Use get_ram_size() to autodetect up to 2Gbyte of RAM on rank 0.
If chips with two ranks would get stuffed one would have to set the size
of one rank in DDRC_ADDRMAP0.
The Colibri iMX7 uses a different pmic
Introduce CONFIG_SERIAL_TAG_BOARD which removes the definition of
void get_board_serial(struct tag_serialnr *serialnr)
in order to allow its definition in board specific code.
Add configs now needed with the update of U-Boot.
Add empty callback now needed when CONFIG_LDO_BYPASS_CHECK is defined.
http://sw-stash.freescale.net/projects/IMX/repos/ddr-scripts-rel/commits/8111e4d0cd81226899be637013048281e3c097b4
http://compass.freescale.net/livelink/livelink?func=ll&objId=234753630&objAction=browse&viewType=1
arik_r2_sabre_ddr3_528_1.13.inc is for sabre-AI
arik_r2_sdb_ddr3_528_1.13.inc is for sabresd
1.13<-1.12:
Change log:
1. Remove 20c4080
1.12<-1.10
Change log:
1. NoC register DDRCONF change to 0 which is compatible
for only CS0 is used on board
2. Change 2 values to compatible with our DDR aid script,
these two registers doesn’t have any effect on current system
tRPA = 0;
//this bit only used in DDR2 mode
tAOFPD/tAONPD=0x4;
//These register only works when MDPDC. SLOW_PD = 1 which is 0 in script
Test results:
One mx6qp-sdb and one mx6qp-ard board and one mx6qp-ard board passed
60 hours memtester stress teset.
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
(cherry picked from commit 5fb08a4dcc7b8478fc4236b90ad8dc2190cf94e7)
This reverts commit e7d4767331f1a2cbef61b4e89beb73731f267499.
This reverts commit 3b548a3ddf03dcbb646912ef7bbdd3cdb2daf81a.
The fastboot.exe will get var partition-type:* firstly when "fastboot flash * *".
The uboot did not support get var partition-type: default.
This patch mask info the error when gat cat partition-type.
Signed-off-by: zhang sanshan <b51434@freescale.com>
The ci_udc driver tries to use the ULPI interface for the USB OTG controller,
but this type is not supported by all i.MX6 and i.MX7 platforms. When setting to
ULPI, other platforms except the 6UL refuse the settings and keep default value.
But on 6UL, the PTW bit of PORTSC1 register which is documented as RO can change.
This cause the interface setting problem with USB PHY.
Fix the issue by removing the ULPI setting for i.MX6 and i.MX7. All will use default
UTMI setting.
Signed-off-by: Ye.Li <B37916@freescale.com>
(cherry picked from commit f78cbee0375dcb81b10bac2e0dcd254d0551baa9)
Fixed the issue that mfgtool failed to download u-boot with plugin enabled.
The u-boot plugin common codes should not call rom___pu_irom_hwcnfg_setup
when using serial download mode.
rom___pu_irom_hwcnfg_setup will load the IVT2 image from boot media, but this
is invalid for USB serial download mode.
(cherry picked from commit b16ae36d2ae3fa9f536fec691a3e1bfa6f26a8d0)
According to the latest datasheet(Rev. B, 07/2015), the VDD_SOC_IN
standby voltage should be 1.05V and on i.MX6QP, we can use the PMIC
'APS' mode in standby. we add a 25mV margin to cover the IR drop and
board tolerance, so the standby voltage of VDD_SOC_IN should be
setting to 1.075V.
Signed-off-by: Bai Ping <b51503@freescale.com>
(cherry picked from commit 3c38fae6dafd3b90fae2598dcbedf6cb7aa6f6af)
on i.MX6QP SDB board, the SW1A/B/C regulator is used by
VDD_SOC_IN, the regulator of VDD_ARM_IN is SW2, the voltage
setting for VDD_ARM_IN should be corresponding to SW2. So fix
the regulator mismatch issue on i.MX6QP SDB board.
(cherry picked from commit 55a80625e81ea9ff5a5286f1d2183a2f0900f5c3)
http://sw-stash.freescale.net/projects/IMX/repos/ddr-scripts-rel/commits/963fbc75ef6d36e12819e81de23410749754e5ef
http://compass.freescale.net/livelink/livelink?func=ll&objId=234709279&objAction=browse&viewType=1
Main change: (SDB board ddr density is different)
1. tRFC is different with density, tXS/tXPR refers tRFC
Test Results:
2 MX6DP-SDB and 2 MX6QP-SDB boards passed overnight stress test.
(cherry picked from commit 603b89c8990868c51b1546db4877d198358485ff)
The current 36M offset will conflict with NAND FCB firmware2 when the
nand chip block is 1MB size. This patch change it to 36M + 1M offset,
so the redundant u-boot at firmware2 will not be broken.
ddr script update to 1.09:
234694528&objAction=browse&viewType=1
arik_r2_sabre_ddr3_528_1.09.inc is for sabre-auto board.
arik_r2_sdb_ddr3_528_1.09.inc is for sabre-sd board.
Changelog:
1. Optimize DQS duty cycle setting
2. Optimize ZQ PU/PD value
Test results:
2 ARD boards.
2 6QP-SDB boards.
1 6DP-SDB board.
All passed overnight memtester stress test.
(cherry picked from commit ba8dcef9d8e10e46130559ce6defe4411bd1d1a6)
1. Default support SPI-NOR for imx6q/dl/solo sabresd board.
2. Fix bug for mx6soloxxx_spinor_defconfig. "nosmp" should be
\"nosmp\".
Same issue as ENGR00321137, commit 3695635.
GIS module need total 3M+3M+1.5M+1.5M=9M video memory.
and sys reserved 16M memory for malloc.
When gis module enabled, malloc may failed to allocate memory
for other modules, that may cause system hang.
Expand malloc pool to 32M.
Signed-off-by: Sandor Yu <R01008@freescale.com>
The previous 8M address for NAND env might conflict with other boot
parameters as the NAND block size increasing, change it to 36M to avoid
it.
Signed-off-by: Han Xu <b45815@freescale.com>
The cod change updated the NAND driver BCH ECC layout algorithm to
support large oob size NAND chips(oob > 1024 bytes).
Current implementation requires each chunk size larger than oob size so
the bad block marker (BBM) can be guaranteed located in data chunk. The
ECC layout always using the unbalanced layout(Ecc for both meta and
Data0 chunk), but for the NAND chips with oob larger than 1k, the driver
cannot support because BCH doesn’t support GF 15 for 2K chunk.
The change keeps the data chunk no larger than 1k and adjust the ECC
strength or ECC layout to locate the BBM in data chunk. General idea for
large oob NAND chips is
1.Try all ECC strength from the minimum value required by NAND spec to
the maximum one that works, any ECC makes the BBM locate in data chunk
can be chosen.
2.If none of them works, using separate ECC for meta, which will add one
extra ecc with the same ECC strength as other data chunks. This extra
ECC can guarantee BBM located in data chunk, of course, we need to check
if oob can afford it.
enlarge the maximum nand page size and oob size to
16k byte and 1280byte.
According to the latest datasheet(Rev. C Draft 1, 10/2015) of
i.MX7D, change the VDD_SOC voltage to 0.95V in run mode, and
add a 25mV margin to cover the IR drop and board tolerance.
So setting VDD_SOC voltage to 0.975V.
IC team releases new DDR script "EVK_IMX6UL_DDR3L_400MHz_16bit_V1.2.inc",
update it to DCD and plugin for i.MX6UL 14x14 EVK board.
Updated items:
Removed:
0x020c4084
0x021B0858
Value changed:
0x020E027C
0x020E0280
0x021B0008
0x021B000C
0x021B0010
0x021B0018
0x021B08C0
The script versions of EVK board and Validation Board from the following link:
http://compass.freescale.net/livelink/livelink?func=ll&objId=234191407&obj
Test Results:
Two boards passed overnight memtester stress test.
The PST bit can't be set too small which will cause performance drop.
Refer the commit for same issue on MX6UL 9x9 EVK, now fix it for 14x14 LPDDR2 ARM2
commit e1ca547d198dde94c4d8278c99499ec2d2008880
The actual memory size is 256MB not 512MB, otherwise it has a wrap
problem in memory and will cause memtester failed.
enable bank interleave feature to improve the performance
downloaded from
http://compass.freescale.net/livelink/livelink?func=ll&objId=234609508&objAction=browse&viewType=1
Before:
$ /opt/fsl-samples/g2d/g2d_test
Width 1920, Height 1088, Format RGBA, Bpp 32
---------------- g2d blit performance ----------------
g2d blit time 15566us, 64fps, 134Mpixel/s ........
g2d blending time 20672us, 48fps, 101Mpixel/s ........
g2d blend-dim time 13616us, 73fps, 153Mpixel/s ........
---------------- g2d clear performance ----------------
g2d clear time 8433us, 118fps, 247Mpixel/s ........
---------------- g2d rotation performance ----------------
90 rotation time 15366us, 65fps, 135Mpixel/s ........
180 rotation time 15374us, 65fps, 135Mpixel/s ........
270 rotation time 15373us, 65fps, 135Mpixel/s ........
g2d flip-h time 15373us, 65fps, 135Mpixel/s ........
g2d flip-v time 15372us, 65fps, 135Mpixel/s ........
After:
g2d blit time 2810us, 355fps, 743Mpixel/s ........
g2d blending time 4025us, 248fps, 518Mpixel/s ........
g2d blend-dim time 2740us, 364fps, 762Mpixel/s ........
g2d clear time 1846us, 541fps, 1131Mpixel/s ........
90 rotation time 5234us, 191fps, 399Mpixel/s ........
180 rotation time 3176us, 314fps, 657Mpixel/s ........
270 rotation time 5248us, 190fps, 398Mpixel/s ........
g2d flip-h time 2765us, 361fps, 755Mpixel/s ........
g2d flip-v time 3179us, 314fps, 657Mpixel/s ........
Signed-off-by: Robby Cai <r63905@freescale.com>
Add android and sata defconfig file.
Since the mx6ul 9x9 evk has different DDR size with 14x14 evk, change
to use the half of PHYS_SDRAM_SIZE for mtest end.
The DDR initialization in plugin needs to update conformably with DCD.
This piece of code is for mx7, we should not use
do_mx6_showclocks.
MMDC auto power saving timer can NOT be too small,
as enter/exit auto self-refresh mode too frequently
may introduce too many latency for MMDC access,
set it to 0x10, same as previous value on i.MX6.
Signed-off-by: Anson Huang <b20788@freescale.com>
Add i.MX6QP SabreSD board support.
Need to check fuse bit 25 of bank 0 word 4 before initialize bee.
The bit: 0 means bee enabled, 1 means bee disabled.
If disabled, continuing initialize bee will cause system hang, so
need to check this bit before initialize bee.
Add macro to enable BEE in header file, default disabled.
We meet reset failure on mx6ul 9x9 evk. The internal reset logic between MMDC and
functional modules seems relate with the issue.
Turn off the LCDIF to stop DDR access before reset to avoid this possible internal
reset problem.
The lpddr2 memsize of mx6ul_9x9_evk is 256MB, not 512M, so
the CS0_END should be 0x47, but not 0x4F.
Disable PFuze3000 low power mode during standby mode, otherwise,
if the power consumption exceed the threshold, PFuze will reboot.
Add new build target: mx6ul_9x9_evk_qspi1_config
Updated items:
memory set 0x307a0000 32 0x03040001 --> memory set 0x307a0000 32 0x01040001
This is just enable when LPDDR4 is enabled .
memory set 0x307a0064 32 0x0040005e --> memory set 0x307a0064 32 0x00400046
T_RFC_MIN this should be: RU(260ns*528Mhz)/2=69 (0x45)
memory set 0x307a00d0 32 0x00020001 --> memory set 0x307a00d0 32 0x00020083
PRE_CKE_X1024 be (500us*528Mhz/2)/1024 = 129, or 0x81
memory set 0x307a00d4 32 0x00010000 --> memory set 0x307a00d4 32 0x00690000
DRAM_RSTN_X1024 (200us*528Mhz)/1024=104, or 0x68
memory set 0x307a00e4 32 0x00090004 --> memory set 0x307a00e4 32 0x00100004
DEV_ZQINIT_X32 . Should be 16 clocks
memory set 0x307a0100 32 0x0908120a --> memory set 0x307a0100 32 0x09081109
T_FAW=(40ns*528Mhz)/2)=11
memory set 0x307a0104 32 0x0002020e --> memory set 0x307a0104 32 0x0007020d
tXPDLL=24ns*528Mhz=13clocks
File:
MX7D_EVK_DDR3_1GB_32bit.ds
Test result:
3 boards pass 2 days stress test.
i.MX6UL-9x9-EVK board has PFUZE3000, so enable LDO
bypass support for this board.
CONFIG_FASTBOOT is not used, since we have CONFIG_FSL_FASTBOOT and
CONFIG_CMD_FASTBOOT for fastboot. "drivers/fastboot" can be discarded.
In current design, if any peripheral was assigned to both A7 and M4,
it will receive ipg_stop or ipg_wait when any of the 2 platforms
enter low power mode. We will have a risk that, if A7 enter wait,
M4 enter stop, peripheral will have chance to get ipg_stop and ipg_wait
asserted same time.
There are 26 peripherals impacted by this IC issue:
SIM2(sim2/emvsim2)
SIM1(sim1/emvsim1)
UART1/UART2/UART3/UART4/UART5/UART6/UART7
SAI1/SAI2/SAI3
WDOG1/WDOG2/WDOG3/WDOG4
GPT1/GPT2/GPT3/GPT4
PWM1/PWM2/PWM3/PWM4
ENET1/ENET2
Software Workaround:
The solution is set M4 to a different domain with A core.
So the peripherals are not shared by them. This way requires
the uboot implemented the RDC driver and set the 26 IPs above to domain 0 only.
CM4 image will set the M4 to domain 1 only.
This patch enables the CONFIG_MXC_RDC for mx7d SABRESD board and ARM2 boards, and
setup the 26 IP resources to domain 0.
