Use a generic 'dram_vals[]' array that has the full initialization
sequence and rename the initialization method so it doesn't has a
frequency on its name.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
The MXS SPL didn't mark local functions "static". Fix it. This also makes the
SPL smaller by roughly 300 bytes.
Cc: Fabio Estevam <fabio.estevam@freescale.com>
The memory setup code adjusted the VDDD voltage. Remove this adjustment
and configure the VDDD voltage correctly in the power supply setup code.
Implement common function to setup the VDDIO, VDDD and VDDA voltage.
Right now, there are two almost identical functions to setup VDDIO
and VDDD, which is prone to breakage. Pull out the differences into
constant structure and pass them as an argument to the common function.
Moreover, the function has almost identical loops for setting higher
and lower VDDx voltage. Merge these two loops.
The elftosb tool is now called with -d switch, which produces debug
output to the stdout. The debug output is completely useless for
regular operation, so silence it.
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
The i.MX23 has different register layout and bit placement in the
power supply. Thus, in order to be able to add support for MX23,
rename the MX28's regs-power.h to regs-power-mx28.h . Moreover,
add ifdef around inclusion of regs-*-mx28.h in imx-regs.h so the
MX23 boards will include proper set of registers.
These registers don't have _SET, _CLR and _TOG at the respective offsets
available, these registers has to be toggled via R-M-W if needed. Thus do
not export these offsets anymore.
The POWER_DCLIMITS_NEGLIMIT_OFFSET bit in mx28 power supply block is
not called POWER_DCLIMITS_NETLIMIT_OFFSET, but POWER_DCLIMITS_NEGLIMIT_OFFSET.
Correct the name in the header file.
The POWER_MINPWR_VBG_OFF bit in mx28 power supply block is not called
POWER_MINPWR_FBG_OFF, but POWER_MINPWR_VBG_OFF. Correct the name in the
header file.
The mx5 lowlevel_init.S contains board-specific code based on the reference
design. Let's keep it since it avoids creating new lowlevel_init files and it
may be used by many boards. But add a config to make it optional in order not to
cause issues on boards not following this part of the reference design.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Cc: Matt Sealey <matt@genesi-usa.com>
The correct bit for H1_PM is 16, not 8, which is the DP pull-up impedance
selection bit.
This issue has been reported by Eric Bénard <eric@eukrea.com> and fixed by
Christoph Fritz <chf.fritz@googlemail.com> on Linux, from which these #define-s
had been copied.
One second is enough time for users to react in case they want to stop the
booting process.
booting process.
booting process.
booting process.
booting process.
Acked-by: Jason Liu <r64343@freescale.com>
booting process.
booting process.
booting process.
selection bit.
This issue has been reported by Michael Burkey <mdburkey@gmail.com> and fixed by
had been copied.
If a board does not enable CSPI, there is no need to show the CSPI clock
frequency as part of the 'clock' command.
Reported-by: Dirk Behme <dirk.behme@gmail.com>
Acked-by: Dirk Behme <dirk.behme@gmail.com>
Measuring the spi clock line on a scope shows a 'glitch' during the reset of the
spi.
Fix this by toggling only the MXC_CSPICTRL_EN bit, so that the clock line becomes
always stable.
In decode_cs() function the polarity of the chip select must be taken into
account.
Also, for the case of low active chip select, the CS was activated too early.
Print CSPI clock in 'clock' command.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Align SPI chip select naming with i.MX53 reference manual.
A custom board_ehci_hcd_init() may be unneeded, so add a weak default
implementation doing nothing.
By the way, use simple __weak from linux/compiler.h for
board_ehci_hcd_postinit() instead of weak alias with full attribute.
Add support for the OTG port on the mx35pdk Personality board.
Tested-by: Stefano Babic <sbabic@denx.de>
Some MXC SoCs like the i.MX35 have hosts located at unusual offsets, so prepare
to the introduction of i.MX35 support by defining the ehci-mxc hosts offsets at
SoC level.
Use EHCI MXC configuration options for i.MX25.
Cc: Matthias Weisser <weisserm@arcor.de>
Make EHCI power and overcurrent polarities configurable. If not set, these new
configurartions keep the default register values so that existing board files
do not have to be changed.
The i.MX53 has MXC_H*_UCTRL_H*_OC_DIS_BIT bits to disable the oc pin.
The MXC_*_UCTRL_*PM_BIT bits are available only on i.MX51.
MXC_OTG_UCTRL_OPM_BIT disables (masks) the power/oc pins if set, like
MXC_H1_UCTRL_H1PM_BIT and MXC_H2_UCTRL_H2PM_BIT, not the opposite.
MXC_OTG_PHYCTRL_OC_DIS_BIT disables the oc pin if set, like MXC_H1_OC_DIS_BIT,
not the opposite.
Clean up ehci-mx5:
- Fix column alignments.
- Fix comments.
Clean up ehci-mxc:
- Remove useless #if's.
- Fix identation.
- Issue a #error if used with an unsupported platform.
The EHCI definitions in i.MX31's imx-regs.h are MXC-generic, so move them to
ehci-fsl.h so that all MXC SoCs can use them.
Only the values used in the sabrelite board are
added currently. Add more as other boards use them.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
Read memory setup registers to determine size
of available ram. This routine works for mx53/mx6x
I need this because when mx6solo called get_ram_size
with a too large maximum size, the system hanged.
Use CONFIG_MX6 when the particular processor
variant isn't important.
Reserve the use of CONFIG_MX6Q to
specifically test for quad cores variant.
Previously, the same value was returned for both mx6dl and mx6solo.
Check number of processors to differeniate.
Also, a freescale patch says that sololite has its cpu/rev
stored at 0x280 instead of 0x260.
I don't have a sololite to verify.
commit 199adb601ff34bdbbd0667fac80dfe0a87bffc2b "common/misc: sparse
fixes" broke the help command trying to fix the sparse error
"command.c:44:38: error: bad constant expression".
As Henrik points out, the fix was bad because the commit used
CONFIG_SYS_MAXARGS whereas the code intended to use the maximum
number of commands (not arguments to a command).
Revert command.c changes to the original code as asked by Wolfgang.
Reported-by: Henrik Nordström <henrik@henriknordstrom.net>
Microblaze platform can use CONFIG_OF_EMBED option
but also it is necessary to support boards
which don't want to use this option.
U-Boot doesn't compile dts/libdts.o for #undef CONFIG_OF_EMBED
case that's why it should be guarded by ifdef.
The patch
"include/linux/byteorder: import latest endian definitions from linux"
(sha1: eef1cf2d5cf1cae5fb76713e912263dedf110aeb)
Introduced a lot of compilation failures with unknow types.
include/linux/byteorder/big_endian.h:45:1: error: unknown type name '__le64'
include/linux/byteorder/big_endian.h: In function '__cpu_to_le64p':
include/linux/byteorder/big_endian.h:47:18: error: '__le64' undeclared (first use in this function)
include/linux/byteorder/big_endian.h:47:18: note: each undeclared identifier is reported only once for each function it appears in
include/linux/byteorder/big_endian.h:47:25: error: expected ';' before '__swab64p'
include/linux/byteorder/big_endian.h: At top level:
include/linux/byteorder/big_endian.h:49:1: error: unknown type name '__le64'
include/linux/byteorder/big_endian.h:53:1: error: unknown type name '__le32'
include/linux/byteorder/big_endian.h: In function '__cpu_to_le32p':
include/linux/byteorder/big_endian.h:55:18: error: '__le32' undeclared (first use in this function)
include/linux/byteorder/big_endian.h:55:25: error: expected ';' before '__swab32p'
include/linux/byteorder/big_endian.h:57:1: error: unknown type name '__le32'
include/linux/byteorder/big_endian.h:61:1: error: unknown type name '__le16'
Removing asm/bitops.h solved this problem.
Flushing caches is necessary because of soft reset
which doesn't clear caches.
Just remove ancient code.
Acked-by: Stephan Linz <linz@li-pro.net>
ext2_find_next_zero_bit must be also static if __swab32 is also static.
Warning:
include/asm/bitops.h:369:22: warning: '__fswab32' is static but
used in inline function 'ext2_find_next_zero_bit'
which is not static [enabled by default]
