Function 'sprintf' does not check buffer boundaries but outputs
to the buffer of fixed size which could potentially cause buffer
overflow. Use a safer function to replace it.
Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com>
Add support for the STM32F1 family to the STM32 gpio driver.
Signed-off-by: Matt Porter <mporter@konsulko.com>
Add ARMv7M STM32F1 support including clocks, timer, gpio, and flash.
On ARM v7M, the processor will return to ARM mode when executing
a blx instruction with bit 0 of the address == 0. Always set it
to 1 to stay in thumb mode.
common/image.c currently implicitly depends on CONFIG_NR_DRAM_BANKS
when CONFIG_ARM is enabled. Make this requirement explicit.
Switch to generic timer implementation from lib/time.c .
This also fixes a signed overflow which was in __udelay()
implementation.
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Tyler Baker <tyler.baker@linaro.org>
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Reorder the timer.h file so it can be included from board config file.
Trivially fix the include check in wdog.h.
The foundation model (FVP) emulator nominally boots using
a clean, uncompressed kernel and the "booti" command. Augment
the default U-Boot script to do this.
Since 741e58e0fc8e (Create a .cfg file containing the CONFIG options
used to build), all the Blackfin boards fail to build if the parallel
(-j) option is passed.
$ make -s bf506f-ezkit_defconfig
# configuration written to .config
$ make -j8 CROSS_COMPILE=bfin-elf-
scripts/kconfig/conf --silentoldconfig Kconfig
CHK include/config.h
UPD include/config.h
GEN include/autoconf.mk
GEN include/autoconf.mk.dep
CHK include/config/uboot.release
CHK include/generated/timestamp_autogenerated.h
UPD include/generated/timestamp_autogenerated.h
CFG u-boot.cfg
include/asm-offsets.h:3:43: fatal error:
generated/generic-asm-offsets.h: No such file or directory
compilation terminated.
make: *** [u-boot.cfg] Error 1
When parsing header files for defined CONFIG options, DO_DEPS_ONLY
must be defined to exclude generated headers that might not have
been available yet.
gd->ram_size is stored as phys_size_t type which can be bigger than an
unsigned long on some architectures. When using unsigned long type,
SDRAM of 4GiB or larger will not print the correct size, but using
phys_size_t will.
Signed-off-by: Andrew Bradford <andrew.bradford@kodakalaris.com>
This introduces a distinction between return codes that are read bytes counts
and errors. Read bytes counts are erroneous when null (no data was read) while
errors are erroneous when non-null.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
Tested-by: Tim Harvey <tharvey@gateworks.com>
Nothing too fancy. A simple test that attmpts to load two loadables and
verify that they are properly unpacked in the u-boot sandbox.
Signed-off-by: Karl Apsite <Karl.Apsite@dornerworks.com>
bootm_find_ramdisk_fdt() renamed to bootm_find_images() for readability.
The function bootm_find_ramdisk_fdt() appears to be a simple wrapper for
bootm_find_ramdisk(), bootm_find_fdt(), and now bootm_find_loadables().
I didn't see any other callers entering a bootm_find<thing>, so removing
the wrapper, and condensing these together hopefully makes the code a
little simpler.
Added a trimmed down instance of boot_get_<thing>() to satisfy the
minimum requierments of the added feature. The function follows the
normal patterns set by other boot_get<thing>'s, which should make it a
bit easier to combine them all together into one boot_get_image()
function in a later refactor.
Documentation for the new function can be found in source:
include/image.h
Added FIT_LOADABLE_PROP, so the user can identify an optional entry
named "loadables" in their .its configuration. "loadables" is a comma
separated list in the .its
Documentation can be found in doc/uImage.FIT/source_file_format.txt and
doc/uImage.Fit/multi-with-loadables.its
Instead of hardcoding -lssl -lcrypto as the flags needed to build
mkimage with FIT signature enabled, use pkg-config when
available. This allows to properly support cases where static linking
is used, which requires linking with -lz, since OpenSSL uses zlib
internally.
We gracefully fallback on the previous behavior of hardcoding -lssl
-lcrypto if pkg-config is not available or fails with an error.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
In the latest Linux coding style, <linux/io.h> should be included
rather than <asm/io.h>. To follow this standard also in U-Boot,
add include/linux/io.h. Currently, it just includes <asm/io.h>.
The Juno reference design typically plugs the root FS
on a USB stick. We need to wait a bit for the root to
appear so tell this on the default command line.
DM3730 CPU used on beagleboard-xm doesn't have any gpio
multiplexed with wait0 pin,
but gpio_63 multiplexed with wait1, so it looks like typo.
At current form it has no sense,
because of wait0 have no function "4".
Signed-off-by: Evgneiy A. Dushistov <dushistov@mail.ru>
Generic board support seems to work just fine. Tested on ml507 with
bitstream generated on the latest ISE software.
Tested-by: Georg Schardt <schardt@team-ctech.de>
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
The ARM Trusted Firmware or other security solutions are
eating memory from the top of the physical SDRAM1 space,
moving backward from 0xffffffff, currently occupying e.g.
0xfe000000-0xffffffff with Trusted Firmware.
This solution to reserving memory for secure world is not
optimal, so we need to think of how the secure world and
earlier boot stages should communicate to U-Boot what
memory they are eating up. For now let's just put 16MB
aside.
Also enable the memory test command and define start and
end of the test range so we can check that we actually have
all that memory available and working.
Suggested-by: Axel Haslam <ahaslam@baylibre.com>
Define U_BOOT_TZ alongside U_BOOT_TIME and U_BOOT_DATE and use it to
include the timezone in the version output.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
If we are displaying detected PCI devices (CONFIG_PCI_SCAN_SHOW) display
a 'PCI:' header prior to scan.
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
Add an error message that gets passed to set_default_env() like
env_nand implements. This message is displayed to the user as the
reason for falling back to the default environment.
Testing on the ARM Versatile Express Juno board showed intermittent CFI
flash detection problems.
Debug output in exception cases showed that the NOR flash was returning
incorrect values to a query command:
fwc addr 0000000008000000 cmd f0 f0f0f0f0 32bit x 8 bit
fwc addr 0000000008000000 cmd ff ffffffff 32bit x 8 bit
fwc addr 0000000008000154 cmd 98 98989898 32bit x 8 bit
is= cmd 51(Q) addr 0000000008000040 is= 00800051 51515151
fwc addr 0000000008001554 cmd 98 98989898 32bit x 8 bit
fwc addr 0000000008000000 cmd f0 00f000f0 32bit x 16 bit
fwc addr 0000000008000000 cmd ff 00ff00ff 32bit x 16 bit
fwc addr 0000000008000154 cmd 98 00980098 32bit x 16 bit
is= cmd 51(Q) addr 0000000008000040 is= 00800051 00510051
fwc addr 0000000008001554 cmd 98 00980098 32bit x 16 bit
Debugging showed that the problem could be solved by preventing u-boot
from scanning different flash widths by specifying
CONFIG_SYS_FLASH_CFI_WIDTH so that only using the 'correct' width was
used.
Signed-off-by: Ryan Harkin <ryan.harkin@linaro.org>
UART3 RX and TX pins are now moved to support uart download capability
on the platform. Old pins are now GPIOs routed to expansion ports.
All original boards should either have been returned for modifications
or already modified for the required change and maintaining
compatibility for older boards are no longer needed.
Signed-off-by: Nishanth Menon <nm@ti.com>
Previously, if the menu activated by the 'sysboot' command gets
interrupted by a Ctrl-C, the behaviour is as if the menu timeout was
reached - i.e. boot the default menu entry. This patch fixes that
so a Ctrl-C now terminates the command as the user would expect.
Previously, a NULL pointer dereference would occur if the 'sysboot'
command is executed without any arguments.
Due to a misunderstanding, in 698a12b we reverted changes that we in
fact wanted to keep. So lets fix that mistake and bring the code back
to how it should have been.
This reverts commit 698a12bef9e782dcd99c555a739c16eec8669f14.
This gives a basic idea about progress.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
In some cases the build for the autoconf breaks. This outputs the errors
following the status so that action can be taken without building again
manually.
A common case for failed builds is a missing compiler. Print a message
for that case to tell the user concisely which compiler was expected
that was not found.
This patch also has the effect of not printing build errors any longer.
The next patch will add a switch to optionally bring that back.
If boards fail, output that list to a file so that it can easily be
passed back into moveconfig.py using the -d option.
Some config.h files live in arch and board directories. They will need
to be cleaned up as well, so run the same filters there.
In some case you may want to only cleanup the headers. Make it possible
without waiting for all boards to compile.
This is helpful to re-attempt to move failed boards from a previous run
without starting over.
When moving configs, it is important to know what was defined in the
config header even if it duplicates the configs coming from Kconfig.
This is specifically needed for the case where a config is set to
default 'y' in the Kconfig. This would previously cause the actual value
from the include config to be filtered out, and moveconfig.py would
think that it was 'n'... This means that the value that should be 'y'
is now (in every defconfig) set to 'not set'.
tools/moveconfig.py now defines KCONFIG_IGNORE_DUPLICATES to prevent the
filtering from happening and selecting wrong values for the defconfig.
This will ensure that the order of the defconfig entries will always
match that of the Kconfig files. After one slightly painful (but
still early in the process) pass over all boards, this should keep
the defconfigs clean from here on.
Users must edit the Kconfig first to add the menu entries and then run
moveconfig.py to update the defconfig files and the include configs.
As such, moveconfig.py cannot compare against the '.config' contents.
This tool was originally written for my local use to ease the task
of tons of CONFIG moves, but there have been some requests for
mainlining it.
So, I have tidied up the code with nicer comments, and here it is.
See the comment block of the script for usage.
The first draft was
http://patchwork.ozlabs.org/patch/430422/
Main updates are:
- Adapted to the single .config configuration
- Support colored log
- Support moving multiple options at once
(and take configs via input file only)
- Continue even if some boards fail
(Idea provided by Joe Hershberger)
- Add more options
- More comments and code cleanups
Move CONFIG_CMD_CACHE to mx6_common and standardise the way it's defined.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
Reviewed-by: Tom Rini <trini at konsulko.com>
Move all standard mx6 MMC configs to mx6_common.
Move all standard filesystem, partition and fdt options to mx6_common.
Move generic miscellaneous options that are standard across most, if not all,
mx6 boards to central mx6_common define to ensure consistent features.
Define common LOADADDR and BOOTDELAY to ensure a consistent experience
across mx6 boards
Define CONFIG_MXC_GPIO and CONFIG_CMD_GPIO by default in mx6_common
