2005-07-01* Patch by Stefan Roese, 1 Jul 2005:stroese
Fix PHY address for CATcenter board (now correct!)
2005-06-30* Patch by Stefan Roese, 30 Jun 2005:stroese
Fix PHY addresses for PPChameleon and CATcenter boards Change MAINTAINER for most esd boards
2005-06-27* Fix baudrate calculation problem on MPC5200 systemswdenk
* Add MPC8220 boards to MAKEALL script * Add EEPROM and RTC support for HMI1001 board * Patch by Detlev Zundel, 20 Jun 2005: Fix initialization of low active GPIO pins on inka4x0 board
2005-06-20Enable redundant environment, disable HW flash protection of HMI1001 boardwdenk
2005-06-20* Patch by Travis Sawyer, 10 Jun 2005:wdenk
Initialize allocated dev and private hw structures after their respective allocation in 440gx_enet.c * Patch by Steven Scholz, 10 Jun 2005: Fix byteorder problems with second argument of "bootm" with standalone images;
2005-06-10* Add support for HMI1001 boardwdenk
* Disable "date" and "sntp" commands on TQM866M which has no RTC
2005-06-05Fix watchdog reset problems on LWMON boardwdenk
2005-05-30Patch by Juergen Selent, 17 May 2005:wdenk
Add support for Funkwerk VoVPN gateway module.
2005-05-23* Extend burst mode RAM test program to take a loop countwdenk
(0 = infinite) * Use CONFIG_DRIVER_KS8695ETH to enable KS8695 ethernet driver on those boards that use it.
2005-05-19Patch by Greg Ungerer, 19 May 2005:wdenk
add support for the OpenGear CM4008 board
2005-05-19* Patch by Greg Ungerer, 19 May 2005:wdenk
add support for the KS8695P (ARM 922 based) CPU * Patch by Steven Scholz, 19 May 2005: Add support for CONFIG_SERIAL_TAG on ARM boards
2005-05-16Add PCI support for Sorcery board.wdenk
Code cleanup (especially Sorcery / Alaska / Yukon serial driver).
2005-05-16Fix compile problems caused by new burst mode SDRAM test;wdenk
make port pins to trigger logic analyzer configurable
2005-05-13Fix timer handling on MPC85xx systemswdenk
2005-05-12* Fix debug code in omap5912osk flash driverLABEL_2005_05_13_0050wdenk
* Add support for MPC8247 based "IDS8247" board.
2005-05-10Add support for 2 x TSEC interfaces on the TQM8540 board.wdenk
2005-05-09On LWMON we must use the watchdog to reset the board as the CPULABEL_2005_05_09_1245wdenk
genereated HRESET pulse is too short to reset the external circuitry.
2005-05-07Add test tool to exercise SDRAM accesses in burst modewdenk
(as standalone program, MPC8xx/PowerPC only)
2005-05-05It's better to handle LZO and LZARI compression mdoes for JFFS2 withLABEL_2005_05_05_1920wdenk
a single #define.
2005-05-05Increase CFG_MONITOR_LEN for Rattler board to match actual code size.wdenk
2005-05-05Major upate of JFFS2 code; now in sync with snapshot of MTD CVS ofwdenk
March 13, 2005); new configuration options CONFIG_JFFS2_LZO and CONFIG_JFFS2_LZARI are added. Both are undefined by default.
2005-05-04Fix problem with symbolic links in JFFS2 code.wdenk
2005-05-04Use linker ASSERT statement to prevent undetected overlapping ofwdenk
sections on PPChameleon board; other boards might use this, too.
2005-05-03README: add explanation about patch policywdenk
net/net.c: fix indentation
2005-05-03* Patch by Stefan Roese, 03 May 2005:stroese
Update for P3G4 Fix problems in cmd_universe.c * Patch by Matthias Fuchs, 03 May 2005: Added missing variable declaration in cmd_nand.c Modified CFG_PCI_PTM1MS in configs/PLU405.h to map 128MB ram
2005-05-03* Patch by Matthias Fuchs, 03 May 2005:stroese
2005-04-22Fix INKA4x0: use CS1 as gpio_wkup_6 outputwdenk
2005-04-21Fix bug in the SDRAM initialization code for canmb, IceCube andwdenk
PM520 boards. Fix PHY address for canmb board.
2005-04-20get rid of obsolete CFG_AT91C_BRGR_DIVISOR definitionwdenk
2005-04-20Cleanup serial console baudrate calculation on AT91RM9200wdenk
2005-04-20Auto-size RAM on canmb board.wdenk
Cleanup.
2005-04-20* Patch by Matthias Fuchs, 18 Apr 2005:stroese
Make PCI target address spaces on PMC405 and CPCI405 boards configurable via environment variables
2005-04-13Add support for canmb boardLABEL_2005_04_14_0115wdenk
2005-04-13* Patch by Stefan Roese, 13 Apr 2005:stroese
Update for esd apc405
2005-04-13Update for esd apc405stroese
2005-04-13* Fixes for TQM8560 board:wdenk
- fix clock rates - remove debug messages - fix flash sector protection * Patch by Steven Scholz, 07 Apr 2005: Fix warning in cpu/arm920t/at91rm9200/i2c.c
2005-04-07Cleanupwdenk
2005-04-07* Patch by Steven Scholz, 07 Apr 2005:wdenk
Add i2c_reg_write() and i2c_reg_write() for at91rm9200 I2C * Patch by Steven Scholz, 07 Apr 2005: Fix compiler warning in altera.c * Patch by Ladislav Michl, 06 Apr 2005: Fix voiceblue configuration.
2005-04-07* Patch by Stefan Roese, 06 Apr 2005:stroese
Updates for OCOTEA board: - Changed U-Boot size from 512kByte to 256kByte - Fixed flash driver to support boot from soldered user flash - Added README for switch from PIBS firmware to U-Boot
2005-04-07Add PPC440GX Revision Cstroese
2005-04-07* Patch by Travis Sawyer, 05 Apr 2005:stroese
- Change timer frequency for ppc 440 from 10 ms to 1 ms. Problem found by Andrew Wozniak.
2005-04-06Patch by Steven Scholz, 06 Apr 2005:wdenk
- creating SoC subdir for Atmel AT91RM9200 cpu/arm920t/at91rm9200 - moving code out of cpu/at91rm9200 into cpu/arm920t/at91rm9200
2005-04-06* Patches by Robert Whaley, 29 Nov 2004:wdenk
- update the pxa-regs.h file for PXA27x chips - add PXA27x based ADSVIX board - add support for MMC on PXA27x processors * Patch by Andrew E. Mileski, 28 Nov 2004: Fix PPC4xx SPD SDRAM detection bug * Patch by Hiroshi Ito, 26 Nov 2004: Fix logic of "test -z" and "test -n" commands
2005-04-05* Patch by Ladislav Michl, 05 Apr 2005:wdenk
Add support for VoiceBlue board. * Patch by Ladislav Michl, 05 Apr 2005: Fix netboot_common() prototypes. * Cleanup.
2005-04-05Patches by Steven Scholz, 05 Apr 2005:wdenk
- Use i.MX watchdog timer for reset_cpu() - Move reset_cpu() out of cpu/arm920t/start.S into the SoC specific subdirectories cpu/arm920t/imx/ and cpu/arm920t/s3c24x0/ (now in interupts.c)
2005-04-05Add support for MPC8220 based "sorcery" board.LABEL_2005_04_05_2345wdenk
2005-04-05Add support for TQM8560 boardLABEL_2005_04_05_1830wdenk
2005-04-04* Add FEC support for TQM8540 board.wdenk
Interfaces are named as follows: "ENET1" - TSEC2, "ENET2" - FEC * Patch by Martin Krause, 04 Apr 2005: Update default configuration for CMC_PU2 board.
