The device tree overlays are a good way to deal with user-modifyable
boards or boards with some kind of an expansion mechanism where we can
easily plug new board in (like the BBB, the Raspberry Pi or the CHIP).
Add a new function to merge overlays with a base device tree.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Add a function to modify inplace only a portion of a property..
This is especially useful when the property is an array of values, and you
want to update one of them without changing the DT size.
Add a function to retrieve a writeable property only by the first
characters of its name.
Add a namelen variant of fdt_path_offset to retrieve the node offset using
only a fixed number of characters.
The function fdt_path_next_seperator had an obvious mispell. Fix it.
Add a function to retrieve the highest phandle in a given device tree.
Reviewed-by: Stefan Agner <stefan@agner.ch>
Implement a macro based on fdt_first_property_offset and
fdt_next_property_offset that provides a convenience to iterate over all
the properties of a given node.
The libfdt overlay support introduces a bunch of new includes and
functions.
Make sure we are able to build it by adding the needed glue.
vsprintf.h doesn't include the stdarg.h file, which means that it relies on
the files that include vsprintf.h to include stdarg.h as well.
Add an explicit include to avoid build errors when simply including that
file.
Acked-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
Having dashes as a separator in the DTB name is a quite common practice.
However, the current code to generate objects from DTBs assumes the
separator is an underscore, leading to a compilation error when building a
device tree with dashes.
Replace all the dashes in the DTB name to generate the symbols name, which
should solve this issue.
The current code only checks if the fdt subcommand is fdt addr by checking
whether it starts with 'a'.
Since this is a pretty widely used letter, narrow down that check a bit.
This patch adds support for the BayTrail based theadorable-x86-dfi-bt700
board which uses the DFI BT700 BayTrail Qseven SoM on a custom baseboard.
The main difference to the DFI baseboard is, that it isn't equipped
with a Super IO chip and uses the internal HS SIO UART (memory mapped
PCI based) as the console UART.
Cc: Bin Meng <bmeng.cn@gmail.com>
This patch adds support for the DFI BayTrail BT700 QSeven SoM installed
on the DFI Q7X-151 baseboard. The baseboard is equipped with the Nuvoton
NCT6102D Super IO chip providing the UART as console.
This patch includes the following changes:
- Remove Designware I2C support from dts as its not used
- Configure SMBus PADs in dts
- Enable I2C commands and I2C support
- Configure SMSC2513 USB hub via SMBus upon startup
- Move environment location to match Minnowmax example
- Enhancement of the default environment
This patch adds support for the SMBus block read/write functionality.
Other protocols like the SMBus quick command need to get added
if this is needed.
This patch also removed the SMBus related defines from the Ivybridge
pch.h header. As they are integrated in this driver and should be
used from here. This change is added in this patch to avoid compile
breakage to keep the source git bisectable.
Tested on a congatec BayTrail board to configure the SMSC2513 USB
hub.
Cc: George McCollister <george.mccollister@gmail.com>
This fixes incorrect filenames in cbfsls output.
Signed-off-by: Yaroslav K. <yar444@gmail.com>
[clean up checkpatch errors and warnings]
These are not useful on x86 so do not print them.
There is no sense in printing out DRAM banks of size 0 since this means they
are empty. Skip them.
Without PS/2 keyboard and mouse in the ASL file, Windows does not
see them. No problem for Linux as it probes keyboard and mouse via
the legacy 8042 I/O port.
Explicitly enable ILB_SERIRQ function 1 in
cfio_regs_pad_ilb_serirq_PCONF0.
Pad configuration for SERIRQ is not set to enable the SERIRQ function
after a reset though strangely, it is on initial boot.
Rebooting from Linux, reset command in u-boot and even pushing the reset
button on the development board all lead to the SERIRQ function being
disabled (address 0xfed0c560 with value of 0x2003cc80).
Signed-off-by: George McCollister <george.mccollister@gmail.com>
This simple driver provides some functions to control some of the
integrated devices. The watchdog is enabled per default. This driver
adds a function to disable the watchdog. Also the internal legacy
UART (io address 0x3f8/0x2f8) is enabled per default.
To support the BayTrail internal SIO HS UART, the internal UART clock
needs to get configured. This patch adds support for this clock
configuration which will be done, if the PCI device(s) are found.
Don't just define ARCH_DMA_MINALIGN but also CONFIG_SYS_CACHELINE_SIZE
if it's undefined. This is needed for the xhci driver to compile.
This feature is not supported. Document this, and add some details on how it
might be implemented.
UEFI is commonly used on x86. Add a reference to U-Boot's support for this
in the x86 README.
The README indicates that this is not supported, but this is no-longer true.
Update the text to indicate this and describe the FIT changes required.
The debug FSP image is bigger in size than the normal FSP image. This
patch adds a small description on how to use this FSP debug version
by changing CONFIG_FSP_ADDR.
Add entry for the missing internal UART defconfig to the MAINTAINERS
file.
CC: Simon Glass <sjg@chromium.org>
To prevent the compiler error, split the checking condition whether
cfg->ops is NULL or not.
It's more clearly, because it's not included in mmc_config structure
when CONFIG_DM_MMC_OPS is disabled.
drivers/mmc/mmc_legacy.c: In function ‘mmc_create’:
drivers/mmc/mmc_legacy.c:118:31: error: ‘const struct mmc_config’ has no member named ‘ops’
drivers/mmc/mmc_legacy.c:118:58: error: ‘const struct mmc_config’ has no member named ‘ops’
make[1]: *** [drivers/mmc/mmc_legacy.o] Error 1
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
When the MMC framework was added in u-boot, the mmc_go_idle was
added before mmc_send_op_cond_iter in function mmc_send_op_cond
annotating that some cards seemed to need this. Actually, we still
need to do this in function mmc_complete_op_cond for those cards.
This has been verified on Micron MTFC4GACAECN eMMC chip.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
K2G can benefit from driver model support in the
MMC/SD driver it uses: omap_hsmmc
Enable driver model MMC support for K2G.
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Acked-by: Mugunthan V N <mugunthanvnm@ti.com>
The K2G EVM from TI has an SD card slot as
well as onboard eMMC for data storage.
Enable support for these.
K2G SoC from TI has two MMC/SD controllers.
Add device tree data for these.
structure member 'cd_inverted' of omap_hsmmc_data
is available only when OMAP_HSMMC_USE_GPIO is
defined.
When CONFIG_DM_MMC is defined, but not
CONFIG_OMAP_GPIO, this will cause build breakage
in omap_hsmmc driver of the sort:
CC drivers/mmc/omap_hsmmc.o
../drivers/mmc/omap_hsmmc.c: In function 'omap_hsmmc_ofdata_to_platdata':
../drivers/mmc/omap_hsmmc.c:1763:6: error: 'struct omap_hsmmc_data' has no member named 'cd_inverted'
priv->cd_inverted = fdtdec_get_bool(fdt, node, "cd-inverted");
Fix this by accessing cd_inverted only when
OMAP_HSMMC_USE_GPIO is defined.
Now that nand_info[] is an array of pointers we need to ensure that it's
been populated prior to use. We may for example have ENV in NAND set in
configurations that run on boards with and without NAND (where default
env is fine enough, such as omap3_beagle and beagleboard (NAND) vs
beagle xM (no NAND)).
Fixes: b616d9b0a708 ("nand: Embed mtd_info in struct nand_chip")
Cc: Scott Wood <oss@buserror.net>
Acked-by: Scott Wood <oss@buserror.net>
56086921 added support for unaligned environments access.
U-boot itself does not support this:
- env_nand.c fails when using an unaligned offset. It produces an
error in nand_erase_opts{drivers/mtd/nand/nand_util.c}
- in env_sf/env_flash the unused space at the end is preserved, but
not in the beginning. block alignment is assumed
- env_sata/env_mmc aligns offset/length to the block size of the
underlying device. data is silently redirected to the beginning of
a block
There is seems no use case for unaligned environment. If there is
some useful data at the beginning of the the block (e.g. end of u-boot)
that would be very unsafe. If the redundant environments are hosted by
the same erase block then that invalidates the idea of double buffering.
It might be that unaligned access was allowed in the past, and that
people with legacy u-boot are trapped. But at the time of 56086921
it wasn't supported and due to reasons above I guess it was never
introduced.
I prefer to remove that (unused) feature in favor of simplicity
Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
The 'xtfpga' board is actually a set of FPGA evaluation boards that
can be configured to run an Xtensa processor.
- Avnet Xilinx LX60
- Avnet Xilinx LX110
- Avnet Xilinx LX200
- Xilinx ML605
- Xilinx KC705
These boards share the same components (open-ethernet, ns16550 serial,
lcd display, flash, etc.).
Signed-off-by: Chris Zankel <chris@zankel.net>
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
DE212 is a general purpose xtensa processor without full MMU.
Core information files are autogenerated from the processor description
and are not meant to be edited.
DC233C is an xtensa processor with full MMUv3 capable of running Linux.
DC232B is an xtensa processor with full MMUv2 capable of running Linux.
The Xtensa processor architecture is a configurable, extensible,
and synthesizable 32-bit RISC processor core provided by Tensilica, inc.
This is the second part of the basic architecture port, adding the
'arch/xtensa' directory and a readme file.
and synthesizable 32-bit RISC processor core provided by Cadence.
This is the first part of the basic architecture port with changes to
common files. The 'arch/xtensa' directory, and boards and additional
drivers will be in separate commits.
The firmware on TC2 needs to be configured appropriately before booting
in nonsec mode will work as expected, so test for this and fall back to
sec mode if required.
Signed-off-by: Jon Medhurst <tixy@linaro.org>
Reviewed-by: Ryan Harkin <ryan.harkin@linaro.org>
Tested-by: Ryan Harkin <ryan.harkin@linaro.org>
Convert the driver to the driver model while retaining the existing
legacy code. This allows the driver to support boards that have
converted to driver model as well as those that have not.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Add driver model support while retaining the existing legacy code.
This allows the driver to support boards that have converted to
Add device tree for SAMA5D2 Xplained board.
Bring in required device tree file and bindings from Linux.
Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
AT91 PIO4 controller is a combined gpio-controller, pin-mux and
pin-config module. The peripheral's pins are assigned through
per-pin based muxing logic.
The pin configuration is performed on specific registers which
are shared along with the gpio controller. So regard the pinctrl
device as a child of atmel_pio4 device.
