2. enlarge fastboot buffer to 320MB
3. correct some usb descriptors
There is a problem that a too long command line parameter in U-Boot
console will actually be truncated and not properly truncated to the
kernel.
The root cause is that the command line in the U-Boot console is read
into a buffer --- console_buffer[CONFIG_SYS_CBSIZE]. Currently the
CONFIG_SYS_CBSIZE is set as 256. Command line parameter larger than it
will not be recorded. On the other hand, max length of boot parameter of
linux kernel is set to 1024, which means it can accept parameter size as
large as 1024.
So we need to align these 2 values. Enlarge CONFIG_SYS_CBSIZE to 1024 as
well.
Signed-off-by: Eric Sun <jian.sun@freescale.com>
This patch changes to use new 8bit 600x400 bmp boot logo.
As this boot logo has black background and white words,
the user experience will be better.
Signed-off-by: Liu Ying <Ying.Liu@freescale.com>
This patch adds new boot 8bit 600x400 bmp logo
who has black background and white words.
The original secure boot implementation make a consumption that
u-boot.bin will not exceed 0x2F000. With this consumption, the hab data
is hard coded in linker script file to relative address 0x2F000 without
causing any problem.
But when this consumption don't hold, the hard coded way will cause
memory region overlap and break build. So we need to change to a dynamic
way of allocating hab_data. The new implementation put hab data at the
next 0x1000 alignment after u-boot data and text section, instead of
hard coded to 0x2F000.
Similar changes is made to uImage authentication implementation.
Changes in U-Boot includes:
- in u-boot.lds file, change "__hab_data" to dynamic align to 0x1000
- change authenticate_image implementation, originally the uImage
parameters are hard coded, now they are retrived from the
"load_addr" and the image_hdr
The new secure image layout:
U-Boot
+-------------------+ DDR_START
| U-Boot Image |
+-------------------+ DDR_START + UBOOT_SIZE
| PADDING |
+-------------------+ align to 0x1000
| CSF Data | -
+-------------------+ +-- CSF + Pad, Size : 0x2000
| PADDING | -
uImage
| uImage |
+-------------------+ DDR_START + UIMAGE_SIZE
| PADDING |
| IVT | ---- Size : 0x20
| CSF Data | -
| PADDING | -
This patch adds splashimage related variables to board configure
file so that splashimage can work without touching the uboot
variables.
variables.
This patch adds CONFIG_SPLASH_SCREEN definition to board
config file to enable splashimage by default.
This patch configures iomux gpr3 register to enable LVDS1
via IPU1 DI1 if user chooses to use it.
The silicon revision is not printed correctly, on ARM2
and sabrelite board, the log is just as the following:
CPU: Freescale i.MX6 family TO0.0 at 792 MHz
We need print the silicon revision correctly as:
CPU: Freescale i.MX6 family TO1.2 at 792 MHz
with i.mx6q TO1.2 chip
Signed-off-by: Jason Liu <r64343@freescale.com>
Fix fastboot crash issue on fastmx6sl-arm2 board.
Enlarge fastboot buffer size to 320MB for mx6 arm2 board, mx6 sabresd
board, thus fastboot could flash system.img up to 320MB
Fix the build warning in uboot build.
Fix bug of incorrect dereference to periph2 clock pre divider.
Fix incorrect type of maxpackage size assign, even it's
not used at all in fastboot.
Signed-off-by: Xinyu Chen <xinyu.chen@freescale.com>
This commit fix the linker error when enable more function(like CONFIG_NAND,
CONFIG_SPASHSCREEN,etc) in uboot ARM2 board, and a possable linker error for
other MX6 boards:
/home/lambert/share/SATA2/R13.3/prebuilt/linux-x86/toolchain/arm-eabi-4.4.3/
bin/arm-eabi-ld: section .bss [27831000 -> 278666e7] overlaps section
.rodata [2782387c -> 278609eb]
bin/arm-eabi-ld: section .rodata.str1.1 [278609ec -> 27867803] overlaps
One issue here is:
A recent gcc added a new unaligned rodata section called '.rodata.str1.1',
which needs to be added the the linker script. Instead of just adding this
one section, we use a wildcard ".rodata*" to get all rodata linker section
gcc has now and might add in the future.
Another issue is:
The secure boot feature require __hab_data section in uboot linker script,
but it's have a hard coding magic number, but if we enable more code, cause
.text section bigger, it will cross the line, so it report the
first linker error.
This commit disable SECURE_BOOT feature by default for android,
and comments if user want to use this feature, it needs change the
.lds by there configure.
Also, enlarge the magic number that this feature needs to cover
if more code is build in.
Signed-off-by: Zhang Jiejing <jiejing.zhang@freescale.com>
To validate LDO bypass function fully, enable CONFIG_MX6_INTER_LDO_BYPASS
on u-boot and kernel, only for mx6sl.
With the secure boot patch. MX6 NAND Boot is not functional. The root
cause is that, the original secure boot patch fills "0xFF' to spacing
regions, due to a issue in ROM code, read pages of all "0xff" will be
treated as a critical error. Thus prevent the U-Boot from booting
normally.
The fix adjust image copy size in IVT so that when secure boot is not
enabled, no unuseful data is copied by ROM code. Also the secure boot
option is default disabled. The end user won't enable it unless they
know what they are doing.
These prevent the ROM code from copied pages of "0xff" data, and fix the
issue.
It prints sd clk freq for cmd of mmcinfo, then it is much
easier to tell which mode sd/mmc card is running at.
enable SD3.0 support on SD1 and SD2 on mx6sl arm2 cpu board.
Move the uImage authentication to an earlier phase, in this way prevent
DDR content changed by OS load code, causing authentication failure.
Move the secure boot related implementation code from mx6q_arm2.c to
mx6/generic.c. In this way the HAB feature can be shared by all MX6
platforms
IC Validation team release new LPDDR2 script V0.93 in the following link,
"http://compass.freescale.net/livelink/livelink?func=ll&objId=226733834/"
Make changes to align to it
1.enable I2C and I2C bus recovery support on mx6sl_arm2
2.enable LDO bypass on u-boot, by configuring 'CONFIG_MX6_INTER_LDO_BYPASS'
nosmp is added in the bootargs originally because of issues in kernel
smp implementation. Now these issues are fixed and we can safely remove
them
For MX6DL LPDDR2 board, in order to use both the 2 channels of the memory, the
"PL301_FAST2" must be set to 0x1. However this bit is not accessible using
DCD. Plugin mode must be utilized for this purpose.
The patch can be verified this way:
Enter U-boot console
> mw.l 0x80000000 0xC0 10
> mw.l 0x10000000 0xC1 10
> md.l 0x10000000 10
> md.l 0x80000000 10
Before the patch, 0x10000000 and 0x80000000 in fact point to the
same memory location. So the last 2 dump will show memory content of
both 0x000000C1
After the patch, 0x80000000 ponit to channel 0, 0x10000000 point to
channel 1. the last 2 dump will show memory content of 0x000000C0
and 0x000000C1 respectively
Move IPU QoS and VDOA/IPU/VPU AXI Cache config
to linux kernel in order to reduce code duplicate
Signed-off-by: Wayne Zou <b36644@freescale.com>
For historical reasons U-Boot set "enable_wait_mode=off" in default
U-Boot parameter. Now wait mode is OK for these platforms so we
remove these settings.
Validation team released lateset LPDDR2 script V0.91, See
k?func=ll&objId=226435628&objAction=browse&viewType=1"
This change is necessary for bus freq scaling
Apply it for both DCD mode and plugin mode.
Fix a hang and a garbage update to the E Ink panel with the following
changes for both MX 6DL/S SabreSD and MX 6DL/S ARM2:
- Update the address for the EPDC waveform file to 6MB offset
in SD card.
- Update the waveform file size to cover the default
Pearl panel waveform file.
Signed-off-by: Danny Nold <dannynold@freescale.com>
issue:
SD1 connector on ARM2 is an MS-SD combo one which can not make
good contact with DAT4~DAT7 of 8bit mmc cards. It is an hw limitation
which will cause boot failure from 8bit mmc.
solution:
disable SD1 8bit mode on MX6SL arm2 board.
We can use weak ODT setting, it will save about 50% DDR
power in runtime. Now we use 0x00007
MMDC0_MPODTCTRL MMDC1_MPODTCTRL, (Ohm)
Setting DDR_ODT imx_ODT Max_overclocking
0x22227 120 060 615MHz
0x11117 120 120 604MHz
0x00007 120 000 576MHz
0x00000 000 000 556MHz
Signed-off-by: Anson Huang <b20788@freescale.com>
- EPDC splash screen changed to be disabled by default in the config
file for MX6DL_SABRESD and MX6DL_ARM2. If left enabled, the U-Boot image
will not boot correctly (hang), since some additional content on the boot device
(waveform file) is required for EPDC splash to work correctly.
- Fixes U-Boot break introduced with commit for ENGR00212287
- EPDC Splash support for MX6DL/S Sabre SD
- EPDC Splash support for MX6DL/S ARM2
- Currently, splash screen consists of a simple black border
around a white screen. Done this way to save in memory footprint.
