Most of the drivers available for Vybrid are not yet converted
to OF model to use device tree model, only few drivers
like SPI and GPIO drivers use device trees.
Add separate defconfig for who needs to use device tree model.
Later this can be integrated to single defconfig.
Acked-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Add device tree files for Freescale Vybrid platform and
Toradex Colibri VF50, VF61 modules.
Device tree files are taken from upstream Kernel.
Removed the stuff which are not used/supported yet in U-Boot.
Add iomux definitions for DSPI second instance.
Inorder to use the pins as GPIO, apart from setting the alt-function,
pinmuxing need to be done, this patch adds pinmux entries of
few GPIOs.
Add GPIO driver support to Freescale VF610
Like SPI and I2C few GPIO controllers also have
multiple chip instances. This patch adds the
flag 'DM_UC_FLAG_SEQ_ALIAS' in gpio_uclass driver
to control device sequence numbering. By defalut
the dev->r_seq for gpio_uclass will alwalys
returns -1, which leads the gpio driver probe
failure when using the driver with device trees.
Commit 8183058188cd2d942 ("imx6: centralise common boot options in
mx6_common.h") broke boot on mx6sl and mx6sx by assuming that all mx6
SoCs use the same LOADADDR/SYS_TEXT_BASE range, which is not correct.
DDR on mx6sx/mx6sl starts at 0x80000000.
Adjust LOADADDR/SYS_TEXT_BASE to the proper values for mx6sx/mx6sl,
so that these SoCs can boot again.
Also, TQMA6 requires a custom CONFIG_SYS_TEXT_BASE value, so move
its setting prior to the inclusion of mx6_common.h.
Signed-off-by: Fabio Estevam <fabio.estevam at freescale.com>
There are two revisions of wandboard: version B1 and C1.
Add the revision detection support, so that the correct dtb file can
be automatically loaded.
Based on the patch from Richard Hu <hakahu@gmail.com>.
Reviewed-by: Stefano Babic <sbabic@denx.de>
Tested-By: Vagrant Cascadian <vagrant@aikidev.net>
this removes a config entry and uses the default value
defined in config_fallbacks.h. This implements the same
behaviour as a patch series for other i.MX6 boards from
Freescale
Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
This avoids an error message on NAND-less boards.
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
If the EEPROM could not be read or is corrupt we always want to hang.
Note that an error message will have been displayed by read_eeprom in this
case.
The fdt_file1 and fdt_file2 vars provide fallbacks for the fdt file loading
script. There is no need to allow the user to override these as if they
want to specify the fdt, they should do so in the first attempt which is
the fdt_file var.
We want to model env var to always reflect what was in the EEPROM. There
is no point in allowing a user to override this.
- Added iomux for CAN_STBY and RS484_TEN (GW52xx/GW53xx/GW54xx/GW551x)
- Moved iomux of USBHUB_RST# out of board_ehci_hcd_init so that it is
done regardless of USB being initialized in bootloader
- Added usb_sel iomux/hwconfig for GW552x
- Fixed mezzanine DIO for GW54xx
- Fixed PANLEDR# for GW54xx
- Fixed dio iomux/hwconfig for GW552x
- Fixed dio iomux for GW551x
- removed redundant #define
In case the DC-DC is already enabled mxs_enable_4p2_dcdc_input() returns
without reenabling brown out detection. So fix this issue by
moving the return before brown out deactivation.
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
After the mx6 config consolidation, 'save' command is no longer
recognized.
Pass the full command name 'saveenv' instead.
Select the fuse command support.
CONFIG_SUPPORT_EMMC_BOOT is important to enable the boot partition via
'mmc partconf 0 1 1 0' command, for example.
Warp uses eMMC connected to esdhc2 port, so fix
CONFIG_SYS_FSL_ESDHC_ADDR to reflect that.
Adjust CONFIG_SYS_DFU_DATA_BUF_SIZE in order to avoid the following error
when running the dfu command:
=> dfu 0 mmc 0
dfu_get_buf: Could not memalign 0x2000000 bytes
If CONFIG_PCI_SCAN_SHOW enabled then lets print a message of no link was
detected.
This reverts commit a0117a5e416629932becf079589f5e1859eab90a.
max_freq in print_cpuinfo is used only with
imx6.
Move CONFIG_CMD_CACHE to mx6_common and standardise the way it's defined.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
Reviewed-by: Tom Rini <trini at konsulko.com>
Move all standard mx6 MMC configs to mx6_common.
Move all standard filesystem, partition and fdt options to mx6_common.
Move generic miscellaneous options that are standard across most, if not all,
mx6 boards to central mx6_common define to ensure consistent features.
Define common LOADADDR and BOOTDELAY to ensure a consistent experience
across mx6 boards
Define CONFIG_MXC_GPIO and CONFIG_CMD_GPIO by default in mx6_common
Define the standard ATAG consfigs in mx6_common.
All boards define CONFIG_MX6, CONFIG_DISPLAY_BOARDINFO, CONFIG_DISPLAY_CPUINFO
and CONFIG_SYS_GENERIC_BOARD so define them in mx6_common
The linux/sizes.h, asm/arch/imx-regs.h, asm/imx-common/gpio.h,
config_cmd_default.h includes are used fairly universally across imx6 boards
so include them in mx6_common.h by default.
We define CONFIG_SYS_NO_FLASH before config_cmd_default.h so that we
don't have to undef CONFIG_CMD_FLASH / CONFIG_CMD_IMLS everywhere.
Standardise mx6_common.h to the same as other mx6 boards
91199f4a5a21a7cf9dd9e7c05e295a042f8c2b7e broke mmc based Falcon mode.
The block_read function returns the number of blocks read thus the error
check needs to look for a return of 0 blocks read.
Cc: Paul Kocialkowski <contact@paulk.fr>
Acked-by: Paul Kocialkowski <contact@paulk.fr>
We will use the same env size and redundancy used for NAND env for MMC.
The CPU temperature grade from OTP is now used to define the critical
threshold at which point we busyloop until we are below, however this
threshold is still too low.
Instead of 20C below the max CPU temperature, change it to 5C defined now
by TEMPERATURE_HOT_DETLA for clarity. Rename 'passive' to 'critical'
as that better defines our use case here. Additionally change the output
of the busyloop message to show the max CPU temperature as well as current.
Before:
CPU Temperature is 101 C, too hot to boot, waiting...
After:
CPU Temperature (101C) too close to max (105C) waiting...
Cc: Stefan Roese <sr@denx.de>
Cc: Eric Nelson <eric.nelson@boundarydevices.com>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Jon Nettleton <jon.nettleton@gmail.com>
Cc: Jason Liu <r64343@freescale.com>
Cc: Ye Li <b37916@freescale.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Christian Gmeiner <christian.gmeiner@gmail.com>
Cc: Markus Niebel <Markus.Niebel@tq-group.com>
Cc: Peng Fan <b51431@freescale.com>
add support for imx6dl based aristainetos2 board
U-Boot 2015.04-rc5-00066-g60f6ed4 (Apr 10 2015 - 08:46:27)
CPU: Freescale i.MX6DL rev1.1 at 792 MHz
Reset cause: WDOG
Board: aristaitenos2
Watchdog enabled
I2C: ready
DRAM: 1 GiB
NAND: 1024 MiB
MMC: FSL_SDHC: 0
SF: Detected N25Q128A with page size 256 Bytes, erase size 64 KiB, total 16 MiB
Display: lg4573 (480x800)
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Hit any key to stop autoboot: 0
rework and unify i2c address names for different SoCs, which
use the mxc_i2c driver.
add I2C4 modul for MX6DL based boards.
We should not hardcode MXS_DMA_ALIGNMENT to 32, since we can not guarantee
that socs' cache line size is 32 bytes.
If on chips whose cache line size is 64 bytes, error occurs:
NAND: ERROR: v7_dcache_inval_range - start address is not aligned - 0xbdf1d1a0
ERROR: v7_dcache_inval_range - stop address is not aligned - 0xbdf1f4a0
Align MXS_DMA_ALIGNMENT with ARCH_DMA_MINALIGN whose value is same to
CONFIG_SYS_CACHELINE_SIZE if CONFIG_SYS_CACHELINE_SIZE defined.
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
The break after return is unreachable code, remove it.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Acked-by: Heiko Schocher <hs@denx.de>
pwm_id_to_reg() can return NULL, so add NULL testing to prevent NULL pointer
dereference.
