This cleanup is done by creating header files for all SoC versions and
moving the SoC specific defines into these special headers. This way the
common header ppc405.h and ppc440.h can be cleaned up finally.
As a part from this cleanup, the GPIO definitions for PPC405EP are
corrected. The high and low parts of the registers (for example
CONFIG_SYS_GPIO0_OSRL vs. CONFIG_SYS_GPIO0_OSRH) have been defined in
the wrong order. This patch now fixes this issue by switching these
xxxH and xxxL values. This brings the GPIO 405EP port in sync with all
other PPC4xx ports.
This patch starts a bit PPC4xx header cleanup. First patch mostly
touches PPC440 files. A later patch will touch the PPC405 files as well.
This patch moves some ppc4xx related headers from the common include
directory (include/) to the powerpc specific one
(arch/powerpc/include/asm/). This way to common include directory is not
so cluttered with files.
features
The Freescale MPC8610 and MPC5121 DIU code had re-implement two features that already
existed in U-Boot: bitmap drawing and top-of-screen logo (CONFIG_VIDEO_LOGO).
So delete the 8610-specific code and use the built-in features instead.
Add support for 4bpp bitmaps, currently only for GDF_32BIT_X888RGB
frame buffer format.
Add the Freescale logo and update the Makefile to build it when building
a Freescale board.
[u-boot next]$ ./MAKEALL 83xx
awk '(NF && $1 !~ /^#/) { print $1 ": " $1 "_config; $(MAKE)" }' boards.cfg > .boards.depend
Configuring for ve8313 board...
This patch modifies jadecpu board so that it is usable
with the relocation patches by Heiko Schocher
Signed-off-by: Matthias Weisser <weisserm@arcor.de>
Fixes most of checkpatch warnings and errors in USB gadget stack.
The most frequently encountered problems are:
1) "(foo*)", "foo * bar", "foo* bar"
2) C99 // comments
3) No spaces before/after/around '?', ':', '=', '==', ',', '&', '('
4) Spaces before '['
5) Spaces between function names and '('
6) Block braces in wrong places
7) Spaces before tabs
8) Macros with complex values not enclosed in parenthesis
9) Multiline comments start just after /*
Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
The patch removes an endless loop in the usb_eth_send
if the tx_complete is not called before going
in the loop. The driver interrupt routine is called
allowing the driver to check if the TX is completed.
The buffer for the status request must be word aligned
because it is accessed with 32 bit pointer in the
eth_status_complete function.
The patch is based on commit bb9496c6f7e853e5d4edd5397c9d45f1968d623c
(done by Julia Lawall <julia@diku.dk>) from linux-2.6.git.
Since num is unsigned, it would seem better to use simple_strtoul that
simple_strtol.
Fix potential oops on rare error path.
The patch is based on commit e7b13ec9235b9fded90f826ceeb8c34548631351
(done by David Brownell <david-b@pacbell.net>) from linux-2.6.git.
Description of the issue taken from linux kernel bugzilla:
(https://bugzilla.kernel.org/show_bug.cgi?id=9594)
The potential error can be tracked down as follows:
(1) line 807: let the second conjunct on the "if" statment be false
meaning "dev->status_ep" is null. This means the "if" evaluates
to false.
follow thru the code until...
(2) line 808: usb_ep_disable(dev->status_ep) passes in a null argument,
however "usb_ep_disable" cannot handle that:
(from include/linux/usb/gadget.h)
191 static inline int
192 usb_ep_disable (struct usb_ep *ep)
193 {
194 return ep->ops->disable (ep);
195 }
Fix possible oops on stat_req->buf initialization and fix ep0 and
status_ep confusion (last one is just intended for stat_req keeping).
Replace 'strcpy' by more safe 'strlcpy' that is implemented in ether.c
Fix in_ep and out_ep confusion (rx_req was allocated from out_ep, not
from in_ep) and add lost dev->req freeing.
Replace Linux-like debug printout macros by native ones.
Applied after removing dead code like '#define DEBUG/#undef DEBUG'
Add lost 'qmult' definition for High Speed devices and make it
configurable through CONFIG_USB_ETH_QMULT.
Prohibit simultaneous usage of both old and new gadget stacks and
allow UDC drivers to be dependent on CONFIG_USB_ETHER.
Derived from Linux kernel 2.6.27
Signed-off-by: Thomas Smits <ts.smits@gmail.com>
Signed-off-by: Remy Bohmer <linux@bohmer.net>
The MUSB_TXCSR_MODE register setting isn't supported on Blackfin musb
parts, so stub it out to 0. This matches Linux behavior.
Now that the defines are moved to header files we don't need this
conditional compilation any more. Remove it.
This patch simplifies the use of CONFIG_SYS_MAX_FLASH_BANKS_DETECT. By
moving these optional variables and defines into the common code, board
specific code is minimized. Currently only the following board use
this feature:
APC405, IDS8247, TQM834x
And IDS8247 doesn't seem to really need this feature, since its not
updating the bank number variable at all. So this patch removes the
definition of CONFIG_SYS_MAX_FLASH_BANKS_DETECT from this board port.
This new framework will be used by the upcoming lwmon5 update as well.
Acked-by: Heiko Schocher <hs@denx.de>
Cc: Matthias Fuchs <matthias.fuchs@esd.eu>
cfi_flash_bank_addr(int bank_nr) returns the base addresses of the
requested bank. Introducing this weak default enables boards to override
this functions with a board specific version when required.
This feature will be used in the lwmon5 board update, supporting runtime
detection of 2 board revisions with different flash layouts.
This patch removes an unecessary check in the return statement. This is
not needed, since "info" is initializes to NULL. And "info" will not be
written to again, if the flash address is not found.
Additionally "info" is not initialized to "0" but to "NULL".
Recent changes caused that the spieval board now is included in the
boards built by MAKEALL, which revealed that compilation for this
board has been broken for a long time:
mpc5xxx_fec.c:899:2: error: #error fec->xcv_type not initialized.
The board is orphaned. Drop support for it.
Recent changes caused that the smmaco4 board now is included in the
Recent changes caused that the HMI10 board now is included in the
ps2ser.c: In function 'ps2ser_init':
ps2ser.c:155: error: 'UART_LCR' undeclared (first use in this function)
ps2ser.c:155: error: (Each undeclared identifier is reported only once
ps2ser.c:155: error: for each function it appears in.)
ps2ser.c:156: error: 'UART_DLL' undeclared (first use in this function)
ps2ser.c:157: error: 'UART_DLM' undeclared (first use in this function)
ps2ser.c:159: error: 'UART_IER' undeclared (first use in this function)
ps2ser.c:160: error: 'UART_MCR' undeclared (first use in this function)
ps2ser.c:161: error: 'UART_FCR' undeclared (first use in this function)
ps2ser.c:162: error: 'UART_FCR_ENABLE_FIFO' undeclared (first use in this function)
ps2ser.c:166: error: 'UART_LSR' undeclared (first use in this function)
ps2ser.c: In function 'ps2ser_putc':
ps2ser.c:198: error: 'UART_LSR' undeclared (first use in this function)
ps2ser.c:200: error: 'UART_TX' undeclared (first use in this function)
ps2ser.c: In function 'ps2ser_getc_hw':
ps2ser.c:224: error: 'UART_LSR' undeclared (first use in this function)
ps2ser.c:225: error: 'UART_RX' undeclared (first use in this function)
ps2ser.c: In function 'ps2ser_interrupt':
ps2ser.c:293: error: 'UART_IIR' undeclared (first use in this function)
The board is orphaned, and AFAICT has reached EOL.
Recent changes caused thatthe aev board now is included in the boards
built by MAKEALL, which revealed that compilation for this board
canmb.c: In function 'initdram':
canmb.c:109: warning: pointer targets in passing argument 1 of 'get_ram_size' differ in signedness
canmb.c:111: warning: pointer targets in passing argument 1 of 'get_ram_size' differ in signedness
canmb.c:137: warning: pointer targets in passing argument 1 of 'get_ram_size' differ in signedness
canmb.c:140: warning: pointer targets in passing argument 1 of 'get_ram_size' differ in signedness
Fix these.
built by MAKEALL, which revealed that compilation for this board has
Fix it.
Split the existing dram_init for da8xx when ARM reloc is enabled, like the
changes to arch/arm/cpu/arm926ejs/orion5x/dram.c in
0f234d263b17ccf1b8fd776eb8c15b7cdb27a887 by Heiko Schocher <hs@denx.de>.
Without these changes gd->ram_size is '0' which leads to incorrect relocation
when CONFIG_SYS_ARM_WITHOUT_RELOC is defined and the board does not boot.
We use get_ram_size to dynamically calculate the available RAM because it runs
on different board version with different ram, as suggested by Heiko in private
communication.
Tested on a da850evm with 128M of DDR2 installed; with both
CONFIG_SYS_ARM_WITHOUT_RELOC defined and undefined.
Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca>
Reviewed-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
CC: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
CC: Heiko Schocher <hs@denx.de>
Change the implementation for arm1176 to relocate the code to
an arbitrary address in RAM.
Portions of this work were supported by funding from
the CE Linux Forum.
Change the implementation for arm720t to relocate the code to
the CE Linux Forum.
Change the implementation for arm_intcm to relocate the code to
the CE Linux Forum.
Change the implementation for lh7a40x to relocate the code to
the CE Linux Forum.
Change the implementation for s3c44b0 to relocate the code to
the CE Linux Forum.
Change the implementation for sa1100 to relocate the code to
the CE Linux Forum.
Change the implementation for ixp to relocate the code to
the CE Linux Forum.
Change the implementation for pxa to relocate the code to
the CE Linux Forum.
Change the implementation for arm946 to relocate the code to
the CE Linux Forum.
Change the implementation for arm925 to relocate the code to
the CE Linux Forum.
Change the implementation for arm920 to relocate the code to
the CE Linux Forum.
Change the implementation for arm926 to relocate the code to
Adapt the TX25 (i.MX25), magnesium board to test the changes.
On the tx25 board TEXT_BASE is set to the final relocation
address to prevent one more copying of u-boot code
when relocating. More info see:
doc/README.arm-relocation
da850 board:
Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
the CE Linux Forum.
Cc: Ben Gardiner <bengardiner@nanometrics.ca>
Change the implementation for ARM V7 to relocate the code to an
Adapt the Beagle board (Cortex A8) to test the changes.
the CE Linux Forum.
Change the implementation for ARM11 to relocate the code to an
Tested on the qong board.
the CE Linux Forum.
