This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
Now that CONFIG_USB_MUSB_HOST is part of Kconfig, migrate that over to
the defconfig files.
U-Boot typically interprets unprefixed numbers as base 16, and DFU RAM
entity parsing has historically done so. Reverse the change to default
to base 10, so that values in previously working command-lines aren't
mis-parsed, causing RAM corruption, crashes, hangs, etc.
Fixes: 6aeb877afef0 ("drivers: dfu: ram: fix a crash with dfu ram with invalid dfu_alt_info env")
Cc: Mugunthan V N <mugunthanvnm@ti.com>
Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com>
Tested-by: Mugunthan V N <mugunthanvnm@ti.com>
[Test HW: AM335x BBB]
U-Boot crashes when an invalid dfu_alt_info is set and tried
using dfu command. Fixing this as it is handled in dfu-mmc.
=> dfu 0 ram 0
data abort
pc : [<9ff893d6>] lr : [<9ff6edb9>]
reloc pc : [<808323d6>] lr : [<80817db9>]
sp : 9ef36cf0 ip : 00000158 fp : 9ffbc0b8
r10: 9ffbc0b8 r9 : 9ef36ed8 r8 : 00000000
r7 : 00000000 r6 : 9ffbc0c8 r5 : 9ef36cfc r4 : 9ef392c8
r3 : 00000004 r2 : 00000000 r1 : 9ff9a985 r0 : ffffffff
Flags: Nzcv IRQs off FIQs on Mode SVC_32
Resetting CPU ...
resetting ...
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
Remaining bytes means bytes that are not yet transferred
and not the bytes that were transferred in the last transfer.
Reported-by: Lukasz Majewski <l.majewski@samsung.com>
Signed-off-by: Roger Quadros <rogerq@ti.com>
Tested-by: Steve Rae <srae@broadcom.com>
[Test HW: bcm28155_ap board]
Request size can be greater than ep.packet and still end in a
short packet. We need to tackle this case as end of transfer
(if short_not_ok is not set) as indicated in USB 2.0 Specification [1],
else we get stuck up on certain protocols like fastboot.
[1] - USB2.0 Specification, Section 5.3.2 Pipes
Reported-by: Steve Rae <steve.rae@broadcom.com>
Tested-by: Steve Rae <steve.rae@broadcom.com>
Tested-by: Lukasz Majewski <l.majewski@samsung.com>
Just use ep->maxpacket to get the maxpacket size
and simplify the bulk-out maxpacket alignment.
In a dual speed configuration we need to check at runtime if
we want to enable the Full-Speed or High-Speed endpoint.
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
[Test HW: bcm235xx board]
wMaxPacketSize for IN endpoing in High-Speed must be 512 and not 64.
While fixing that we do some clean ups like
- use cpu_to_le16(decimal_length) instead of hexadecimal length.
- No need to initialize bInterval to 0. Static variables are 0 initialized.
- Move descriptor setting from fastboot_add to to fastboot_bind.
- check for dual speed configuration before setting the high speed descriptors.
Tested-by: Steve Rae <srae@broadcom.com> [Test HW: bcm235xx board]
After concatenation of "dfu_alt_info" variable from "dfu_alt_boot" and
"dfu_alt_system" it may happen that test and dummy files alt settings
are different than default 0 and 1.
This patch provides the ability to set different values for them.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Changes for v3:
- replace variables declarations with ones read from configuration file
- remove not necessary str() conversion at DFU host command generation
Changes for v2:
- generate "alt_info" automatically
- use file names as alt settings instead of numerical values
- extend in-code documentation
By default (on almost all systems) the dfu env variable, which defines
available alt settings, is named as "dfu_alt_info".
However on some platforms (i.e. Odroid XU3), the 'dfu_alt_info' is concatenated
from other variables - namely 'dfu_alt_boot' and 'dfu_alt_system' at run time
(when one types 'dfu 0 mmc 0' for first time).
'dfu_alt_boot' describes alt settings which depend on boot medium - for example
boot loader's LBA sectors which are different on eMMC and SD card because of e.g.
MBR/GPT.
'dfu_alt_system' describes board agnostic alt settings - like rootfs, kernel.
On such system we can only append/modify this env variable.
Because of the above, we must have way to modify other than "dfu_ale_info"
variable to perform tests.
Changes for v3:
- None
Changes for v2:
- Rewrite of "alt_info_env_name" variable description
- Use of get() method on python's dictionary to easily obtain default
value
This patch replaces hardcoded (i.e. 0 and 1) values passed to dfu_{read|write}
with variables.
Changes for v3:
- Replace per module global variables with ones defined inside a function
Changes for v2:
- None
This patch adds support for the PCI(e) based I2C cores. Which can be
found for example on the Intel Bay Trail SoC. It has 7 I2C controllers
implemented as PCI devices.
This patch also adds the fixed values for the timing registers for
BayTrail which are taken from the Linux designware I2C driver.
Cc: Bin Meng <bmeng.cn@gmail.com>
This patch adds DM support to the designware I2C driver. It currently
supports DM and the legacy I2C support. The legacy support should be
removed, once all platforms using it have DM enabled.
This patch prepares the designware I2C driver for the DM conversion.
This is mainly done by removing struct i2c_adapter from the functions
that shall be used by the DM driver version as well.
Integrating set_speed() into dw_i2c_set_bus_speed() will make the
conversion to DM easier for this driver.
dw_i2c_enable() is used to dis-/en-able the I2C controller. It makes
sense to add such a function, as the controller is dis-/en-abled
multiple times in the code. Additionally, this function now checks,
if the controller is really dis-/en-abled. This code is copied
from the Linux I2C driver version.
Add the ic_enable_status register to the i2c_regs struct. Additionally
the register offsets are added, to better check, if the offset matches
the register description in the datasheet.
On some platforms (e.g. x86), the return value of dev_get_addr() can't
be assigned to a pointer type variable directly. As there might be a
difference between the size of fdt_addr_t and the pointer type. On
x86 for example, "fdt_addr_t" is 64bit but "void *" only 32bit. So
assigning the register base directly in dev_get_addr() results in this
compilation warning:
warning: cast to pointer from integer of different size
This patch introduces the new function dev_get_addr_ptr() that
returns a pointer to the 'reg' address that can be used by drivers
in this case.
Copy the kernel image double-word-wise rather than byte-wise.
PH1-LD20 needs this for its SD card controller.
PH1-LD20 does not support 1.8V signaling for SD card; only Default
Speed and High Speed (up to 50MHz) with 3.3V signaling is supported.
The last 64 byte of each DDR channel of PH1-LD20 is periodically
used as a scratch area for the DDR PHY training.
This is the first ARMv8 SoC from Socionext Inc.
The current table look-up for the DTB file name turned out bothersome
in terms of maintainability; I ended up adding a new entry every time
a new board is supported.
There is a common pattern between the DT compatible string and the
corresponding file name; drop the vendor prefix "socionext," and
prefix it with "uniphier-" and suffix it with ".dtb".
No need to stop booting U-Boot even if boot mode is unknown.
Setting the "bootmode" environment is only useful for booting
Linux Kernel. Anyway, U-Boot has already booted by this point.
For PH1-LD20 or later, per-pin input-enable control is supported,
that is, we need to set-up IECTRL registers for a group of pins.
This helper function will be useful for a bunch of register settings.
Currently, fdtgrep would not accept uniphier-ph1-ld20-ref.dtb
and uniphier-ph1-ld11-ref.dtb unless the aliases node comes
the first in the root node.
$ make -s uniphier_pxs2_ld6b_defconfig
$ make CROSS_COMPILE=arm-linux-gnueabi- DEVICE_TREE=uniphier-ph1-ld20-ref
[snip]
LDS spl/u-boot-spl.lds
LD spl/u-boot-spl
OBJCOPY spl/u-boot-spl-nodtb.bin
FDTGREP spl/u-boot-spl.dtb
Error at 'fdt_find_regions': FDT_ERR_BADLAYOUT
/aliases node must come before all other nodes
Error: FDT_ERR_BADMAGIC
make[1]: *** [spl/u-boot-spl.dtb] Error 1
make: *** [spl/u-boot-spl] Error 2
This commit moves the aliases node as the error message from the
fdtgrep tool suggests, although this requirement does not sound
reasonable to me.
This makes the EEPROM device on the Reference Daughter board
available.
Because DT properties are 4-byte aligned, the pointer access
*(fdt64_t *) in this code causes unaligned access.
I found many mistakes in the initial version.
Fixes: 8a3328c209d0 ("pinctrl: uniphier: support UniPhier PH1-LD20 pinctrl driver")
Make function/array names match the file names for consistency.
In list "super_blocks" ubifs collects allocated super_block
structs. U-Boot frees on unmount the allocated struct,
so the pointer stored in this list is free after the umount.
On a new ubifs mount, the new allocated super_block struct
get inserted into the super_blocks list ... which contains
now a freed pointer, and the list_add_tail() corrupts the
freed memory ...
2 solutions are possible:
- remove the super_block from the super_blocks list
on umount
- as U-Boot does not use the super_blocks list ...
remove it complete for U-Boot.
Both solutions should not introduce problems for porting
to newer linux version, so this patch removes the unused
super_blocks list, as it saves code size and execution
time.
Set free_count to zero before walking through ai->erase list
in wl_init().
As U-Boot has no workqueue/threads, it immediately calls
erase_worker(), which increase for each erased block
free_count. Without this patch, free_count gets after
this initialized to zero in wl_init(), so the free_count
variable always has the maybe wrong value 0.
Detected this behaviour on the dxr2 board, where the
UBI fastmap gets not written when attaching/dettaching
on an empty NAND. It drops instead the error message:
could not find any anchor PEB
With this patch, fastmap gets written on dettach.
Reviewed-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Miao Yan's email address is wrong in fw_cfg.c. Fix it.
Our own ACPI implementation (when CONFIG_QEMU_ACPI_TABLE is not set)
does not build anymore after x86 has been fully converted to DM PCI.
Instead of trying to fix the build errors, given we now have the ACPI
support via QEMU's fw_cfg interface, which is a more reliable way to
generate correct ACPI tables than by ourselves, hence drop our own
ACPI implementation.
flush_dcache_all() is used in the very end of U-Boot self relocation
to write back all copied and then patched code and data to their
new location in the very end of available memory space.
Since that has nothing to do with IO (i.e. no external DMA happens
here) IOC won't help here and we need to write back data cache contents
manually.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
As part of 3457bba these configs didn't get updated. Update them now.
Previously, ret could be used uninitialized if
blk_get_device_part_str() failed. Default to ret being set to -1 so
that we always return an err up if we have a problem and then invert the
logic on testing ums_count as when that is non-zero is the time we can
return 0.
Cc: John Tobias <john.tobias.ph@gmail.com>
configs/bcm28155_ap_defconfig
configs/dra72_evm_defconfig
configs/dra74_evm_defconfig
configs/ma5d4evk_defconfig
And also reformat defconfigs using "make savedefconfig" rule.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
