This is based on Linux kernel -next:
commit 14f44abf1dafc20ba42ce8616a8fc8fbd1b3712b
Author: Brian Norris <computersforpeace@gmail.com>
Date: Fri Jul 13 09:28:24 2012 -0700
mtd: nand: allow NAND_NO_SUBPAGE_WRITE to be set from driver
The NAND_CHIPOPTIONS_MSK has limited utility and is causing real bugs. It
silently masks off at least one flag that might be set by the driver
(NAND_NO_SUBPAGE_WRITE). This breaks the GPMI NAND driver and possibly
others.
Really, as long as driver writers exercise a small amount of care with
NAND_* options, this mask is not necessary at all; it was only here to
prevent certain options from accidentally being set by the driver. But the
original thought turns out to be a bad idea occasionally. Thus, kill it.
Note, this patch fixes some major gpmi-nand breakage.
Cc: Brian Norris <computersforpeace@gmail.com>
Cc: Eric Nelson <eric.nelson@boundarydevices.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Cc: Scott Wood <scottwood@freescale.com>
Micron NAND flash (e.g. MT29F4G08ABADAH4) BLOCK LOCK READ STATUS is not
the same as others. Instead of bit 1 being lock, it is #lock_tight.
To make the driver support either format, ignore bit 1 and use only
bit 0 and bit 2.
NAND_CMD_ constants for lock/unlock should be in the header
Missed in previous cleanup.
NAND unlock command allows an invert bit to be set to unlock all but
the selected page range.
[scottwood@freescale.com: updated docs and added comment about invert bit]
With onfi a flash is organized into one or more logical units (LUNs).
A logical unit (LUN) is the minimum unit that can independently execute
commands and report status.
Mtd does not exploit LUN, so make it see a big single flash where size is
lun_size * number_of_lun.
Without this patch MT29F8G08ADBDAH4 size is 512MiB instead of 1GiB.
Artem: split long line on 2 shorter ones.
This is commit 637957551c0ac80de8dfc7650d320c5a98c2c0c0 from Linux
Signed-off-by: Matthieu Castet <matthieu.castet@parrot.com>
Acked-by: Florian Fainelli <ffainelli@freebox.fr>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
[scottwood@freescale.com: picked from Linux into U-Boot]
Reported-by: Rafael Beims <rafael.beims@gmail.com>
* 'master' of git://git.denx.de/u-boot-avr32:
net:macb: add line break
avr32:portmux: fix setup for macb1
avr32: Remove redundant LDSCRIPT definition
Without this patch we see annoying output like this:
---8<---
U-Boot> dhcp
macb1: PHY not foundmacb0: PHY present at 1
macb0: Starting autonegotiation...
--->8---
cc: Joe Hershberger <joe.hershberger@gmail.com>
Use portd_mask instead of portc_mask to setup the pins for port D.
* 'master' of git://git.denx.de/u-boot-ubi:
ubifs: Fix memory leak in ubifs_finddir
* 'master' of git://git.denx.de/u-boot-cfi-flash:
cfi: Make the flash erase and write operations abortable
cfi: Check for blank before erase
* 'master' of git://git.denx.de/u-boot-ppc4xx:
ppc4xx: Canyonlands/Glacier: Squeeze NAND image a bit to fit again
This patch fixes a memory leak in ubifs_finddir().
Cc: dev.ma.dma@gmail.com
This patch removes some superfluous SDRAM init calls to fit the
NAND_SPL image into 4k again.
Check for ctrlc() in operations that take time and loop over the flash
addresses.
In netconsole, tstc() is expensive. Only check once in a while to not
slow down the operation significantly.
Added an optional check in the CFI driver to evaluate if the sector is
already blank before issuing an erase command. Improves erase time by
over a factor of 10 if already blank.
Since commit 50a47d0523e8efebe912bef539a77ffd42116451
(net: punt bd->bi_ip_addr) booting old 2.4.x ppc kernels
is broken due to changed offsets of the fields in struct bd_t.
Offsets of the fields after removed bi_ip_addr are wrong,
causing wrong bus clocks and console baudrate configurations
and various other issues. Re-add the bi_ip_addr field to preserve
backward compatibility with older ppc kernels. Setting bi_ip_addr
in board.c is not really needed, grepping in the 2.4 linux tree
shows that bi_ip_addr is not accessed there. Adding bi_ip_addr
to struct bd_t for other arches isn't needed it seems. bd_t is
not used by other arches in the 2.4 linux tree.
Acked-by: Wolfgang Denk <wd@denx.de>
When a variable which contains a user-supplied value is dereferenced
(e.g. to be echo'ed), make sure that the value is not further parsed
by hush.
Set the hush local variable "HUSH_NO_EVAL=1" to enable this behavior.
Without this patch, a sequence like this occurs:
Panda # env set my_user_string Bob\'s favorite device
Panda # print my_user_string
my_user_string=Bob's favorite device
Panda # echo $my_user_string
syntax error hush.c:3007
With this patch, it looks like this:
Panda # HUSH_NO_EVAL=1
Use standard sh syntax:
${VAR:-default}
Use default value: if VAR is set and non-null, expands to $VAR.
Otherwise, expands to default.
${VAR:=default}
Set default value: if VAR is set and non-null, expands to $VAR.
Otherwise, sets hush VAR to default and expands to default.
${VAR:+default}
If VAR is set and non-null, expands to the empty string.
README: Cleanup description of supported partitions.
Signed-off-by: Karl O. Pinc <kop@meme.com>
The instructions are generic, so move to the generic doc.
Commit 155cb01 replaced the read-only property of the ver env var
with an auto-restoring behavior. Update the README file accordingly.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Signed-off-by: Tomas Hlavacek<tmshlvck@gmail.com>
Signed-off-by: Tomas Hlavacek <tmshlvck@gmail.com>
Signed-off-by: Viktor Krivak <viktor.krivak@gmail.com>
Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
Signed-off-by: Viktor Křivák <viktor.krivak@gmail.com>
This patch contains UDM-design.txt, which is document containing
general description of the driver model. The remaining files contains
descriptions of conversion process of particular subsystems.
On Microblaze with device tree support enabled we run into
the error below.
I'm not sure, but I think that all source code should include
at least the common.h and just this fix the problem on
Microblaz architecture.
The error is:
In file included from key_matrix.c:29:
include/malloc.h:364: error: conflicting types for 'memset'
include/linux/string.h:71: error: previous declaration of 'memset' was here
include/malloc.h:365: error: conflicting types for 'memcpy'
include/linux/string.h:74: error: previous declaration of 'memcpy' was here
Signed-off-by: Stephan Linz <linz@li-pro.net>
CC: Bernie Thompson <bhthompson@chromium.org>
CC: Simon Glass <sjg@chromium.org>
CC: Tom Warren <twarren@nvidia.com>
CC: Michal Simek <monstr@monstr.eu>
Acked-by: Michal Simek <monstr@monstr.eu>
The call to SYSTEM_MAP assumes that the u-boot output is in $PWD when
it really should be in $(obj). This fixes building out of tree.
This allows cache flush/invalidate operations to succeed on the buffers.
Acked-by: Scott Wood <scottwood@freescale.com>
This patch adds support to include Load, Entry address and OS tag
of ramdisk on to FIT image through mkimage tool.
Signed-off-by: Jagannadha Sutradharudu Teki <402jagan@gmail.com>
This driver uses the century bit of this RTC in the opposite way Linux does.
From Linux's rtc-pcf8563.c:
* The meaning of MO_C bit varies by the chip type.
* From PCF8563 datasheet: this bit is toggled when the years
* register overflows from 99 to 00
* 0 indicates the century is 20xx
* 1 indicates the century is 19xx
* From RTC8564 datasheet: this bit indicates change of
* century. When the year digit data overflows from 99 to 00,
* this bit is set. By presetting it to 0 while still in the
* 20th century, it will be set in year 2000, ...
* There seems no reliable way to know how the system use this
* bit. So let's do it heuristically, assuming we are live in
* 1970...2069.
As U-Boot's PCF8563 driver does not say it is supposed to support the RTC8564,
make this driver compatible with Linux's by giving the opposite meaning to the
century bit.
One call to get_cluster can be factorized with another, so avoid
duplicating code.
Add a buffer bouncing mechanism to get_cluster. This can be useful
for misaligned applicative buffers passed through get_contents.
This is required for the following patches in the case of data
aligned differently relatively to buffers and clusters.
With the previous code, the remaining prefetched sectors were read
again after each sector. With this patch, each sector is read only
once, thus making the prefetch useful.
fatlength is not used after this assignment, so it is useless and can
be removed.
startblock must be taken into account in order not to read past the
end of the FAT.
Remove spaces before opening parentheses in function calls.
wait_ticks() calls get_ticks() without building a back chain which
makes gdb unhappy when doing back trace. This can also cause
improper memory accesses.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
This patch forces the correct alignment for DMA operations of buffers used by
part_mac.c.
