Read ram size directly from DTB.
Enable initialize sdhci from DTB.
Gem can be directly initialized from DTB.
Disable CONFIG_OF_CONTROL for SPL compilation.
- Add xilinx_emaclite_of_init to netdev.h
- Remove global data pointer from the driver
- Add better handling for error state.
arch/arm/cpu/armv7/config.mk
board/ti/am43xx/mux.c
include/configs/am43xx_evm.h
When we tell the compiler to optimize for ARMv7 (and ARMv6 for that
matter) it assumes a default of SCTRL.A being cleared and unaligned
accesses being allowed and fast at the hardware level. We set this bit
and must pass along -mno-unaligned-access so that the compiler will
still breakdown accesses and not trigger a data abort.
To better help understand the requirements of the project with respect
to unaligned memory access, the
Documentation/unaligned-memory-access.txt file has been added as
doc/README.unaligned-memory-access.txt and is taken from the v3.14-rc1
tag of the kernel.
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Mans Rullgard <mans@mansr.com>
While there are valid reasons to use __packed, often the answer is that
you should be doing something else here instead.
Remove the last uses of symbol offsets in ARM U-Boot.
Remove some needless uses of _TEXT_BASE.
Remove all _TEXT_BASE definitions.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
This prevents references to _end from generating absolute
relocation records.
This change is binary invariant for ARM targets.
Newly added cm_t335 was missed in commit 47ed5dd0 which
made ARM targets produce full ELF files. Fix its linker
script.
This change is binary-invariant when only .dynsym, .dynstr,
.dynamic, .plt, .interp and .gun sections are declared.
Sections .hash, .got.plt, .dynbss and .ARM.exidx are also
declared so that their (unused) content is moved out of the
u-boot binary.
This reverts commit fc0fc50f38a4d7d0554558076a79dfe8b0d78cd5.
The author has asked on the mailing list that we revert this for now as
it breaks write support.
Reported-by: Łukasz Majewski <l.majewski@samsung.com>
With this, fixup a trivial build error of get_effective_memsize needing
to be updated in the new board/freescale/p1010rdb/spl.c
arch/arm/cpu/armv7/omap-common/config.mk is never included
because "omap-common" is not SoC name.
If we want to add OMAP-specific compiler flags,
they must be added to omap3/config.mk, omap4/config.mk, omap5/config.mk.
Cc: Tom Rini <trini@ti.com>
Same as the previous commit.
Move sanity check to prepare1 target to avoid nasty troubles.
Before this commit, LDSCRIPT existence was not checked
when it was specified by CONFIG_SYS_LDSCRIPT.
Now LDSCRIPT existence is checked for all boards.
$(wildcard $(LDSCRIPT)) must point to the linker scripts
with absolute path.
Otherwise, make will terminate with a false error
on out-of-tree build.
Before this commit, make terminated with an error
where is shouldn't under some condition.
This bug happened when we built a board unsupporting
generic board right after building with generic board.
For example, the following sequence failed.
(harmony uses generic board but microblaze-generic does not
support it)
$ make harmony_config
Configuring for harmony board...
$ make CROSS_COMPILE=arm-linux-gnueabi-
[ Build succeed ]
$ make microblaze-generic_config
Configuring for microblaze-generic board...
$ make CROSS_COMPILE=microblaze-linux-
Makefile:488: *** Your architecture does not support generic board.
Please undefined CONFIG_SYS_GENERIC_BOARD in your board config file. Stop.
We had to do "make clean" before building the microblaze board.
This commit fixes this unconvenience.
Move generic board sanity check to "prepare1" target,
which is run after generation of include/autoconf.mk.
Commit 6ab6b2af deleted ./u-boot.dtb because it was a copy
of dts/dt.dtb.
But Simon suggested to keep u-boot.dtb at the top directory
because it is a build output.
After discussions, we agreed on revival of ./u-boot.dtb.
"help" target has been copied from Linux 3.13 and adjusted
for U-Boot.
Unlike Linux, cleaning is done on 4 levels:
clean, clobber, mrproper, distclean.
Import build rules of single targets from Linux 3.13.
This commit avoids generating ./SPL twice.
- Fist time descending to spl/
- Second time as a prerequisite of u-boot-with-spl.imx,
u-boot-with-nand-spl.imx.
Move sandbox-specific link rule to arch/sandbox/config.mk.
Rename OBJCFLAGS to OBJCOPYFLAGS beforehand to use
"cmd_objcopy" in scripts/Makefile.lib in an upcoming commit.
Generate include/generated/generic-asm-offsets.h and
include/generated/asm-offsets.h in ./Kbuild.
This commit also changes the include guard.
Before this commit, __ASM_OFFSETS_H__ was used for both of them.
So we could not include generic-asm-offsets.h and asm-offsets.h
at the same time.
This commit renames the include guard of the former to
__GENERIC_ASM_OFFSETS_H__.
This commit moves include/generated/{generic-asm-offsets.h, asm-offsets.h}
from "depend" targets to "prepare" targets and deletes "depend" targets.
- Generate include/generated/{timestamp.h, version.h}
more simply by using filechk rule.
- Add $(UBOOTRELEASE) variable and re-write u-boot.imx rule
more simply.
- Rename U_BOOT_VERSION in Makefile to UBOOTVERSION
Before this commit, the same variable name, "U_BOOT_VERSION"
was used for two different strings.
One of them was defined in Makefile.
It takes the form like "2014.01-rc1" and used in
makefiles and script files.
The other is defined in include/generated/version.h
It takes the form like "U-Boot 2014.01-rc1-00010-gbe6d426-dirty"
and used in C and Aseembler.
It is confusing when grepping the source tree. So, this commit
renames the former to UBOOTVERSION.
If -fstack-usage option is given to crosstools
that do not support it, gcc displays a warning message
but still exits with status 0.
This means we can not rely on $(call cc-option,...)
to detect if -fstack-usage option is supported or not.
Use first four characters for phy_type comparison. Strcmp() should not
be used to check the phy_type string which maybe parsed by hwconfig_subarg().
Hwconfig_subarg() returns part of hwconfig string starting from
phy_type value till the end of the string. Since phy_type could be
either "utmi" or "ulpi", strncmp() should be used so that a comparison
of "utmi;fsl_ddr:bank_intlv=auto" with "utmi" will succeed.
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
Signed-off-by: Nikhil Badola <nikhil.badola@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
u-boot binary size for Freescale mpc8536DS platforms is 512KB.
This has been reached to upper limit of the platforms and causig
linker error. So increase the u-boot binary size to 768KB.
Signed-off-by: Haijun Zhang <Haijun.Zhang@freescale.com>
Function "genphy_parse_link()" used "if (mii_reg & BMSR_ANEGCAPABLE)" before
while "if (phydev->supported & SUPPORTED_Autoneg)" now.
So assign "phydev->supported" to "phydev->drv->features" for ar8031/8033
to enable autonegotiation.
Signed-off-by: Zhao Qiang <B45475@freescale.com>
In the previous patches, we introduced the SPL/TPL fraamework.
For SD/SPI flash booting way, we introduce the SPL to enable a loader stub. The
SPL was loaded by the code from the internal on-chip ROM. The SPL initializes
the DDR according to the SPD and loads the final uboot image into DDR, then
jump to the DDR to begin execution.
For NAND booting way, the nand SPL has size limitation on some board(e.g.
P1010RDB), it can not be more than 8KB, we can call it "minimal SPL", So the
dynamic DDR driver doesn't fit into this minimum SPL. We added the TPL that is
loaded by the the minimal SPL. The TPL initializes the DDR according to the SPD
and loads the final uboot image into DDR,then jump to the DDR to begin execution.
This patch enabled SPL/TPL for P1010RDB to support starting from NAND/SD/SPI
flash with SPL framework and initializing the DDR according to SPD in the SPL/TPL.
Because the minimal SPL load the TPL to L2 SRAM and the jump to the L2 SRAM to
execute, so the section .resetvec is no longer needed.
Signed-off-by: Ying Zhang <b40530@freescale.com>
There was no enough memory for malloc in SPL booting from spi flash, so
relayout the memory in SPL: reduce the memory for global data from 16K
Bytes to 4K Bytes, save the space for malloc.
There was no enough stack in SPL, so the buffer needed in SPL is to malloc
from memory pool and to repalce the temporary variable.
1. The SPL's length of SDCARD boot has not enough,expand the SPL's
length to 128K.
2. deleted unused symbol: CONFIG_SYS_RUN_INDDR
T2081 QDS is a high-performance computing evaluation, development and
test platform supporting the T2081 QorIQ Power Architecture processor.
T2081QDS board Overview
- T2081 SoC integrating four 64-bit dual-threads e6500 cores up to 1.8GHz
- 2MB shared L2 and 512KB L3 CoreNet platform cache (CPC)
- CoreNet fabric supporting coherent and noncoherent transactions with
prioritization and bandwidth allocation
- 32-/64-bit DDR3/DDR3LP SDRAM memory controller with ECC and interleaving
- Ethernet interfaces:
- Two on-board 10M/100M/1G bps RGMII ports
- Two 10Gbps XFI with on-board SFP+ cage
- 1Gbps/2.5Gbps SGMII Riser card
- 10Gbps XAUI Riser card
- Accelerator:
- DPAA components consist of FMan, BMan, QMan, PME, DCE and SEC
- SerDes:
- 8 lanes up to 10.3125GHz
- Supports SGMII, HiGig, XFI, XAUI and Aurora debug,
- IFC:
- 512MB NOR Flash, 2GB NAND Flash, PromJet debug port and Qixis FPGA
- eSPI:
- Three SPI flash (16MB N25Q128A + 16MB EN25S64 + 512KB SST25WF040)
- USB:
- Two USB2.0 ports with internal PHY (one Type-A + one micro Type mini-AB)
- PCIe:
- Four PCI Express controllers (two PCIe 2.0 and two PCIe 3.0 with SR-IOV)
- eSDHC:
- Supports various SD/SDHC/SDXC/eMMC devices with adapter cards and
voltage translators
- I2C:
- Four I2C controllers.
- UART:
- Dual 4-pins UART serial ports
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
- fix serdes definition for t2081.
- fix clock speed for t2081.
- update ids, as CONFIG_FSL_SATA_V2 is needed only for t2080,
T2081 has no SATA.
Run "tools/reformat.py -i -d '-' -s 8 <boards.cfg >boards0.cfg && mv boards0.cfg boards.cfg"
in order to keep arc entries sorted.
Cc: Tom Warren <twarren@nvidia.com>
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Rajeshwari Birje <rajeshwari.s@samsung.com>
Cc: Inderpal Singh <inderpal.singh@linaro.org>
HOSTCFLAGS_autoconf.mk.dep was added by commit 422322f
but it has never been used.
Cc: Vadim Bendebury <vbendeb@chromium.org>
are passed
Lack of this check resulted in a data abort when CPU tried to execute the
following command (without further mandatory input): 'pmic MAX77686_PMIC'.
Only the 'pmic list' command requires one passed parameter.
Other require at least two valid parameters for correct operation.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Commit 6825a95 (kbuild: use Linux Kernel build scripts)
changed the behavior of linkage when USE_PRIAVATE_LIBGCC
is defined as "yes".
(It dropped arch/arm/lib/eabi_compat.o from the
target library.)
Affected boards are all Tegra boards.
This commit gets back the same behavior as before Kbuild series.
The calloc() call was allocating space for the sizeof the struct
pointer rather than for the struct contents.
Besides, since this buffer is passed to mmc for writing and some
platforms may use cache, the legacy_mbr struct should be cache-aligned.
Signed-off-by: Hector Palacios <hector.palacios@digi.com>
Tested-by: Lukasz Majewski <l.majewski@samsung.com>
Add support for the bcm28155_ap reference board.
Signed-off-by: Darwin Rambo <drambo@broadcom.com>
Reviewed-by: Steve Rae <srae@broadcom.com>
Reviewed-by: Tim Kryger <tkryger@linaro.org>
