2013-12-13common/config_defaults.h: make CONFIG_BOOTM_VXWORKS default configurationMiao Yan
Signed-off-by: Miao Yan <miao.yan@windriver.com>
2013-12-13common/cmd_bootm.c: seperate do_bootm_vxworks related code from CONFIG_CMD_ELF.Miao Yan
do_bootm_vxworks now is available under the configuration option CONFIG_BOOTM_VXWORKS, thus aligned with other operating systems that supported by bootm command. The bootvx command still depneds on CONFIG_CMD_ELF. Signed-off-by: Miao Yan <miao.yan@windriver.com>
2013-12-13Makefile: delete unnecessary CPPFLAGS settingsMasahiro Yamada
2013-12-13Makefile: Move some scripts imported from LinuxMasahiro Yamada
We have some scripts imported from Linux Kernel: setlocalversion, checkstack.pl, checkpatch.pl, cleanpatch They are located under tools/ directory in U-Boot now. But they were originally located under scripts/ directory in Linux Kernel. This commit moves them to the original location. It is true that binutils-version.sh and dtc-version.sh do not originate in Linux Kernel, but they should be moved by analogy to gcc-version.sh. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-13drivers/mtd: descend into sub directories only when it is necessaryMasahiro Yamada
2013-12-13drivers/usb/gadget: select objects by obj-$(CONFIG-...)Masahiro Yamada
Before switching to the real Kbuild, drivers/usb/gadget/Makefile must be fixed. If none of CONFIG_USB_GADGET, CONFIG_USB_ETHER, CONFIG_USB_DEVICE is defined, both obj- and obj-y get empty. We need non-empty obj- or obj-y on each Makefile to generate built-in.o on the real Kbuild. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-13post: descend only when CONFIG_HAS_POST is definedMasahiro Yamada
All objects under post/ directory are enabled by CONFIG_HAS_POST. (post/tests.o is enabled by CONFIG_POST_STD_LIST. But CONFIG_POST_STD_LIST depends on CONFIG_HAS_POST.) We can move CONFIG_HAS_POST switch to the top Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-13Makefile: delete a make rule of $(LDSCRIPT)Masahiro Yamada
$(LDSCRIPT) is a source file, not a generated file. We do not need a make rule of $(LDSCRIPT). And one more trivial fix: $(obj)/u-boot should not dierectly depend on $(LDSCRIPTS). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-13board_f: explicitly disable console on early bootAlexey Brodkin
If U-Boot build with DEBUG enabled/defined the first call of "debug" function (that dumps data to any available console) will happen before zeroing of initial "gd" in init call "zero_global_data" in "init_sequence_f". And if stack was not filled with zeros chances are high that "gd->have_console" won't be 0. In its turn it will cause attempt to output things to non-initialized yet serial console. So for safety and predictability we set "gd->have_console = 0". Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Mischa Jonker <mjonker@synopsys.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-12-13Correct vxWorks elf boot to load at correct addressStany MARCEL
argv[0] contains bootvx (command name) not the load address, if called with argv < 2 use load_addr, else use address argument given to the command. Signed-off-by: Stany MARCEL <smarcel@novasys-ingenierie.com>
2013-12-13.gitignore: ignore spl/ and tpl/ directories except spl/MakefileMasahiro Yamada
Before this commit, output files under tpl/ directry were not ignored. This commit fixes this problem. And we have only one source file under spl/ directory: spl/Makefile So, we can describe .gitignore more simply. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-13PowerPC: merge commonly-defined flagsMasahiro Yamada
PLATFORM_RELFLAGS += -meabi PLATFORM_CPPFLAGS += -ffixed-r2 were defined in all arch/powerpc/${CPU}/config.mk. This commit moves them to arch/powerpc/config.mk. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-13netbsd:fix documentation typo.Kees Jongenburger
The documentation suggested the arguments where passed over r3-r6 while the code below simply does that over r0-r3. Cc: Kumar Gala <galak@kernel.crashing.org>
2013-12-13spl/Makefile: merge LIBS-y += arch/$(ARCH)/imx-commonMasahiro Yamada
2013-12-13yaffs2: Use lldiv for 64bit divisionTom Rini
2013-12-13JFFS2: Correct jffs2_1pass_build_lists to use lldivTom Rini
Since part_info size became 64bit we need to use lldiv here. Signed-off-by: Tom Rini <trini@ti.com>
2013-12-13ARM:PXA: Correct tick_to_time / us_to_tick to use lldivTom Rini
Cc: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Marek Vasut <marex@denx.de>
2013-12-13ARM:zynq: Correct __udelay to use lldivTom Rini
Cc: Michal Simek <monstr@monstr.eu> Signed-off-by: Tom Rini <trini@ti.com>
2013-12-13time: fix usec_to_tick()Stephen Warren
Commit 8dfafdde88eb ("Introduce common timer functions") created a common definition of usec_to_tick() which had a couple problems: static unsigned long long usec_to_tick(unsigned long usec) { uint64_t tick = usec * get_tbclk(); That likely overflows. usec *= get_tbclk(); That was an attempt to fix it by performing the multiply after the promotion of usec to 64-bit, but was applied to the wrong variable, which was never used. This patch fixes these issues. A user-visible symptom of the problem was the e.g. "dhcp zImage" using an ASIX USB Ethernet dongle would print: Waiting for Ethernet connection... unable to connect. ... with no delay before "unable to connect". There are likely other symptoms. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Rob Herring <rob.herring@calxeda.com>
2013-12-13Makefile: correct dependencies of asm-offsets.[hs]Masahiro Yamada
These four generated files depends on neither {spl,tpl}-autoconf.mk nor autoconf.mk.dep. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-13Makefile: use two double-quotations as a pairMasahiro Yamada
Some editors such as Emacs can highlight source files. But their parser algorithm is not perfect. If you use one double-quotation alone, some editor cannot handle it nicely and mark source lines as a string by mistake. It is preferable to use two double-quotations as a pair. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-13Makefile: Do not create empty autoconf.mk on errorMasahiro Yamada
The build rules of - include/autoconf.mk.dep - include/autoconf.mk - include/spl-autoconf.mk - include/tpl-autoconf.mk were not nice. They created empty files (which are never updated) if an error occurs during preprocessing. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-13sandbox: dumpimage: Test dumpimageGuilherme Maciel Ferreira
Add a test for dumpimage. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-12-13Add dumpimage, a tool to extract data from U-Boot imagesGuilherme Maciel Ferreira
Given a multi-file image created through the mkimage's -d option: $ mkimage -A x86 -O linux -T multi -n x86 -d vmlinuz:initrd.img:System.map \ multi.img Image Name: x86 Created: Thu Jul 25 10:29:13 2013 Image Type: Intel x86 Linux Multi-File Image (gzip compressed) Data Size: 13722956 Bytes = 13401.32 kB = 13.09 MB Load Address: 00000000 Entry Point: 00000000 Contents: Image 0: 4040128 Bytes = 3945.44 kB = 3.85 MB Image 1: 7991719 Bytes = 7804.41 kB = 7.62 MB Image 2: 1691092 Bytes = 1651.46 kB = 1.61 MB It is possible to perform the innverse operation -- extracting any file from the image -- by using the dumpimage's -i option: $ dumpimage -i multi.img -p 2 System.map Although it's feasible to retrieve "data files" from image through scripting, the requirement to embed tools such 'dd', 'awk' and 'sed' for this sole purpose is cumbersome and unreliable -- once you must keep track of file sizes inside the image. Furthermore, extracting data files using "dumpimage" tool is faster than through scripting. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-12-13tools: moved code common to all image tools to a separated module.Guilherme Maciel Ferreira
In order to avoid duplicating code and keep only one point of modification, the functions, structs and defines useful for "dumpimage" were moved from "mkimage" to a common module called "imagetool". This modification also weakens the coupling between image types (FIT, IMX, MXS, and so on) and image tools (mkimage and dumpimage). Any tool may initialize the "imagetool" through register_image_tool() function, while the image types register themselves within an image tool using the register_image_type() function: +---------------+ +------| fit_image | +--------------+ +-----------+ | +---------------+ | mkimage |--------> | | <-----+ +--------------+ | | +---------------+ | imagetool | <------------| imximage | +--------------+ | | +---------------+ | dumpimage |--------> | | <-----+ +--------------+ +-----------+ | +---------------+ +------| default_image | +---------------+ register_image_tool() register_image_type() Also, the struct "mkimage_params" was renamed to "image_tool_params" to make clear its general purpose. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-12-13mkimage: added 'static' specifier to match function's prototype.Guilherme Maciel Ferreira
This function should be declared static. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-12-13kgdb: configs: remove obsolete CONFIG_KGDB_SER_INDEXVladimir Zapolskiy
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should care about this parameter or it should be gone completely. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2013-12-13serial: lpc32xx: send CR before LFVladimir Zapolskiy
For LPC32XX high-speed UART it is required to send a carriage return symbol along with line feed. The problem was introduced in e503f90a commit. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Cc: Marek Vasut <marex@denx.de> Acked-by: Marek Vasut <marex@denx.de>
2013-12-11powerpc/mpc85xx: Update CONFIG_SYS_FSL_TBCLK_DIV for T1040Prabhakar Kushwaha
The default value of CONFIG_SYS_FSL_TBCLK_DIV is 16. So, update its value as default. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-12-11powerpc/p1_p2_rdb_pc: Fix warnings for __iomem pointersClaudiu Manoil
Add the __iomem address space marker for the tsec pointers to struct tsec_mii_mng memory mapped register regions. This solves the sparse warnings for mixig normal pointers with __iomem pointers for tsec. p1_p2_rdb_pc.c:373:24: warning: incorrect type in assignment (different address spaces) p1_p2_rdb_pc.c:373:24: expected struct tsec_mii_mng [noderef] <asn:2>*regs p1_p2_rdb_pc.c:373:24: got struct tsec_mii_mng *<noident> Use TSEC_GET_MDIO_REGS_BASE() for the remaining mdio 'regs' initializations to remove the __iomem warnings and for consistency. Signed-off-by: Claudiu Manoil <claudiu.manoil@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-12-11net/fman: add ft_fixup_xgec to support 3rd and 4th 10GECShengzhou Liu
As mEMAC1 and mEMAC2 are dual-role MACs, which are used as 1G or 10G MAC. So we update dynamically 'cell-index' to '2' and '3' for 10GEC3 and 10GEC4. Also change 'fsl,fman-port-1g-rx' to 'fsl,fman-port-10g-rx', ditto for Tx. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-12-11powerpc/t4240: Add a frequency setting case for fman1Shaohui Xie
A new valid setting case added for fman1, it uses platform frequency. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-12-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Conflicts: board/samsung/trats2/trats2.c include/configs/exynos5250-dt.h Signed-off-by: Tom Rini <trini@ti.com>
2013-12-10Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/armv7/rmobile/Makefile doc/README.scrapyard Needed manual fix: arch/arm/cpu/armv7/omap-common/Makefile board/compulab/cm_t335/u-boot.lds
2013-12-10Merge branch 'spi' of git://git.denx.de/u-boot-x86Tom Rini
2013-12-10Merge branch 'master' of git://git.denx.de/u-boot-mmcTom Rini
2013-12-10Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
2013-12-10vexpress: use correct timer address on extended memory map systemsIan Campbell
Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Cc: albert.u.boot@aribaud.net
2013-12-10serial: zynq: Remove unused #definesSoren Brinkmann
Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-12-09sandbox: spi: Enable new spi/sf layersMike Frysinger
We want to test SPI flash code in the sandbox, so enable the new drivers and the 'sf test' command. This command is used to validate the sandbox SPI / SPI flash implementation, so enable it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-12-09sandbox: spi: Add new SPI flash driverMike Frysinger
This adds a SPI flash driver which simulates SPI flash clients. Currently supports the bare min that U-Boot requires: you can probe, read, erase, and write. Should be easy to extend to make it behave more exactly like a real SPI flash, but this is good enough to merge now. sjg@chromium.org added a README and tidied up code a little. Added a required map_sysmem() for sandbox. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-12-09sandbox: spi: Add SPI emulation busMike Frysinger
This adds a SPI framework for people to hook up simulated SPI clients. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-12-09spi: Add device tree binding for SPI busSimon Glass
This was obtained from Linux 3.12 commit 5e01dc7b26. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-12-09spi_flash: Add spi_flash_probe_fdt() to locate SPI by FDT nodeSimon Glass
This allows us to put the SPI flash chip inside the SPI interface node, with U-Boot finding the correct bus and chip select automatically. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-12-09sandbox: Rename sb_cmdline_option to sandbox_cmdline_optionSimon Glass
The new name is longer but more clearly related to sandbox. This is in a separate patch within the same series since some comments on the SPI series rely on it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Hung-ying Tyan <tyanh@chromium.org>
2013-12-09arm: at91: support for the Calao USB-A9263 board (based on AT91SAM9263)Mateusz Kulikowski
Add support for USB-A9263 board manufactured by Calao Systems (http://www.calao-systems.com/). Code is based on old U-Boot sources (2010.09) released by Calao. Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-12-09arm, at91: add siemens corvus boardHeiko Schocher
enable support for the siemens AT91SAM9G20 based board corvus. Signed-off-by: Boris Schmidt <boris.schmidt@siemens.com> Reviewed-by: Heiko Schocher <hs@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-12-09arm, at91: add Siemens board taurus and axmHeiko Schocher
enable support for the siemens AT91SAM9G20 based boards taurus and axm. Signed-off-by: Roger Meier <r.meier@siemens.com> Reviewed-by: Heiko Schocher <hs@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-12-09at91: switch coloured LED to gpio APIAndreas Bießmann
2013-12-09at91: nand: switch atmel_nand to generic GPIO APIAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de> Tested-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de> Acked-by: Scott Wood <scottwood@freescale.com>
