With the addition of GPIO_ACTIVE_LOW parsing in gpio-uclass,
the intel_broadwell driver doesn't need a custom xlate routine.
Signed-off-by: Eric Nelson <eric@nelint.com>
Many drivers use a common form of offset + flags for device
tree nodes. e.g.:
<&gpio1 2 GPIO_ACTIVE_LOW>
This patch adds a common implementation of this type of parsing
and calls it when a gpio driver doesn't supply its' own xlate
routine.
This will allow removal of the driver-specific versions in a
handful of drivers and simplify the addition of new drivers.
Add common usb code which usb drivers makes use of it.
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
Introduce driver to support "fairchild,74hc595" devices.
1. Take linux drivers/drivers/gpio/gpio-74x164.c as reference.
2. Following the naming used in Linux driver with gen_7x164 as the prefix.
3. Enable CONFIG_DM_74X164 to use this driver.
4. Follow Documentation/devicetree/bindings/gpio/gpio-74x164.txt to add device
nodes
5. Tested on i.MX6 UltraLite with 74LV595 using gpio command and oscillograph.
Signed-off-by: Peng Fan <van.freenix@gmail.com>
Cc: Chin Liang See <clsee@altera.com>
Cc: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Introduce dm_spi_claim_bus, dm_spi_release_bus and dm_spi_xfer
Convert spi_claim_bus, spi_release_bus and spi_xfer to use
the new API.
Cc: Jagan Teki <jteki@openedev.com>
1. Support compatible string "spi-gpio" which is used by Linux
Linux use different bindings, so use UBOOT_COMPAT and
LINUX_COMPAT to differentiate them.
2. Introduce SPI_MASTER_NO_RX and SPI_MASTER_NO_TX to handle
no rx or no tx case.
3. Tested on i.MX6 UltraLite board with 74LV595 spi-gpio chip.
Cc: Przemyslaw Marczak <p.marczak@samsung.com>
When doing xfer, should use device->parent, but not device
When doing bit xfer, should use "!!(tmpdout & 0x80)", but not
"(tmpdout & 0x80)"
Use the device's own DT offset, not the device's parent's.
Fixes: 43c4d44e3330 ("fdt: implement dev_get_addr_name()")
This prevents the following boot-time message on any board where only the
first DC is in use, yet the DC's DT node is enabled:
stdio_add_devices: Video device failed (ret=-22)
(This happens on at least Harmony, Ventana, and likely any other Tegra20
board with display enabled other than Seaboard).
The Tegra DC's DT node represents a display controller. It may itself
drive an integrated RGB display output, or be used by some other display
controller such as HDMI. For this reason the DC node itself is not
enabled/disabled in DT; the DC itself is considered a shared resource, not
the final (board-specific) display output. The node should instantiate a
display output driver only if the rgb subnode is enabled. Other output
drivers are free to use the DC if they are enabled and their DT node
references the DC's DT node. Adapt the Tegra display drivers' bind()
routine to only bind to the DC's DT node if the RGB subnode is enabled.
Now that the display driver does the right thing, remove the workaround
for this issue from Seaboard's DT file.
Cc: Thierry Reding <treding@nvidia.com>
Acked-by: Thierry Reding <treding@nvidia.com>
In some cases, drivers may not want to bind to a device. Allow bind() to
return -ENODEV in this case, and don't treat this as an error. This can
be useful in situations where some information source other than the DT
node's main status property indicates whether the device should be
enabled, for example other DT properties might indicate this, or the
driver might query non-DT sources such as system fuses or a version number
register.
One use-case for buildman is to continually run it interactively after
each small step in a large refactoring operation. This gives more
immediate feedback than making a number of commits and then going back and
testing them. For this to work well, buildman needs to be extremely fast.
At present, a couple issues prevent it being as fast as it could be:
1) Each time buildman runs "make %_defconfig", it runs "make mrproper"
first. This throws away all previous build results, requiring a
from-scratch build. Optionally avoiding this would speed up the build, at
the cost of potentially causing or missing some build issues.
2) A build tree is created per thread rather than per board. When a thread
switches between building different boards, this often causes many files
to be rebuilt due to changing config options. Using a separate build tree
for each board would avoid this. This does put more strain on the system's
disk cache, but it is worth it on my system at least.
This commit adds two command-line options to implement the changes
described above; -I ("--incremental") turns of "make mrproper" and -P
("--per-board-out-dir") creats a build directory per board rather than per
thread.
Tested:
./tools/buildman/buildman.py tegra
./tools/buildman/buildman.py -I -P tegra
./tools/buildman/buildman.py -b tegra_dev tegra
./tools/buildman/buildman.py -b tegra_dev -I -P tegra
... each once after deleting the buildman result/work directory, and once
"incrementally" after a previous identical invocation.
Acked-by: Simon Glass <sjg@chromium.org> # v1
Tested-by: Simon Glass <sjg@chromium.org> # v1
Boards can now use DM serial driver, or still legacy mcf uart
driver version.
Signed-off-by: Angelo Dureghello <angelo@sysam.it>
To use serial uclass and DM, CONFIG_SYS_MALLOC_F must be used.
So CONFIG_SYS_GENERIC_GLOBAL_DATA has been undefined and
call to board_init_f_mem() is added for all cpu's.
Introduce a new driver that supports driver model for pca953x.
The pca953x chips are used as I2C I/O expanders.
This driver is designed to support the following chips:
4 bits: pca9536, pca9537
8 bits: max7310, max7315, pca6107, pca9534, pca9538, pca9554,
pca9556, pca9557, pca9574, tca6408, xra1202
16 bits: max7312, max7313, pca9535, pca9539, pca9555, pca9575,
tca6416
24 bits: tca6424
40 bits: pca9505, pca9698
But for now this driver only supports max 24 bits and pca953x compatible
chips. pca957x compatible chips are not supported now.
These can be addressed when we need to add such support for the different
chips.
This driver has been tested on i.MX6 SoloX Sabreauto board with max7310
i2c expander using gpio command as following:
=>gpio status -a
Bank gpio@30_:
gpio@30_0: input: 1 [ ]
=> dm tree:
i2c [ ] | | `-- i2c@021a8000
gpio [ ] | | |-- gpio@30
gpio [ ] | | `-- gpio@32
Cc: Wenyou Yang <wenyou.yang@atmel.com>
Cc: Purna Chandra Mandal <purna.mandal@microchip.com>
Cc: Thomas Chou <thomas@wytron.com.tw>
Cc: Andrea Scian <andrea.scian@dave.eu>
Cc: Michal Simek <michal.simek@xilinx.com>
Tested-by: Michal Simek <michal.simek@xilinx.com> #on ZynqMP zcu102
Reported-and-tested-by: Dennis Gilmore <dennis@ausil.us>
Acked-by: Ian Campbell <ijc@hellion.org.uk>
update tbot documentation in U-Boot, as I just
merged the event system into tbots master
branch.
test/py raises an error, if a board has not enabled bdi command
> pytest.skip('bdinfo command not supported')
E NameError: global name 'pytest' is not defined
import pytest in test/py/u_boot_utils.py fixes this.
Commit bfb33f0bc45b ("sunxi: mctl_mem_matches: Add missing memory
barrier") broke compilation for the Pine64, as dram_helper.c now
includes <asm/armv7.h>, which does not compile on arm64.
Fix this by moving all barrier instructions into a separate header
file, which can easily be shared between arm and arm64.
Also extend the inline assembly to take the "sy" argument, which is
optional for ARMv7, but mandatory for v8.
This fixes compilation for 64-bit sunxi boards (Pine64).
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Update the pinmux and pll configuration for the Cyclone5 RevE or later devkit.
Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
CONFIG_OF_LIBFDT needs to be selected to avoid the following
boot problem:
reading zImage
6346216 bytes read in 118 ms (51.3 MiB/s)
Booting from mmc ...
reading imx7d-warp.dtb
32593 bytes read in 11 ms (2.8 MiB/s)
Kernel image @ 0x80800000 [ 0x000000 - 0x60d5e8 ]
FDT and ATAGS support not compiled in - hanging
### ERROR ### Please RESET the board ###
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Reported by Coverity:
Logically dead code (DEADCODE)
dead_error_line: Execution cannot reach this statement:
(f_dfu->strings + --i).s = ....
If calloc failed, i is still 0 and no need to call free,
so discard the dead code.
Cc: "Łukasz Majewski" <l.majewski@samsung.com>
When dfu_fill_entity fail, need to free dfu to avoid memory leak.
Resource leak (RESOURCE_LEAK)
leaked_storage: Variable dfu going out of scope leaks the storage
it points to.
With patch c998da0d (usb: Change power-on / scanning timeout handling),
the USB scanning is started earlier and with a smaller timeout. This
resulted on SoCFPGA (using the DWC2 driver) in some USB sticks not
getting detected any more. This patch now adds a 1 second delay (in
the host mode only) to the DWC2 driver before the scanning is started.
With this delay, now all problematic USB keys are detected successfully
again. And there is no need any more to change the delay / timeout
in the common USB code (usb_hub.c).
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Stephen Warren <swarren@nvidia.com>
The code shouldn't continue probing the port if get_port_status() failed.
Cc: Stefan Roese <sr@denx.de>
The Kingston DT Ultimate USB 3.0 stick is sensitive to this first
Get Descriptor request and if the request is not in a separate
microframe, the stick refuses to operate. Add slight delay, which
is enough for one microframe to pass on any USB spec revision.
Some devices, like the SanDisk Cruzer Pop need some time to process
the Set Configuration request, so wait a little until they are ready.
Building without ethernet driver doesn't work. Fix it.
The indirect read code is a pile of nastiness. This patch replaces
the whole unmaintainable indirect read implementation with the one
from upcoming Linux CQSPI driver, which went through multiple rounds
of thorough review and testing. All the patch does is it plucks out
duplicate ad-hoc code distributed across the driver and replaces it
with more compact code doing exactly the same thing. There is no
speed change of the read operation.
Cc: Pavel Machek <pavel@denx.de>
Cc: Vignesh R <vigneshr@ti.com>
The indirect write code is buggy pile of nastiness which fails horribly
when the system runs fast enough to saturate the controller. The failure
results in some pages (256B) not being written to the flash. This can be
observed on systems which run with Dcache enabled and L2 cache enabled,
like the Altera SoCFPGA.
This patch replaces the whole unmaintainable indirect write implementation
with the one from upcoming Linux CQSPI driver, which went through multiple
rounds of thorough review and testing. While this makes the patch look
terrifying and violates all best-practices of software development, all
the patch does is it plucks out duplicate ad-hoc code distributed across
the driver and replaces it with more compact code doing exactly the same
thing.
The time command is very helpful for performance and regressions tests.
So lets enable it on SoCrates.
This is mandatory, otherwise the USB does not work.
Cc: Dinh Nguyen <dinguyen@kernel.org>
The pointer should always be inited to NULL, not zero (0). These are
two different things and not necessarily equal.
There could be runtime determined board specific reason why a EHCI
initialization fails (e.g. ENODEV if a Port is not available). In
this case, properly return the error code.
While at it, that function (board_ehci_hcd_init) has actually two
documentation blocks... Use the correct function name for the
documentation block of board_usb_phy_mode.
Signed-off-by: Stefan Agner <stefan@agner.ch>
According PL310 TRM, Auxiliary Control Register
The register must be written to using a secure access, and it can be
read using either a secure or a NS access. If you write to this register
with a NS access, it results in a write response with a DECERR response,
and the register is not updated. Writing to this register with the L2
cache enabled, that is, bit[0] of L2 Control Register set to 1,
results in a SLVERR.
So If L2 cache is already enabled by ROM, chaning value of ACR
will cause SLVERR and uboot hang.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
It can take a while for a host machine to notice that a USB device has
disconnected, and process the change. At the end of the DFU test, we wait
up to 10 seconds for this to happen. This change makes the test wait the
same (up to) 10 seconds at the start of the test for any previously active
USB device-mode session to be cleaned up. Such as session might have been
used to download U-Boot into memory for example; this is certainly true
on my Tegra test systems. This changes should solve the DFU test
intermittency issues I've been seeing on some Tegra devices.
The current delays in the DDR initialization routines for am33xx
architectures are sometimes not running long enough leading to DDR
init errors. On am437x, this shows up as an L3 NOC error after the
kernel boots. This is due to the timer not being initialized
properly, but instead still containing the timer init values from
the boot ROM which cause timers to expire in 1/4th the time
required.
timer_init is typically not called until board_init_r, however on
am33xx/am43xx udelay is required in sdram_init which is called
from board_init_f, so a call to timer_init is required earlier.
Note that this issue introduced in v2015.01 by:
b352dde "am33xx: Drop timer_init call from s_init".
Although this could instead fixed by reverting said commit, it
would cause timer_init to be called twice in both SPL and non-SPL
cases. This gives a little more fine grained control and also
matches what is being done on omap-command and fsl-layerscape.
Signed-off-by: Russ Dill <russ.dill@ti.com>
Commit 724219a65f55 "ARM: always perform per-CPU GIC init" removed some
ifdefs to unify the MULTIENTRY-vs-non-MULTIENTRY paths. However, the
wrong endif was removed. This patch adds back that missing endif, and
adds a new ifdef to match the endif the now-correctly-terminated block
used to match against. Use "git show -U25 724219a65f55" to see enough
context to make the original issue clear.
In practical terms, this makes no difference to runtime behaviour. The
code that was incorrectly compiled into the binary when ifndef MULTIENTRY
is a no-op for other cases, since branch_if_master evaluates to a hard-
coded jump. The only issues were:
- A few extra instructions were added to the binary.
- The comment on the endif at the very end of the function, indicating
which ifdef it matched, were wrong.
An alternative might be to simply fix the comment on that trailing ifdef,
but that only addresses the second point above, not the first.
Fixes: 724219a65f55 ("ARM: always perform per-CPU GIC init")
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Spelling corrections for (among other things):
* environment
* override
* variable
* ftd (should be "fdt", for flattened device tree)
* embedded
* FTDI
* emulation
* controller
Since we do not build any board with CONFIG_SUPPORT_EMMC_RPMB , this
piece of code evaded conversion. Fix the following compiler error:
cmd/mmc.c: In function 'do_mmcrpmb':
cmd/mmc.c:316:32: error: 'struct blk_desc' has no member named 'part_num'
original_part = mmc->block_dev.part_num;
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
The DuoVero board fails to compile with EFI enabled as the generated
binaries are too large. As this platform doesn't currently need EFI,
disable this feature.
Signed-off-by: Ash Charles <ashcharles@gmail.com>
Be sure to load the zImage and fdtfile prior to actually booting in
case we are doing a legacy boot.
This imports v11 of "Jetson TK1 Development Platform Pin Mux" from
https://developer.nvidia.com/embedded/downloads.
The new version defines the mux option for the MIPI pad ctrl selection.
The OWR pin no longer has an entry in the configuration table because
the only mux option it support is OWR, that feature isn't supported, and
hence can't conflict with any other pin. This pin can only usefully be
used as a GPIO.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Tegra20's PCIe controller has a couple of quirks. There are workarounds in
the driver for these, but they don't work after the DM conversion:
1) The PCI_CLASS value is wrong in HW.
This is worked around in pci_tegra_read_config() by patching up the value
read from that register. Pre-DM, the PCIe core always read this via a
16-bit access to the 16-bit offset 0xa. With DM, 32-bit accesses are used,
so we need to check for offset 0x8 instead. Mask the offset value back to
32-bit alignment to make this work in all cases.
2) Accessing devices other than dev 1 causes a data abort.
Pre-DM, this was worked around in pci_skip_dev(), which the PCIe core code
called during enumeration while iterating over a bus. The DM PCIe core
doesn't use this function. Instead, enhance tegra_pcie_conf_address() to
validate the bdf being accessed, and refuse to access invalid devices.
Since pci_skip_dev() isn't used, delete it.
I've also validated that both these WARs are only needed for Tegra20, by
testing on Tegra30/Cardhu and Tegra124/Jetson TKx. So, compile them in
conditionally.
Fixes: e81ca88451cf ("dm: tegra: pci: Convert tegra boards to driver model for PCI")
Reviewed-by: Thierry Reding <treding@nvidia.com>
In current Linux kernel Tegra DT files, 64-bit addresses are represented
in unit addresses as a pair of comma-separated 32-bit values. Apparently
this is no longer the correct representation for simple busses, and the
unit address should be represented as a single 64-bit value. If this is
changed in the DTs, arm/arm/mach-tegra/board2.c:ft_system_setup() will no
longer be able to find and enable the GPU node, since it looks up the node
by name.
Fix that function to enable nodes based on their compatible value rather
than their node name. This will work no matter what the node name is, i.e
for DTs both before and after any rename operation.
Cc: Alexandre Courbot <acourbot@nvidia.com>
Ethernet packages with IEEE 802.1Q VLAN support may be up to 1522
bytes long. Increase the default size used to allocate packet
storage by 4 bytes. While at it, let git care about history and
rewrite the comment to represent the situation today only.
VLAN identifiers are 12-bit decimal numbers, not IP addresses.
