Support New emaclite AXI IP.
Some boards need their board-specific PHY quirks to be called
to PHY to work normally. As mpc5xxx_fec driver uses on demand
PHY initialization and can even reinit PHY during normal operation
we can't count on reset_phy() call from arch/<arch>/lib/board.c
(it is most likely called _before_ we init the PHY from the
driver) so we need to add call to reset_phy() directly in the
driver.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
Some return values pretended correct pass. This patch changes them according
to README.drivers.net. This patch changes e.g. command 'dhcp' to stop after
errorneous autonegotiation.
This patch increases timeout for autonegotiation from 1 second to 3 seconds.
Some boards (e.g. at91rm9200ek) did not negotiate within 1 second.
V3: further refinements:
- use priv member instead of container method
- allow setting of MAC address by write_hwaddr method
- avoid shutting down link between commands
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
Instead of always performing an autoneg, check if the PHY
already has a link and if it matches one of the requested
modes. Initially only 100MbFD is optimized this way.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
All are within an #ifdef CONFIG_NET_MULTI block already
This udelay looks bogus and doesn't help my board.
Acked-by: Kim Phillips <kim.phillips@freescale.com>
uec_init() adds an udelay(100000) even though
the PHY status read went well, don't do that.
This patch is required before the upcoming new enc28j60 driver
using SPI framework patch can be applied:
- Move legacy enc28j60.c to enc28j60_lpc2292.c.
- Change Makefile and the two affected boards' definition files.
Tested with ./MAKEALL ARM7 that both boards still compile.
Signed-off-by: Reinhard Meyer<info@emk-elektronik.de>
The correct definition is in drivers/qe/uec.h so just
remove this one.
Freescale application note AN3638 describes an update to the NXID format,
which stores MAC addresses and related data on an on-board EEPROM. The new
version adds support for up to 23 MAC addresses, instead of just 8. Since
the initial implementation of NXID had a "0" in the 'version' field, this
new version is called "v1".
Boards that are shipped with EEPROMs in the NXID v1 format should define
CONFIG_SYS_I2C_EEPROM_NXID_1 instead of CONFIG_SYS_I2C_EEPROM_NXID.
pumping line-rate traffic though a p4080 rev.2, which
is configured to encrypt packets prior to forwarding through
an IPsec tunnel, gets this error:
of_platform ffe302000.jq: DECO: desc idx 22: LIODN error. DECO was trying
to share from itself or from another DECO but the two Non-SEQ LIODN
values didn't match or the "shared from" DECO's Descriptor required that
the SEQ LIODNs be the same and they aren't.
Since high traffic rates cause DECOs to begin to start sharing
shared descriptors amongst themselves, and DECOs inherit job queue
LIODNs when accessing shared descriptors, and a recently discovered
rev.2 h/w erratum requires all sharing job queues in a partition
have same liodn assignment, reassign the first job queue's liodn
assignment to the rest.
Manual was updated to add a new register for disabling CDQ speculation.
We configure the controller but dont have virtual address space thus any
devices on the 4th controller are not accessible in u-boot.
* Make the U-Boot update command sequence conditional. Helps prevent
accidental erasing if an upload or previous step fails
* Make it easier to update other FLASH banks
* Enable DDR controller cache line interleaving and bank cs0/cs1 by default
Signed-off-by: Emil Medve <Emilian.Medve@Freescale.com>
Signed-off-by: York Sun <yorksun@freescale.com>
Update the code which writes to the on-board EEPROM so that it can detect if
the write failed because the EEPROM is write-protected. Most of the 8xxx-class
Freescale reference boards use an AT24C02 EEPROM to store MAC addresses and
similar information. With this patch, if the EEPROM is protected, the
"mac save" command will display an error message indicating that the write
has not succeeded.
The Freescale P1022DS can use either a 12.288MHz or a 11.2896MHz reference
clock for the audio codec, but by default both are disabled. Add a 'audclk'
hwconfig option that allows the user to choose which clock he wants.
The 12.288MHz clock allows the codec to use sampling rates of 16, 24, 32, 48,
64, and 96KHz. The 11.2896 clock allows 14700, 22050, 29400, 44100, 58800, and
88200Hz.
Also configure a pin muxing to select some SSI signals, which will disable
I2C1.
Enable half drive strength, set RTT to 60Ohm and set write leveling override.
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
The original code maps boot flash as non-cacheable region. When calling
relocate_code in flash to copy u-boot from flash to ddr, every loop copy command
is read from flash. The flash read speed will be the bottleneck, which consuming
long time to do this operation. To resovle this, map the boot flash as
write-through cache via tlb. And set tlb to remap the flash after code
executing in ddr, to confirm flash erase operation properly done.
Signed-off-by: Kai.Jiang <Kai.Jiang@freescale.com>
CONFIG_ENV_SIZE of MPC8569MDS was wrongly set to CONFIG_ENV_SECT_SIZE which
is 128KB, so it took longer time to do crc32 calculation for ENV than it should
do. It causes the bootup for MPC8569MDS significantly slow. This patch fixs it
to 0x2000(8KB), also fix the comment for CONFIG_ENV_SECT_SIZE to correct size.
u-boot.bin can be loaded at any 4-byte aligned memory location and directly
'jumped' to using the 'go' command using the load address as the start
address. Doing so performs a 'warm boot' which skips memory initialisation
and other low-level initialisations, relocates U-Boot to upper memory and
starts U-Boot in RAM as per normal 'cold boot'
Provides a small speed increase and prepares for fully relocatable image.
Downside is the TEXT_BASE, bss, load address etc must ALL be aligned on a
a 4-byte boundary which is not such a terrible restriction as everything
is already 4-byte aligned anyway
Tidy up the linker script and discard some sections to save space
Create more generic names for the symbols exported from the linker script
By reserving space for the Global Data immediately below the stack during
assembly level initialisation, the C declaration of the static global data
can be removed, along with the 'RAM Bootstrap' function. This results in
cleaner code, and the ability to pass boot-up flags from assembler into C
By using another register, reduce code size by one instruction
%ebx will hold low-level boot flags and must be preserved
Using %ebp as a return pointer prevents creating 'load anywhere' images
To allow for 'load anywhere' images, the %ebp return pointer 'hack' must
be removed, so we cannot have two 'calls' to get_mem_size
Progress indication is not relocation friendly so remove it in
preperation for full relocatability support
Change to:
- reparam=3
- no-from-pointer
- no-stack-protector
- preferred-stack-boundary=2
- no-top-level-reorder
These options make the code a little smaller and faster
Perform some basic code cleanups of the x86 files
Linux has C macros and code to load the GTD after switching to Protected
Mode. Using these greatly simplifies the assembler code
Follow the discussion of Charles Manning and Mike Frysinger.
Using gc_sections helps reduce image size.
The header of recent Linux Kernels includes the size of the image, and
therefore is not needed to be passed to zboot. Still process the third
parameter (size of image) in the event that an older kernel is being loaded
Use TEXT_BASE rather than a hard-coded base address on x86 linker scripts.
This will allow any board to define its base link address without having
to modify the linker script
Relocation is not board-specific for the x86 architectrure, so
CONFIG_RELOC_FIXUP_WORKS can be defined globally in the config.h
Commit 55e97429d1e6cf0976711e4e0f29ea924b7e5917 removed the definition
from /arch/i386/include/asm/u-boot.h but not its usage in do_bdinfo()
and clean up error messages and help,
removed pointless debug() call.
This patch introduces an extra mask-field in spansion_spi_flash_params
to support flash chips with 1-byte extended ID (like the S25FL032P).
Signed-off-by: David Jander <david@protonic.nl>
The spansion_erase currently only works when the sector size is 64KB.
cmd[1] should contain the higher 8 bit of the 24 bit address of the
sector to be erased. Currently it is holding the sector index to be
erased which happens to be the same thing when the sector size is
64KB.
Signed-off-by: Marc-Andre Hebert <marc-andre.hebert@humanware.com>
uint is typedefed twice if __MACH__ is defined. This generates an error
when calling MAKEALL for netstar bord on OS X.
This patch removes the typedef for __MACH__ case in favor of general
definiton some lines below.
The MAX_CMDBUF_SIZE define is unneeded as it should always
equal CONFIG_SYS_CBSIZE.
Fix bug where signed data was processed as unsigned. The bug previously
resulted in negative temperature readings wrapping around, eg -10 became
245.
Signed-off-by: Jeff Dischler <jdischler@xes-inc.com>
