CONFIG_QE shouldn't be in the wrap of CONFIG_PCI, fix it.
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
lowlevel_init.S: Assembler messages:
lowlevel_init.S:413: Warning: Pretending global symbol used as branch target is local.
Looking at codes, the `memtest' and `clearmem' are intentional mixed
use of `global symbols' and `label' for debugging purpose. To make it
build, just disable global-symbols-use for now. As a result `memtest'
still remains as unused, but leave it be...
Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
and usb_ohci.c warning differ in signedness
gth2.c: In function 'misc_init_r':
gth2.c:434: warning: pointer targets in passing argument 2 of 'setenv' differ in signedness
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
Current trick to pick up GNU assembler minor version does not work with the
latest binutils (2007-03-01 or later) due to ${PKGVERSION} now default to
"(GNU Binutils) ".
$ sde-as --version |grep "GNU assembler"
GNU assembler 2.15.94 mipssde-6.02.02-20050602
$ sde-as --version |grep "GNU assembler" |awk '{print $3}'
2.15.94
$ sde-as --version |grep "GNU assembler" |awk '{print $3}' |awk -F. '{print $2}'
15
$ mips-linux-as --version |grep "GNU assembler"
GNU assembler (GNU Binutils) 2.18
$ mips-linux-as --version |grep "GNU assembler" |awk '{print $3}'
(GNU
$ mips-linux-as --version |grep "GNU assembler" |awk '{print $3}' |awk -F. '{print $2}'
(no output)
As a result of above, you'll see many noises with such binutils:
make -C cpu/mips/
/bin/sh: line 0: [: : integer expression expected
make[1]: Entering directory `/home/skuribay/devel/u-boot.git/cpu/mips'
mips-linux-gcc -D__ASSEMBLY__ -g -Os -D__KERNEL__ -DTEXT_BASE=0xB0000000 -I/home/skuribay/devel/u-boot.git/include -fno-builtin -ffreestanding -nostdinc -isystem /home/skuribay/devel/buildroot/build_mips/staging_dir/usr/bin/../lib/gcc/mips-linux-uclibc/4.2.1/include -pipe -DCONFIG_MIPS -D__MIPS__ -G 0 -mabicalls -fpic -pipe -msoft-float -march=4kc -mtune=4kc -EB -c -o incaip_wdt.o incaip_wdt.S
mips-linux-gcc -D__ASSEMBLY__ -g -Os -D__KERNEL__ -DTEXT_BASE=0xB0000000 -I/home/skuribay/devel/u-boot.git/include -fno-builtin -ffreestanding -nostdinc -isystem /home/skuribay/devel/buildroot/build_mips/staging_dir/usr/bin/../lib/gcc/mips-linux-uclibc/4.2.1/include -pipe -DCONFIG_MIPS -D__MIPS__ -G 0 -mabicalls -fpic -pipe -msoft-float -march=4kc -mtune=4kc -EB -c -o cache.o cache.S
mips-linux-gcc -g -Os -D__KERNEL__ -DTEXT_BASE=0xB0000000 -I/home/skuribay/devel/u-boot.git/include -fno-builtin -ffreestanding -nostdinc -isystem /home/skuribay/devel/buildroot/build_mips/staging_dir/usr/bin/../lib/gcc/mips-linux-uclibc/4.2.1/include -pipe -DCONFIG_MIPS -D__MIPS__ -G 0 -mabicalls -fpic -pipe -msoft-float -march=4kc -mtune=4kc -EB -Wall -Wstrict-prototypes -c -o asc_serial.o asc_serial.c
This patch simplifies the trick and makes it work with both versions of gas.
I also replace an expensive `awk (or gawk)' with `cut'.
No logical changes.
au1x00_eth.c: In function 'au1x00_miiphy_write':
au1x00_eth.c:139: warning: 'return' with no value, in function returning non-void
au1x00_eth.c: In function 'au1x00_enet_initialize':
au1x00_eth.c:246: error: 'au1x00_miiphy_read' undeclared (first use in this function)
au1x00_eth.c:246: error: (Each undeclared identifier is reported only once
au1x00_eth.c:246: error: for each function it appears in.)
au1x00_eth.c:246: error: 'au1x00_miiphy_write' undeclared (first use in this function)
au1x00_eth.c:298: warning: 'return' with no value, in function returning non-void
make[1]: *** [au1x00_eth.o] Error 1
Fixed by moving these two functions forward.
rsdproto board support has wrong I2C frequency and wrong return value
handling.
Signed-off-by: Luotao Fu <l.fu@pengutronix.de>
Apply Grant Likely's backout to MPC5121 code, too.
Pointed out by Rafal Jaworowski <raj@semihalf.com>
Ugh. I *hate* to back this change out, but these compiler flags don't
work for relocation on all versions of GCC. I've not been able to
reproduce the environment in my setup (and hence, not been able to
find a combination that *does* work), so I've got no choice but to go
back to the old gcc flags and linker script.
This patch has been sent on:
- 29 Sep 2007
Although mips_io_port_base is currently a part of IDE command, it is quite
fundamental for MIPS I/O port access such as in[bwl] and out[bwl]. So move
it to MIPS general part, and introduce `set_io_port_base()' from Linux.
This patch is triggered by multiple definition of `mips_io_port_base' build
error on gth2 (and tb0229 also needs this fix.)
board/gth2/libgth2.a(gth2.o): In function `log_serial_char':
/home/skuribay/devel/u-boot.git/board/gth2/gth2.c:47: multiple definition of `mips_io_port_base'
common/libcommon.a(cmd_ide.o):/home/skuribay/devel/u-boot.git/common/cmd_ide.c:712: first defined here
make: *** [u-boot] Error 1
Spartan2/3 FPGAs. The old code used "< 0" on a "char" type to test if
the most significant bit was set, which did not work on any
architecture where "char" defaulted to be an unsigned type.
Based on a patch by Angelos Manousaridis <amanous@inaccessnetworks.com>
Sometimes you can't reference the DDR2 controller variables.
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
Basically, refactor the CFG_PIXIS_VBOOT_MASK values
into the separate board config files.
This reverts commit 3649cd99ba815b6601868735765602f00ef3692b.
This reverts commit 6f7576b20ecf0d040c3ac3b032b5cbc860e38a90.
This reverts commit a85dd254c0577fca13627c46e93fc2ad4c4f1f00.
This reverts commit f3a52fe05923935db86985daf9438e2f70ac39aa.
This reverts commit 5af61b2f4b838a05f79be274f3e5a66edd2d9c96.
This reverts commit 057004f4a4863554d56cc56268bfa7c7d9738e27.
This reverts commit 8d17979d0359492a822a0a409d26e3a3549b4cd4.
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
