The patch adds SPL for the arm1136 architecture and
inserts SPL (the produced binary) to clobber target
in the main Makefile.
The functions are required to use the generic
SPL Framework.
This patch modifies start.S for the arm1136 to make it
conform to start.S in armv7 architecture, to make it
usable if the SPL framework is used.
Patch fix warnings compiling with ELDK-4.2:
clock.c: In function 'get_standard_pll_sel_clk':
clock.c:341: warning: 'freq' may be used uninitialized in this function
Reported-by : Marek Vasut <marex@denx.de>
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
Call with the value the function will use
instead of going through a pointer.
When later we change to variable length
header, we won't know the file size when
set_imx_hdr is called. So this is prep work.
sbuf->st_size already includes sizeof(struct imx_header),
so remove extra addition.
Both set_imx_hdr_v1 and set_imx_hdr_v2 perform the
same check. Move check to before the set_imx_hdr call.
Before the len was checked after the entire file
was processed, so it could have already overflowed.
Data cache and CONFIG_MMC_BOUNCE_BUFFER can be safely enabled now.
Use internal RAM for stack pointer as it is done in other i.MX boards.
Add the software workaround for ARM erratum ID 468414.
According to mx53/mx51 errata document:
"ENGcm11133 - ARM: NEON load data can be incorrectly forwarded to a
subsequent request
Description:
Under very specific set of conditions, data from a Neon load request can be incorrectly forwarded
to a subsequent, unrelated memory request.
The conditions are as follows:
• Neon loads and stores must be in use
• Neon L1 caching must be disabled
• Trustzone must be configured and in use
• The secure memory address space and the non-secure memory address space both use the same
physical addresses, either as an alias or the same memory location or for separate memory
locations
The issue is reported by ARM, erratum ID 468414, Category 2"
The recent U-Boot version 2012.07 has improved drivers
(e.g. MMC and network/FEC) regarding DCache handling.
So it should be safe to use the DCache on the i.MX6, now.
Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com>
mx53evk has only one Ethernet port, so remove CONFIG_HAS_ETH1 option.
mx51evk has only one Ethernet port, so remove CONFIG_HAS_ETH1 option.
mx53loco has only one Ethernet port, so remove CONFIG_HAS_ETH1 option.
Since PLL2 now has changed, it is necessary to adapt the CONFIG_IPUV3_CLK
accordingly.
Currently PLL2 is not explicitely configured for mx53 and it runs at 333MHz.
Since PLL2 is the parent clock for DDR2, IPU, VPU, we should set it at 400MHz
instead.
Without doing so, it is not possible to use a 2.6.35 FSL kernel and display HDMI
at 1080p because the IPU clock cannot reach the requested frequency.
Set PLL2 to 400MHz, so that 1080p can be played and the DDR2 can run at its
maximum frequency.
Also, setup the other PLL's as done in FSL U-boot and re-arrange the code a little
bit to allow easier comparison with the original clock setup from FSL U-boot.
init_clock is currently shared between mx51 and mx53 and it contains lots of
ifdef's which makes it really hard to follow the code.
Split the init_clock between mx51 and mx53 to allow easier readability.
No functional changes are made.
Clean up i.MX25 imx-regs.h:
- Update mx31 imx-regs.h filename.
- Test for __KERNEL_STRICT_NAMES just in case.
- Define internal RAM size.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Adds support for HDMI, two LVDS panels and one RGB panel to
the SABRE-Lite board.
Displays supported:
HDMI - 1024 x 768 for maximum compatibility
Hannstar-XGA - 1024 x 768 LVDS (Freescale part number MCIMX-LVDS1)
wsvga-lvds - 1024 x 600 LVDS (Boundary p/n Nit6X_1024x600)
wvga-rgb - 800 x 480 RGB (Boundary p/n Nit6X_800x480)
Since the ipuv3_fb display driver currently supports only a single display,
this code auto-detects panel by probing the HDMI Phy for Hot Plug Detect
or the I2C touch controller of the LVDS and RGB displays in the priority
listed above.
Setting 'panel' environment variable to one of the names above will
override auto-detection.
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
Original source from Pengutronix HDMI driver work:
http://git.pengutronix.de/?p=imx/linux-2.6.git;a=commitdiff;h=72c31cd67ac880bd90785af86f8e46f8ea7b3bb0
Default drive strength is disabled and won't function.
The kernel from Freescale expects that the bootloader passes the board revision.
Read the board revision and pass it via get_board_rev().
Without passing the board revision the kernel does not operate properly as the
initialization of peripherals are different in revA versus revB boards.
The mmcroot setting vary between mx6qsabreauto and mx6qsabresd so we
move this to the board configuration file.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
On mxc, each SDHC instance has a dedicated clock, so gd->sdhc_clk is not
suitable for the multi-instance use case (initialization made directly with
fsl_esdhc_initialize()).
This patch fixes this issue by adding a configuration field for the SDHC input
clock frequency.
Cc: Eric Bénard <eric@eukrea.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Jason Liu <r64343@freescale.com>
Cc: Matt Sealey <matt@genesi-usa.com>
Cc: Andy Fleming <afleming@gmail.com>
Each eSDHC instance has a dedicated clock.
gd->sdhc_clk must also be set accordingly. This is good for the case only a
single SDHC instance is used (initialization made with fsl_esdhc_mmc_init()). A
future patch will fix the multi-instance use case (initialization made directly
with fsl_esdhc_initialize()).
Clean up mx35 lowlevel_init:
- Indent with tabs.
- Fix comments.
- Use defined values instead of literal constants.
- Use defined macros instead of duplicating code.
- Use macro parameters with default values instead of #define'd configs.
This was introduced in:
8679d0ffdcc0beafea8e6942c0c67cf859afa18e -
COMMON: Use __stringify() instead of MK_STR()
The header is now needed since common.h is not included in this tool.
Add entry for kerneldoc into the git-mailrc pointing to the U-Boot ML
and myself.
The default kernel-doc strips starting spaces from every single
line in the Example section. This makes the code look bad. Thus,
implement special handling for this section.
Import basic CSS stylesheet for the HTML documentation. The base for
the stylesheet is taken from:
http://ds9a.nl/docbook/minimal-page.html
I customized the CSS a bit further, for example to add curvy corners
to example section and change the tint of gray. The HTML documentation
does not look that crude anymore.
Pull slightly modified version of Documentation/DocBook, the related perl
script scripts/kernel-doc and the scripts/docproc.c from Linux kernel and
implant it into U-Boot. This will allow smooth generation of kerneldoc
style documentation.
It was necessary to modify the DocBook/Makefile to work with U-Boot build
system. The changes were only minor though and involved replacing the kbuild
specific parts.
It was also necessary to replace use of variables like KERNEL_VERSION with
U_BOOT_VERSION, strings like Linux kernel with U-Boot Bootloader etc. so
the generated result actually matches.
Finally, it was necessary to adjust docproc.c, since the documentation in
U-Boot is located in doc/DocBook instead of Documentation/DocBook as is in
case of the Linux kernel.
Some parts of the DocBook Makefile are unused, but to allow easier sync with
Linux kernel, these parts are still left in. The targets enabled now are
"htmldocs" "pdfdocs" "psdocs" "xmldocs" and "cleandocs" to remove the results
of documentation build.
Linux scripts/docproc.c:
commit f0f3ca8d967462dafb815412b14ca3339b9817a6
Date: Wed Jun 15 11:53:13 2011 +0200
Linux scripts/kernel-doc:
commit 1b40c1944db445c1de1c47ffd8cd426167f488e8
Date: Sun Aug 12 10:46:15 2012 +0200
Linux Documentation/DocBook:
commit bb8187d35f820671d6dd76700d77a6b55f95e2c5
Date: Thu May 17 19:06:13 2012 -0400
Since commit 50d4a707f0 (mx5/6: Define default SoC input clock frequencies)
we can use the default clock values.
mx6qsabreauto has a AR8031 Gigabit PHY.
Add support for it.
Clean up mx25 lowlevel_init:
- Add comments.
- Do not use write32 repeatedly with the same value in order not to increase
code size.
- Make register values configurable.
- Use macro parameters with default values instead of literal constants.
Cc: John Rigby <jcrigby@gmail.com>
Cc: Matthias Weisser <weisserm@arcor.de>
The CSI PODF bit-field used by the previous code for the i.MX31 CCM PDR0
register is actually composed of two bit-fields: one pre-divider and one
post-divider. This patch fixes the CCM access macros and the code using them
accordingly.
Optimize mx5 lowlevel_init.S code size:
- Compute values at compile time rather than at runtime where possible.
- Assign r4 to hold the zero value rather than setting registers to 0 again and
again.
- Associate a function to setup_pll rather than expanding its large macro code
multiple times.
- Allocate constant values in section only if used.
Tested-by: Stefano Babic <sbabic@denx.de>
